SketchPlugin_MacroEllipticArc.h
20#ifndef SketchPlugin_MacroEllipticArc_H_
21#define SketchPlugin_MacroEllipticArc_H_
23#include <ModelAPI_IReentrant.h>
24#include <SketchPlugin.h>
25#include <SketchPlugin_SketchEntity.h>
26#include <GeomAPI_IPresentable.h>
27
28class GeomAPI_Pnt2d;
29class GeomAPI_Shape;
30
38{
39public:
41 inline static const std::string& ID()
42 {
43 static const std::string ID("SketchMacroEllipticArc");
44 return ID;
45 }
46
48 inline static const std::string& CENTER_ID()
49 {
50 static const std::string ID("center");
51 return ID;
52 }
53
55 inline static const std::string& CENTER_REF_ID()
56 {
57 static const std::string ID("center_ref");
58 return ID;
59 }
60
62 inline static const std::string& MAJOR_AXIS_POINT_ID()
63 {
64 static const std::string ID("major_axis_point");
65 return ID;
66 }
67
69 inline static const std::string& MAJOR_AXIS_POINT_REF_ID()
70 {
71 static const std::string ID("major_axis_point_ref");
72 return ID;
73 }
74
76 inline static const std::string& START_POINT_ID()
77 {
78 static const std::string ID("start_point");
79 return ID;
80 }
81
83 inline static const std::string& START_POINT_REF_ID()
84 {
85 static const std::string ID("start_point_ref");
86 return ID;
87 }
88
90 inline static const std::string& END_POINT_ID()
91 {
92 static const std::string ID("end_point");
93 return ID;
94 }
95
97 inline static const std::string& END_POINT_REF_ID()
98 {
99 static const std::string ID("end_point_ref");
100 return ID;
101 }
102
104 inline static const std::string& MAJOR_RADIUS_ID()
105 {
106 static const std::string ID("major_radius");
107 return ID;
108 }
109
111 inline static const std::string& MINOR_RADIUS_ID()
112 {
113 static const std::string ID("minor_radius");
114 return ID;
115 }
116
118 inline static const std::string& REVERSED_ID()
119 {
120 static const std::string ID("reversed");
121 return ID;
122 }
123
125 SKETCHPLUGIN_EXPORT virtual const std::string& getKind()
126 {
127 static std::string MY_KIND = SketchPlugin_MacroEllipticArc::ID();
128 return MY_KIND;
129 }
130
132 SKETCHPLUGIN_EXPORT virtual void initAttributes();
133
135 SKETCHPLUGIN_EXPORT virtual void attributeChanged(const std::string& theID);
136
138 virtual AISObjectPtr getAISObject(AISObjectPtr thePrevious);
139
141 SKETCHPLUGIN_EXPORT virtual void execute();
142
145 SKETCHPLUGIN_EXPORT virtual bool isMacro() const
146 {return true;}
147
148 SKETCHPLUGIN_EXPORT virtual bool isPreviewNeeded() const
149 {return false;}
150
153 virtual std::string processEvent(const std::shared_ptr<Events_Message>& theMessage);
154
157
158private:
159 std::shared_ptr<GeomAPI_Shape> getArcShape();
160
161 FeaturePtr createEllipticArcFeature();
162 void constraintsForEllipticArc(FeaturePtr theEllipticArc);
163
164private:
165 std::shared_ptr<GeomAPI_Pnt2d> myCenter;
166 std::shared_ptr<GeomAPI_Pnt2d> myMajorAxis;
167 std::shared_ptr<GeomAPI_Pnt2d> myStartPnt;
168 std::shared_ptr<GeomAPI_Pnt2d> myEndPnt;
169 double myMajorRadius;
170 double myMinorRadius;
171 double myParamDelta;
172};
173
174#endif
A class which defines an interface of object which is able to create its own presentation.
Definition: GeomAPI_IPresentable.h:29
Interface of a class which can process specific messages.
Definition: ModelAPI_IReentrant.h:36
Feature for creation of the new elliptic arc in Sketch.
Definition: SketchPlugin_MacroEllipticArc.h:38
virtual SKETCHPLUGIN_EXPORT void execute()
Definition: SketchPlugin_MacroEllipticArc.cpp:84
static const std::string & START_POINT_ID()
Attribute for the start point of the elliptic arc selected during creation.
Definition: SketchPlugin_MacroEllipticArc.h:76
SketchPlugin_MacroEllipticArc()
Definition: SketchPlugin_MacroEllipticArc.cpp:50
static const std::string & END_POINT_ID()
Attribute for the end point of the elliptic arc selected during creation.
Definition: SketchPlugin_MacroEllipticArc.h:90
virtual std::string processEvent(const std::shared_ptr< Events_Message > &theMessage)
Apply information of the message to current object.
Definition: SketchPlugin_MacroEllipticArc.cpp:186
Elliptic arc feature kind.
Definition: SketchPlugin_MacroEllipticArc.h:41
virtual SKETCHPLUGIN_EXPORT void attributeChanged(const std::string &theID)
Definition: SketchPlugin_MacroEllipticArc.cpp:97
static const std::string & CENTER_ID()
Attribute for the central point selected during elliptic arc creation.
Definition: SketchPlugin_MacroEllipticArc.h:48
static const std::string & MAJOR_AXIS_POINT_ID()
Attribute for the point on major semi-axis selected during elliptic arc creation.
Definition: SketchPlugin_MacroEllipticArc.h:62
static const std::string & MINOR_RADIUS_ID()
Minor radius of the ellipse.
Definition: SketchPlugin_MacroEllipticArc.h:111
static const std::string & END_POINT_REF_ID()
Reference for the end point selection.
Definition: SketchPlugin_MacroEllipticArc.h:97
virtual SKETCHPLUGIN_EXPORT bool isPreviewNeeded() const
Returns true if preview update during the edition needed.
Definition: SketchPlugin_MacroEllipticArc.h:148
virtual SKETCHPLUGIN_EXPORT bool isMacro() const
Reimplemented from ModelAPI_Feature::isMacro().
Definition: SketchPlugin_MacroEllipticArc.h:145
virtual SKETCHPLUGIN_EXPORT void initAttributes()
Definition: SketchPlugin_MacroEllipticArc.cpp:58
static const std::string & MAJOR_AXIS_POINT_REF_ID()
Reference to the second selected point (major semi-axis of the ellipse).
Definition: SketchPlugin_MacroEllipticArc.h:69
static const std::string & START_POINT_REF_ID()
Reference for the start point selection.
Definition: SketchPlugin_MacroEllipticArc.h:83
static const std::string & CENTER_REF_ID()
Reference to the first selected point (center of ellipse).
Definition: SketchPlugin_MacroEllipticArc.h:55
static const std::string & REVERSED_ID()
Flag the arc is reversed.
Definition: SketchPlugin_MacroEllipticArc.h:118
virtual SKETCHPLUGIN_EXPORT const std::string & getKind()
Definition: SketchPlugin_MacroEllipticArc.h:125
Returns the AIS preview.
Definition: SketchPlugin_MacroEllipticArc.cpp:335
static const std::string & MAJOR_RADIUS_ID()
Major radius of the ellipse.
Definition: SketchPlugin_MacroEllipticArc.h:104
Sketch Entity for creation of the new feature in PartSet.
Definition: SketchPlugin_SketchEntity.h:45
