Config_Prop Class Reference
Class which describes a one property. More...
#include <Config_Prop.h>
enum  PropType {
  Disabled , Space , Boolean , Color ,
  String , Selector , DblSpin , IntSpin ,
  Double , Integer , GroupBox , Tab ,
  Frame , Font , DirList , File ,
  Slider , Shortcut , ShortcutTree , BiColor ,
  Background , Directory , Cursor
 Type of stored property. More...
enum  CursorType { ArrowCursor , CrossCursor , HandCursor }
 Config_Prop (const std::string &theSection, const std::string &theName, const std::string &theTitle, PropType theType, const std::string &theDefaultValue, const std::string &theMin, const std::string &theMax)
 Creates a one property. More...
const std::string & section () const
 Get name of section. More...
const std::string & name () const
 Get name of property. More...
const std::string & title () const
 Get title of property. More...
void setTitle (const std::string &theTitle)
 Set title of property. More...
PropType type () const
 Get type of property. More...
void setType (PropType theType)
 Set type of property. More...
const std::string & value () const
 Get property's value in string format. More...
void setValue (const std::string &theValue)
 Set property's value in string format. More...
const std::string & defaultValue () const
 Get default value of property. More...
void setDefaultValue (const std::string &theValue)
 Set default value of property. More...
bool operator== (const Config_Prop *theProp) const
 Allows to compare Config_Prop with each other. More...
const std::string & min () const
 Returns minimal value. More...
void setMin (const std::string &theMin)
const std::string & max () const
 Returns maximal value. More...
void setMax (const std::string &theMax)
◆ PropType
◆ Config_Prop()
Config_Prop::Config_Prop ( const std::string &  theSection,
const std::string &  theName,
const std::string &  theTitle,
PropType  theType,
const std::string &  theDefaultValue,
const std::string &  theMin,
const std::string &  theMax
theSection- name of section (domain of using) of the property.
theName- name (title) of the value.
theTitle- title of the value
theType- type of the value.
theDefaultValue- default value of the property. This is an initial property value
◆ section()
const std::string & Config_Prop::section ( ) const
const std::string & Config_Prop::name ( ) const
◆ title()
const std::string & Config_Prop::title ( ) const
◆ setTitle()
void Config_Prop::setTitle ( const std::string &  theTitle)
◆ type()
PropType Config_Prop::type ( ) const
◆ setType()
void Config_Prop::setType ( PropType  theType)
◆ value()
const std::string & Config_Prop::value ( ) const
◆ setValue()
void Config_Prop::setValue ( const std::string &  theValue)
◆ defaultValue()
const std::string & Config_Prop::defaultValue ( ) const
◆ setDefaultValue()
void Config_Prop::setDefaultValue ( const std::string &  theValue)
◆ operator==()
bool Config_Prop::operator== ( const Config_Prop *  theProp) const
◆ min()
const std::string & Config_Prop::min ( ) const
◆ max()
const std::string & Config_Prop::max ( ) const
