The main class that performs the high-level operations for connection to the PlaneGCS. More...
#include <PlaneGCSSolver_Solver.h>
Public Types | |
| enum | SolveStatus { STATUS_OK , STATUS_INCONSISTENT , STATUS_EMPTYSET , STATUS_DEGENERATED , STATUS_FAILED , STATUS_UNKNOWN } |
| The result of constraints solution. More... | |
| void | clear () |
| Clear system of equations. More... | |
| void | addConstraint (const ConstraintID &theMultiConstraintID, const std::list< GCSConstraintPtr > &theConstraints) |
| Add constraint to the system of equations. More... | |
| void | removeConstraint (const ConstraintID &theID) |
| Remove constraints from the system of equations. More... | |
| double * | createParameter () |
| Initialize memory for new solver's parameter. More... | |
| void | addParameters (const GCS::SET_pD &theParams) |
| Add parameters created elsewhere. More... | |
| void | removeParameters (const GCS::SET_pD &theParams) |
| Release memory occupied by parameters. More... | |
| void | initialize () |
| Preliminary initialization of solver (useful for moving a feature). More... | |
| SolveStatus | solve () |
| Solve the set of equations. More... | |
| void | undo () |
| Revert solution to initial values. More... | |
| bool | isConflicting (const ConstraintID &theConstraint) const |
| Check the constraint is conflicted with others. More... | |
| void | diagnose (const GCS::Algorithm &theAlgo=GCS::DogLeg) |
| Check conflicting/redundant constraints and DoF. More... | |
| void | getFreeParameters (GCS::SET_pD &theFreeParams) |
| Return the list of modifiable parameters. More... | |
| int | dof () |
| Degrees of freedom. More... | |
| void PlaneGCSSolver_Solver::clear | ( | ) |
| void PlaneGCSSolver_Solver::addConstraint | ( | const ConstraintID & | theMultiConstraintID, |
| const std::list< GCSConstraintPtr > & | theConstraints | ||
| [in] | theMultiConstraintID | ID of the multi constraint which may consists of several primitive constraints |
| [in] | theConstraints | list of primitive constraints |
| void PlaneGCSSolver_Solver::removeConstraint | ( | const ConstraintID & | theID | ) |
| double * PlaneGCSSolver_Solver::createParameter | ( | ) |
| void PlaneGCSSolver_Solver::addParameters | ( | const GCS::SET_pD & | theParams | ) |
| void PlaneGCSSolver_Solver::removeParameters | ( | const GCS::SET_pD & | theParams | ) |
| void PlaneGCSSolver_Solver::initialize | ( | ) |
When called, the solve() method does not reinitialize a set of constraints.
| PlaneGCSSolver_Solver::SolveStatus PlaneGCSSolver_Solver::solve | ( | ) |
| void PlaneGCSSolver_Solver::undo | ( | ) |
| bool PlaneGCSSolver_Solver::isConflicting | ( | const ConstraintID & | theConstraint | ) | const |
| void PlaneGCSSolver_Solver::diagnose | ( | const GCS::Algorithm & | theAlgo = GCS::DogLeg | ) |
| void PlaneGCSSolver_Solver::getFreeParameters | ( | GCS::SET_pD & | theFreeParams | ) |
| int PlaneGCSSolver_Solver::dof | ( | ) |
Degrees of freedom.
