SMDS_MeshFace Class Reference
Mesh face. More...
#include <SMDS_MeshFace.hxx>
Inheritance diagram for SMDS_MeshFace:
typedef SMDS_StdIterator< const SMDS_MeshNode *, SMDS_NodeIteratorPtr > iterator
virtual SMDSAbs_ElementType GetType () const
virtual int NbEdges () const
virtual int NbFaces () const
virtual int NbNodes () const
 Return The number of nodes owned by the current element. More...
virtual int NbCornerNodes () const
virtual bool ChangeNodes (const SMDS_MeshNode *nodes[], const int nbNodes)
virtual int GetNodeIndex (const SMDS_MeshNode *node) const
 Check if a node belongs to the element. More...
virtual const SMDS_MeshNode * GetNode (const int ind) const
 Return node by its index. More...
virtual SMDSAbs_EntityType GetEntityType () const
virtual SMDSAbs_GeometryType GetGeomType () const
virtual VTKCellType GetVtkType () const
virtual bool IsPoly () const
virtual bool IsQuadratic () const
virtual SMDS_ElemIteratorPtr nodesIterator () const
 Create an iterator which iterate on nodes owned by the element. More...
virtual SMDS_NodeIteratorPtr nodeIterator () const
virtual SMDS_NodeIteratorPtr interlacedNodesIterator () const
virtual SMDS_NodeIteratorPtr nodesIteratorToUNV () const
iterator begin_nodes () const
iterator end_nodes () const
virtual bool IsMediumNode (const SMDS_MeshNode *node) const
 Check if a node is a medium node of a quadratic cell. More...
const SMDS_MeshNode * GetNodeWrap (const int ind) const
virtual bool IsValidIndex (const int ind) const
 Return true if index of node is valid (0 <= ind < NbNodes()) More...
int WrappedIndex (const int ind) const
 Return a valid corner node index, fixing the given one if necessary. More...
virtual smIdType GetID () const
 Return ID of an element. More...
virtual vtkIdType GetVtkID () const
 Return VTK ID of this element. More...
virtual int getshapeId () const
virtual int GetShapeID () const
 Return ID of a shape this element was generated on. More...
virtual void setIsMarked (bool is) const
 Mark this element. More...
virtual bool isMarked () const
 Check if this element is marked. More...
bool IsNull () const
SMDS_Mesh * GetMesh () const
 Return the mesh this element belongs to. More...
virtual void Print (std::ostream &OS) const
 Print self. More...
static SMDSAbs_ElementType Type ()
static int NbEdges (SMDSAbs_EntityType entityType)
static int NbFaces (SMDSAbs_EntityType entityType)
static int NbNodes (SMDSAbs_EntityType entityType)
static int NbCornerNodes (SMDSAbs_EntityType entityType)
static bool IsPoly (SMDSAbs_EntityType entityType)
static bool IsQuadratic (SMDSAbs_EntityType entityType)
static void InitStaticMembers ()
static VTKCellType toVtkType (SMDSAbs_EntityType entityType)
 Return VTKCellType corresponding to SMDSAbs_EntityType. More...
static SMDSAbs_EntityType toSmdsType (VTKCellType vtkType)
 Return SMDSAbs_EntityType corresponding to VTKCellType. More...
static SMDSAbs_ElementType ElemType (SMDSAbs_GeometryType geomType)
 Return SMDSAbs_ElementType by SMDSAbs_GeometryType. More...
static SMDSAbs_ElementType ElemType (SMDSAbs_EntityType entityType)
 Return SMDSAbs_ElementType by SMDSAbs_EntityType. More...
static SMDSAbs_GeometryType GeomType (SMDSAbs_EntityType entityType)
static const std::vector< int > & toVtkOrder (VTKCellType vtkType)
 Return indices to transform cell connectivity from SMDS to VTK Usage: vtkIDs[i] = smdsIDs[ indices[ i ]]. More...
static const std::vector< int > & toVtkOrder (SMDSAbs_EntityType smdsType)
static const std::vector< int > & fromVtkOrder (VTKCellType vtkType)
 Return indices to transform cell connectivity from VTK to SMDS Usage: smdsIDs[i] = vtkIDs[ indices[ i ]]. More...
