XAO::IntegerStep Class Reference
Step with integer values. More...
#include <XAO_IntegerStep.hxx>
Inheritance diagram for XAO::IntegerStep:
 IntegerStep (int step, int stamp, int nbElements, int nbComponents)
virtual XAO::Type getType ()
 Gets the type of the step. More...
std::vector< int > getValues ()
 Gets all the values of the step as a list. More...
std::vector< int > getElement (int element)
 Gets all the values for a given element. More...
std::vector< int > getComponent (int component)
 Gets all the values for a given component. More...
int getValue (int element, int component)
 Gets the value for an element and a component. More...
void setValues (const std::vector< int > &values)
 Sets all the values from a list. More...
void setElement (int element, const std::vector< int > &elements)
 Sets the values for an element. More...
void setComponent (int component, const std::vector< int > &components)
 Sets the values for a component. More...
void setValue (int element, int component, int value)
 Sets the value for an element and a component. More...
virtual const std::string getStringValue (int element, int component)
 Gets a value as a string. More...
virtual void setStringValue (int element, int component, const std::string &value)
 Sets a value as a string. More...
int getStep ()
 Gets the step index. More...
void setStep (int step)
 Sets the number of the step. More...
int getStamp ()
 Gets the stamp of the index. More...
void setStamp (int stamp)
 Sets the stamp of the index. More...
int countComponents ()
 Gets the number of components of the step. More...
int countElements ()
 Gets the number of elements for the step. More...
int countValues ()
 Gets the number of values for the step. More...
void checkElementIndex (int element)
 Checks that given element index is in the range of element indexes. More...
void checkComponentIndex (int component)
 Checks that given component index is in the range of component indexes. More...
void checkNbElements (int nbElements)
 Checks that the given number of elements is correct. More...
void checkNbComponents (int nbComponents)
 Checks that the given number of components is correct. More...
void checkNbValues (int nbValues)
 checks that the given number of values is correct. More...
int m_step
 the index of the step. More...
int m_stamp
 The stamp of the step. More...
int m_nbComponents
 The number of components. More...
int m_nbElements
 The number of elements. More...
◆ IntegerStep()
IntegerStep::IntegerStep ( int  step,
int  stamp,
int  nbElements,
int  nbComponents
stepthe step number.
stampthe stamp of the step.
nbElementsthe number elements of the geometry.
nbComponentsthe number of components of the field.
◆ getType()
virtual XAO::Type XAO::IntegerStep::getType ( )
Implements XAO::Step.
◆ getValues()
std::vector< int > IntegerStep::getValues ( )
a vector containing all the values of the step.
◆ getElement()
std::vector< int > IntegerStep::getElement ( int  element)
elementthe index of the element.
a vector containing all the values for the given element.
◆ getComponent()
std::vector< int > IntegerStep::getComponent ( int  component)
componentthe index of the component.
a vector containing all the values for the given component.
◆ getValue()
int IntegerStep::getValue ( int  element,
int  component
the value for the given element and component.
◆ setValues()
void IntegerStep::setValues ( const std::vector< int > &  values)
valuesthe list of values to set.
◆ setElement()
void IntegerStep::setElement ( int  element,
const std::vector< int > &  elements
elementthe index of the element to set.
elementsthe values to set.
◆ setComponent()
void IntegerStep::setComponent ( int  component,
const std::vector< int > &  components
componentthe index of the component to set.
componentsthe values to set.
◆ setValue()
void IntegerStep::setValue ( int  element,
int  component,
int  value
valuethe value.
◆ getStringValue()
const std::string IntegerStep::getStringValue ( int  element,
int  component
the value as a string.
◆ setStringValue()
void IntegerStep::setStringValue ( int  element,
int  component,
const std::string &  value
valuethe string value.
Exceptions
XAO_Exceptionif the value is not valid.
◆ getStep()
int XAO::Step::getStep ( )
◆ setStep()
void XAO::Step::setStep ( int  step)
stepthe index to set.
◆ getStamp()
int XAO::Step::getStamp ( )
◆ setStamp()
void XAO::Step::setStamp ( int  stamp)
stampthe stamp to set.
◆ countComponents()
int XAO::Step::countComponents ( )
the number of components.
◆ countElements()
int XAO::Step::countElements ( )
the number of elements.
◆ countValues()
int XAO::Step::countValues ( )
the number of values.
◆ checkElementIndex()
void Step::checkElementIndex ( int  element)
elementthe index to check.
◆ checkComponentIndex()
void Step::checkComponentIndex ( int  component)
componentthe index to check.
◆ checkNbElements()
void Step::checkNbElements ( int  nbElements)
nbElementsthe number of elements to check.
◆ checkNbComponents()
void Step::checkNbComponents ( int  nbComponents)
nbComponentsthe number of components to check.
◆ checkNbValues()
void Step::checkNbValues ( int  nbValues)
nbValuesthe number of values to check.
◆ m_step
int XAO::Step::m_step
◆ m_stamp
int XAO::Step::m_stamp
◆ m_nbComponents
int XAO::Step::m_nbComponents
◆ m_nbElements
int XAO::Step::m_nbElements
