StdMeshers_Prism_3D Class Reference
Algo building prisms on a prism shape. More...
#include <StdMeshers_Prism_3D.hxx>
Inheritance diagram for StdMeshers_Prism_3D:
enum  Hypothesis_Status {
enum  hypothesis_type {
  ALGO_3D
 StdMeshers_Prism_3D (int hypId, SMESH_Gen *gen)
virtual ~StdMeshers_Prism_3D ()
void ProjectTriangles ()
 Enable removal of quadrangles from the bottom face and triangles creation there by projection from the top (sole face meshed with triangles is considered to be a bottom one). More...
virtual void CancelCompute ()
 return compute error More...
void InitComputeError ()
bool OnlyUnaryInput () const
bool NeedShape () const
virtual int GetDim () const
SMESH_Gen * GetGen () const
const char * GetName () const
int GetID () const
int GetType () const
 Equality. More...
static bool AddPrisms (std::vector< const TNodeColumn * > &nodeColumns, SMESH_MesherHelper *helper)
 Create prisms. More...
static bool IsApplicable (const TopoDS_Shape &aShape, bool toCheckAll)
 Return true if the algorithm can mesh this shape. More...
bool _onlyUnaryInput
bool _requireDiscreteBoundary
bool _requireShape
bool _supportSubmeshes
bool _neededLowerHyps [4]
bool _quadraticMesh
int _error
std::string _comment
const SMDS_Mesh * _mesh
double _progress
int _progressTic
SMESH_Gen * _gen
int _shapeType
int _param_algo_dim
int _hypId
hypothesis_type _type
bool initPrism (Prism_3D::TPrismTopo &thePrism, const TopoDS_Shape &theSolid, const bool selectBottom=true)
 Analyse shape geometry and mesh. More...
bool getWallFaces (Prism_3D::TPrismTopo &thePrism, const int totalNbFaces)
 Fill thePrism.myWallQuads and thePrism.myTopEdges. More...
bool compute (const Prism_3D::TPrismTopo &thePrism)
 Compute mesh on a SOLID. More...
bool computeBase (const Prism_3D::TPrismTopo &thePrism)
 Compute the base face of a prism. More...
bool computeWalls (const Prism_3D::TPrismTopo &thePrism)
 Compute 2D mesh on walls FACEs of a prism. More...
void makeQuadsForOutInProjection (const Prism_3D::TPrismTopo &thePrism, std::multimap< int, int > &wgt2quad, std::map< int, FaceQuadStruct > &iW2oiQuads)
 Create artificial wall quads for vertical projection between the outer and inner walls. More...
TopoDS_Edge findPropagationSource (const TopoDS_Edge &E)
 Returns a source EDGE of propagation to a given EDGE. More...
bool assocOrProjBottom2Top (const gp_Trsf &bottomToTopTrsf, const Prism_3D::TPrismTopo &thePrism)
 Find correspondence between bottom and top nodes. More...
bool projectBottomToTop (const gp_Trsf &bottomToTopTrsf, const Prism_3D::TPrismTopo &thePrism)
 Remove quadrangles from the top face and create triangles there by projection from the bottom. More...
double getSweepTolerance (const Prism_3D::TPrismTopo &thePrism)
 Compute tolerance to pass to StdMeshers_Sweeper. More...
bool isSimpleBottom (const Prism_3D::TPrismTopo &thePrism)
 Defines if it's safe to use the block approach. More...
bool allVerticalEdgesStraight (const Prism_3D::TPrismTopo &thePrism)
 Defines if all "vertical" EDGEs are straight. More...
bool project2dMesh (const TopoDS_Face &source, const TopoDS_Face &target)
 Project mesh faces from a source FACE of one prism to a source FACE of another prism. More...
bool setFaceAndEdgesXYZ (const int faceID, const gp_XYZ &params, int z)
 Set projection coordinates of a node to a face and it's sub-shapes. More...
bool toSM (bool isOK)
 If (!isOK), sets the error to a sub-mesh of a current SOLID. More...
int shapeID (const TopoDS_Shape &S)
 Return index of a shape. More...
bool myProjectTriangles
bool mySetErrorToSM
bool myUseBlock
StdMeshers_PrismAsBlock myBlock
SMESH_MesherHelper * myHelper
SMESH_subMesh * myPrevBottomSM
std::vector< gp_XYZ > myShapeXYZ
TNode2ColumnMap myBotToColumnMap
TopTools_IndexedMapOfShape * myPropagChains
std::string _libName
◆ EMeshError
enum SMESH_Algo::EMeshError
MEr_OK
MEr_HOLES
MEr_BAD_ORI
MEr_EMPTY
◆ Hypothesis_Status
HYP_OK
HYP_MISSING
HYP_CONCURRENT
HYP_BAD_PARAMETER
HYP_HIDDEN_ALGO
HYP_HIDING_ALGO
HYP_UNKNOWN_FATAL
HYP_INCOMPATIBLE
HYP_NOTCONFORM
HYP_ALREADY_EXIST
HYP_BAD_DIM
HYP_BAD_SUBSHAPE
HYP_BAD_GEOMETRY
HYP_NEED_SHAPE
HYP_INCOMPAT_HYPS
◆ hypothesis_type
PARAM_ALGO
ALGO_0D
ALGO_1D
ALGO_2D
ALGO_3D
◆ InitWay
BY_MESH
BY_GEOM
BY_AVERAGE_LENGTH
◆ StdMeshers_Prism_3D()
◆ ~StdMeshers_Prism_3D()
StdMeshers_Prism_3D::~StdMeshers_Prism_3D ( )
◆ addBadInputElement()
◆ addBadInputElements()
const bool  addNodes = false
◆ AddPrisms()
bool StdMeshers_Prism_3D::AddPrisms ( std::vector< const TNodeColumn * > &  nodeColumns,
SMESH_MesherHelper *  helper
Create prisms.
