SketchPlugin_MacroCircle.h
20#ifndef SketchPlugin_MacroCircle_H_
21#define SketchPlugin_MacroCircle_H_
23#include <ModelAPI_IReentrant.h>
24
25#include "SketchPlugin.h"
26
27#include "SketchPlugin_SketchEntity.h"
28
29#include <GeomAPI_IPresentable.h>
30
31class GeomAPI_Circ2d;
32class GeomAPI_Pnt2d;
33
41{
42 public:
44 inline static const std::string& ID()
45 {
46 static const std::string ID("SketchMacroCircle");
47 return ID;
48 }
49
50 inline static const std::string& CIRCLE_TYPE()
51 {
52 static const std::string ID("circle_type");
53 return ID;
54 }
55
56 inline static const std::string& EDIT_CIRCLE_TYPE()
57 {
58 static const std::string ID("edit_circle_type");
59 return ID;
60 }
61
63 inline static const std::string& CIRCLE_TYPE_BY_CENTER_AND_PASSED_POINTS()
64 {
65 static const std::string ID("circle_type_by_center_and_passed_points");
66 return ID;
67 }
68
70 inline static const std::string& CIRCLE_TYPE_BY_THREE_POINTS()
71 {
72 static const std::string ID("circle_type_by_three_points");
73 return ID;
74 }
75
77 inline static const std::string& CENTER_POINT_ID()
78 {
79 static const std::string ID("center_point");
80 return ID;
81 }
82
84 inline static const std::string& CENTER_POINT_REF_ID()
85 {
86 static const std::string ID("center_point_ref");
87 return ID;
88 }
89
91 inline static const std::string& PASSED_POINT_ID()
92 {
93 static const std::string ID("passed_point");
94 return ID;
95 }
96
98 inline static const std::string& PASSED_POINT_REF_ID()
99 {
100 static const std::string ID("passed_point_ref");
101 return ID;
102 }
103
105 inline static const std::string& FIRST_POINT_ID()
106 {
107 static const std::string ID("first_point");
108 return ID;
109 }
110
112 inline static const std::string& FIRST_POINT_REF_ID()
113 {
114 static const std::string ID("first_point_ref");
115 return ID;
116 }
117
119 inline static const std::string& SECOND_POINT_ID()
120 {
121 static const std::string ID("second_point");
122 return ID;
123 }
124
126 inline static const std::string& SECOND_POINT_REF_ID()
127 {
128 static const std::string ID("second_point_ref");
129 return ID;
130 }
131
133 inline static const std::string& THIRD_POINT_ID()
134 {
135 static const std::string ID("third_point");
136 return ID;
137 }
138
140 inline static const std::string& THIRD_POINT_REF_ID()
141 {
142 static const std::string ID("third_point_ref");
143 return ID;
144 }
145
147 inline static const std::string& CIRCLE_RADIUS_ID()
148 {
149 static const std::string ID("circle_radius");
150 return ID;
151 }
152
154 inline static const std::string& ADD_CONSTRUCTION_POINT_ID()
155 {
156 static const std::string ID("add_construction_point");
157 return ID;
158 }
159
161 inline static const std::string& CIRCLE_ROTATE_ANGLE_ID()
162 {
163 static const std::string ID("circle_angle");
164 return ID;
165 }
166
168 SKETCHPLUGIN_EXPORT virtual const std::string& getKind()
169 {
170 static std::string MY_KIND = SketchPlugin_MacroCircle::ID();
171 return MY_KIND;
172 }
173
175 SKETCHPLUGIN_EXPORT virtual void initAttributes();
176
178 SKETCHPLUGIN_EXPORT virtual void attributeChanged(const std::string& theID);
179
181 virtual AISObjectPtr getAISObject(AISObjectPtr thePrevious);
182
184 SKETCHPLUGIN_EXPORT virtual void execute();
185
188 SKETCHPLUGIN_EXPORT virtual bool isMacro() const {return true;};
189
190 SKETCHPLUGIN_EXPORT virtual bool isPreviewNeeded() const {return false;};
191
194 virtual std::string processEvent(const std::shared_ptr<Events_Message>& theMessage);
195
198
199private:
200 void fillByCenterAndPassed();
201 void fillByThreePoints();
203 void fillByTwoPassedPoints();
204
205 void constraintsForCircleByCenterAndPassed(FeaturePtr theCircleFeature);
206 void constraintsForCircleByThreePoints(FeaturePtr theCircleFeature);
207
208 void computeNewAngle(std::shared_ptr<GeomAPI_Circ2d>& theCircle);
209
210 FeaturePtr createCircleFeature();
211
212private:
213 std::shared_ptr<GeomAPI_Pnt2d> myCenter;
214 double myRadius;
215};
216
217#endif
Circle in 2D.
