SMESH_MeshEditor Class Reference
Editor of a mesh. More...
#include <SMESH_MeshEditor.hxx>
struct  ElemFeatures
 < Features of element to create More...
class  ExtrusParam
 Generator of nodes for extrusion functionality. More...
enum  SplitVolumToTetraFlags {
  HEXA_TO_5 = 1 , HEXA_TO_6 , HEXA_TO_24 , HEXA_TO_2_PRISMS ,
  HEXA_TO_4_PRISMS
enum  SmoothMethod { LAPLACIAN = 0 , CENTROIDAL }
enum  ExtrusionFlags {
  EXTRUSION_FLAG_BOUNDARY = 0x01 , EXTRUSION_FLAG_SEW = 0x02 , EXTRUSION_FLAG_GROUPS = 0x04 , EXTRUSION_FLAG_BY_AVG_NORMAL = 0x08 ,
  EXTRUSION_FLAG_USE_INPUT_ELEMS_ONLY = 0x10 , EXTRUSION_FLAG_SCALE_LINEAR_VARIATION = 0x20 , EXTRUSION_FLAG_ANGLE_LINEAR_VARIATION = 0x40
 Flags of extrusion. More...
enum  Extrusion_Error {
  EXTR_OK , EXTR_NO_ELEMENTS , EXTR_PATH_NOT_EDGE , EXTR_BAD_PATH_SHAPE ,
  EXTR_BAD_STARTING_NODE , EXTR_BAD_ANGLES_NUMBER , EXTR_CANT_GET_TANGENT
enum  Sew_Error {
  SEW_OK , SEW_BORDER1_NOT_FOUND , SEW_BORDER2_NOT_FOUND , SEW_BOTH_BORDERS_NOT_FOUND ,
  SEW_BAD_SIDE_NODES , SEW_VOLUMES_TO_SPLIT , SEW_DIFF_NB_OF_ELEMENTS , SEW_TOPO_DIFF_SETS_OF_ELEMENTS ,
  SEW_BAD_SIDE1_NODES , SEW_BAD_SIDE2_NODES , SEW_INTERNAL_ERROR
enum  Bnd_Dimension { BND_2DFROM3D , BND_1DFROM3D , BND_1DFROM2D }
typedef std::map< const SMDS_MeshElement *, int, TIDCompare > TFacetOfElem
 2nd arg of SplitVolumes() More...
typedef TIDTypeCompare TElemSort
typedef std::map< const SMDS_MeshElement *, std::list< const SMDS_MeshElement * >, TElemSort > TTElemOfElemListMap
typedef std::map< const SMDS_MeshNode *, std::list< const SMDS_MeshNode * > > TNodeOfNodeListMap
typedef TNodeOfNodeListMap::iterator TNodeOfNodeListMapItr
typedef std::vector< TNodeOfNodeListMapItr > TVecOfNnlmiMap
typedef std::map< const SMDS_MeshElement *, TVecOfNnlmiMap, TElemSort > TElemOfVecOfNnlmiMap
typedef std::unique_ptr< std::list< int > > PGroupIDs
typedef std::list< std::list< const SMDS_MeshNode * > > TListOfListOfNodes
typedef std::list< std::list< smIdType > > TListOfListOfElementsID
 SMESH_MeshEditor (SMESH_Mesh *theMesh)
SMESH_Mesh * GetMesh ()
SMESHDS_Mesh * GetMeshDS ()
 Return mesh DS. More...
const SMESH_SequenceOfElemPtr & GetLastCreatedNodes () const
const SMESH_SequenceOfElemPtr & GetLastCreatedElems () const
void ClearLastCreated ()
 Clears myLastCreatedNodes and myLastCreatedElems. More...
SMESH_ComputeErrorPtr & GetError ()
SMDS_MeshElement * AddElement (const std::vector< const SMDS_MeshNode * > &nodes, const ElemFeatures &features)
 Add element. More...
SMDS_MeshElement * AddElement (const std::vector< smIdType > &nodeIDs, const ElemFeatures &features)
void RemoveNodeWithReconnection (const SMDS_MeshNode *node)
 Remove a node and fill a hole appeared by changing surrounding faces. More...
smIdType Remove (const std::list< smIdType > &theElemIDs, const bool isNodes)
void Create0DElementsOnAllNodes (const TIDSortedElemSet &elements, TIDSortedElemSet &all0DElems, const bool duplicateElements)
 Create 0D elements on all nodes of the given object. More...
bool InverseDiag (const SMDS_MeshElement *theTria1, const SMDS_MeshElement *theTria2)
bool InverseDiag (const SMDS_MeshNode *theNode1, const SMDS_MeshNode *theNode2)
bool DeleteDiag (const SMDS_MeshNode *theNode1, const SMDS_MeshNode *theNode2)
void SplitEdge (const SMDS_MeshNode *theNode1, const SMDS_MeshNode *theNode2, double thePosition)
void SplitFace (const SMDS_MeshElement *theFace, double theX, double theY, double theZ)
bool Reorient (const SMDS_MeshElement *theElement)
int Reorient2D (TIDSortedElemSet &theFaces, const gp_Vec &theDirection, TIDSortedElemSet &theRefFaces, bool theAllowNonManifold)
 Reorient faces. More...
int Reorient2DBy3D (TIDSortedElemSet &theFaces, TIDSortedElemSet &theVolumes, const bool theOutsideNormal)
 Reorient faces basing on orientation of adjacent volumes. More...
bool TriToQuad (TIDSortedElemSet &theElems, SMESH::Controls::NumericalFunctorPtr theCriterion, const double theMaxAngle)
 Fuse neighbour triangles into quadrangles. More...
bool QuadToTri (TIDSortedElemSet &theElems, SMESH::Controls::NumericalFunctorPtr theCriterion)
 Split quadrangles into triangles. More...
bool QuadToTri (TIDSortedElemSet &theElems, const bool the13Diag)
void QuadTo4Tri (TIDSortedElemSet &theElems)
 Split each of given quadrangles into 4 triangles. More...
int BestSplit (const SMDS_MeshElement *theQuad, SMESH::Controls::NumericalFunctorPtr theCriterion)
 Find better diagonal for splitting. More...
void SplitVolumes (const TFacetOfElem &theElems, const int theMethodFlags, const bool avoidOverConstrainedVolumes=false)
 Split volumic elements into tetrahedra or prisms. More...
void GetHexaFacetsToSplit (TIDSortedElemSet &theHexas, const gp_Ax1 &theFacetNormal, TFacetOfElem &theFacets)
 For hexahedra that will be split into prisms, finds facets to split into triangles. More...
void SplitBiQuadraticIntoLinear (TIDSortedElemSet &theElems)
 Split bi-quadratic elements into linear ones without creation of additional nodes. More...
bool isVariantOverConstrained (SMDS_VolumeTool &vol, const int *connVariants)
 Return true if one of the tetras included in the variant will be an overconstrained tetra. More...
void Smooth (TIDSortedElemSet &theElements, std::set< const SMDS_MeshNode * > &theFixedNodes, const SmoothMethod theSmoothMethod, const int theNbIterations, double theTgtAspectRatio=1.0, const bool the2D=true)
PGroupIDs RotationSweep (TIDSortedElemSet theElements[2], const gp_Ax1 &theAxis, const double theAngle, const int theNbSteps, const double theToler, const bool theMakeGroups, const bool theMakeWalls=true)
PGroupIDs ExtrusionSweep (TIDSortedElemSet theElems[2], const gp_Vec &theStep, const int theNbSteps, TTElemOfElemListMap &newElemsMap, const int theFlags, const double theTolerance=1.e-6)
 Generate new elements by extrusion of theElements It is a method used in .idl file. More...