nodeColumns- columns of nodes generated from nodes of a mesh face
helper- helper initialized by mesh and shape to add prisms to
columns- columns of nodes generated from nodes of a mesh face
References SMESH_MesherHelper::AddPolyhedralVolume(), SMESH_MesherHelper::AddVolume(), SMDS_VolumeTool::IsForward(), SMDS_VolumeTool::Set(), and SMESH_MesherHelper::SetElementsOnShape().
Referenced by compute(), and StdMeshers_RadialPrism_3D::Compute().
◆ allVerticalEdgesStraight()
bool StdMeshers_Prism_3D::allVerticalEdgesStraight ( const Prism_3D::TPrismTopo &  thePrism)
References SMESH_Algo::IsContinuous(), SMESH_Algo::IsStraight(), Prism_3D::TPrismTopo::myWallQuads, and QUAD_RIGHT_SIDE.
Referenced by compute().
◆ assocOrProjBottom2Top()
bool StdMeshers_Prism_3D::assocOrProjBottom2Top ( const gp_Trsf &  bottomToTopTrsf,
Find correspondence between bottom and top nodes If elements on the bottom and top faces are topologically different, and projection is possible and allowed, perform the projection.
bool- is a success or not
RETURN_BAD_RESULT("Need to project but not allowed");
References SMESH_Hypothesis::_gen, SMESH_Gen::Compute(), SMESH_Algo::error(), StdMeshers_ProjectionUtils::FindMatchingNodesOnFaces(), StdMeshers_ProjectionUtils::FindSubShapeAssociation(), SMESH_subMesh::GetId(), SMESH_MesherHelper::GetMesh(), SMDS_MeshNode::GetPosition(), SMESH_Mesh::GetSubMesh(), SMESH_subMesh::GetSubMeshDS(), SMESH_subMesh::GetSubShape(), StdMeshers_PrismAsBlock::HasNodeColumn(), StdMeshers_ProjectionUtils::InsertAssociation(), SMESH_subMesh::IsMeshComputed(), SMESH_MesherHelper::IthVertex(), MESSAGE, myBlock, myBotToColumnMap, Prism_3D::TPrismTopo::myBottom, myHelper, Prism_3D::TPrismTopo::myTop, Prism_3D::TPrismTopo::myWallQuads, SMESHDS_SubMesh::NbElements(), SMESHDS_SubMesh::NbNodes(), projectBottomToTop(), QUAD_BOTTOM_SIDE, QUAD_LEFT_SIDE, QUAD_RIGHT_SIDE, QUAD_TOP_SIDE, SMDS_TOP_FACE, toSM(), and StdMeshers_PrismAsBlock::VerticalSize().
◆ CancelCompute()
◆ CheckHypothesis()
bool StdMeshers_Prism_3D::CheckHypothesis ( SMESH_Mesh &  aMesh,
const TopoDS_Shape &  aShape,
SMESH_Hypothesis::Hypothesis_Status &  aStatus
aMesh- the mesh
aShape- the shape
aStatus- check result
bool- true if hypothesis is well defined
Textual description of a problem can be stored in _comment field.
Implements SMESH_Algo.
References SMESH_Hypothesis::HYP_OK.
Referenced by ComputePentahedralMesh(), and EvaluatePentahedralMesh().
