SMDS_MeshFace.hxx
23// SMESH SMDS : implementation of Salome mesh data structure
24// File : SMDS_MeshFace.hxx
25// Module : SMESH
26//
27#ifndef _SMDS_MeshFace_HeaderFile
28#define _SMDS_MeshFace_HeaderFile
30#include "SMESH_SMDS.hxx"
31
32#include "SMDS_MeshCell.hxx"
33
34#include "Utils_SALOME_Exception.hxx"
35
41{
42 void init( const std::vector<vtkIdType>& vtkNodeIds )
43 {
45 switch ( vtkNodeIds.size())
46 {
47 case 3: entity = SMDSEntity_Triangle; break;
48 case 4: entity = SMDSEntity_Quadrangle; break;
49 case 6: entity = SMDSEntity_Quad_Triangle; break;
50 case 8: entity = SMDSEntity_Quad_Quadrangle; break;
51 case 7: entity = SMDSEntity_BiQuad_Triangle; break;
52 case 9: entity = SMDSEntity_BiQuad_Quadrangle; break;
53 default: throw SALOME_Exception("wrong face nodes");
54 }
55 SMDS_MeshCell::init( entity, vtkNodeIds );
56 }
57
58 friend class SMDS_Mesh;
59
60 public:
61
62 virtual SMDSAbs_ElementType GetType() const { return SMDSAbs_Face; }
63
65};
66
67#endif
SMDSAbs_ElementType
Type (node, edge, face or volume) of elements.
Definition: SMDSAbs_ElementType.hxx:34
@ SMDSAbs_Face
Definition: SMDSAbs_ElementType.hxx:38
SMDSAbs_EntityType
Enumeration of entity type used in mesh info array.
Definition: SMDSAbs_ElementType.hxx:79
@ SMDSEntity_Quad_Triangle
Definition: SMDSAbs_ElementType.hxx:85
@ SMDSEntity_Quadrangle
Definition: SMDSAbs_ElementType.hxx:87
@ SMDSEntity_BiQuad_Triangle
Definition: SMDSAbs_ElementType.hxx:86
@ SMDSEntity_Triangle
Definition: SMDSAbs_ElementType.hxx:84
@ SMDSEntity_Quad_Quadrangle
Definition: SMDSAbs_ElementType.hxx:88
@ SMDSEntity_BiQuad_Quadrangle
Definition: SMDSAbs_ElementType.hxx:89
#define SMDS_EXPORT
Definition: SMESH_SMDS.hxx:37
Base class for all cells.
Definition: SMDS_MeshCell.hxx:32
void init(SMDSAbs_EntityType entityType, int nbNodes,...)
Definition: SMDS_MeshCell.cxx:436
Mesh face.
Definition: SMDS_MeshFace.hxx:41
static SMDSAbs_ElementType Type()
Definition: SMDS_MeshFace.hxx:64
void init(const std::vector< vtkIdType > &vtkNodeIds)
Definition: SMDS_MeshFace.hxx:42
Definition: SMDS_MeshFace.hxx:62
Definition: SMDS_Mesh.hxx:53
