SketchSolver_ConstraintCoincidence.h
20#ifndef SketchSolver_ConstraintCoincidence_H_
21#define SketchSolver_ConstraintCoincidence_H_
23#include <SketchSolver_Constraint.h>
24
30{
31public:
33 SketchSolver_ConstraintCoincidence(ConstraintPtr theConstraint) :
34 SketchSolver_Constraint(theConstraint),
35 myInSolver(false)
36 {}
37
39 virtual void notify(const FeaturePtr& theFeature,
40 PlaneGCSSolver_Update* theUpdater);
41
43 virtual bool remove();
44
45protected:
47 virtual void process();
48
52 virtual void getAttributes(EntityWrapperPtr& theValue,
53 std::vector<EntityWrapperPtr>& theAttributes);
54
57 virtual void adjustConstraint();
58
59protected:
61 EntityWrapperPtr myFeatureExtremities[2];
62 ScalarWrapperPtr myAuxValue;
63};
64
65#endif
Send events to listeners about changing a feature.
Definition: PlaneGCSSolver_Update.h:38
Convert coincidence constraint to SolveSpace structure.
Definition: SketchSolver_ConstraintCoincidence.h:30
bool myInSolver
shows the constraint is added to the solver
Definition: SketchSolver_ConstraintCoincidence.h:60
virtual void notify(const FeaturePtr &theFeature, PlaneGCSSolver_Update *theUpdater)
Notify this object about the feature is changed somewhere.
Definition: SketchSolver_ConstraintCoincidence.cpp:296
Converts SketchPlugin constraint to a list of solver constraints.
Definition: SketchSolver_ConstraintCoincidence.cpp:211
Constructor based on SketchPlugin constraint.
Definition: SketchSolver_ConstraintCoincidence.h:33
This method is used in derived objects to check consistency of constraint.
Definition: SketchSolver_ConstraintCoincidence.cpp:351
virtual void getAttributes(EntityWrapperPtr &theValue, std::vector< EntityWrapperPtr > &theAttributes)
Generate list of attributes of constraint in order useful for constraints.
Definition: SketchSolver_ConstraintCoincidence.cpp:252
Remove constraint.
Definition: SketchSolver_ConstraintCoincidence.cpp:237
parameter on B-spline curve
Definition: SketchSolver_ConstraintCoincidence.h:62
extremities of a feature, a point is coincident to
Definition: SketchSolver_ConstraintCoincidence.h:61
Converts SketchPlugin constraint to the constraint applicable for solver.
Definition: SketchSolver_Constraint.h:39
