ModuleBase_WidgetDoubleValue.h
20#ifndef ModuleBase_WidgetDoubleValue_H
21#define ModuleBase_WidgetDoubleValue_H
23#include "ModuleBase.h"
24#include "ModuleBase_ModelWidget.h"
28class QWidget;
29class QLabel;
30class QTimer;
31
41{
42Q_OBJECT
43 public:
47 ModuleBase_WidgetDoubleValue(QWidget* theParent, const Config_WidgetAPI* theData);
48
50
52 virtual void activateCustom();
53
55 virtual void selectContent();
56
59 virtual QList<QWidget*> getControls() const;
60
62 virtual bool isModified() const;
63
64 public slots:
65 // Delayed value chnged: when user starts typing something,
66 // it gives him a 0,5 second to finish typing, when sends valueChnaged() signal
67// void onValueChanged();
68
69protected:
71 virtual bool processEnter();
72
75 virtual bool storeValueCustom();
76
78 // \return True in success
79 virtual bool restoreValueCustom();
80
83 virtual bool resetCustom();
84
85protected:
88
91
92 FeaturePtr myParameter;
93
94 double myDefaultVal;
95 bool myHasDefault;
96};
97
98#endif
Provides low-level API for WidgetFactory for reading xml definitions of widgets.
Definition: Config_WidgetAPI.h:46
An abstract custom widget class.
Definition: ModuleBase_ModelWidget.h:60
The method called when widget is activated.
Definition: ModuleBase_ModelWidget.h:410
virtual QList< QWidget * > getControls() const =0
Returns list of widget controls.
Returns True if data of its attribute was modified.
Definition: ModuleBase_ModelWidget.h:325
Select the internal content if it can be selected. It is empty in the default realization.
Definition: ModuleBase_ModelWidget.h:198
virtual bool storeValueCustom()=0
Saves the internal parameters to the given feature.
virtual bool restoreValueCustom()=0
Restore value from attribute data to the widget's control.
Fills the widget with default values.
Definition: ModuleBase_ModelWidget.h:407
An extension of a double spin box which let to use parameters and expressions for value definition.
Definition: ModuleBase_ParamSpinBox.h:37
A class of property panel widget for double value input It can be defined with "doublevalue" keyword.
Definition: ModuleBase_WidgetDoubleValue.h:41
QLabel * myLabel
Label of the widget.
Definition: ModuleBase_WidgetDoubleValue.h:87
ModuleBase_ParamSpinBox * mySpinBox
Input value control.
Definition: ModuleBase_WidgetDoubleValue.h:90
