SketchSolver_ConstraintTangent.h
20#ifndef SketchSolver_ConstraintTangent_H_
21#define SketchSolver_ConstraintTangent_H_
23#include <SketchSolver_Constraint.h>
24
30{
31public:
33 SketchSolver_ConstraintTangent(ConstraintPtr theConstraint) :
34 SketchSolver_Constraint(theConstraint),
35 isArcArcInternal(false),
36 myCurveCurveAngle(0.0)
37 {}
38
40 virtual void notify(const FeaturePtr& theFeature,
41 PlaneGCSSolver_Update* theUpdater);
42
46 virtual bool remove();
47
48protected:
50 virtual void process();
51
53 void rebuild();
54
57 virtual void adjustConstraint();
58
59private:
60 bool isArcArcInternal;
61 double myCurveCurveAngle;
62 AttributePtr mySharedPoint;
63 EntityWrapperPtr myAuxPoint;
64 ScalarWrapperPtr myAuxParameters[2];
65};
66
67#endif
Send events to listeners about changing a feature.
Definition: PlaneGCSSolver_Update.h:38
Convert tangency constraint to SolveSpace structure.
Definition: SketchSolver_ConstraintTangent.h:30
void rebuild()
Remove current constraint from the storage and build is again.
Definition: SketchSolver_ConstraintTangent.cpp:108
Tries to remove constraint.
Definition: SketchSolver_ConstraintTangent.cpp:343
virtual void notify(const FeaturePtr &theFeature, PlaneGCSSolver_Update *theUpdater)
Notify this object about the feature is changed somewhere.
Definition: SketchSolver_ConstraintTangent.cpp:281
Constructor based on SketchPlugin constraint.
Definition: SketchSolver_ConstraintTangent.h:33
Converts SketchPlugin constraint to a list of solver constraints.
Definition: SketchSolver_ConstraintTangent.cpp:87
This method is used in derived objects to check consistency of constraint.
Definition: SketchSolver_ConstraintTangent.cpp:268
Converts SketchPlugin constraint to the constraint applicable for solver.
Definition: SketchSolver_Constraint.h:39
