ModuleBase_ParamIntSpinBox Class Reference
An extension of a double spin box which let to use parameters and expressions for value definition. More...
#include <ModuleBase_ParamIntSpinBox.h>
Inheritance diagram for ModuleBase_ParamIntSpinBox:
 ModuleBase_ParamIntSpinBox (QWidget *theParent=0)
virtual ~ModuleBase_ParamIntSpinBox ()
virtual void stepBy (int)
 Perform steps increment/decrement steps. More...
virtual int valueFromText (const QString &) const
 Convert Int value from text string. More...
virtual QString textFromValue (int) const
 Convert text string from int value. More...
virtual QValidator::State validate (QString &, int &) const
 Validate the value. More...
virtual void setValue (int)
 Set current int value. More...
virtual void setText (const QString &)
 Set current text value. More...
void setAcceptVariables (const bool)
 Set a flag about accepted variable. More...
bool isAcceptVariables () const
 Returns accepted variables flag. More...
bool hasVariable () const
 Returns True if the input value contains variable. More...
Protected Slots
void onTextChanged (const QString &)
 A slot called on text change. More...
bool hasVariable (const QString &theText) const
 Returns True if the given text contains variable. More...
State isValid (const QString &, double &) const
 Returns state of the control. More...
bool checkRange (const double) const
 Returns True if the given value is within min and max of the control. More...
bool findVariable (const QString &theName, double &outValue) const
 Finds a variable by its name. More...
virtual void showEvent (QShowEvent *)
 This function is called when the spinbox receives show event. More...
virtual void keyPressEvent (QKeyEvent *theEvent)
 Called on key press event. More...
◆ ModuleBase_ParamIntSpinBox()
ModuleBase_ParamIntSpinBox::ModuleBase_ParamIntSpinBox ( QWidget *  theParent = 0)
explicit
Constructs a spin box with 0.0 as minimum value and 99.99 as maximum value, a step value of 1.0 and a precision of 2 decimal places. The value is initially set to 0.00.
theParenta parent object
◆ ~ModuleBase_ParamIntSpinBox()
ModuleBase_ParamIntSpinBox::~ModuleBase_ParamIntSpinBox ( )
◆ stepBy()
void ModuleBase_ParamIntSpinBox::stepBy ( int  steps)
Re-implemented to handle cases when Notebook variable name is specified by the user as the widget text. Otherwise, simply calls the base implementation.
stepsnumber of increment/decrement steps
◆ valueFromText()
int ModuleBase_ParamIntSpinBox::valueFromText ( const QString &  theText) const
◆ textFromValue()
QString ModuleBase_ParamIntSpinBox::textFromValue ( int  theValue) const
◆ validate()
QValidator::State ModuleBase_ParamIntSpinBox::validate ( QString &  str,
int &  pos
Validate the value.
This function is used to determine whether input is valid.
strcurrently entered value
poscursor position in the string
validating operation result
◆ setValue()
void ModuleBase_ParamIntSpinBox::setValue ( int  value)
This function is used to set a current value for this spinbox.
valuecurrent value
The new value is ignored if the spinbox has a variable.
◆ setText()
void ModuleBase_ParamIntSpinBox::setText ( const QString &  value)
This function is used to set a text for this spinbox.
valuecurrent value
◆ setAcceptVariables()
void ModuleBase_ParamIntSpinBox::setAcceptVariables ( const bool  flag)
Enables or disables variable names in the spin box. By default, variable names are enabled.
flagIf true, variable names are enabled.
◆ isAcceptVariables()
bool ModuleBase_ParamIntSpinBox::isAcceptVariables ( ) const
Returns true if the spin box accepts variable names.
◆ hasVariable() [1/2]
bool ModuleBase_ParamIntSpinBox::hasVariable ( ) const
◆ hasVariable() [2/2]
bool ModuleBase_ParamIntSpinBox::hasVariable ( const QString &  theText) const
theTexta text string
◆ isValid()
ModuleBase_ParamIntSpinBox::State ModuleBase_ParamIntSpinBox::isValid ( const QString &  theText,
double &  theValue
◆ checkRange()
bool ModuleBase_ParamIntSpinBox::checkRange ( const double  theValue) const
This function is used to check that string value lies within predefined range.
check status
◆ findVariable()
bool ModuleBase_ParamIntSpinBox::findVariable ( const QString &  theName,
double &  outValue
This function is used to determine whether input is a variable name and to get its value.
Returns true in success
theNamea name of variable
outValuean output value of the variable
status of search operation
◆ showEvent()
void ModuleBase_ParamIntSpinBox::showEvent ( QShowEvent *  theEvent)
◆ onTextChanged
void ModuleBase_ParamIntSpinBox::onTextChanged ( const QString &  text)
protectedslot
◆ keyPressEvent()
void ModuleBase_IntSpinBox::keyPressEvent ( QKeyEvent *  theEvent)