Definition: GeomAPI_Circ2d.h:37
A class which defines an interface of object which is able to create its own presentation.
Definition: GeomAPI_IPresentable.h:29
Interface of a class which can process specific messages.
Definition: ModelAPI_IReentrant.h:36
Feature for creation of the new circle in Sketch.
Definition: SketchPlugin_MacroCircle.h:41
Reimplemented from ModelAPI_Feature::isMacro().
Definition: SketchPlugin_MacroCircle.h:188
static const std::string & CENTER_POINT_ID()
2D point - center of the circle.
Definition: SketchPlugin_MacroCircle.h:77
SketchPlugin_MacroCircle()
Definition: SketchPlugin_MacroCircle.cpp:71
static const std::string & SECOND_POINT_REF_ID()
Reference for second point selection.
Definition: SketchPlugin_MacroCircle.h:126
static const std::string & PASSED_POINT_REF_ID()
Reference for passed point selection.
Definition: SketchPlugin_MacroCircle.h:98
static const std::string & THIRD_POINT_ID()
Third point id.
Definition: SketchPlugin_MacroCircle.h:133
static const std::string & SECOND_POINT_ID()
Second point id.
Definition: SketchPlugin_MacroCircle.h:119
static const std::string & FIRST_POINT_ID()
First point id.
Definition: SketchPlugin_MacroCircle.h:105
static const std::string & ADD_CONSTRUCTION_POINT_ID()
Is to create construction point or not.
Definition: SketchPlugin_MacroCircle.h:154
static const std::string & CIRCLE_TYPE_BY_CENTER_AND_PASSED_POINTS()
Creation method by center and passed point.
Definition: SketchPlugin_MacroCircle.h:63
static const std::string & PASSED_POINT_ID()
2D point - passed point of the circle
Definition: SketchPlugin_MacroCircle.h:91
static const std::string & CENTER_POINT_REF_ID()
Reference for center point selection.
Definition: SketchPlugin_MacroCircle.h:84
Returns true if preview update during the edition needed.
Definition: SketchPlugin_MacroCircle.h:190
static const std::string & CIRCLE_ROTATE_ANGLE_ID()
Rotate angle of the circle.
Definition: SketchPlugin_MacroCircle.h:161
static const std::string & CIRCLE_RADIUS_ID()
Radius of the circle.
Definition: SketchPlugin_MacroCircle.h:147
Definition: SketchPlugin_MacroCircle.cpp:124
static const std::string & THIRD_POINT_REF_ID()
Reference for third point selection.
Definition: SketchPlugin_MacroCircle.h:140
Definition: SketchPlugin_MacroCircle.cpp:77
virtual std::string processEvent(const std::shared_ptr< Events_Message > &theMessage)
Apply information of the message to current object.
Definition: SketchPlugin_MacroCircle.cpp:146
static const std::string & FIRST_POINT_REF_ID()
Reference for first point selection.
Definition: SketchPlugin_MacroCircle.h:112
virtual void attributeChanged(const std::string &theID)
Definition: SketchPlugin_MacroCircle.cpp:439
static const std::string & CIRCLE_TYPE_BY_THREE_POINTS()
Creation method by three points.
Definition: SketchPlugin_MacroCircle.h:70
Returns the AIS preview.
Definition: SketchPlugin_MacroCircle.cpp:392
Circle feature kind.
Definition: SketchPlugin_MacroCircle.h:44
Definition: SketchPlugin_MacroCircle.h:168
Sketch Entity for creation of the new feature in PartSet.
Definition: SketchPlugin_SketchEntity.h:45