static const std::vector< int > & fromVtkOrder (SMDSAbs_EntityType smdsType)
static const std::vector< int > & reverseSmdsOrder (SMDSAbs_EntityType smdsType, const size_t nbNodes=0)
 Return indices to reverse an SMDS cell of given type. More...
static const std::vector< int > & interlacedSmdsOrder (SMDSAbs_EntityType smdsType, const size_t nbNodes=0)
 Return indices to set nodes of a quadratic 1D or 2D element in interlaced order Usage: interlacedIDs[i] = smdsIDs[ indices[ i ]]. More...
template<class VECT >
static void applyInterlace (const std::vector< int > &interlace, VECT &data)
static void applyInterlaceRev (const std::vector< int > &interlace, VECT &data)
void init (SMDSAbs_EntityType entityType, int nbNodes,...)
void init (SMDSAbs_EntityType entityType, const std::vector< const SMDS_MeshNode * > &nodes)
void init (SMDSAbs_EntityType entityType, const std::vector< vtkIdType > &vtkNodeIds)
void setVtkID (const vtkIdType vtkID)
 Store VTK ID. More...
virtual void setShapeID (const int shapeID) const
 Set ID of a shape this element was generated on. More...
SMDS_UnstructuredGrid * getGrid () const
 Return a SMDS_UnstructuredGrid. More...
SMDS_ElementChunk * myHolder
void init (const std::vector< vtkIdType > &vtkNodeIds)
Friends
class SMDS_Mesh
Mesh face.
This type is not allocated. It is only used as function argument type to provide more clear semantic.
◆ iterator
◆ applyInterlace()
◆ applyInterlaceRev()
static void SMDS_MeshCell::applyInterlaceRev ( const std::vector< int > &  interlace,
VECT &  data
◆ begin_nodes()
◆ ChangeNodes()
bool SMDS_MeshCell::ChangeNodes ( const SMDS_MeshNode *  nodes[],
const int  nbNodes
◆ ElemType() [1/2]
SMDSAbs_ElementType SMDS_MeshCell::ElemType ( SMDSAbs_EntityType  entityType)
◆ ElemType() [2/2]
◆ end_nodes()
◆ fromVtkOrder() [1/2]
const std::vector< int > & SMDS_MeshCell::fromVtkOrder ( SMDSAbs_EntityType  smdsType)
◆ fromVtkOrder() [2/2]
const std::vector< int > & SMDS_MeshCell::fromVtkOrder ( VTKCellType  vtkType)
References SMDS_MeshCell::fromVtkOrder(), and SMDS_MeshCell::toSmdsType().
Referenced by _GetVtkNodes::_GetVtkNodes(), SMDS_MeshCell::fromVtkOrder(), and SMDS_MeshCell::GetNode().
◆ GeomType()
SMDSAbs_GeometryType SMDS_MeshCell::GeomType ( SMDSAbs_EntityType  entityType)
◆ GetEntityType()
◆ GetGeomType()
SMDSAbs_GeometryType SMDS_MeshCell::GetGeomType ( ) const
Implements SMDS_MeshElement.
Reimplemented in SMDS_MeshEdge.
References SMDS_MeshCell::GetVtkType().
◆ getGrid()
◆ GetID()
smIdType SMDS_MeshElement::GetID ( ) const
Reimplemented in SMDS_CellOfNodes.
References SMDS_ElementChunk::GetID(), and SMDS_MeshElement::myHolder.