◆ compute()
bool StdMeshers_Prism_3D::compute ( const Prism_3D::TPrismTopo &  thePrism)
References SMESH_Algo::_computeCanceled, SMESHDS_Mesh::AddNode(), AddPrisms(), allVerticalEdgesStraight(), assocOrProjBottom2Top(), Prism_3D::TNode::ChangeParams(), SMESH_subMesh::CHECK_COMPUTE_STATE, StdMeshers_Sweeper::CheckSameZ(), StdMeshers_PrismAsBlock::Clear(), COMPERR_BAD_INPUT_MESH, COMPERR_CANCELED, computeBase(), StdMeshers_Sweeper::ComputeNodesByTrsf(), StdMeshers_Sweeper::ComputeNodesOnStraight(), StdMeshers_Sweeper::ComputeNodesOnStraightSameZ(), SMESH_Block::ComputeParameters(), SMESH_subMesh::ComputeStateEngine(), computeWalls(), SMESH_Algo::error(), SMESH_subMesh::GetComputeError(), Prism_3D::TNode::GetCoords(), SMESH_subMesh::getDependsOnIterator(), SMESHDS_SubMesh::GetElements(), StdMeshers_PrismAsBlock::GetError(), SMDS_MeshElement::GetID(), SMESH_subMesh::GetId(), SMESH_MesherHelper::GetMesh(), SMESH_MesherHelper::GetMeshDS(), SMDS_MeshElement::GetNode(), StdMeshers_PrismAsBlock::GetNodeColumn(), StdMeshers_PrismAsBlock::GetParam2ColumnMap(), Prism_3D::TNode::GetParams(), SMDS_MeshNode::GetPosition(), Prism_3D::TNode::GetPositionType(), SMESH_Mesh::GetSubMesh(), getSweepTolerance(), SMDS_MeshElement::GetType(), gpXYZ, StdMeshers_PrismAsBlock::HasNodeColumn(), Prism_3D::TNode::HasParams(), ID_BOT_FACE, SMESH_Block::ID_F0yz, SMESH_Block::ID_F1yz, SMESH_Block::ID_FirstE, SMESH_Block::ID_FirstV, SMESH_Block::ID_Fx0z, SMESH_Block::ID_Fx1z, ID_TOP_FACE, StdMeshers_PrismAsBlock::Init(), Prism_3D::TNode::IsNeighbor(), SMESH_MesherHelper::IsQuadraticSubMesh(), isSimpleBottom(), myBlock, StdMeshers_Sweeper::myBndColumns, StdMeshers_Sweeper::myBotFace, myBotToColumnMap, Prism_3D::TPrismTopo::myBottom, Prism_3D::TPrismTopo::myBottomEdges, StdMeshers_Sweeper::myHelper, myHelper, StdMeshers_Sweeper::myIntColumns, Prism_3D::TNode::myNode, Prism_3D::TPrismTopo::myShape3D, myShapeXYZ, Prism_3D::TPrismTopo::myTop, StdMeshers_Sweeper::myTopFace, myUseBlock, SMDS_MeshElement::NbCornerNodes(), SMESH_Block::NbSubShapes(), SMESH_ComputeError::New(), SMESH_MesherHelper::SetElementsOnShape(), setFaceAndEdgesXYZ(), SMESHDS_Mesh::SetNodeInVolume(), SMESHDS_Mesh::ShapeToIndex(), SMESH_Block::ShellPoint(), SHOWYXZ, SMDS_TOP_FACE, SMDSAbs_Face, StdMeshers_PrismAsBlock::SubMesh(), StdMeshers_PrismAsBlock::SubMeshDS(), toSM(), and SMESH_Block::VertexPoint().
Referenced by Compute().
◆ Compute() [1/2]
bool StdMeshers_Prism_3D::Compute ( SMESH_Mesh &  aMesh,
aMesh- the mesh
aShape- the shape
bool- is a success
Algorithms that !NeedDiscreteBoundary() || !OnlyUnaryInput() are to set SMESH_ComputeError returned by SMESH_submesh::GetComputeError() to report problematic sub-shapes
References SMESH_Algo::_computeCanceled, SMESH_subMesh::CHECK_COMPUTE_STATE, Prism_3D::TPrismTopo::Clear(), COMPERR_BAD_INPUT_MESH, COMPERR_CANCELED, COMPERR_OK, compute(), SMESH_subMesh::COMPUTE_SUBMESH, SMESH_subMesh::ComputeStateEngine(), SMESH_MesherHelper::Count(), SMESH_Algo::error(), Face, SMESH_subMesh::GetAlgo(), SMESH_MesherHelper::GetAncestors(), SMESH_subMesh::GetComputeError(), SMESH_subMesh::getDependsOnIterator(), SMESH_MesherHelper::GetMesh(), SMESH_Mesh::GetMeshDS(), StdMeshers_ProjectionUtils::GetPropagationEdge(), SMESH_Mesh::GetSubMesh(), SMESH_subMesh::GetSubMeshDS(), SMESH_Algo::InitComputeError(), initPrism(), SMESH_MesherHelper::IsBlock(), SMESH_subMesh::IsEmpty(), SMESH_subMesh::IsMeshComputed(), SMESH_MesherHelper::IsSameElemGeometry(), SMESH_MesherHelper::IsStructured(), SMESH_MesherHelper::IsSubShape(), SMESHDS_Mesh::MeshElements(), Prism_3D::TPrismTopo::myAlgoSM, Prism_3D::TPrismTopo::myBottom, myHelper, myPrevBottomSM, myPropagChains, mySetErrorToSM, Prism_3D::TPrismTopo::myTop, SMESHDS_SubMesh::NbElements(), SMESH_Mesh::NbQuadrangles(), SMESH_ComputeError::New(), project2dMesh(), QUAD_TOP_SIDE, SMDSGeom_QUADRANGLE, and toSM().
Referenced by ComputePentahedralMesh().