PGroupIDs ExtrusionSweep (TIDSortedElemSet theElems[2], ExtrusParam &theParams, TTElemOfElemListMap &newElemsMap)
 Generate new elements by extrusion of theElements. More...
Extrusion_Error ExtrusionAlongTrack (TIDSortedElemSet theElements[2], SMESH_Mesh *theTrackMesh, SMDS_ElemIteratorPtr theTrackIterator, const SMDS_MeshNode *theNodeStart, std::list< double > &theAngles, const bool theAngleVariation, std::list< double > &theScales, const bool theScaleVariation, const gp_Pnt *theRefPoint, const bool theMakeGroups)
PGroupIDs Transform (TIDSortedElemSet &theElements, const gp_Trsf &theTrsf, const bool theCopy, const bool theMakeGroups, SMESH_Mesh *theTargetMesh=0)
 Move or copy theElements applying theTrsf to their nodes. More...
PGroupIDs Offset (TIDSortedElemSet &theElements, const double theValue, SMESH_Mesh *theTgtMesh, const bool theMakeGroups, const bool theCopyElements, const bool theFixSelfIntersection)
 Make an offset mesh from a source 2D mesh. More...
void FindCoincidentNodes (TIDSortedNodeSet &theNodes, const double theTolerance, TListOfListOfNodes &theGroupsOfNodes, bool theSeparateCornersAndMedium)
 Return list of group of nodes close to each other within theTolerance. More...
void MergeNodes (TListOfListOfNodes &theNodeGroups, const bool theAvoidMakingHoles=false)
void FindEqualElements (TIDSortedElemSet &theElements, TListOfListOfElementsID &theGroupsOfElementsID)
void MergeElements (TListOfListOfElementsID &theGroupsOfElementsID)
void MergeEqualElements ()
int SimplifyFace (const std::vector< const SMDS_MeshNode * > &faceNodes, std::vector< const SMDS_MeshNode * > &poly_nodes, std::vector< int > &quantities) const
Sew_Error SewFreeBorder (const SMDS_MeshNode *theBorderFirstNode, const SMDS_MeshNode *theBorderSecondNode, const SMDS_MeshNode *theBorderLastNode, const SMDS_MeshNode *theSide2FirstNode, const SMDS_MeshNode *theSide2SecondNode, const SMDS_MeshNode *theSide2ThirdNode=0, const bool theSide2IsFreeBorder=true, const bool toCreatePolygons=false, const bool toCreatePolyedrs=false)
Sew_Error SewSideElements (TIDSortedElemSet &theSide1, TIDSortedElemSet &theSide2, const SMDS_MeshNode *theFirstNode1ToMerge, const SMDS_MeshNode *theFirstNode2ToMerge, const SMDS_MeshNode *theSecondNode1ToMerge, const SMDS_MeshNode *theSecondNode2ToMerge)
void InsertNodesIntoLink (const SMDS_MeshElement *theFace, const SMDS_MeshNode *theBetweenNode1, const SMDS_MeshNode *theBetweenNode2, std::list< const SMDS_MeshNode * > &theNodesToInsert, const bool toCreatePoly=false)
void UpdateVolumes (const SMDS_MeshNode *theBetweenNode1, const SMDS_MeshNode *theBetweenNode2, std::list< const SMDS_MeshNode * > &theNodesToInsert)
void ConvertToQuadratic (const bool theForce3d, const bool theToBiQuad)
void ConvertToQuadratic (const bool theForce3d, TIDSortedElemSet &theElements, const bool theToBiQuad)
 Makes given elements quadratic. More...
bool ConvertFromQuadratic ()
void ConvertFromQuadratic (TIDSortedElemSet &theElements)
 Makes given elements linear. More...
int FindShape (const SMDS_MeshElement *theElem)
void DoubleElements (const TIDSortedElemSet &theElements)
 Create elements equal (on same nodes) to given ones. More...
bool DoubleNodes (const std::list< int > &theListOfNodes, const std::list< int > &theListOfModifiedElems)
 Creates a hole in a mesh by doubling the nodes of some particular elements. More...
bool DoubleNodes (const TIDSortedElemSet &theElems, const TIDSortedElemSet &theNodesNot, const TIDSortedElemSet &theAffectedElems)
bool AffectedElemGroupsInRegion (const TIDSortedElemSet &theElems, const TIDSortedElemSet &theNodesNot, const TopoDS_Shape &theShape, TIDSortedElemSet &theAffectedElems)
 Identify the elements that will be affected by node duplication (actual duplication is not performed). More...
bool DoubleNodesInRegion (const TIDSortedElemSet &theElems, const TIDSortedElemSet &theNodesNot, const TopoDS_Shape &theShape)
double OrientedAngle (const gp_Pnt &p0, const gp_Pnt &p1, const gp_Pnt &g1, const gp_Pnt &g2)
 compute an oriented angle between two planes defined by four points. More...
bool DoubleNodesOnGroupBoundaries (const std::vector< TIDSortedElemSet > &theElems, bool createJointElems, bool onAllBoundaries)
 Double nodes on shared faces between groups of volumes and create flat elements on demand. More...
bool CreateFlatElementsOnFacesGroups (const std::vector< TIDSortedElemSet > &theElems)
 Double nodes on some external faces and create flat elements. More...
void CreateHoleSkin (double radius, const TopoDS_Shape &theShape, SMESH_NodeSearcher *theNodeSearcher, const char *groupName, std::vector< double > &nodesCoords, std::vector< std::vector< int > > &listOfListOfNodes)
 identify all the elements around a geom shape, get the faces delimiting the hole Build groups of volume to remove, groups of faces to replace on the skin of the object, groups of faces to remove inside the object, (idem edges). More...
bool Make2DMeshFrom3D ()
 Generated skin mesh (containing 2D cells) from 3D mesh The created 2D mesh elements based on nodes of free faces of boundary volumes. More...
int MakeBoundaryMesh (const TIDSortedElemSet &elements, Bnd_Dimension dimension, SMESH_Group *group=0, SMESH_Mesh *targetMesh=0, bool toCopyElements=false, bool toCopyExistingBondary=false, bool toAddExistingBondary=false, bool aroundElements=false, bool toCreateAllElements=false)
 Creates missing boundary elements. More...
static bool CheckFreeBorderNodes (const SMDS_MeshNode *theNode1, const SMDS_MeshNode *theNode2, const SMDS_MeshNode *theNode3=0)
static bool FindFreeBorder (const SMDS_MeshNode *theFirstNode, const SMDS_MeshNode *theSecondNode, const SMDS_MeshNode *theLastNode, std::list< const SMDS_MeshNode * > &theNodes, std::list< const SMDS_MeshElement * > &theFaces)
static void AddToSameGroups (const SMDS_MeshElement *elemToAdd, const SMDS_MeshElement *elemInGroups, SMESHDS_Mesh *aMesh)
static void RemoveElemFromGroups (const SMDS_MeshElement *element, SMESHDS_Mesh *aMesh)
static void ReplaceElemInGroups (const SMDS_MeshElement *elemToRm, const SMDS_MeshElement *elemToAdd, SMESHDS_Mesh *aMesh)
 Replace elemToRm by elemToAdd in the all groups. More...
