PythonAddons.macros.pipeNetwork.feature.pipeNetwork Class Reference
Inheritance diagram for PythonAddons.macros.pipeNetwork.feature.pipeNetwork:
def __init__ (self)
def getKind (self)
def initAttributes (self)
def decodingCode (self, code)
def readNodeInfo (self, line)
def readConnectivity (self, line, method)
def correctConnectivity (self)
def correctConnectivity_a (self, l_noeuds)
def newConnectivity (self, key, value)
def readFillet (self, line)
def retrieveSubshapesforWire (self, copy, key, ind)
def retrieveLastElement (self, obj, typeOfElement)
def retrieveFirstElement (self, obj, typeOfElement)
def createPipe (self, part, connectivityInfos)
def createPoints (self, part)
def createPolylines (self, part)
def createFillets (self, part)
def searchRightConnections (self, part)
def createPaths (self, part)
def createSketches (self, part)
def createPipes (self, part, nameRes)
def print_info (self, verbose, comment="")
def execute (self)
def isMacro (self)
def ID ()
def FILE_ID ()
Static Public Attributes
 lfeatures = list()
 ledges = list()
 folder = None
bool isHexa = False
string twopartwo = "2par2"
string parligne = "par_ligne"
float radius = 0.5
 infoPoints = dict()
 connectivities = dict()
Creation of a network of pipes
◆ __init__()
def PythonAddons.macros.pipeNetwork.feature.pipeNetwork.__init__ (   self)
x.__init__(...) initializes x; see x.__class__.__doc__ for signature
◆ ID()
def PythonAddons.macros.pipeNetwork.feature.pipeNetwork.ID ( )
Return Id of the Feature.
◆ FILE_ID()
def PythonAddons.macros.pipeNetwork.feature.pipeNetwork.FILE_ID ( )
Returns ID of the file select parameter.
◆ getKind()
def PythonAddons.macros.pipeNetwork.feature.pipeNetwork.getKind (   self)
Override Feature.getKind()
◆ initAttributes()
def PythonAddons.macros.pipeNetwork.feature.pipeNetwork.initAttributes (   self)
Override Feature.initAttributes()
◆ decodingCode()
def PythonAddons.macros.pipeNetwork.feature.pipeNetwork.decodingCode (   self,
  code
decodingCode
◆ readNodeInfo()
def PythonAddons.macros.pipeNetwork.feature.pipeNetwork.readNodeInfo (   self,
  line
Lecture des noeuds
La ligne à décoder est formée des informations :
. l'identifiant du noeud
. si les coordonnées sont données en absolu : "-" suivi des 3 coordonnées
. si les coordonnées sont données en relatif : l'identifiant du noeud de départ, suivi des 3 coordonnées de la translation
Par défaut, on supposera que la connection est angulaire et que ce n'est pas une extrémité.
◆ readConnectivity()
def PythonAddons.macros.pipeNetwork.feature.pipeNetwork.readConnectivity (   self,
  line,
  method
Lecture des connectivités
. si la méthode est par ligne : la liste des identifiants des noeuds formant le trajet
. si la méthode est 2 par 2 : chaque tronçon est décrit par les identifiants des 2 noeuds
Par défaut, on supposera que la méthode est par ligne.
◆ correctConnectivity()
def PythonAddons.macros.pipeNetwork.feature.pipeNetwork.correctConnectivity (   self)
Correction des connectivités pour tenir compte de points alignés
Si 3 points sont alignés sur une ligne et qu'aucune ligne ne part du point central,
il faut scinder la ligne au niveau de ce point pour traiter correctement la suite : on se mettrait
à créer un plan avec ces 3 points alignés et tout s'effondre ensuite.
◆ correctConnectivity_a()
def PythonAddons.macros.pipeNetwork.feature.pipeNetwork.correctConnectivity_a (   self,
  l_noeuds
On explore toutes les lignes et on cherche un cas où sur une ligne 3 points consécutifs sont alignés
Entrées :
:l_noeuds: liste des noeuds de la ligne
Sorties :
:modif: on a modifié ou non la description des lignes
◆ newConnectivity()
def PythonAddons.macros.pipeNetwork.feature.pipeNetwork.newConnectivity (   self,
  key,
  value
newConnectivity
◆ readFillet()
def PythonAddons.macros.pipeNetwork.feature.pipeNetwork.readFillet (   self,
  line
Décodage des caractéristiques de la connection entre deux tuyaux
La ligne est formée de deux informations :
. la caractérisation de la connection : "angular_connection" ou "radius=xxx"
◆ retrieveSubshapesforWire()
def PythonAddons.macros.pipeNetwork.feature.pipeNetwork.retrieveSubshapesforWire (   self,
  copy,
  key,
  ind
◆ retrieveLastElement()
def PythonAddons.macros.pipeNetwork.feature.pipeNetwork.retrieveLastElement (   self,
  obj,
  typeOfElement
retrieveLastElement
◆ retrieveFirstElement()
def PythonAddons.macros.pipeNetwork.feature.pipeNetwork.retrieveFirstElement (   self,
  obj,
  typeOfElement
◆ createPipe()
def PythonAddons.macros.pipeNetwork.feature.pipeNetwork.createPipe (   self,
  part,
  connectivityInfos
createPipe
◆ createPoints()
def PythonAddons.macros.pipeNetwork.feature.pipeNetwork.createPoints (   self,
  part
Création des points
Le point est créé en tant qu'objet de construction avec ses coordonnées.
Il est nommé conformément au texte donné dans le fichier de données. Cela n'a qu'un intérêt graphique mais agréable en débogage.
◆ createPolylines()
def PythonAddons.macros.pipeNetwork.feature.pipeNetwork.createPolylines (   self,
  part
Création des polylines
La polyligne est créée en tant que résultat en enchaînant ses points.
Elle est nommée conformément aux 1er et dernier noeud. Cela n'a qu'un intérêt graphique mais agréable en débogage.
◆ createFillets()
def PythonAddons.macros.pipeNetwork.feature.pipeNetwork.createFillets (   self,
  part
Création des fillets
Le fillet est créé en tant que résultat.
Il est nommé conformément au noeud d'application. Cela n'a qu'un intérêt graphique mais agréable en débogage.
◆ searchRightConnections()
def PythonAddons.macros.pipeNetwork.feature.pipeNetwork.searchRightConnections (   self,
  part
Recherche des coudes droits
◆ createPaths()
def PythonAddons.macros.pipeNetwork.feature.pipeNetwork.createPaths (   self,
  part
Création des paths pour le pipeNetwork
◆ createSketches()
def PythonAddons.macros.pipeNetwork.feature.pipeNetwork.createSketches (   self,
  part
Création des sketchs
◆ createPipes()
def PythonAddons.macros.pipeNetwork.feature.pipeNetwork.createPipes (   self,
  part,
  nameRes
Création des pipes
◆ print_info()
def PythonAddons.macros.pipeNetwork.feature.pipeNetwork.print_info (   self,
  verbose,
  comment = ""
Impression si verbose est valide. Avec un comentaire introductif éventuellement.
◆ execute()
def PythonAddons.macros.pipeNetwork.feature.pipeNetwork.execute (   self)
F.execute() -- execute the Feature
◆ isMacro()
def PythonAddons.macros.pipeNetwork.feature.pipeNetwork.isMacro (   self)
Override Feature.initAttributes().
F.isMacro() -> True
pipeNetwork feature is macro: removes itself on the creation transaction
finish.
