Step with boolean values.
More...
#include <XAO_BooleanStep.hxx>
| | BooleanStep (int step, int stamp, int nbElements, int nbComponents) |
| | Constructor. More...
| virtual XAO::Type | getType () |
| | Gets the type of the step. More...
| std::vector< bool > | getValues () |
| | Gets all the values in a vector by elements and by components. More...
| std::vector< bool > | getElement (int element) |
| | Gets all the values for an element. More...
| std::vector< bool > | getComponent (int component) |
| | Gets all the values for a component. More...
| bool | getValue (int element, int component) |
| | Gets a value for an element and a component. More...
| void | setValues (const std::vector< bool > &values) |
| | Sets all the values from a list. More...
| void | setElement (int element, const std::vector< bool > &elements) |
| | Sets the values for an element. More...
| void | setComponent (int component, const std::vector< bool > &components) |
| | Sets the values for a component. More...
| void | setValue (int element, int component, bool value) |
| | Sets the value for an element and a component. More...
| virtual const std::string | getStringValue (int element, int component) |
| | Gets a value as a string. More...
| virtual void | setStringValue (int element, int component, const std::string &value) |
| | Sets a value as a string. More...
| int | getStep () |
| | Gets the step index. More...
| void | setStep (int step) |
| | Sets the number of the step. More...
| int | getStamp () |
| | Gets the stamp of the index. More...
| void | setStamp (int stamp) |
| | Sets the stamp of the index. More...
| int | countComponents () |
| | Gets the number of components of the step. More...
| int | countElements () |
| | Gets the number of elements for the step. More...
| int | countValues () |
| | Gets the number of values for the step. More...
◆ BooleanStep()
| BooleanStep::BooleanStep |
int |
step, |
int |
stamp, |
int |
nbElements, |
int |
nbComponents |
- Parameters
| step | the step number. |
| stamp | the stamp of the step. |
| nbElements | the number elements of the geometry. |
| nbComponents | the number of components of the field. |
◆ getType()
| virtual XAO::Type XAO::BooleanStep::getType |
inlinevirtual |
- Returns
Implements XAO::Step.
◆ getValues()
| std::vector< bool > BooleanStep::getValues |
- Returns
- a vector containing all the values.
◆ getElement()
| std::vector< bool > BooleanStep::getElement |
int |
element | ) |
- Parameters
| element | the index of the element to get. |
- Returns
- a vector containing all the values for the given element.
◆ getComponent()
| std::vector< bool > BooleanStep::getComponent |
int |
component | ) |
- Parameters
| component | the index of the component to get. |
- Returns
- a vector containing all the values for the given component.
◆ getValue()
| bool BooleanStep::getValue |
int |
element, |
int |
component |
- Parameters
| element | the index of the element. |
| component | the index of the component. |
- Returns
- the value.
◆ setValues()
| void BooleanStep::setValues |
const std::vector< bool > & |
values | ) |
- Parameters
| values | the list of values to set. |
◆ setElement()
| void BooleanStep::setElement |
int |
element, |
elements |
- Parameters
| element | the index of the element to set. |
| elements | the values to set. |
◆ setComponent()
| void BooleanStep::setComponent |
int |
component, |
components |
- Parameters
| component | the index of the component to set. |
| components | the values to set. |
◆ setValue()
| void BooleanStep::setValue |
int |
element, |
int |
component, |
bool |
value |
- Parameters
| value | the value. |
◆ getStringValue()
| const std::string BooleanStep::getStringValue |
int |
element, |
int |
component |
- Parameters
- Returns
- the value as a string.
◆ setStringValue()
| void BooleanStep::setStringValue |
int |
element, |
int |
component, |
const std::string & |
value |
- Parameters
| value | the string value. |
- Exceptions
◆ getStep()
| int XAO::Step::getStep |
inlineinherited |
- Returns
- the index of the step.
◆ setStep()
| void XAO::Step::setStep |
int |
step | ) |
inlineinherited |
- Parameters
◆ getStamp()
| int XAO::Step::getStamp |
inlineinherited |
- Returns
- the stamp of the index.
◆ setStamp()
| void XAO::Step::setStamp |
int |
stamp | ) |
inlineinherited |
- Parameters
◆ countComponents()
| int XAO::Step::countComponents |
inlineinherited |
- Returns
- the number of components.
◆ countElements()
| int XAO::Step::countElements |
inlineinherited |
- Returns
- the number of elements.
◆ countValues()
| int XAO::Step::countValues |
inlineinherited |
- Returns
- the number of values.
◆ checkElementIndex()
| void Step::checkElementIndex |
int |
element | ) |
protectedinherited |
Checks that given element index is in the range of element indexes.
- Parameters
| element | the index to check. |
◆ checkComponentIndex()
| void Step::checkComponentIndex |
int |
component | ) |
Checks that given component index is in the range of component indexes.
- Parameters
| component | the index to check. |
◆ checkNbElements()
| void Step::checkNbElements |
int |
nbElements | ) |
Checks that the given number of elements is correct.
- Parameters
| nbElements | the number of elements to check. |
◆ checkNbComponents()
| void Step::checkNbComponents |
int |
nbComponents | ) |
Checks that the given number of components is correct.
- Parameters
| nbComponents | the number of components to check. |
◆ checkNbValues()
| void Step::checkNbValues |
int |
nbValues | ) |
checks that the given number of values is correct.
- Parameters
| nbValues | the number of values to check. |
◆ m_step
◆ m_stamp
◆ m_nbComponents
| int XAO::Step::m_nbComponents |
The number of components.
◆ m_nbElements
| int XAO::Step::m_nbElements |