static void ReplaceElemInGroups (const SMDS_MeshElement *elemToRm, const std::vector< const SMDS_MeshElement * > &elemToAdd, SMESHDS_Mesh *aMesh)
static void GetLinkedNodes (const SMDS_MeshNode *node, TIDSortedElemSet &linkedNodes, SMDSAbs_ElementType type=SMDSAbs_All)
 Return nodes linked to the given one in elements of the type. More...
static Sew_Error FindMatchingNodes (std::set< const SMDS_MeshElement * > &theSide1, std::set< const SMDS_MeshElement * > &theSide2, const SMDS_MeshNode *theFirstNode1, const SMDS_MeshNode *theFirstNode2, const SMDS_MeshNode *theSecondNode1, const SMDS_MeshNode *theSecondNode2, TNodeNodeMap &theNodeReplaceMap)
 Find corresponding nodes in two sets of faces. More...
static bool IsMedium (const SMDS_MeshNode *node, const SMDSAbs_ElementType typeToCheck=SMDSAbs_All)
 Returns true if given node is medium. More...
smIdType convertElemToQuadratic (SMESHDS_SubMesh *theSm, SMESH_MesherHelper &theHelper, const bool theForce3d)
 Convert elements contained in a submesh to quadratic. More...
smIdType removeQuadElem (SMESHDS_SubMesh *theSm, SMDS_ElemIteratorPtr theItr, const int theShapeID)
 Convert quadratic elements to linear ones and remove quadratic nodes. More...
PGroupIDs generateGroups (const SMESH_SequenceOfElemPtr &nodeGens, const SMESH_SequenceOfElemPtr &elemGens, const std::string &postfix, SMESH_Mesh *targetMesh=0, const bool topPresent=true)
 Create groups of elements made during transformation. More...
void sweepElement (const SMDS_MeshElement *elem, const std::vector< TNodeOfNodeListMapItr > &newNodesItVec, std::list< const SMDS_MeshElement * > &newElems, const size_t nbSteps, SMESH_SequenceOfElemPtr &srcElements)
 Create elements by sweeping an element. More...
bool applyMerge (const SMDS_MeshElement *elems, std::vector< ElemFeatures > &newElemDefs, TNodeNodeMap &nodeNodeMap, const bool avoidMakingHoles)
 Computes new connectivity of an element after merging nodes. More...
void makeWalls (TNodeOfNodeListMap &mapNewNodes, TTElemOfElemListMap &newElemsMap, TElemOfVecOfNnlmiMap &elemNewNodesMap, TIDSortedElemSet &elemSet, const int nbSteps, SMESH_SequenceOfElemPtr &srcElements)
 Create 1D and 2D elements around swept elements. More...
bool doubleNodes (SMESHDS_Mesh *theMeshDS, const TIDSortedElemSet &theElems, const TIDSortedElemSet &theNodesNot, TNodeNodeMap &theNodeNodeMap, const bool theIsDoubleElem)
void copyPosition (const SMDS_MeshNode *from, const SMDS_MeshNode *to)
 Copy node position and set to node on the same geometry. More...
static void linearAngleVariation (const int NbSteps, std::list< double > &theAngles)
static void linearScaleVariation (const int NbSteps, std::list< double > &theScales)
SMESH_Mesh * myMesh
SMESH_SequenceOfElemPtr myLastCreatedNodes
SMESH_SequenceOfElemPtr myLastCreatedElems
SMESH_ComputeErrorPtr myError
Editor of a mesh.
◆ PGroupIDs
typedef std::unique_ptr< std::list< int > > SMESH_MeshEditor::PGroupIDs
◆ TElemOfVecOfNnlmiMap
◆ TElemSort
◆ TFacetOfElem
◆ TListOfListOfElementsID
typedef std::list< std::list< smIdType > > SMESH_MeshEditor::TListOfListOfElementsID
◆ TListOfListOfNodes
typedef std::list< std::list< const SMDS_MeshNode* > > SMESH_MeshEditor::TListOfListOfNodes
◆ TNodeOfNodeListMap
typedef std::map<const SMDS_MeshNode*, std::list<const SMDS_MeshNode*> > SMESH_MeshEditor::TNodeOfNodeListMap
◆ TNodeOfNodeListMapItr
typedef TNodeOfNodeListMap::iterator SMESH_MeshEditor::TNodeOfNodeListMapItr
◆ TTElemOfElemListMap
typedef std::map< const SMDS_MeshElement*, std::list<const SMDS_MeshElement*>, TElemSort > SMESH_MeshEditor::TTElemOfElemListMap
◆ TVecOfNnlmiMap
◆ Bnd_Dimension
BND_2DFROM3D
BND_1DFROM3D
BND_1DFROM2D
◆ Extrusion_Error
EXTR_OK
EXTR_NO_ELEMENTS
EXTR_PATH_NOT_EDGE
EXTR_BAD_PATH_SHAPE
◆ ExtrusionFlags
Flags of extrusion.
BOUNDARY: create or not boundary for result of extrusion SEW: try to use existing nodes or create new nodes in any case GROUPS: to create groups BY_AVG_NORMAL: step size is measured along average normal to elements, else step size is measured along average normal of any element USE_INPUT_ELEMS_ONLY: to use only input elements to compute extrusion direction for ExtrusionByNormal() SCALE_LINEAR_VARIATION: to make linear variation of scale factors ANGLE_LINEAR_VARIATION: to make linear variation of angles
EXTRUSION_FLAG_SEW
◆ Sew_Error
SEW_OK
SEW_BAD_SIDE_NODES
SEW_BAD_SIDE1_NODES
SEW_BAD_SIDE2_NODES
SEW_INTERNAL_ERROR
◆ SmoothMethod
LAPLACIAN
CENTROIDAL
◆ SplitVolumToTetraFlags
HEXA_TO_5
HEXA_TO_6
HEXA_TO_24
HEXA_TO_2_PRISMS
HEXA_TO_4_PRISMS
◆ SMESH_MeshEditor()
SMESH_MeshEditor::SMESH_MeshEditor ( SMESH_Mesh *  theMesh)
◆ AddElement() [1/2]
SMDS_MeshElement * SMESH_MeshEditor::AddElement ( const std::vector< const SMDS_MeshNode * > &  nodes,
const ElemFeatures &  features
◆ AddElement() [2/2]
SMDS_MeshElement * SMESH_MeshEditor::AddElement ( const std::vector< smIdType > &  nodeIDs,
Add element.
References AddElement(), DriverMED::FindNode(), and GetMeshDS().
◆ AddToSameGroups()
◆ AffectedElemGroupsInRegion()
bool SMESH_MeshEditor::AffectedElemGroupsInRegion ( const TIDSortedElemSet &  theElems,
const TIDSortedElemSet &  theNodesNot,
const TopoDS_Shape &  theShape,
TIDSortedElemSet &  theAffectedElems
This method is the first step of DoubleNodeElemGroupsInRegion.
theElems- list of groups of elements (edges or faces) to be replicated
theNodesNot- list of groups of nodes not to replicate
theShape- shape to detect affected elements (element which geometric center located on or inside shape). If the shape is null, detection is done on faces orientations (select elements with a gravity center on the side given by faces normals). This mode (null shape) is faster, but works only when theElems are faces, with coherents orientations. The replicated nodes should be associated to affected elements.
true
See also
DoubleNodeElemGroupsInRegion()
References cast2Node, Face, SMDS_MeshNode::GetInverseElementIterator(), and SMDS_MeshElement::nodesIterator().
