ModuleBase_WidgetLabel.h
20#ifndef ModuleBase_WidgetLabel_H
21#define ModuleBase_WidgetLabel_H
23#include "ModuleBase.h"
24#include "ModuleBase_ModelWidget.h"
26class QLabel;
27
32class MODULEBASE_EXPORT ModuleBase_WidgetLabel : public ModuleBase_ModelWidget
33{
34Q_OBJECT
35 public:
39 ModuleBase_WidgetLabel(QWidget* theParent, const Config_WidgetAPI* theData);
40
42
45 virtual bool canAcceptFocus() const { return false; };
46
47 virtual bool restoreValueCustom();
48
49 virtual QList<QWidget*> getControls() const;
50
52 virtual bool focusTo();
53
54protected:
57 virtual bool storeValueCustom()
58 {
59 return true;
60 }
61
65 std::string myPrefix;
66};
67
68#endif
Provides low-level API for WidgetFactory for reading xml definitions of widgets.
Definition: Config_WidgetAPI.h:46
An abstract custom widget class.
Definition: ModuleBase_ModelWidget.h:60
virtual QList< QWidget * > getControls() const =0
Returns list of widget controls.
virtual bool restoreValueCustom()=0
Restore value from attribute data to the widget's control.
Set focus to the first control of the current widget.
Definition: ModuleBase_ModelWidget.cpp:267
Implementation of model widget for a label control.
Definition: ModuleBase_WidgetLabel.h:33
Defines if it is supported to set the value in this widget It returns false because this is an info w...
Definition: ModuleBase_WidgetLabel.h:45
Saves the internal parameters to the given feature.
Definition: ModuleBase_WidgetLabel.h:57
A prefix for label.
Definition: ModuleBase_WidgetLabel.h:65
QLabel * myLabel
A label control.
Definition: ModuleBase_WidgetLabel.h:63
