SketcherPrs_SensitivePoint Class Reference
This sensitive point is done in order to optimize process of the sinzitive area update It referes on point array directly and this lets to avoid procedure of the point synchronisation. More...
#include <SketcherPrs_SensitivePoint.h>
Inheritance diagram for SketcherPrs_SensitivePoint:
 SketcherPrs_SensitivePoint (const Handle &OwnerId, int theId)
 Constructs a sensitive point object defined by the. More...
virtual Standard_Integer NbSubElements () Standard_OVERRIDE
 Returns number of sub-elements. More...
virtual Handle GetConnected () Standard_OVERRIDE
 Update location of the point. More...
virtual Standard_Boolean Matches (SelectBasics_SelectingVolumeManager &theMgr, SelectBasics_PickResult &thePickResult) Standard_OVERRIDE
 Checks whether the point overlaps current selecting volume. More...
gp_Pnt Point () const
 Returns the point used at the time of construction. More...
virtual gp_Pnt CenterOfGeometry () const Standard_OVERRIDE
 Returns center of point. More...
virtual Select3D_BndBox3d BoundingBox () Standard_OVERRIDE
 Returns bounding box of the point. More...
virtual void Clear () Standard_OVERRIDE
 Clear sub-elements. More...
◆ SketcherPrs_SensitivePoint()
SketcherPrs_SensitivePoint::SketcherPrs_SensitivePoint ( const Handle &  OwnerId,
int  theId
OwnerIdan Id of the Owner.
theIdand Id of its point
◆ NbSubElements()
Standard_Integer SketcherPrs_SensitivePoint::NbSubElements ( )
◆ GetConnected()
Handle SketcherPrs_SensitivePoint::GetConnected ( )
◆ Matches()
Standard_Boolean SketcherPrs_SensitivePoint::Matches ( SelectBasics_SelectingVolumeManager &  theMgr,
SelectBasics_PickResult &  thePickResult
theMgrselection manager
thePickResultreturns pick result
◆ Point()
gp_Pnt SketcherPrs_SensitivePoint::Point ( ) const
◆ CenterOfGeometry()
gp_Pnt SketcherPrs_SensitivePoint::CenterOfGeometry ( ) const
If location transformation is set, it will be applied
◆ BoundingBox()
Select3D_BndBox3d SketcherPrs_SensitivePoint::BoundingBox ( )
◆ Clear()
void SketcherPrs_SensitivePoint::Clear ( )
Clear sub-elements.