Referenced by SMESH_MeshEditor_i::AffectedElemGroupsInRegion().
◆ applyMerge()
bool SMESH_MeshEditor::applyMerge ( const SMDS_MeshElement *  elems,
std::vector< ElemFeatures > &  newElemDefs,
TNodeNodeMap &  nodeNodeMap,
◆ BestSplit()
int SMESH_MeshEditor::BestSplit ( const SMDS_MeshElement *  theQuad,
theQuad- The face to find better splitting of.
theCriterion- Is used to choose a diagonal for splitting.
int - 1 for 1-3 diagonal, 2 for 2-4, -1 - for errors.
References ClearLastCreated(), getBadRate(), SMDS_MeshElement::GetType(), SMDS_MeshElement::IsQuadratic(), SMDS_MeshElement::NbNodes(), SMDS_MeshElement::nodesIterator(), and SMDSAbs_Face.
Referenced by SMESH_MeshEditor_i::BestSplit().
◆ CheckFreeBorderNodes()
bool SMESH_MeshEditor::CheckFreeBorderNodes ( const SMDS_MeshNode *  theNode1,
const SMDS_MeshNode *  theNode2,
const SMDS_MeshNode *  theNode3 = 0
References FindFreeBorder().
◆ ClearLastCreated()
◆ convertElemToQuadratic()
◆ ConvertFromQuadratic() [1/2]
◆ ConvertFromQuadratic() [2/2]
◆ ConvertToQuadratic() [1/2]
void SMESH_MeshEditor::ConvertToQuadratic ( const bool  theForce3d,
References SMESH_MesherHelper::AddEdge(), SMESH_MesherHelper::AddFace(), SMESH_MesherHelper::AddPolygonalFace(), SMESH_MesherHelper::AddPolyhedralVolume(), SMESH_MesherHelper::AddTLinks(), SMESH_MesherHelper::AddVolume(), SMDS_MeshElement::begin_nodes(), convertElemToQuadratic(), SMDS_Mesh::edgesIterator(), SMDS_MeshElement::end_nodes(), SMDS_Mesh::facesIterator(), SMESH_MesherHelper::FixQuadraticElements(), SMDS_MeshCell::GetEntityType(), SMDS_MeshElement::GetID(), GetMeshDS(), SMDS_MeshCell::GetNode(), SMESH_Mesh::GetShapeToMesh(), SMESH_Mesh::GetSubMeshContaining(), SMESH_subMesh::GetSubMeshDS(), SMESH_subMesh::GetSubShape(), SMESH_Mesh::HasShapeToMesh(), SMDS_MeshCell::IsQuadratic(), myError, myMesh, SMDS_Mesh::NbEdges(), SMDS_Mesh::NbFaces(), SMDS_Mesh::NbVolumes(), SMESHDS_Mesh::RemoveFreeElement(), SMESHDS_Mesh::RemoveFreeNode(), ReplaceElemInGroups(), SMESH_MesherHelper::SetElementsOnShape(), SMESH_MesherHelper::SetIsBiQuadratic(), SMESH_MesherHelper::SetIsQuadratic(), SMESH_MesherHelper::SetSubShape(), SMDSEntity_BiQuad_Penta, SMDSEntity_BiQuad_Quadrangle, SMDSEntity_BiQuad_Triangle, SMDSEntity_Hexa, SMDSEntity_Hexagonal_Prism, SMDSEntity_Penta, SMDSEntity_Polyhedra, SMDSEntity_Pyramid, SMDSEntity_Quad_Hexa, SMDSEntity_Quad_Penta, SMDSEntity_Quad_Quadrangle, SMDSEntity_Quad_Triangle, SMDSEntity_Quadrangle, SMDSEntity_Tetra, SMDSEntity_Triangle, SMDSEntity_TriQuad_Hexa, SMESH_MesherHelper::ToFixNodeParameters(), and SMDS_Mesh::volumesIterator().
Referenced by StdMeshers_Projection_2D::Compute(), and SMESH_MeshEditor_i::convertToQuadratic().
◆ ConvertToQuadratic() [2/2]
TIDSortedElemSet &  theElements,
◆ copyPosition()
◆ Create0DElementsOnAllNodes()
void SMESH_MeshEditor::Create0DElementsOnAllNodes ( const TIDSortedElemSet &  elements,
TIDSortedElemSet &  all0DElems,
elements- Elements on whose nodes to create 0D elements; if empty, the all mesh is treated
all0DElems- returns all 0D elements found or created on nodes of elements
duplicateElements- to add one more 0D element to a node or not
References cast2Node, SMDS_Mesh::elementsIterator(), SMESHUtils::elemSetIterator(), SMDS_MeshNode::GetInverseElementIterator(), GetMeshDS(), myLastCreatedElems, SMDS_MeshElement::nodesIterator(), SMDSAbs_0DElement, and SMDSAbs_Node.
Referenced by SMESH_MeshEditor_i::Create0DElementsOnAllNodes().
◆ CreateFlatElementsOnFacesGroups()
bool SMESH_MeshEditor::CreateFlatElementsOnFacesGroups ( const std::vector< TIDSortedElemSet > &  theElems)
Flat elements are mainly used by some types of mechanic calculations.
Each group of the list must be constituted of faces. Triangles are transformed in prisms, and quadrangles in hexahedrons.
theElems- list of groups of faces, where a group of faces is a set of SMDS_MeshElements sorted by Id.
TRUE if operation has been completed successfully, FALSE otherwise
References SMESHDS_Group::Add(), SMESH_Mesh::AddGroup(), SMESHDS_Mesh::AddNode(), SMESHDS_Mesh::AddVolume(), copyPosition(), SMDS_Mesh::DownCast(), SMDS_MeshElement::GetID(), SMESH_Mesh::GetMeshDS(), SMDS_MeshCell::GetVtkType(), SMDS_MeshElement::IsMediumNode(), SMDS_MeshCell::IsQuadratic(), myMesh, SMDS_MeshCell::nodeIterator(), SMDSAbs_Volume, SMDS_MeshNode::X(), SMDS_MeshNode::Y(), and SMDS_MeshNode::Z().
Referenced by SMESH_MeshEditor_i::CreateFlatElementsOnFacesGroups().
◆ CreateHoleSkin()
void SMESH_MeshEditor::CreateHoleSkin ( double  radius,
SMESH_NodeSearcher *  theNodeSearcher,
const char *  groupName,
std::vector< double > &  nodesCoords,
std::vector< std::vector< int > > &  listOfListOfNodes
◆ DeleteDiag()
◆ DoubleElements()
◆ DoubleNodes() [1/2]
bool SMESH_MeshEditor::DoubleNodes ( const std::list< int > &  theListOfNodes,
const std::list< int > &  theListOfModifiedElems
theNodes- identifiers of nodes to be doubled
theModifiedElems- identifiers of elements to be updated by the new (doubled) nodes. If list of element identifiers is empty then nodes are doubled but they not assigned to elements
References SMESHDS_Mesh::AddNode(), SMDS_MeshElement::begin_nodes(), SMESHDS_Mesh::ChangeElementNodes(), ClearLastCreated(), copyPosition(), SMDS_MeshElement::end_nodes(), SMDS_Mesh::FindElement(), SMDS_Mesh::FindNode(), GetMeshDS(), myLastCreatedNodes, SMDS_MeshNode::X(), SMDS_MeshNode::Y(), and SMDS_MeshNode::Z().