Referenced by SMESH_Gen_i::_GetInside(), SMESHDS_SubMesh::add(), SMESHDS_Mesh::Add0DElement(), SMESH_MeshEditor_i::Add0DElement(), SMESHDS_Mesh::Add0DElementWithID(), SMESHDS_Mesh::AddBall(), SMESH_MeshEditor_i::AddBall(), SMESHDS_Mesh::AddBallWithID(), SMESHDS_Mesh::AddEdge(), SMESH_MeshEditor_i::AddEdge(), SMESHDS_Mesh::AddEdgeWithID(), SMESHDS_Mesh::AddFace(), SMESH_MeshEditor_i::AddFace(), SMESHDS_Mesh::AddFaceWithID(), SMESH_MeshEditor_i::AddNode(), SMESHDS_Mesh::AddNode(), SMESHDS_Mesh::AddNodeWithID(), SMESH_MeshEditor_i::AddPolygonalFace(), SMESHDS_Mesh::AddPolygonalFace(), SMESH_MeshEditor_i::AddPolyhedralVolume(), SMESHDS_Mesh::AddPolyhedralVolume(), SMESH_MeshEditor_i::AddPolyhedralVolumeByFaces(), SMESH_MeshEditor_i::AddQuadPolygonalFace(), SMESHDS_Mesh::AddQuadPolygonalFace(), SMESHDS_Mesh::AddVolume(), SMESH_MeshEditor_i::AddVolume(), SMESHDS_Mesh::AddVolumeWithID(), SMESH_MeshEditor_i::AffectedElemGroupsInRegion(), SMESH_VisualObjDef::buildElemPrs(), SMESHDS_Mesh::ChangeElementNodes(), SMESHDS_Mesh::ChangePolyhedronNodes(), SMESHGUI_CreatePolyhedralVolumeDlg::checkEditLine(), SMESH_MesherHelper::CheckNodeU(), VISCOUS_3D::_ConvexFace::CheckPrisms(), SMDS_NodeFactory::Compact(), StdMeshers_Prism_3D::compute(), StdMeshers_Import_1D2D::Compute(), StdMeshers_PolyhedronPerSolid_3D::Compute(), StdMeshers_Projection_3D::Compute(), StdMeshers_RadialPrism_3D::Compute(), VISCOUS_3D::_ViscousBuilder::computeGeomSize(), StdMeshers_Sweeper::ComputeNodesOnStraight(), SMESH_Gen_i::ConcatenateCommon(), SMESHDS_GroupBase::Contains(), SMESHDS_GroupOnFilter::Contains(), SMDS_Mesh::Contains(), SMESH_MeshEditor::convertElemToQuadratic(), SMESH_MeshEditor::ConvertFromQuadratic(), SMESH_MeshEditor::ConvertToQuadratic(), MeshEditor_I::TPreviewMesh::Copy(), SMESH_Gen_i::CopyMesh(), SMESH_Gen_i::CopyMeshWithGeom(), SMESH_Mesh_i::CreateDimGroup(), SMESH_MeshEditor::CreateFlatElementsOnFacesGroups(), SMESH_MeshEditor::CreateHoleSkin(), SMESH_VisualObjDef::createPoints(), SMESH_MeshAlgos::Intersector::Algo::Cut(), SMESH_MeshAlgos::Intersector::CutByPlanes(), SMESHGUI_CuttingOfQuadsDlg::displayPreview(), SMESHGUI_CreatePolyhedralVolumeDlg::displaySimulation(), SMESH_MeshEditor::DoubleNodesOnGroupBoundaries(), StdMeshers_PrismAsBlock::THorizontalEdgeAdaptor::dumpNodes(), SMESH::SelectionProxy::elementConnectivity(), enlargeBoundingBox(), SMESH_MeshEditor::ExtrusionSweep(), VISCOUS_3D::_ViscousBuilder::findCollisionEdges(), SMESH::Controls::ManifoldPart::findConnected(), StdMeshers_Sweeper::findDelaunayTriangles(), SMESH_Mesh_i::FindElementByNodes(), SMESH_MeshEditor::FindEqualElements(), SMESH_MeshEditor::FindFreeBorder(), SMESH_MeshEditor::FindMatchingNodes(), SMESH_MeshEditor::FindShape(), SMESH_MeshEditor_i::FindSharpEdges(), findTriangles(), SMDS_ElementFactory::Free(), SMESH::Controls::FreeEdges::GetBoreders(), VISCOUS_3D::getDistFromEdge(), SMESH_VisualObjDef::GetEdgeNodes(), SMESHGUI_PreVisualObj::GetEdgeNodes(), SMESHDS_GroupOnFilter::getElementIds(), MeshEditor_I::getElementsAround(), SMESH_subMesh_i::GetElementsByType(), SMESH::Controls::Filter::GetElementsId(), SMESH_Mesh_i::GetElemNode(), LinkID_Gen::GetLinkID(), SMESH::