Class to represent a Geometrical Group.
More...
#include <XAO_Group.hxx>
| | Group (XAO::Dimension dim, int nbElements, const std::string &name=std::string("")) |
| | Constructor. More...
| virtual | ~Group () |
| | Destructor. More...
| const std::string | getName () |
| | Gets the name of the group. More...
| void | setName (const std::string &name) |
| | Sets the name of the group. More...
| XAO::Dimension | getDimension () |
| | Gets the dimension of the group. More...
| int | getNbElements () |
| | Gets the numbers of elements in the geometry of the same type than the group. More...
| int | count () const |
| | Gets the number of elements in the group. More...
| int | get (int index) |
| | Gets the reference of an element. More...
| void | add (int value) |
| | Adds an element to the group. More...
| void | remove (int value) |
| | Removes an element from the group. More...
| std::set< int >::iterator | begin () |
| | Gets an iterator on the first element in the group. More...
| std::set< int >::iterator | end () |
| | Gets an iterator on the last element in the group. More...
◆ Group()
| Group::Group |
XAO::Dimension |
dim, |
int |
nbElements, |
const std::string & |
name = std::string("") |
- Parameters
| dim | the dimension of the group. |
| nbElements | the number of geometrical elements for the dimension in the geometry. |
| name | the name of the group. |
◆ ~Group()
◆ getName()
| const std::string XAO::Group::getName |
inline |
- Returns
- the name of the group.
◆ setName()
| void XAO::Group::setName |
name | ) |
inline |
- Parameters
◆ getDimension()
| XAO::Dimension XAO::Group::getDimension |
inline |
- Returns
- the dimension of the group.
◆ getNbElements()
| int XAO::Group::getNbElements |
inline |
- Returns
- the number of elements in the associated geometry.
◆ count()
| int XAO::Group::count |
const |
inline |
- Returns
- the number of elements.
◆ get()
| int XAO::Group::get |
int |
index | ) |
inline |
- Parameters
| index | the index of the element. |
- Returns
- the reference of the element.
- Note
- use begin() and end() if you need to iterate.
◆ add()
| void Group::add |
int |
value | ) |
- Parameters
| value | the index of the element to add. |
◆ remove()
| void Group::remove |
int |
value | ) |
- Parameters
| value | the index of the element to remove. |
◆ begin()
| std::set< int >::iterator XAO::Group::begin |
inline |
- Returns
- an iterator on the first element.
◆ end()
| std::set< int >::iterator XAO::Group::end |
inline |
- Returns
- an iterator on the last element.
