Widget for dialog. More...
#include <ModuleBase_ModelDialogWidget.h>
Public Types | |
Signals | |
| void | valuesChanged () |
| void | valuesModified () |
| void | objectUpdated () |
| ModuleBase_ModelDialogWidget (QWidget *theParent, const Config_WidgetAPI *theData) | |
| Constructor. More... | |
| virtual void | setDialogButtons (QDialogButtonBox *theButtons) |
| Set general buttons from dialog. More... | |
| bool | reset () |
| Checks if the selection presentation is valid in widget. More... | |
| bool | restoreValue () |
| bool | storeValue () |
| virtual bool | focusTo () |
| void | activate () |
| virtual QList< QWidget * > | getControls () const =0 |
| Returns True if data of its attribute was modified. More... | |
Protected Slots | |
| virtual bool | storeValueCustom ()=0 |
| virtual bool | restoreValueCustom ()=0 |
Protected Attributes | |
| QDialogButtonBox * | myOkCancelBtn |
| Contains dialog buttons to enable/disable Ok and Cancel buttons. More... | |
| FeaturePtr | myFeature |
| std::string | myFeatureId |
| A feature ID. More... | |
| bool | myIsObligatory |
| ValueState | myState |
Widget for dialog.
inline |
| theParent | the parent object |
| theData | the widget configuration. The attribute of the model widget is obtained from a low-level API for reading xml definitions of widgets |
inlinevirtual |
| theButtons | the dialog buttons |
Reimplemented in ParametersPlugin_WidgetParamsMgr.
| [out] | theSelectionFilters | selection filters |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlinevirtualinherited |
inlineinherited |
Reimplemented in CollectionPlugin_WidgetField, ModuleBase_WidgetMultiSelector, ModuleBase_WidgetSelector, ModuleBase_WidgetValidated, PartSet_BSplineWidget, PartSet_WidgetBSplinePoints, PartSet_WidgetFeaturePointSelector, PartSet_WidgetPoint2D, PartSet_WidgetSketchCreator, and PartSet_WidgetSketchLabel.
pure virtualinherited |
Implemented in CollectionPlugin_WidgetField, ModuleBase_PagedContainer, ModuleBase_WidgetAction, ModuleBase_WidgetBoolValue, ModuleBase_WidgetChoice, ModuleBase_WidgetConcealedObjects, ModuleBase_WidgetDoubleValue, ModuleBase_WidgetExprEditor, ModuleBase_WidgetFeatureSelector, ModuleBase_WidgetFileSelector, ModuleBase_WidgetIntValue, ModuleBase_WidgetLabel, ModuleBase_WidgetLabelValue, ModuleBase_WidgetLineEdit, ModuleBase_WidgetMultiSelector, ModuleBase_WidgetOptionalBox, ModuleBase_WidgetPointInput, ModuleBase_WidgetSelectionFilter, ModuleBase_WidgetShapeSelector, ParametersPlugin_WidgetParamsMgr, PartSet_BSplineWidget, PartSet_WidgetBSplinePoints, PartSet_WidgetPoint2D, PartSet_WidgetSketchCreator, PartSet_WidgetSketchLabel, and SamplePanelPlugin_ModelWidget.
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
staticinherited |
By default does nothing
Reimplemented in ModuleBase_WidgetDoubleValue, ModuleBase_WidgetIntValue, ModuleBase_WidgetLineEdit, ModuleBase_WidgetMultiSelector, ModuleBase_WidgetShapeSelector, and PartSet_WidgetSketchLabel.
inlineinherited |
signalinherited |
signalinherited |
signalinherited |
signalinherited |
signalinherited |
signalinherited |
signalinherited |
signalinherited |
signalinherited |
signalinherited |
signalinherited |
signalinherited |
protectedinherited |
inlineprotectedinherited |
| theState | a new state |
protectedvirtualinherited |
protectedpure virtualinherited |
Implemented in CollectionPlugin_WidgetField, ModuleBase_PagedContainer, ModuleBase_WidgetAction, ModuleBase_WidgetBoolValue, ModuleBase_WidgetChoice, ModuleBase_WidgetConcealedObjects, ModuleBase_WidgetDoubleValue, ModuleBase_WidgetExprEditor, ModuleBase_WidgetFeatureSelector, ModuleBase_WidgetFileSelector, ModuleBase_WidgetIntValue, ModuleBase_WidgetLabel, ModuleBase_WidgetLabelValue, ModuleBase_WidgetLineEdit, ModuleBase_WidgetMultiSelector, ModuleBase_WidgetNameEdit, ModuleBase_WidgetOptionalBox, ModuleBase_WidgetPointInput, ModuleBase_WidgetSelectionFilter, ModuleBase_WidgetShapeSelector, ParametersPlugin_WidgetParamsMgr, PartSet_BSplineWidget, PartSet_WidgetBSplinePoints, PartSet_WidgetFileSelector, PartSet_WidgetPoint2D, PartSet_WidgetSketchCreator, PartSet_WidgetSketchLabel, and SamplePanelPlugin_ModelWidget.
Implemented in CollectionPlugin_WidgetField, ModuleBase_PagedContainer, ModuleBase_WidgetAction, ModuleBase_WidgetBoolValue, ModuleBase_WidgetChoice, ModuleBase_WidgetConcealedObjects, ModuleBase_WidgetDoubleValue, ModuleBase_WidgetExprEditor, ModuleBase_WidgetFeatureSelector, ModuleBase_WidgetFileSelector, ModuleBase_WidgetIntValue, ModuleBase_WidgetLabel, ModuleBase_WidgetLabelValue, ModuleBase_WidgetLineEdit, ModuleBase_WidgetMultiSelector, ModuleBase_WidgetNameEdit, ModuleBase_WidgetOptionalBox, ModuleBase_WidgetPointInput, ModuleBase_WidgetSelectionFilter, ModuleBase_WidgetShapeSelector, ModuleBase_WidgetUndoLabel, ParametersPlugin_WidgetParamsMgr, PartSet_BSplineWidget, PartSet_WidgetBSplinePoints, PartSet_WidgetFileSelector, PartSet_WidgetPoint2D, PartSet_WidgetSketchCreator, PartSet_WidgetSketchLabel, and SamplePanelPlugin_ModelWidget.
Reimplemented in ModuleBase_PagedContainer, ModuleBase_WidgetDoubleValue, ModuleBase_WidgetExprEditor, ModuleBase_WidgetFeatureSelector, ModuleBase_WidgetIntValue, ModuleBase_WidgetMultiSelector, ModuleBase_WidgetSelector, ParametersPlugin_WidgetParamsMgr, PartSet_WidgetFeaturePointSelector, PartSet_WidgetPoint2D, and PartSet_WidgetSketchLabel.
protectedslotinherited |
protected |
A feature ID.