Filter_i::GetMeshInfo(), SMESH::Filter_i::GetNbElementsByType(), getNodeElemDistance(), SMESH_Mesh_i::GetNodeInverseElements(), SMESH::Controls::ElementsOnShape::getNodeIsOut(), getNodeNodeDistance(), SMESH_VisualObjDef::GetNodeObjId(), SMESHGUI_PreVisualObj::GetNodeObjId(), SMESHGUI_PreVisualObj::GetNodeVTKId(), VISCOUS_3D::_EdgesOnShape::GetNormal(), SMESH_MeshEditor_i::GetPreviewData(), SMDS_ElementFactory::GetShapeIterator(), SMESH_Mesh_i::GetSubMeshNodesId(), SMESH::Controls::MultiConnection2D::GetValue(), SMESH::Controls::MultiConnection2D::GetValues(), SMESH::Controls::Length2D::GetValues(), SMDS_ElementChunk::GetVtkID(), SMESH_Hasher::HashCode(), SMESH_TLinkHasher::HashCode(), SMDS_VolumeTool::ID(), VISCOUS_3D::_ViscousBuilder::invalidateBadSmooth(), SMESH::Controls::FreeEdges::IsFreeEdge(), SMESH::Controls::ManifoldPart::isInPlane(), SMESH::Controls::ConnectedElements::IsSatisfy(), SMESH_ProxyMesh::IsTemporary(), VISCOUS_3D::_ViscousBuilder::makeGroupOfLE(), SMESH_Mesh_i::MakeGroupsOfBadInputElements(), StdMeshers_Penta_3D::MakeMeshOnFxy1(), SMESH_MeshAlgos::Intersector::Algo::MakeNewFaces(), StdMeshers_Penta_3D::MakeNodes(), SMESH_MeshAlgos::MakeOffset(), StdMeshers_Penta_3D::MakeVolumeMesh(), SMESH_MeshEditor::MergeNodes(), SMESH_MeshEditor_i::MoveClosestNodeToPoint(), SMESHDS_Mesh::MoveNode(), SMESH::Predicate_i::NbSatisfying(), SMESH::SelectionProxy::nodeConnectivity(), SMESH_MeshEditor::Offset(), SMESHGUI_CreatePolyhedralVolumeDlg::onTextChange(), SMESHGUI_ExtrusionAlongPathDlg::onTextChange(), SMESHGUI_RotationDlg::onTextChange(), SMESHGUI_ScaleDlg::onTextChange(), SMESHGUI_SewingDlg::onTextChange(), SMESHGUI_SingleEditDlg::onTextChange(), SMESHGUI_SymmetryDlg::onTextChange(), SMESHGUI_TranslationDlg::onTextChange(), SMESHGUI_MeshPatternDlg::onTextChanged(), TIDTypeCompare::operator()(), TIDCompare::operator()(), Prism_3D::TNode::operator<(), operator<<(), SMESH::SelectionProxy::perFaceConnectivity(), DriverCGNS_Write::Perform(), DriverDAT_W_SMDS_Mesh::Perform(), DriverUNV_W_SMDS_Mesh::Perform(), DriverMED_W_SMESHDS_Mesh::PerformInternal(), StdMeshers_Sweeper::prepareTopBotDelaunay(), SMDS_MeshNode::Print(), SMESH::Controls::ManifoldPart::process(), SMESH::Controls::ElementsOnSurface::process(), StdMeshers_Prism_3D::projectBottomToTop(), SMESH_MeshEditor_i::ProjectPoint(), SMESHDS_Mesh::RemoveElement(), SMESHDS_Mesh::RemoveFreeElement(), SMESHDS_Mesh::RemoveFreeNode(), SMESHDS_Mesh::RemoveNode(), SMESH_MeshEditor::RemoveNodeWithReconnection(), SMESH_MeshEditor::removeQuadElem(), SMESH_ProxyMesh::removeTmpElement(), SMESH_MeshAlgos::Intersector::Algo::replaceIntNode(), SMESH_Mesh_i::ReplaceShape(), SMESH_Gen_i::Save(), VISCOUS_3D::_ViscousBuilder::setEdgeData(), SMESH::Controls::CoplanarFaces::SetMesh(), SMESH::Controls::ElementsOnShape::setNodeIsOut(), StdMeshers_MaxElementVolume::SetParametersByMesh(), SMDS_ElementChunk::SetVTKID(), SMESH_MeshEditor::SewSideElements(), VISCOUS_2D::_ViscousBuilder2D::shrink(), SMESH_TLink::SMESH_TLink(), VISCOUS_3D::_ViscousBuilder::smoothAndCheck(), SMESH_MeshEditor::SplitEdge(), SMESH_MeshEditor::SplitFace(), splitPolygon(), and SMESH_MeshEditor::sweepElement().