Referenced by SMESH_MeshEditor_i::DoubleNodeElem(), SMESH_MeshEditor_i::DoubleNodeElemGroup(), SMESH_MeshEditor_i::DoubleNodeElemGroup2New(), SMESH_MeshEditor_i::DoubleNodeElemGroups(), SMESH_MeshEditor_i::DoubleNodeElemGroups2New(), SMESH_MeshEditor_i::DoubleNodeGroups(), SMESH_MeshEditor_i::DoubleNodes(), and DoubleNodesInRegion().
◆ DoubleNodes() [2/2]
bool SMESH_MeshEditor::DoubleNodes ( const TIDSortedElemSet &  theElems,
const TIDSortedElemSet &  theAffectedElems
theElems- the list of elements (edges or faces) to be replicated The nodes for duplication could be found from these elements
theNodesNot- list of nodes to NOT replicate
theAffectedElems- the list of elements (cells and edges) to which the replicated nodes should be associated to.
References ClearLastCreated(), doubleNodes(), and GetMeshDS().
◆ doubleNodes()
bool SMESH_MeshEditor::doubleNodes ( SMESHDS_Mesh *  theMeshDS,
TNodeNodeMap &  theNodeNodeMap,
theMeshDS- mesh instance
theElems- the elements replicated or modified (nodes should be changed)
theNodesNot- nodes to NOT replicate
theNodeNodeMap- relation of old node to new created node
theIsDoubleElem- flag os to replicate element or modify
References AddElement(), SMESHDS_Mesh::AddNode(), SMESHDS_Mesh::ChangeElementNodes(), SMESHDS_Mesh::ChangePolyhedronNodes(), copyPosition(), SMDS_MeshElement::GetEntityType(), SMDS_MeshVolume::GetQuantities(), SMESH_MeshEditor::ElemFeatures::Init(), MESSAGE, myLastCreatedNodes, SMDS_MeshElement::NbNodes(), SMDS_MeshElement::nodesIterator(), SMDSEntity_Polyhedra, SMDS_MeshNode::X(), SMDS_MeshNode::Y(), and SMDS_MeshNode::Z().
Referenced by DoubleNodes().
◆ DoubleNodesInRegion()
bool SMESH_MeshEditor::DoubleNodesInRegion ( const TIDSortedElemSet &  theElems,
theElems- group of of elements (edges or faces) to be replicated
theNodesNot- group of nodes not to replicate
theShape- shape to detect affected elements (element which geometric center located on or inside shape). The replicated nodes should be associated to affected elements.
References SMESHUtils::Deleter< TOBJ >::_obj, cast2Node, DoubleNodes(), Face, SMDS_MeshNode::GetInverseElementIterator(), and SMDS_MeshElement::nodesIterator().
Referenced by SMESH_MeshEditor_i::DoubleNodeElemGroupInRegion(), SMESH_MeshEditor_i::DoubleNodeElemGroupsInRegion(), and SMESH_MeshEditor_i::DoubleNodeElemInRegion().
◆ DoubleNodesOnGroupBoundaries()
bool SMESH_MeshEditor::DoubleNodesOnGroupBoundaries ( const std::vector< TIDSortedElemSet > &  theElems,
The list of groups must contain at least two groups. The groups have to be disjoint: no common element into two different groups. The nodes of the internal faces at the boundaries of the groups are doubled. Optionally, the internal faces are replaced by flat elements. Triangles are transformed into prisms, and quadrangles into hexahedrons. The flat elements are stored in groups of volumes. These groups are named according to the position of the group in the list: the group j_n_p is the group of the flat elements that are built between the group #n and the group #p in the list. If there is no shared faces between the group #n and the group #p in the list, the group j_n_p is not created. All the flat elements are gathered into the group named "joints3D" (or "joints2D" in 2D situation). The flat element of the multiple junctions between the simple junction are stored in a group named "jointsMultiples".
theElems- list of groups of volumes, where a group of volume is a set of SMDS_MeshElements sorted by Id.
createJointElems- if TRUE, create the elements
onAllBoundaries- if TRUE, the nodes and elements are also created on the boundary between theDomains and the rest mesh
References SMESHDS_Group::Add(), SMDS_Mesh::AddFaceFromVtkIds(), SMESH_Mesh::AddGroup(), SMESHDS_Mesh::AddNode(), SMDS_Mesh::AddVolumeFromVtkIds(), SMESHDS_Mesh::BuildDownWardConnectivity(), DownIdType::cellId, SMDS_UnstructuredGrid::CellIdToDownId(), DownIdType::cellType, CHRONO, CHRONOSTOP, SMESHDS_Mesh::CleanDownWardConnectivity(), copyPosition(), SMDS_UnstructuredGrid::DeleteLinks(), SMDS_UnstructuredGrid::extrudeVolumeFromFace(), SMDS_Mesh::FindElement(), SMDS_Mesh::FindNodeVtk(), SMDS_Mesh::FromVtkToSmds(), SMDS_UnstructuredGrid::getDownArray(), SMDS_Downward::getDownCells(), SMDS_Downward::getDownTypes(), SMDS_Mesh::GetGrid(), SMDS_MeshElement::GetID(), SMDS_UnstructuredGrid::GetLinks(), SMESH_Mesh::GetMeshDS(), GetMeshDS(), SMDS_UnstructuredGrid::GetNeighbors(), SMDS_UnstructuredGrid::GetNodeIds(), SMDS_Downward::getNodes(), SMDS_Downward::getNumberOfDownCells(), SMDS_Downward::getNumberOfUpCells(), SMDS_UnstructuredGrid::GetParentVolumes(), SMDS_MeshCell::GetType(), SMDS_Downward::getUpCells(), SMDS_Downward::getUpTypes(), SMDS_Downward::getVtkCellId(), SMDS_MeshElement::GetVtkID(), MESSAGE, SMESHDS_Mesh::ModifyCellNodes(), myMesh, NBMAXNEIGHBORS, OrientedAngle(), SMESH_Mesh::RemoveGroup(), SMDSAbs_Face, and SMDSAbs_Volume.
Referenced by SMESH_MeshEditor_i::DoubleNodesOnGroupBoundaries().
◆ ExtrusionAlongTrack()
◆ ExtrusionSweep() [1/2]
SMESH_MeshEditor::PGroupIDs SMESH_MeshEditor::ExtrusionSweep ( TIDSortedElemSet  theElems[2],
const gp_Vec &  theStep,
TTElemOfElemListMap &  newElemsMap,
const int  theFlags,
const double  theTolerance = 1.e-6
All functionality is implemented in the next method (see below) which is used in the current method.
theElems- list of elements for extrusion
newElemsMapreturns history of extrusion
theFlagsset flags for performing extrusion (see description of enum ExtrusionFlags for additional information)
theTolerance- uses for comparing locations of nodes if flag EXTRUSION_FLAG_SEW is set
References ExtrusionSweep().
Referenced by SMESH_MeshEditor_i::AdvancedExtrusion(), ExtrusionAlongTrack(), SMESH_MeshEditor_i::ExtrusionByNormal(), ExtrusionSweep(), and SMESH_MeshEditor_i::ExtrusionSweepObjects().
