ModuleBase_ResultPrs Class Reference
A redefinition of standard AIS Interactive Object in order to provide specific behaviour for wire presentations based in a one plane. More...
#include <ModuleBase_ResultPrs.h>
Inheritance diagram for ModuleBase_ResultPrs:
enum  SelectionModes { Sel_Result = TopAbs_SHAPE + 1 }
 ModuleBase_ResultPrs (ResultPtr theResult)
virtual void HilightSelected (const Handle &thePM, const SelectMgr_SequenceOfOwner &theOwners)
 Method which draws selected owners ( for fast presentation draw ) More...
virtual void HilightOwnerWithColor (const Handle &thePM, const Handle &theStyle, const Handle &theOwner)
 Method which highlight an owner belonging to this selectable object ( for fast presentation draw ) More...
ResultPtr getResult () const
 Returns result object. More...
int getAdditionalSelectionPriority () const
 Returns selection priorities that will be added to created selection owner. More...
void setAdditionalSelectionPriority (const int thePriority)
 Appends a special priority for the mode of selection. More...
virtual void SetColor (const Quantity_Color &theColor)
 Updates color of sub shape drawer. More...
void setSubShapeHidden (const TopoDS_ListOfShape &theShapes)
 Change presentation to have given shape hidden. More...
bool isSubShapeHidden (const TopoDS_Shape &theShape)
 Returns true if parameter shape has been hidden. More...
const TopoDS_ListOfShape & hiddenSubShapes () const
 Returns hidden sub shapes list. More...
bool hasSubShapeVisible (const TopoDS_ListOfShape &theShapesToSkip)
 Returns true if there are no hidden sub shapes or original shape has at least one not hidden. More...
bool setHiddenSubShapeTransparency (double theTransparency)
 Set transparency of hidden sub shapes: if value is 1, shapes are entirely hidden. More...
TopoDS_Shape originalShape () const
 Returns the original shape of the presentation. More...
bool isSubstituted () const
 Returns True if the original shape is substituted by a corresponded shell. More...
void updateIsoLines ()
virtual DEFINE_STANDARD_RTTIEXT(ModuleBase_ResultPrs, ViewerData_AISShape) protected void ComputeSelection (const Handle &aSelection, const Standard_Integer theMode)
 Redefinition of virtual function. More...
◆ ModuleBase_ResultPrs()
ModuleBase_ResultPrs::ModuleBase_ResultPrs ( ResultPtr  theResult)
theResulta result object
◆ HilightSelected()
void ModuleBase_ResultPrs::HilightSelected ( const Handle &  thePM,
const SelectMgr_SequenceOfOwner &  theOwners
◆ HilightOwnerWithColor()
void ModuleBase_ResultPrs::HilightOwnerWithColor ( const Handle &  thePM,
const Handle &  theStyle,
const Handle &  theOwner
◆ getResult()
ResultPtr ModuleBase_ResultPrs::getResult ( ) const
◆ getAdditionalSelectionPriority()
int ModuleBase_ResultPrs::getAdditionalSelectionPriority ( ) const
integer value
◆ setAdditionalSelectionPriority()
void ModuleBase_ResultPrs::setAdditionalSelectionPriority ( const int  thePriority)
theSelectionModea mode of selection, used in ComputeSelection
thePrioritya new priority value
◆ SetColor()
void ModuleBase_ResultPrs::SetColor ( const Quantity_Color &  theColor)
◆ setSubShapeHidden()
void ModuleBase_ResultPrs::setSubShapeHidden ( const TopoDS_ListOfShape &  theShapes)
It supports FACE type of the shape to be hidden. If presentation type is greater than FACE, the SHELL with be shown with the FACE hidden It is possible to hide more than one FACE by calling the method with given FACES Visual state of the face is controlled by the second parameter
theShapesa container of shape objects
true if the presentation is changed, or false (if for example it was hidden)
◆ isSubShapeHidden()
bool ModuleBase_ResultPrs::isSubShapeHidden ( const TopoDS_Shape &  theShape)
theShapesub-shape of the presentation shape
boolean value
◆ hiddenSubShapes()
const TopoDS_ListOfShape & ModuleBase_ResultPrs::hiddenSubShapes ( ) const
◆ hasSubShapeVisible()
bool ModuleBase_ResultPrs::hasSubShapeVisible ( const TopoDS_ListOfShape &  theShapesToSkip)
theShapesToSkipcontainer of shape to be hidden in the presentation (faces)
boolean value
◆ setHiddenSubShapeTransparency()
bool ModuleBase_ResultPrs::setHiddenSubShapeTransparency ( double  theTransparency)
theTransparencytransparency value
false if parameter is out of [0, 1]
◆ originalShape()
TopoDS_Shape ModuleBase_ResultPrs::originalShape ( ) const
◆ isSubstituted()
bool ModuleBase_ResultPrs::isSubstituted ( ) const
◆ ComputeSelection()
void ModuleBase_ResultPrs::ComputeSelection ( const Handle &  aSelection,