◆ Compute() [2/2]
SMESH_MesherHelper *  aHelper
aMesh- the mesh
bool- is a success
aMesh- the mesh
bool- is a success
◆ computeBase()
◆ computeWalls()
bool StdMeshers_Prism_3D::computeWalls ( const Prism_3D::TPrismTopo &  thePrism)
References SMESH_Algo::addBadInputElements(), SMESH_MesherHelper::AddEdge(), SMESHDS_Mesh::AddNode(), SMESH_MesherHelper::AddTLinks(), SMESH_subMesh::CHECK_COMPUTE_STATE, SMESH_subMesh::CLEAN, COMPERR_ALGO_FAILED, COMPERR_BAD_INPUT_MESH, SMESH_subMesh::COMPUTE, SMESH_subMesh::ComputeStateEngine(), SMESH_subMesh::ComputeSubMeshStateEngine(), DBGOUT, Edge, SMESH_Algo::error(), findPropagationSource(), SMESH_MesherHelper::GetAncestors(), SMESH_subMesh::GetComputeError(), SMESH_subMesh::getDependsOnIterator(), SMESHDS_SubMesh::GetElements(), SMESH_subMesh::GetId(), SMESH_MesherHelper::GetIsQuadratic(), SMESH_MesherHelper::GetMediumPos(), SMESH_MesherHelper::GetMesh(), SMESH_MesherHelper::GetMeshDS(), SMESH_Mesh::GetSubMesh(), SMESH_subMesh::GetSubMeshDS(), SMESH_subMesh::GetSubShape(), SMESH_subMesh::IsMeshComputed(), SMESH_MesherHelper::IthVertex(), makeQuadsForOutInProjection(), SMESH_MeshEditor::MergeNodes(), SMESHDS_Mesh::MeshElements(), SMESHDS_Mesh::MoveNode(), myHelper, Prism_3D::TPrismTopo::myRightQuadIndex, Prism_3D::TPrismTopo::myShape3D, Prism_3D::TPrismTopo::myWallQuads, NB_QUAD_SIDES, SMESHDS_SubMesh::NbElements(), SMESHDS_SubMesh::NbNodes(), QUAD_BOTTOM_SIDE, QUAD_LEFT_SIDE, QUAD_RIGHT_SIDE, QUAD_TOP_SIDE, SMESH_MesherHelper::SetElementsOnShape(), SMESHDS_Mesh::SetMeshElementOnShape(), SMESHDS_Mesh::SetNodeOnEdge(), SMESHDS_Mesh::SetNodeOnVertex(), shapeID(), SMESHDS_Mesh::ShapeToIndex(), FaceQuadStruct::side, SMESH_subMesh::SubMeshesComputed(), toSM(), SMESHDS_Mesh::UnSetNodeOnShape(), SMESH_Algo::VertexNode(), and SMESH_MesherHelper::WrapIndex().
◆ Continuity()
const TopoDS_Edge &  theE2
E1- the 1st edge
E2- the 2nd edge
References OCC_CATCH_SIGNALS.
◆ DataDependOnParams()
◆ EdgeLength()
◆ error() [1/3]
◆ error() [2/3]
Referenced by StdMeshers_Quadrangle_2D::addEnforcedNodes(), assocOrProjBottom2Top(), StdMeshers_Quadrangle_2D::CheckHypothesis(), StdMeshers_Hexa_3D::CheckHypothesis(), StdMeshers_PolyhedronPerSolid_3D::CheckHypothesis(), StdMeshers_Projection_2D::CheckHypothesis(), StdMeshers_Quadrangle_2D::CheckNbEdges(), StdMeshers_Quadrangle_2D::checkNbEdgesForEvaluate(), compute(), StdMeshers_Cartesian_3D::Compute(), StdMeshers_CompositeHexa_3D::Compute(), StdMeshers_CompositeSegment_1D::Compute(), StdMeshers_Hexa_3D::Compute(), StdMeshers_Import_1D::Compute(), StdMeshers_Import_1D2D::Compute(), StdMeshers_PolygonPerFace_2D::Compute(), Compute(), StdMeshers_Projection_1D::Compute(), StdMeshers_Projection_1D2D::Compute(), StdMeshers_Projection_2D::Compute(), StdMeshers_Projection_3D::Compute(), StdMeshers_QuadFromMedialAxis_1D2D::Compute(), StdMeshers_Quadrangle_2D::Compute(), StdMeshers_RadialPrism_3D::Compute(), StdMeshers_RadialQuadrangle_1D2D::Compute(), SMESH_Algo::Compute(), StdMeshers_HexaFromSkin_3D::Compute(), TNodeDistributor::Compute(), computeBase(), StdMeshers_RadialPrism_3D::computeLayerPositions(), StdMeshers_RadialQuadrangle_1D2D::computeLayerPositions(), StdMeshers_Quadrangle_2D::computeQuadDominant(), StdMeshers_Quadrangle_2D::computeQuadPref(), StdMeshers_Quadrangle_2D::computeReduced(), computeWalls(), SMESH_Algo::error(), StdMeshers_HexaFromSkin_3D::Evaluate(), StdMeshers_Import_1D::Evaluate(), StdMeshers_Import_1D2D::Evaluate(), StdMeshers_PolygonPerFace_2D::Evaluate(), Evaluate(), StdMeshers_Projection_1D::Evaluate(), StdMeshers_Projection_1D2D::Evaluate(), StdMeshers_Projection_2D::Evaluate(), StdMeshers_Projection_3D::Evaluate(), StdMeshers_CompositeHexa_3D::findBoxFaces(), StdMeshers_Quadrangle_2D::getCorners(), StdMeshers_Quadrangle_2D::getEnforcedUV(), SMESH_Algo::GetFeatures(), StdMeshers_ViscousLayerBuilder::GetShrinkGeometry(), getWallFaces(), initPrism(), projectBottomToTop(), and StdMeshers_Quadrangle_2D::setNormalizedGrid().
