GeomAPI_Circ2d Class Reference
Circle in 2D. More...
#include <GeomAPI_Circ2d.h>
Inheritance diagram for GeomAPI_Circ2d:
GEOMAPI_EXPORT GeomAPI_Circ2d (const double theCenterX, const double theCenterY, const double theRadius)
 Creation of circle defined by center point and circle radius. More...
GEOMAPI_EXPORT GeomAPI_Circ2d (const std::shared_ptr< GeomAPI_Pnt2d > &theCenter, const std::shared_ptr< GeomAPI_Pnt2d > &theCirclePoint)
GEOMAPI_EXPORT GeomAPI_Circ2d (const std::shared_ptr< GeomAPI_Pnt2d > &theCenter, const std::shared_ptr< GeomAPI_Dir2d > &theDir, double theRadius)
 Creation of circle defined by center point, direction and circle radius. More...
GEOMAPI_EXPORT const std::shared_ptr< GeomAPI_Pnt2d > center () const
 Return center of the circle. More...
GEOMAPI_EXPORT double radius () const
 Return radius of the circle. More...
GEOMAPI_EXPORT const std::shared_ptr< GeomAPI_Pnt2d > project (const std::shared_ptr< GeomAPI_Pnt2d > &thePoint) const
 Project point on line. More...
GEOMAPI_EXPORT const bool parameter (const std::shared_ptr< GeomAPI_Pnt2d > thePoint, const double theTolerance, double &theParameter) const
 Computes the parameter of a given point on a circle. More...
GEOMAPI_EXPORT void D0 (const double theU, std::shared_ptr< GeomAPI_Pnt2d > &thePoint)
 Returns in thePoint the point of parameter theU. More...
template<class T >
T * implPtr ()
template<class T >
const T * implPtr () const
template<class T >
const T & impl () const
template<class T >
void setImpl (T *theImpl)
Circle in 2D.
◆ GeomAPI_Circ2d() [1/3]
GeomAPI_Circ2d::GeomAPI_Circ2d ( const double  theCenterX,
◆ GeomAPI_Circ2d() [2/3]
GeomAPI_Circ2d::GeomAPI_Circ2d ( const std::shared_ptr< GeomAPI_Pnt2d > &  theCenter,
const std::shared_ptr< GeomAPI_Pnt2d > &  theCirclePoint
◆ GeomAPI_Circ2d() [3/3]
const std::shared_ptr< GeomAPI_Dir2d > &  theDir,
double  theRadius
◆ center()
const std::shared_ptr< GeomAPI_Pnt2d > GeomAPI_Circ2d::center ( ) const
◆ radius()
double GeomAPI_Circ2d::radius ( ) const
◆ project()
const std::shared_ptr< GeomAPI_Pnt2d > GeomAPI_Circ2d::project ( const std::shared_ptr< GeomAPI_Pnt2d > &  thePoint) const
◆ parameter()
const bool GeomAPI_Circ2d::parameter ( const std::shared_ptr< GeomAPI_Pnt2d >  thePoint,
double &  theParameter
The point must be located either on the circle itself or relatively to the latter at a distance less than the tolerance value. Return FALSE if the point is beyond the tolerance limit or if computation fails. Max Tolerance value is currently limited to 1.e-4
[in]thePointpoint of origin.
[in]theTolerancetolerance of computation.
[out]theParameterresulting parameter.
◆ D0()
void GeomAPI_Circ2d::D0 ( const double  theU,
P = C + R * Cos (U) * XDir + R * Sin (U) * YDir where C is the center of the circle, XDir the XDirection and YDir the YDirection of the circle's local coordinate system.
[in]theUparameter.
[out]thePointresulting point.
◆ implPtr() [1/2]
template<class T >
◆ implPtr() [2/2]
template<class T >
◆ impl()
template<class T >
◆ setImpl()
template<class T >
◆ empty()