◆ GetMesh()
◆ GetNode()
◆ GetNodeIndex()
int SMDS_MeshCell::GetNodeIndex ( const SMDS_MeshNode *  node) const
node- the node to check
int- node index within the element, -1 if not found
Reimplemented from SMDS_MeshElement.
Reimplemented in SMDS_MeshVolume.
References SMDS_MeshElement::getGrid(), SMDS_MeshVolume::GetNodeIndex(), SMDS_MeshElement::GetVtkID(), SMDS_MeshCell::GetVtkType(), SMDS_MeshElement::IsNull(), and SMDS_MeshCell::toVtkOrder().
Referenced by SMDS_MeshVolume::GetNodeIndex(), and SMESH_MeshEditor::makeWalls().
◆ GetNodeWrap()
const SMDS_MeshNode * SMDS_MeshElement::GetNodeWrap ( const int  ind) const
ind- node index
constSMDS_MeshNode* - the node
Index is wrapped if it is out of a valid range of corner nodes
Referenced by SMESH_MeshAlgos::Intersector::Algo::Cut(), SMESH_MeshEditor::GetLinkedNodes(), and SMESH_MeshEditor::makeWalls().
◆ getshapeId()
virtual int SMDS_MeshElement::getshapeId ( ) const
Referenced by SMESH_Delaunay::addCloseNodes(), SMESHDS_SubMesh::AddNode(), areNodesBound(), StdMeshers_Quadrangle_2D::check(), SMESH_MesherHelper::CheckNodeU(), SMESH_MesherHelper::CheckNodeUV(), StdMeshers_Import_1D2D::Compute(), VISCOUS_3D::_ViscousBuilder::computeGeomSize(), SMESHDS_SubMesh::Contains(), SMESH_MeshEditor::convertElemToQuadratic(), SMESH_MeshEditor::ConvertToQuadratic(), SMESH_MeshEditor::copyPosition(), SMESH_Pattern::createElements(), SMESH_MeshEditor::CreateHoleSkin(), SMESH_MeshEditor::DeleteDiag(), SMESH_Mesh_i::exportMEDFields(), VISCOUS_3D::_ViscousBuilder::findEdgesToUpdateNormalNearConvexFace(), StdMeshers_ProjectionUtils::FindMatchingNodesOnFaces(), SMESH_MeshEditor::FindShape(), VISCOUS_3D::_ViscousBuilder::findShapesToSmooth(), SMESH_MesherHelper::FixQuadraticElements(), SMESH_MesherHelper::GetCentralNode(), VISCOUS_3D::_ViscousBuilder::getFaceNormal(), SMESH_MesherHelper::GetMediumNode(), SMESH_MesherHelper::getMediumNodeOnComposedWire(), SMESH_MesherHelper::GetMediumPos(), StdMeshers_PrismAsBlock::GetNodeColumn(), SMESH_MesherHelper::GetNodeU(), SMESH_MesherHelper::GetNodeUV(), VISCOUS_3D::_EdgesOnShape::GetNormal(), StdMeshers_FaceSide::GetOrderedNodes(), SMESH_ProxyMesh::GetProxyNode(), SMESH_Mesh_i::GetShapeID(), VISCOUS_3D::_Simplex::GetSimplices(), SMESH_MesherHelper::GetSubShapeByNode(), StdMeshers_FaceSide::GetUVPtStruct(), SMESH::Controls::Deflection2D::GetValue(), StdMeshers_PrismAsBlock::HasNodeColumn(), StdMeshers_PrismAsBlock::Init(), SMESH_MeshEditor::InsertNodesIntoLink(), SMESH_MeshEditor::InverseDiag(), SMESH_MesherHelper::IsCornerOfStructure(), SMESH::Controls::BelongToGeom::IsSatisfy(), SMESH::Controls::LyingOnGeom::IsSatisfy(), SMESH_Pattern::Load(), VISCOUS_3D::_ViscousBuilder::makeLayer(), SMESH_MeshEditor::MergeNodes(), StdMeshers_QuadToTriaAdaptor::MergePiramids(), DriverGMF_Write::Perform(), SMESH_MeshEditor::QuadTo4Tri(), SMESH_MeshEditor::Remove(), SMESHDS_Mesh::RemoveElement(), SMESHDS_SubMesh::RemoveElement(), SMESHDS_Mesh::RemoveFreeElement(), SMESHDS_Mesh::RemoveFreeNode(), SMESHDS_Mesh::RemoveNode(), SMESHDS_SubMesh::RemoveNode(), SMESH_MeshEditor::removeQuadElem(), VISCOUS_3D::_ViscousBuilder::setEdgeData(), SMESH_MeshEditor::SewSideElements(), VISCOUS_2D::_ViscousBuilder2D::shrink(), StdMeshers_Quadrangle_2D::smooth(), VISCOUS_3D::_ViscousBuilder::smoothAndCheck(), SMESH_MeshEditor::SplitBiQuadraticIntoLinear(), StdMeshers_PrismAsBlock::TPCurveOnHorFaceAdaptor::TPCurveOnHorFaceAdaptor(), SMESH_MeshEditor::TriToQuad(), SMESHDS_Mesh::UnSetElementOnShape(), SMESHDS_Mesh::UnSetNodeOnShape(), SMESH_MeshEditor::UpdateVolumes(), StdMeshers_PrismAsBlock::TSideFace::Value(), and SMESH_Algo::VertexNode().
◆ GetShapeID()
◆ GetType()
virtual SMDSAbs_ElementType SMDS_MeshFace::GetType ( ) const
Reimplemented from SMDS_MeshCell.
References SMDSAbs_Face.
◆ GetVtkID()
vtkIdType SMDS_MeshElement::GetVtkID ( ) const
References SMDS_ElementChunk::GetVtkID(), and SMDS_MeshElement::myHolder.
Referenced by SMDS_MeshNode::AddInverseElement(), SMDS_ElementHolder::beforeCompacting(), SMDS_MeshCell::ChangeNodes(), SMDS_MeshVolume::ChangeNodes(), SMDS_MeshNode::ClearInverseElements(), SMDS_ElementFactory::Compact(), SMESH_MeshEditor::CreateHoleSkin(), SMESH_MeshEditor::DoubleNodesOnGroupBoundaries(), SMDS_UnstructuredGrid::extrudeVolumeFromFace(), SMDS_ElementFactory::Free(), SMDS_MeshNode::getCoord(), SMDS_BallElement::GetDiameter(), SMESH_VisualObjDef::GetElemVTKId(), SMESHGUI_PreVisualObj::GetElemVTKId(), SMDS_MeshVolume::GetFaceNode(), SMDS_MeshNode::GetInverseElementIterator(), SMDS_MeshCell::GetNode(), SMDS_MeshVolume::GetNode(), SMDS_MeshCell::GetNodeIndex(), SMDS_MeshVolume::GetNodeIndex(), SMESH_VisualObjDef::GetNodeVTKId(), SMDS_MeshVolume::GetQuantities(), SMESH::Controls::AspectRatio3D::GetValue(), SMDS_MeshCell::GetVtkType(), SMDS_MeshNode::GetXYZ(), SMDS_BallElement::init(), SMDS_MeshNode::init(), SMDS_MeshCell::init(), SMDS_MeshVolume::NbEdges(), SMDS_MeshVolume::NbFaceNodes(), SMDS_MeshVolume::NbFaces(), SMDS_MeshNode::NbInverseElements(), SMDS_MeshCell::NbNodes(), SMDS_MeshVolume::NbNodes(), SMDS_MeshCell::nodeIterator(), SMDS_MeshVolume::nodeIterator(), SMDS_MeshCell::nodesIterator(), SMDS_MeshVolume::nodesIterator(), SMDS_MeshCell::nodesIteratorToUNV(), SMDS_Mesh::RemoveFreeElement(), SMDS_MeshNode::RemoveInverseElement(), SMDS_BallElement::SetDiameter(), and SMDS_MeshNode::setXYZ().
◆ GetVtkType()
◆ init() [1/4]
◆ init() [2/4]
void SMDS_MeshCell::init ( SMDSAbs_EntityType  entityType,
const std::vector< const SMDS_MeshNode * > &  nodes
◆ init() [3/4]
const std::vector< vtkIdType > &  vtkNodeIds
◆ init() [4/4]
◆ InitStaticMembers()
void SMDS_MeshCell::InitStaticMembers ( )
Referenced by SMDS_Mesh::SMDS_Mesh().