◆ error() [3/3]
◆ Evaluate()
bool StdMeshers_Prism_3D::Evaluate ( SMESH_Mesh &  aMesh,
MapShapeNbElems &  aResMap
aMesh- the mesh
aShape- the shape
aResMap- prospective number of elements by SMDSAbs_ElementType by a sub-mesh
bool- is a success
References SMESH_Algo::error(), Evaluate(), SMESH_Mesh::GetSubMesh(), myHelper, SMESH_MesherHelper::SetSubShape(), SMDSEntity_Edge, SMDSEntity_Hexa, SMDSEntity_Last, SMDSEntity_Node, SMDSEntity_Penta, SMDSEntity_Quad_Edge, SMDSEntity_Quad_Hexa, SMDSEntity_Quad_Penta, SMDSEntity_Quad_Quadrangle, SMDSEntity_Quad_Triangle, SMDSEntity_Quadrangle, SMDSEntity_Triangle, and toSM().
Referenced by Evaluate(), and EvaluatePentahedralMesh().
◆ findPropagationSource()
TopoDS_Edge StdMeshers_Prism_3D::findPropagationSource ( const TopoDS_Edge &  E)
References Edge, and myPropagChains.
Referenced by computeWalls().
◆ GetAssignedShapes()
◆ GetCompatibleHypoFilter()
◆ GetCompatibleHypothesis()
◆ GetComputeError()
◆ GetDim()
◆ GetFeatures() [1/2]
◆ GetFeatures() [2/2]
◆ GetGen()
◆ GetID()
◆ GetLibName()
◆ GetMeshByPersistentID()
◆ GetMeshError()
◆ GetName()
◆ GetNodeParamOnEdge()
const TopoDS_Edge &  theEdge,
Warning
◆ GetProgress()
◆ GetProgressByTic()
◆ GetShapeType()
◆ GetSortedNodesOnEdge()
theNodes- The resulting map
Warning
◆ getSweepTolerance()
◆ GetType()
◆ GetUsedHypothesis()
aMesh- the mesh
aShape- the shape
Referenced by StdMeshers_Cartesian_3D::CheckHypothesis(), StdMeshers_QuadFromMedialAxis_1D2D::CheckHypothesis(), StdMeshers_Quadrangle_2D::CheckHypothesis(), StdMeshers_Hexa_3D::CheckHypothesis(), StdMeshers_Import_1D::CheckHypothesis(), StdMeshers_Import_1D2D::CheckHypothesis(), StdMeshers_PolyhedronPerSolid_3D::CheckHypothesis(), StdMeshers_Projection_1D::CheckHypothesis(), StdMeshers_Projection_2D::CheckHypothesis(), StdMeshers_Projection_3D::CheckHypothesis(), StdMeshers_RadialPrism_3D::CheckHypothesis(), StdMeshers_RadialQuadrangle_1D2D::CheckHypothesis(), StdMeshers_SegmentAroundVertex_0D::CheckHypothesis(), SMESH_subMesh::ComputeStateEngine(), VISCOUS_2D::_ViscousBuilder2D::findEdgesWithLayers(), VISCOUS_3D::_ViscousBuilder::findSolidsWithLayers(), SMESH_subMesh::getCollection(), StdMeshers_CompositeSegment_1D::GetFaceSide(), StdMeshers_Regular_1D::GetUsedHypothesis(), StdMeshers_Regular_1D::getVertexHyp(), and StdMeshers_ProjectionUtils::MakeComputed().
◆ getWallFaces()
◆ InitComputeError()
◆ initPrism()
◆ IsApplicable()
bool StdMeshers_Prism_3D::IsApplicable ( const TopoDS_Shape &  shape,
bool  toCheckAll
[in]aShape- shape to check
References SMESH_MesherHelper::Count(), Face, SMESH_Block::FindBlockShapes(), and SMESH_MesherHelper::WrapIndex().
◆ IsApplicableToShape()
virtual bool StdMeshers_Prism_3D::IsApplicableToShape ( const TopoDS_Shape &  shape,
bool  toCheckAll
bool- true by default
Reimplemented from SMESH_3D_Algo.
References SMESH::IsApplicable().
◆ IsAuxiliary()
bool- auxiliary or not
◆ IsContinuous()
const TopoDS_Edge &  E2
Referenced by allVerticalEdgesStraight(), and StdMeshers_Quadrangle_2D::checkNbEdgesForEvaluate().