◆ ExtrusionSweep() [2/2]
ExtrusParam &  theParams,
◆ FindCoincidentNodes()
void SMESH_MeshEditor::FindCoincidentNodes ( TIDSortedNodeSet &  theNodes,
TListOfListOfNodes &  theGroupsOfNodes,
** Search among theNodes or in the whole mesh if theNodes is empty using
  • an Octree algorithm
    [in,out]theNodes- the nodes to treat
    [in]theTolerance- the tolerance
    [out]theGroupsOfNodes- the result groups of coincident nodes
    [in]theSeparateCornersAndMedium- if true, in quadratic mesh puts corner and medium nodes in separate groups
References ClearLastCreated(), SMESH_OctreeNode::FindCoincidentNodes(), GetMeshDS(), SMESH_MesherHelper::IsMedium(), myMesh, SMESH_Mesh::NbEdges(), SMESH_Mesh::NbFaces(), SMESH_Mesh::NbVolumes(), SMDS_Mesh::nodesIterator(), and ORDER_QUADRATIC.
Referenced by SMESH_Gen_i::ConcatenateCommon(), SMESH_MeshEditor_i::findCoincidentNodes(), and StdMeshers_Cartesian_VL::ViscousBuilder::MakeViscousLayers().
◆ FindEqualElements()
◆ FindFreeBorder()
bool SMESH_MeshEditor::FindFreeBorder ( const SMDS_MeshNode *  theFirstNode,
const SMDS_MeshNode *  theSecondNode,
const SMDS_MeshNode *  theLastNode,
std::list< const SMDS_MeshNode * > &  theNodes,
std::list< const SMDS_MeshElement * > &  theFaces
◆ FindMatchingNodes()
SMESH_MeshEditor::Sew_Error SMESH_MeshEditor::FindMatchingNodes ( std::set< const SMDS_MeshElement * > &  theSide1,
std::set< const SMDS_MeshElement * > &  theSide2,
const SMDS_MeshNode *  theFirstNode1,
const SMDS_MeshNode *  theFirstNode2,
const SMDS_MeshNode *  theSecondNode1,
const SMDS_MeshNode *  theSecondNode2,
TNodeNodeMap &  nReplaceMap
theSide1- first face set
theSide2- second first face
theFirstNode1- a boundary node of set 1
theFirstNode2- a node of set 2 corresponding to theFirstNode1
theSecondNode1- a boundary node of set 1 linked with theFirstNode1
theSecondNode2- a node of set 2 corresponding to theSecondNode1
nReplaceMap- output map of corresponding nodes
Sew_Error - is a success or not
bool - is a success or not
References SMDS_MeshElement::GetID(), SMDS_MeshNode::GetInverseElementIterator(), SMDS_MeshElement::GetNode(), SMDS_MeshElement::GetNodeIndex(), SMDS_MeshElement::IsQuadratic(), MESSAGE, SMDS_MeshElement::NbNodes(), reverse(), SEW_BAD_SIDE1_NODES, SEW_BAD_SIDE2_NODES, SEW_OK, SEW_TOPO_DIFF_SETS_OF_ELEMENTS, and SMDSAbs_Face.
Referenced by StdMeshers_ProjectionUtils::FindMatchingNodesOnFaces(), and VISCOUS_3D::ShrinkFace::IsPeriodic().
◆ FindShape()
◆ generateGroups()
SMESH_MeshEditor::PGroupIDs SMESH_MeshEditor::generateGroups ( const SMESH_SequenceOfElemPtr &  nodeGens,
const SMESH_SequenceOfElemPtr &  elemGens,
const std::string &  postfix,
SMESH_Mesh *  targetMesh = 0,
const bool  topPresent = true
nodeGens- nodes making corresponding myLastCreatedNodes
elemGens- elements making corresponding myLastCreatedElems
postfix- to append to names of new groups
targetMesh- mesh to create groups in
topPresent- is there "top" elements that are created by sweeping
postfix- to push_back to names of new groups
topPresent- is there are "top" elements that are created by sweeping
References SMDS_MeshGroup::Add(), SMESH_Mesh::AddGroup(), SMESHDS_GroupBase::Contains(), SMESHDS_Group::GetElements(), SMESH_Group::GetGroupDS(), SMESH_Mesh::GetGroupIds(), SMESH_Mesh::GetGroups(), SMESHDS_GroupBase::GetID(), GetMesh(), SMESH_Mesh::GetMeshDS(), SMESH_Group::GetName(), SMESHDS_GroupBase::GetStoreName(), SMESHDS_GroupBase::GetType(), SMDS_MeshElement::GetType(), SMESHDS_Group::IsEmpty(), SMESHDS_GroupBase::IsEmpty(), MESSAGE, myLastCreatedElems, myLastCreatedNodes, SMESHDS_Mesh::RemoveGroup(), SMESHDS_GroupBase::SetStoreName(), SMESHDS_Group::SetType(), and SMDSAbs_NbElementTypes.
Referenced by ExtrusionSweep(), Offset(), RotationSweep(), and Transform().
◆ GetError()
◆ GetHexaFacetsToSplit()
void SMESH_MeshEditor::GetHexaFacetsToSplit ( TIDSortedElemSet &  theHexas,
const gp_Ax1 &  theFacetNormal,
TFacetOfElem &  theFacets
◆ GetLastCreatedElems()
◆ GetLastCreatedNodes()
const SMESH_SequenceOfElemPtr & SMESH_MeshEditor::GetLastCreatedNodes ( ) const
◆ GetLinkedNodes()
void SMESH_MeshEditor::GetLinkedNodes ( const SMDS_MeshNode *  theNode,
TIDSortedElemSet &  linkedNodes,
SMDSAbs_ElementType  type = SMDSAbs_All
◆ GetMesh()
◆ GetMeshDS()
◆ InsertNodesIntoLink()
◆ InverseDiag() [1/2]
◆ InverseDiag() [2/2]
◆ IsMedium()
bool SMESH_MeshEditor::IsMedium ( const SMDS_MeshNode *  node,
n- node to check
typeToCheck- type of elements containing the node to ask about node status
bool - check result
References SMDS_MeshNode::GetInverseElementIterator(), and SMDS_MeshElement::IsMediumNode().
Referenced by StdMeshers_FaceSide::GetEdgeNodes(), SMESH_MesherHelper::IsMedium(), SMESH_Pattern::Load(), and Smooth().
◆ isVariantOverConstrained()
bool SMESH_MeshEditor::isVariantOverConstrained ( SMDS_VolumeTool &  vol,
const int *  connVariants
◆ linearAngleVariation()
void SMESH_MeshEditor::linearAngleVariation ( const int  NbSteps,
std::list< double > &  theAngles
staticprivate
◆ linearScaleVariation()
void SMESH_MeshEditor::linearScaleVariation ( const int  NbSteps,
std::list< double > &  theScales
staticprivate
◆ Make2DMeshFrom3D()
bool SMESH_MeshEditor::Make2DMeshFrom3D ( )
Generates skin mesh (containing 2D cells) from 3D mesh The created 2D mesh elements based on nodes of free faces of boundary volumes.
