ModuleBase_WidgetNameEdit.h
20#ifndef MODULEBASE_WIDGETNAMEEDIT_H_
21#define MODULEBASE_WIDGETNAMEEDIT_H_
23#include <ModuleBase.h>
24#include <ModuleBase_WidgetLineEdit.h>
27{
28 Q_OBJECT
29public:
31 const Config_WidgetAPI* theData,
32 const std::string& thePlaceHolder)
33 : ModuleBase_WidgetLineEdit(theParent, theData, thePlaceHolder) {}
34
37 virtual bool usesAttribute() const { return false; }
38
39 virtual bool focusTo() { return false; }
40
41protected:
44 virtual bool storeValueCustom();
45
47 virtual bool restoreValueCustom();
48};
49
50#endif
Provides low-level API for WidgetFactory for reading xml definitions of widgets.
Definition: Config_WidgetAPI.h:46
Implementation of model widget for line edit widget.
Definition: ModuleBase_WidgetLineEdit.h:39
ModuleBase_WidgetLineEdit(QWidget *theParent, const Config_WidgetAPI *theData, const std::string &thePlaceHolder)
Definition: ModuleBase_WidgetLineEdit.cpp:89
Definition: ModuleBase_WidgetNameEdit.h:27
Redefinition of virtual method.
Definition: ModuleBase_WidgetNameEdit.cpp:42
Saves the internal parameters to the given feature.
Definition: ModuleBase_WidgetNameEdit.cpp:27
Set focus to the first control of the current widget.
Definition: ModuleBase_WidgetNameEdit.h:39
Returns True if the widget uses feature attribute.
Definition: ModuleBase_WidgetNameEdit.h:37
