PythonAddons.macros.rectangle.feature.SketchPlugin_Rectangle Class Reference
Inheritance diagram for PythonAddons.macros.rectangle.feature.SketchPlugin_Rectangle:
def __init__ (self)
def getKind (self)
def initAttributes (self)
def isMacro (self)
def execute (self)
def attributeChanged (self, theID)
def ID ()
def START_ID ()
def END_ID ()
def AUXILIARY_ID ()
def LINES_LIST_ID ()
def RECTANGLE_TYPE_ID ()
def RECTANGLE_BY_CORNERS_ID ()
def RECTANGLE_CENTERED_ID ()
def CENTER_ID ()
def CENTER_REF_ID ()
def CORNER_ID ()
Implementation of rectangle creation.
It produced 2 horizontal lines and 2 vertical lines connected by coincidence constraints
◆ __init__()
def PythonAddons.macros.rectangle.feature.SketchPlugin_Rectangle.__init__ (   self)
x.__init__(...) initializes x; see x.__class__.__doc__ for signature
◆ ID()
def PythonAddons.macros.rectangle.feature.SketchPlugin_Rectangle.ID ( )
Rectangle feature kind.
◆ START_ID()
def PythonAddons.macros.rectangle.feature.SketchPlugin_Rectangle.START_ID ( )
Returns ID of first corner.
◆ END_ID()
def PythonAddons.macros.rectangle.feature.SketchPlugin_Rectangle.END_ID ( )
Returns ID of second corner.
◆ AUXILIARY_ID()
def PythonAddons.macros.rectangle.feature.SketchPlugin_Rectangle.AUXILIARY_ID ( )
Returns whether the rectangle is accessory.
◆ LINES_LIST_ID()
def PythonAddons.macros.rectangle.feature.SketchPlugin_Rectangle.LINES_LIST_ID ( )
Returns ID of list containing lines created.
◆ RECTANGLE_TYPE_ID()
def PythonAddons.macros.rectangle.feature.SketchPlugin_Rectangle.RECTANGLE_TYPE_ID ( )
Returns ID of type of rectangle creation (by corners or by center and corner).
◆ RECTANGLE_BY_CORNERS_ID()
def PythonAddons.macros.rectangle.feature.SketchPlugin_Rectangle.RECTANGLE_BY_CORNERS_ID ( )
Returns ID of creation type by opposite corners.
◆ RECTANGLE_CENTERED_ID()
def PythonAddons.macros.rectangle.feature.SketchPlugin_Rectangle.RECTANGLE_CENTERED_ID ( )
Returns ID of creation type by center point and a corner.
◆ CENTER_ID()
def PythonAddons.macros.rectangle.feature.SketchPlugin_Rectangle.CENTER_ID ( )
Returns ID of center point.
◆ CENTER_REF_ID()
def PythonAddons.macros.rectangle.feature.SketchPlugin_Rectangle.CENTER_REF_ID ( )
Returns ID of the reference to the center point.
◆ CORNER_ID()
def PythonAddons.macros.rectangle.feature.SketchPlugin_Rectangle.CORNER_ID ( )
Returns ID of a corner.
◆ getKind()
def PythonAddons.macros.rectangle.feature.SketchPlugin_Rectangle.getKind (   self)
Override Feature.getKind()
◆ initAttributes()
def PythonAddons.macros.rectangle.feature.SketchPlugin_Rectangle.initAttributes (   self)
Override Feature.initAttributes()
◆ isMacro()
def PythonAddons.macros.rectangle.feature.SketchPlugin_Rectangle.isMacro (   self)
Override Feature.isMacro().
Rectangle feature is macro: removes itself on the creation transaction finish.