◆ isDegenerated()
◆ IsSameName()
◆ isSimpleBottom()
bool StdMeshers_Prism_3D::isSimpleBottom ( const Prism_3D::TPrismTopo &  thePrism)
◆ IsStatusFatal()
◆ IsStraight()
Referenced by allVerticalEdgesStraight(), Handle(), and VISCOUS_3D::_ViscousBuilder::limitMaxLenByCurvature().
◆ LoadFrom()
load- the stream
std::ostream& - the stream
◆ LoadStringFromStream()
std::string &  txt
◆ makeQuadsForOutInProjection()
void StdMeshers_Prism_3D::makeQuadsForOutInProjection ( const Prism_3D::TPrismTopo &  thePrism,
std::multimap< int, int > &  wgt2quad,
std::map< int, FaceQuadStruct > &  iW2oiQuads
◆ NeedDiscreteBoundary()
◆ NeedLowerHyps()
◆ NeedShape()
Referenced by SMESH_Hypothesis_i::LoadFrom(), StdMeshers_CartesianParameters3D::SetAxisDirs(), StdMeshers_BlockRenumber::SetBlocksOrientation(), StdMeshers_ViscousLayers::SetBndShapes(), StdMeshers_Geometric1D::SetCommonRatio(), StdMeshers_ImportSource1D::SetCopySourceMesh(), StdMeshers_Adaptive1D::SetDeflection(), StdMeshers_Deflection1D::SetDeflection(), StdMeshers_QuadrangleParams::SetEnforcedNodes(), StdMeshers_AutomaticLength::SetFineness(), StdMeshers_CartesianParameters3D::SetFixedPoint(), StdMeshers_CartesianParameters3D::SetGrid(), StdMeshers_CartesianParameters3D::SetGridSpacing(), StdMeshers_ViscousLayers::SetGroupName(), StdMeshers_ImportSource1D::SetGroups(), StdMeshers_LayerDistribution::SetLayerDistribution(), StdMeshers_LocalLength::SetLength(), StdMeshers_MaxLength::SetLength(), StdMeshers_SegmentLengthAroundVertex::SetLength(), StdMeshers_Arithmetic1D::SetLength(), StdMeshers_StartEndLength::SetLength(), StdMeshers_MaxElementArea::SetMaxArea(), StdMeshers_Adaptive1D::SetMaxSize(), StdMeshers_MaxElementVolume::SetMaxVolume(), StdMeshers_ViscousLayers::SetMethod(), StdMeshers_Adaptive1D::SetMinSize(), StdMeshers_LengthFromEdges::SetMode(), StdMeshers_FixedPoints1D::SetNbSegments(), StdMeshers_ViscousLayers::SetNumberLayers(), StdMeshers_NumberOfLayers::SetNumberOfLayers(), StdMeshers_FixedPoints1D::SetPoints(), StdMeshers_LocalLength::SetPrecision(), StdMeshers_QuadrangleParams::SetQuadType(), StdMeshers_CartesianParameters3D::SetQuanta(), StdMeshers_Reversible1D::SetReversedEdges(), StdMeshers_CartesianParameters3D::SetSizeThreshold(), StdMeshers_ProjectionSource3D::SetSource3DShape(), StdMeshers_ProjectionSource1D::SetSourceEdge(), StdMeshers_ProjectionSource2D::SetSourceFace(), StdMeshers_ProjectionSource1D::SetSourceMesh(), StdMeshers_ProjectionSource2D::SetSourceMesh(), StdMeshers_ProjectionSource3D::SetSourceMesh(), StdMeshers_Geometric1D::SetStartLength(), StdMeshers_ViscousLayers::SetStretchFactor(), StdMeshers_CartesianParameters3D::SetToAddEdges(), StdMeshers_CartesianParameters3D::SetToConsiderInternalFaces(), StdMeshers_CartesianParameters3D::SetToCreateFaces(), StdMeshers_ViscousLayers::SetTotalThickness(), StdMeshers_CartesianParameters3D::SetToUseQuanta(), StdMeshers_CartesianParameters3D::SetToUseThresholdForInternalFaces(), StdMeshers_QuadrangleParams::SetTriaVertex(), StdMeshers_ProjectionSource1D::SetVertexAssociation(), StdMeshers_ProjectionSource2D::SetVertexAssociation(), and StdMeshers_ProjectionSource3D::SetVertexAssociation().
◆ NumberOfPoints()
const TopoDS_Wire &  W
◆ OnlyUnaryInput()
◆ operator!=()
◆ operator==()
Equality.