References AddElement(), SMDS_Mesh::FindElement(), SMDS_VolumeTool::GetFaceNodes(), GetMeshDS(), SMDS_VolumeTool::IsFreeFace(), SMDS_MeshCell::IsQuadratic(), SMDS_VolumeTool::NbFaceNodes(), SMDS_VolumeTool::NbFaces(), SMDS_VolumeTool::SetExternalNormal(), SMESH_MeshEditor::ElemFeatures::SetPoly(), SMESH_MeshEditor::ElemFeatures::SetQuad(), SMDSAbs_Face, and SMDS_Mesh::volumesIterator().
Referenced by SMESH_MeshEditor_i::Make2DMeshFrom3D().
◆ MakeBoundaryMesh()
int SMESH_MeshEditor::MakeBoundaryMesh ( const TIDSortedElemSet &  elements,
SMESH_Group *  group = 0,
bool  toCopyElements = false,
bool  toCopyExistingBoundary = false,
bool  toAddExistingBondary = false,
bool  aroundElements = false,
bool  toCreateAllElements = false
elements- elements whose boundary is to be checked
dimension- defines type of boundary elements to create
group- a group to store created boundary elements in
targetMesh- a mesh to store created boundary elements in
toCopyElements- if true, the checked elements will be copied into the targetMesh
toCopyExistingBoundary- if true, not only new but also pre-existing boundary elements will be copied into the targetMesh
toAddExistingBondary- if true, not only new but also pre-existing boundary elements will be added into the new group
aroundElements- if true, elements will be created on boundary of given elements else, on boundary of the whole mesh.
nb of added boundary elements
References AddElement(), SMESH_MesherHelper::AddNode(), BND_1DFROM2D, BND_2DFROM3D, SMDS_Mesh::elementsIterator(), SMESHUtils::elemSetIterator(), SMDS_Mesh::FindEdge(), SMDS_Mesh::FindElement(), SMESH_MeshAlgos::FindFaceInSet(), SMDS_VolumeTool::GetCenterNodeIndex(), SMDS_VolumeTool::GetFaceBaryCenter(), SMDS_VolumeTool::GetFaceNodes(), SMESH_Group::GetGroupDS(), SMESH_MesherHelper::GetMediumPos(), GetMesh(), GetMeshDS(), SMDS_MeshElement::GetNode(), SMDS_MeshElement::GetNodeIndex(), SMDS_VolumeTool::GetNodes(), SMDS_MeshElement::GetType(), SMESH_Mesh::HasShapeToMesh(), SMESHDS_Mesh::IndexToShape(), SMESH_MeshEditor::ElemFeatures::Init(), SMDS_MeshElement::interlacedNodesIterator(), SMDS_VolumeTool::IsFreeFace(), SMDS_MeshElement::IsQuadratic(), SMESH_MesherHelper::IsSubShape(), myLastCreatedElems, myMesh, SMDS_MeshElement::NbCornerNodes(), SMDS_VolumeTool::NbFaceNodes(), SMDS_VolumeTool::NbFaces(), SMDS_MeshElement::NbNodes(), SMDS_VolumeTool::Set(), SMDS_VolumeTool::SetExternalNormal(), SMESHDS_Mesh::SetMeshElementOnShape(), SMDSAbs_Edge, SMDSAbs_Face, and SMDSAbs_Volume.
Referenced by VISCOUS_3D::_ViscousBuilder::Compute(), SMESH_MeshEditor_i::MakeBoundaryElements(), and SMESH_MeshEditor_i::MakeBoundaryMesh().
◆ makeWalls()
void SMESH_MeshEditor::makeWalls ( TNodeOfNodeListMap &  mapNewNodes,
TElemOfVecOfNnlmiMap &  elemNewNodesMap,
TIDSortedElemSet &  elemSet,
const int  nbSteps,
SMESH_SequenceOfElemPtr &  srcElements
◆ MergeElements()
void SMESH_MeshEditor::MergeElements ( TListOfListOfElementsID &  theGroupsOfElementsID)
◆ MergeEqualElements()
void SMESH_MeshEditor::MergeEqualElements ( )
◆ MergeNodes()
◆ Offset()
SMESH_MeshEditor::PGroupIDs SMESH_MeshEditor::Offset ( TIDSortedElemSet &  theElements,
SMESH_Mesh *  theTgtMesh,
[in]theElements- source faces
[in]theValue- offset value
[out]theTgtMesh- a mesh to add offset elements to
[in]theMakeGroups- to generate groups
PGroupIDs - IDs of created groups. NULL means failure
References AddElement(), SMESHDS_Mesh::AddNodeWithID(), ClearLastCreated(), SMDS_Mesh::elementsIterator(), SMESHUtils::elemSetIterator(), SMDS_Mesh::FindElement(), SMDS_Mesh::FindNode(), generateGroups(), SMDS_MeshElement::GetID(), SMESH_Mesh::GetMeshDS(), GetMeshDS(), SMESH_MeshEditor::ElemFeatures::Init(), SMESH_MeshAlgos::MakeOffset(), SMDS_Mesh::MaxNodeID(), myLastCreatedElems, myLastCreatedNodes, myMesh, SMESH_MeshEditor::ElemFeatures::myNodes, SMESHDS_Mesh::RemoveFreeElement(), and SMDSAbs_Face.
Referenced by SMESH_MeshEditor_i::Offset().
◆ OrientedAngle()
double SMESH_MeshEditor::OrientedAngle ( const gp_Pnt &  p0,
const gp_Pnt &  p1,
const gp_Pnt &  g1,
const gp_Pnt &  g2
The vector (p0,p1) defines the intersection of the 2 planes (p0,p1,g1) and (p0,p1,g2)
p0base of the rotation axe
p1extremity of the rotation axe
g1belongs to the first plane
g2belongs to the second plane
Referenced by DoubleNodesOnGroupBoundaries().
◆ QuadTo4Tri()
◆ QuadToTri() [1/2]
◆ QuadToTri() [2/2]
◆ Remove()
◆ RemoveElemFromGroups()
void SMESH_MeshEditor::RemoveElemFromGroups ( const SMDS_MeshElement *  element,
SMESHDS_Mesh *  aMesh
◆ RemoveNodeWithReconnection()
void SMESH_MeshEditor::RemoveNodeWithReconnection ( const SMDS_MeshNode *  node)
◆ removeQuadElem()
◆ Reorient()
◆ Reorient2D()
int SMESH_MeshEditor::Reorient2D ( TIDSortedElemSet &  theFaces,
const gp_Vec &  theDirection,
TIDSortedElemSet &  theRefFaces,
Reorient faces.
theFaces- the faces to reorient. If empty the whole mesh is meant
theDirection- desired direction of normal of theRefFaces. It can be (0,0,0) in order to keep orientation of theRefFaces.
theRefFaces- correctly oriented faces whose orientation defines orientation of other faces.
number of reoriented faces.
References SMESH_MeshAlgos::FaceNormal(), SMDS_Mesh::facesIterator(), SMESH_MeshAlgos::FindFaceInSet(), GetMeshDS(), SMDS_MeshElement::GetNode(), SMDS_MeshElement::isMarked(), SMDS_MeshElement::NbCornerNodes(), Reorient(), and SMDS_Mesh::SetAllCellsNotMarked().
Referenced by SMESH_MeshEditor_i::Reorient2D(), and SMESH_MeshEditor_i::Reorient2DByNeighbours().
