Config_ValidatorMessage Class Reference
Transmits info about created validator on "ValidatorLoaded" event. More...
#include <Config_ValidatorMessage.h>
Inheritance diagram for Config_ValidatorMessage:
CONFIG_EXPORT Config_ValidatorMessage (const Events_ID theId, const void *theParent=0)
CONFIG_EXPORT const std::string & validatorId () const
 Get id of the filter. More...
CONFIG_EXPORT const std::string & featureId () const
 Get id of a feature to which the filter belongs to. More...
CONFIG_EXPORT const std::string & attributeId () const
 Get id of an attribute to which the filter belongs to. More...
CONFIG_EXPORT const std::list< std::string > & parameters () const
 Get filter parameters. More...
CONFIG_EXPORT bool isValid () const
 Returns true if validator id is not empty. More...
CONFIG_EXPORT void setValidatorId (const std::string &theId)
 Set id of the filter. More...
CONFIG_EXPORT void setFeatureId (const std::string &theId)
 Set id of a feature to which the filter belongs to. More...
CONFIG_EXPORT void setAttributeId (const std::string &theId)
 Set id of an attribute to which the filter belongs to. More...
CONFIG_EXPORT void setValidatorParameters (const std::list< std::string > &parameters)
const Events_ID & eventID () const
 Returns identifier of the message. More...
void * sender () const
 Returns sender of the message or NULL if it is anonymous message. More...
◆ Config_ValidatorMessage()
Config_ValidatorMessage::Config_ValidatorMessage ( const Events_ID  theId,
const void *  theParent = 0
theId- Events_ID of the message
theParent- pointer to the sender
◆ validatorId()
const std::string & Config_ValidatorMessage::validatorId ( ) const
◆ featureId()
const std::string & Config_ValidatorMessage::featureId ( ) const
◆ attributeId()
const std::string & Config_ValidatorMessage::attributeId ( ) const
◆ parameters()
const std::list< std::string > & Config_ValidatorMessage::parameters ( ) const
◆ isValid()
bool Config_ValidatorMessage::isValid ( ) const
◆ setValidatorId()
void Config_ValidatorMessage::setValidatorId ( const std::string &  theId)
◆ setFeatureId()
void Config_ValidatorMessage::setFeatureId ( const std::string &  theId)
◆ setAttributeId()
void Config_ValidatorMessage::setAttributeId ( const std::string &  theId)
◆ setValidatorParameters()
void Config_ValidatorMessage::setValidatorParameters ( const std::list< std::string > &  parameters)
◆ eventID()
const Events_ID & Events_Message::eventID ( ) const
◆ sender()
void * Events_Message::sender ( ) const