◆ project2dMesh()
bool StdMeshers_Prism_3D::project2dMesh ( const TopoDS_Face &  source,
const TopoDS_Face &  target
◆ projectBottomToTop()
bool StdMeshers_Prism_3D::projectBottomToTop ( const gp_Trsf &  bottomToTopTrsf,
Remove faces from the top face and re-create them by projection from the bottom.
bool- a success or not
References SMESH_Algo::_computeCanceled, SMESH_MesherHelper::AddFace(), SMESHDS_Mesh::AddNode(), SMESHDS_Mesh::AddPolygonalFace(), SMESH_MeshEditor::CENTROIDAL, Prism_3D::TNode::ChangeParams(), SMESH_MesherHelper::CheckNodeUV(), COMPERR_CANCELED, SMESH_Block::ComputeParameters(), SMESH_Algo::error(), SMESH_Block::FacePoint(), SMESH_Block::FaceUV(), Prism_3D::TNode::GetCoords(), SMESHDS_SubMesh::GetElements(), SMDS_MeshElement::GetID(), SMESH_subMesh::GetId(), SMESH_MesherHelper::GetMesh(), SMESH_MesherHelper::GetMeshDS(), SMDS_MeshElement::GetNode(), StdMeshers_PrismAsBlock::GetNodeColumn(), SMESHDS_SubMesh::GetNodes(), SMESH_MesherHelper::GetNodeUV(), Prism_3D::TNode::GetParams(), SMDS_MeshNode::GetPosition(), SMESH_Mesh::GetSubMesh(), SMESH_subMesh::GetSubMeshDS(), SMDS_MeshElement::GetType(), Handle(), ID_BOT_FACE, ID_TOP_FACE, SMESH_MesherHelper::IsDistorted2D(), Prism_3D::TNode::IsNeighbor(), SMESH_MesherHelper::IsReversedSubMesh(), SMESH_MeshEditor::LAPLACIAN, SMESH_MesherHelper::MaxTolerance(), StdMeshers_PrismAsBlock::Mesh(), SMESHDS_Mesh::MoveNode(), myBlock, myBotToColumnMap, Prism_3D::TPrismTopo::myBottom, myHelper, Prism_3D::TPrismTopo::myTop, myUseBlock, SMESH_MesherHelper::NbAncestors(), SMDS_MeshElement::NbCornerNodes(), SMESHDS_SubMesh::NbElements(), Prism_3D::TPrismTopo::NbWires(), SMESH_ComputeError::New(), project2dMesh(), SMESHDS_Mesh::RemoveFreeElement(), SMESHDS_Mesh::RemoveFreeNode(), SMESH_MesherHelper::SetElementsOnShape(), SMESHDS_Mesh::SetMeshElementOnShape(), SMESHDS_Mesh::SetNodeOnFace(), SMESH_MesherHelper::SetSubShape(), SMESHDS_Mesh::ShapeToIndex(), SMDS_TOP_FACE, SMDSAbs_Face, SMESH_MeshEditor::Smooth(), SMESH_MesherHelper::ToFixNodeParameters(), toSM(), StdMeshers_PrismAsBlock::VerticalSize(), and SMDS_MeshNode::X().
Referenced by assocOrProjBottom2Top().
◆ ProjectTriangles()
void StdMeshers_Prism_3D::ProjectTriangles ( )
If there are two faces with triangles, triangles must be of the same topology, else the algo fails. The method must be called before Compute()
◆ SaveStringToStream()
const std::string &  txt
◆ SaveTo()
save- the stream
◆ SetEventListener()
void SMESH_Algo::SetEventListener ( SMESH_subMesh *  subMesh)
This method is called when a submesh gets HYP_OK algo_state. After being set, event listener is notified on each event of a submesh. By default none listener is set
After being set, event listener is notified on each event of a submesh. By default non listener is set
Reimplemented in StdMeshers_Cartesian_3D, StdMeshers_CompositeSegment_1D, StdMeshers_Import_1D, StdMeshers_Import_1D2D, StdMeshers_QuadFromMedialAxis_1D2D, StdMeshers_RadialQuadrangle_1D2D, StdMeshers_Regular_1D, StdMeshers_Projection_1D, StdMeshers_Projection_1D2D, StdMeshers_Projection_2D, and StdMeshers_Projection_3D.
Referenced by SMESH_subMesh::AlgoStateEngine().
◆ setFaceAndEdgesXYZ()
bool StdMeshers_Prism_3D::setFaceAndEdgesXYZ ( const int  faceID,
const gp_XYZ &  params,
int  z
faceID- the face given by in-block ID
params- node normalized parameters
bool- is a success
References SMESH_Block::EdgePoint(), SMESH_Block::FacePoint(), SMESH_Block::GetFaceEdgesIDs(), SMESH_Block::ID_Fx0z, SMESH_Block::ID_Fx1z, myBlock, myShapeXYZ, and SHOWYXZ.
◆ SetLibName()
◆ SetParametersByDefaults()
Implements SMESH_Hypothesis.
◆ SetParametersByMesh()
◆ setSubMeshesToCompute()
◆ shapeID()
int StdMeshers_Prism_3D::shapeID ( const TopoDS_Shape &  S)
◆ SubMeshesToCompute()
◆ SubmeshRestored()
subMesh- restored submesh
◆ SupportSubmeshes()
◆ toSM()
◆ VertexNode() [1/3]
const SMESH_Mesh *  mesh
V- the vertex
mesh- mesh
◆ VertexNode() [2/3]
const SMESHDS_Mesh *  meshDS
◆ VertexNode() [3/3]
const SMESH_Mesh *  mesh,
const bool  checkV = true
V- the vertex
mesh- the mesh
V- the vertex
◆ _assigedShapeList
◆ _badInputElements
◆ _comment
Referenced by SMESH_Algo::error(), SMESH_Algo::GetComputeError(), SMESH_Algo::InitComputeError(), and toSM().