◆ interlacedNodesIterator()
◆ interlacedSmdsOrder()
const std::vector< int > & SMDS_MeshCell::interlacedSmdsOrder ( SMDSAbs_EntityType  smdsType,
const size_t  nbNodes = 0
References SMDSEntity_Quad_Polygon.
Referenced by _GetVtkNodesToUNV::_GetVtkNodesToUNV(), SMESH_MeshEditor::applyMerge(), SMESH_MeshAlgos::DeMerge(), SMESH_MeshEditor::makeWalls(), DriverCGNS_Write::Perform(), and SMESH_MeshEditor::sweepElement().
◆ isMarked()
◆ IsMediumNode()
◆ IsNull()
◆ IsPoly() [1/2]
◆ IsPoly() [2/2]
bool SMDS_MeshCell::IsPoly ( SMDSAbs_EntityType  entityType)
◆ IsQuadratic() [1/2]
◆ IsQuadratic() [2/2]
bool SMDS_MeshCell::IsQuadratic ( SMDSAbs_EntityType  entityType)
◆ IsValidIndex()
bool SMDS_MeshElement::IsValidIndex ( const int  ind) const
ind- node index
bool- index check result
References SMDS_MeshElement::NbNodes().
◆ NbCornerNodes() [1/2]
int SMDS_MeshCell::NbCornerNodes ( ) const
◆ NbCornerNodes() [2/2]
int SMDS_MeshCell::NbCornerNodes ( SMDSAbs_EntityType  entityType)
◆ NbEdges() [1/2]
◆ NbEdges() [2/2]
int SMDS_MeshCell::NbEdges ( SMDSAbs_EntityType  entityType)
◆ NbFaces() [1/2]
int SMDS_MeshCell::NbFaces ( ) const
◆ NbFaces() [2/2]
int SMDS_MeshCell::NbFaces ( SMDSAbs_EntityType  entityType)
◆ NbNodes() [1/2]
◆ NbNodes() [2/2]
int SMDS_MeshCell::NbNodes ( SMDSAbs_EntityType  entityType)
◆ nodeIterator()
◆ nodesIterator()
◆ nodesIteratorToUNV()
◆ Print()
void SMDS_MeshElement::Print ( std::ostream &  OS) const
Print self.
Reimplemented in SMDS_FaceOfNodes, SMDS_MeshNode, SMDS_PolygonalFaceOfNodes, and SMDS_VolumeOfNodes.
Referenced by operator<<().
◆ reverseSmdsOrder()
const std::vector< int > & SMDS_MeshCell::reverseSmdsOrder ( SMDSAbs_EntityType  smdsType,
◆ setIsMarked()
◆ setShapeID()
void SMDS_MeshElement::setShapeID ( const int  shapeID) const
◆ setVtkID()
void SMDS_MeshElement::setVtkID ( const vtkIdType  vtkID)
◆ toSmdsType()
SMDSAbs_EntityType SMDS_MeshCell::toSmdsType ( VTKCellType  vtkType)
Referenced by SMDS_MeshCell::fromVtkOrder(), SMDS_MeshCell::GetEntityType(), and SMDS_MeshCell::toVtkOrder().
◆ toVtkOrder() [1/2]
const std::vector< int > & SMDS_MeshCell::toVtkOrder ( SMDSAbs_EntityType  smdsType)
◆ toVtkOrder() [2/2]
const std::vector< int > & SMDS_MeshCell::toVtkOrder ( VTKCellType  vtkType)
◆ toVtkType()
VTKCellType SMDS_MeshCell::toVtkType ( SMDSAbs_EntityType  entityType)
◆ Type()
static SMDSAbs_ElementType SMDS_MeshFace::Type ( )
◆ WrappedIndex()
int SMDS_MeshElement::WrappedIndex ( const int  ind) const
ind- node index
int- valid node index
References SMDS_MeshElement::NbCornerNodes().
Referenced by SMDS_PolygonalFaceOfNodes::GetNode().
◆ SMDS_Mesh
friend class SMDS_Mesh
friend
◆ myHolder