◆ Reorient2DBy3D()
int SMESH_MeshEditor::Reorient2DBy3D ( TIDSortedElemSet &  theFaces,
TIDSortedElemSet &  theVolumes,
theFaces- faces to reorient. If empty, all mesh faces are treated.
theVolumes- reference volumes.
theOutsideNormal- to orient faces to have their normal pointing either outside or inside the adjacent volumes.
References SMDS_MeshElement::begin_nodes(), SMDS_Mesh::elementsIterator(), SMESHUtils::elemSetIterator(), SMDS_MeshElement::end_nodes(), SMDS_VolumeTool::GetFaceIndex(), SMDS_VolumeTool::GetFaceNodes(), GetMeshDS(), SMDS_MeshElement::GetNodeIndex(), SMDS_MeshElement::GetType(), SMDS_MeshElement::NbCornerNodes(), Reorient(), SMDS_VolumeTool::Set(), SMDS_VolumeTool::SetExternalNormal(), SMDSAbs_Face, and SMDSAbs_Volume.
Referenced by SMESH_MeshEditor_i::Reorient2DBy3D().
◆ ReplaceElemInGroups() [1/2]
void SMESH_MeshEditor::ReplaceElemInGroups ( const SMDS_MeshElement *  elemToRm,
const SMDS_MeshElement *  elemToAdd,
◆ ReplaceElemInGroups() [2/2]
const std::vector< const SMDS_MeshElement * > &  elemToAdd,
References SMDS_MeshGroup::Add(), SMESHDS_Mesh::GetGroups(), SMDS_MeshGroup::Remove(), and SMESHDS_Group::SMDSGroup().
◆ RotationSweep()
◆ SewFreeBorder()
◆ SewSideElements()
◆ SimplifyFace()
int SMESH_MeshEditor::SimplifyFace ( const std::vector< const SMDS_MeshNode * > &  faceNodes,
std::vector< const SMDS_MeshNode * > &  poly_nodes,
std::vector< int > &  quantities
Referenced by applyMerge().
◆ Smooth()
◆ SplitBiQuadraticIntoLinear()
void SMESH_MeshEditor::SplitBiQuadraticIntoLinear ( TIDSortedElemSet &  theElems)
  • bi-quadratic triangle will be split into 3 linear quadrangles;
  • bi-quadratic quadrangle will be split into 4 linear quadrangles;
  • tri-quadratic hexahedron will be split into 8 linear hexahedra; Quadratic elements of lower dimension adjacent to the split bi-quadratic element will be split in order to keep the mesh conformal.
    elems- elements to split
References SMESHDS_SubMesh::AddElement(), AddElement(), SMDS_MeshElement::begin_nodes(), SMDS_ElementHolder::clear(), SMDS_MeshElement::end_nodes(), SMDS_MeshElement::GetEntityType(), GetMeshDS(), SMDS_MeshElement::getshapeId(), SMESHDS_Mesh::MeshElements(), SMESHDS_Mesh::RemoveFreeElement(), ReplaceElemInGroups(), SMDSAbs_Edge, SMDSAbs_Face, SMDSAbs_Volume, SMDSEntity_BiQuad_Quadrangle, SMDSEntity_BiQuad_Triangle, SMDSEntity_Quad_Edge, and SMDSEntity_TriQuad_Hexa.
Referenced by SMESH_MeshEditor_i::SplitBiQuadraticIntoLinear().
◆ SplitEdge()
◆ SplitFace()
◆ SplitVolumes()
void SMESH_MeshEditor::SplitVolumes ( const TFacetOfElem &  theElems,
const bool  avoidOverConstrainedVolumes = false
If facet ID < 0, element is split into tetrahedra, else a hexahedron is split into prisms so that the given facet is split into triangles if avoidOverConstrainedVolumes is True , the split method will choose the variant with no over-constrained volumes.
References SMESHDS_SubMesh::AddElement(), SMESH_MesherHelper::CheckNodeUV(), SMESHDS_SubMesh::Contains(), Face, FindShape(), SMDS_VolumeTool::GetBaryCenter(), SMDS_VolumeTool::GetCenterNodeIndex(), SMDS_MeshElement::GetEntityType(), SMDS_VolumeTool::GetFaceBaryCenter(), SMDS_VolumeTool::GetFaceNodes(), SMDS_VolumeTool::GetFaceNodesIndices(), SMESHDS_SubMesh::GetID(), GetMesh(), GetMeshDS(), SMDS_VolumeTool::GetNodes(), SMDS_MeshElement::GetType(), SMESHDS_Mesh::IndexToShape(), SMDS_VolumeTool::IsFaceExternal(), SMDS_MeshElement::IsQuadratic(), SMESHDS_Mesh::MeshElements(), SMESHDS_Mesh::MoveNode(), myLastCreatedElems, myLastCreatedNodes, SMDS_VolumeTool::NbFaceNodes(), SMDS_VolumeTool::NbFaces(), SMDS_VolumeTool::NbNodes(), SMDS_MeshElement::NbNodes(), SMESHDS_Mesh::RemoveFreeElement(), SMESHDS_Mesh::RemoveNode(), SMESHDS_SubMesh::RemoveNode(), ReplaceElemInGroups(), SMDS_VolumeTool::Set(), SMESHDS_Mesh::SetNodeOnFace(), SMESH_MesherHelper::SetSubShape(), SMDSAbs_Face, SMDSAbs_Volume, SMDSEntity_Quad_Tetra, SMDSEntity_Tetra, SMDSEntity_TriQuad_Hexa, and SMESH_MesherHelper::ToFixNodeParameters().
Referenced by SMESH_MeshEditor_i::SplitHexahedraIntoPrisms(), SMESH_MeshEditor_i::SplitVolumesIntoTetra(), and SMESH_MeshEditor_i::SplitVolumesIntoTetraAvoidOverConstrainedVolumes().
◆ sweepElement()
◆ Transform()
SMESH_MeshEditor::PGroupIDs SMESH_MeshEditor::Transform ( TIDSortedElemSet &  theElems,
const gp_Trsf &  theTrsf,
const bool  theCopy,
SMESH_Mesh *  theTargetMesh = 0
◆ TriToQuad()
bool SMESH_MeshEditor::TriToQuad ( TIDSortedElemSet &  theElems,
theElems- The triangles to be fused.
theCriterion- Is used to choose a neighbour to fuse with.
theMaxAngle- Is a max angle between element normals at which fusion is still performed; theMaxAngle is measured in radians.
bool - Success or not.
References SMESHDS_Mesh::AddFace(), AddToSameGroups(), ClearLastCreated(), getAngle(), getBadRate(), GetMeshDS(), getNodesFromTwoTria(), getQuadrangleNodes(), SMDS_MeshElement::getshapeId(), SMDS_MeshElement::GetType(), myLastCreatedElems, SMDS_MeshElement::NbCornerNodes(), SMDS_MeshElement::NbNodes(), SMDS_MeshElement::nodeIterator(), SMESHDS_Mesh::RemoveElement(), SMESHDS_Mesh::RemoveNode(), SMESHDS_Mesh::SetMeshElementOnShape(), and SMDSAbs_Face.
Referenced by SMESH_MeshEditor_i::TriToQuad().
◆ UpdateVolumes()
◆ myError
SMESH_ComputeErrorPtr SMESH_MeshEditor::myError
Referenced by ConvertToQuadratic().
◆ myLastCreatedElems
◆ myLastCreatedNodes
◆ myMesh