◆ _compatibleAllHypFilter
◆ _compatibleHypothesis
◆ _compatibleNoAuxHypFilter
◆ _computeCanceled
◆ _error
int SMESH_Algo::_error
◆ _gen
◆ _hypId
◆ _libName
privateinherited
◆ _mesh
◆ _name
Referenced by SMESHDS_Hypothesis::GetName(), SMESHDS_Hypothesis::IsSameName(), SMESHDS_Hypothesis::operator==(), SMESHDS_Hypothesis::SMESHDS_Hypothesis(), StdMeshers_Adaptive1D::StdMeshers_Adaptive1D(), StdMeshers_Arithmetic1D::StdMeshers_Arithmetic1D(), StdMeshers_AutomaticLength::StdMeshers_AutomaticLength(), StdMeshers_BlockRenumber::StdMeshers_BlockRenumber(), StdMeshers_Cartesian_3D::StdMeshers_Cartesian_3D(), StdMeshers_CartesianParameters3D::StdMeshers_CartesianParameters3D(), StdMeshers_CompositeHexa_3D::StdMeshers_CompositeHexa_3D(), StdMeshers_CompositeSegment_1D::StdMeshers_CompositeSegment_1D(), StdMeshers_Deflection1D::StdMeshers_Deflection1D(), StdMeshers_FixedPoints1D::StdMeshers_FixedPoints1D(), StdMeshers_Geometric1D::StdMeshers_Geometric1D(), StdMeshers_Hexa_3D::StdMeshers_Hexa_3D(), StdMeshers_HexaFromSkin_3D::StdMeshers_HexaFromSkin_3D(), StdMeshers_Import_1D::StdMeshers_Import_1D(), StdMeshers_Import_1D2D::StdMeshers_Import_1D2D(), StdMeshers_ImportSource1D::StdMeshers_ImportSource1D(), StdMeshers_ImportSource2D::StdMeshers_ImportSource2D(), StdMeshers_LayerDistribution::StdMeshers_LayerDistribution(), StdMeshers_LayerDistribution2D::StdMeshers_LayerDistribution2D(), StdMeshers_LengthFromEdges::StdMeshers_LengthFromEdges(), StdMeshers_LocalLength::StdMeshers_LocalLength(), StdMeshers_MaxElementArea::StdMeshers_MaxElementArea(), StdMeshers_MaxElementVolume::StdMeshers_MaxElementVolume(), StdMeshers_MaxLength::StdMeshers_MaxLength(), StdMeshers_NotConformAllowed::StdMeshers_NotConformAllowed(), StdMeshers_NumberOfLayers::StdMeshers_NumberOfLayers(), StdMeshers_NumberOfLayers2D::StdMeshers_NumberOfLayers2D(), StdMeshers_NumberOfSegments::StdMeshers_NumberOfSegments(), StdMeshers_PolygonPerFace_2D::StdMeshers_PolygonPerFace_2D(), StdMeshers_PolyhedronPerSolid_3D::StdMeshers_PolyhedronPerSolid_3D(), StdMeshers_Prism_3D(), StdMeshers_Projection_1D::StdMeshers_Projection_1D(), StdMeshers_Projection_1D2D::StdMeshers_Projection_1D2D(), StdMeshers_Projection_2D::StdMeshers_Projection_2D(), StdMeshers_Projection_3D::StdMeshers_Projection_3D(), StdMeshers_ProjectionSource1D::StdMeshers_ProjectionSource1D(), StdMeshers_ProjectionSource2D::StdMeshers_ProjectionSource2D(), StdMeshers_ProjectionSource3D::StdMeshers_ProjectionSource3D(), StdMeshers_Propagation::StdMeshers_Propagation(), StdMeshers_PropagOfDistribution::StdMeshers_PropagOfDistribution(), StdMeshers_QuadFromMedialAxis_1D2D::StdMeshers_QuadFromMedialAxis_1D2D(), StdMeshers_Quadrangle_2D::StdMeshers_Quadrangle_2D(), StdMeshers_QuadrangleParams::StdMeshers_QuadrangleParams(), StdMeshers_QuadranglePreference::StdMeshers_QuadranglePreference(), StdMeshers_QuadraticMesh::StdMeshers_QuadraticMesh(), StdMeshers_RadialPrism_3D::StdMeshers_RadialPrism_3D(), StdMeshers_RadialQuadrangle_1D2D::StdMeshers_RadialQuadrangle_1D2D(), StdMeshers_Regular_1D::StdMeshers_Regular_1D(), StdMeshers_SegmentAroundVertex_0D::StdMeshers_SegmentAroundVertex_0D(), StdMeshers_SegmentLengthAroundVertex::StdMeshers_SegmentLengthAroundVertex(), StdMeshers_StartEndLength::StdMeshers_StartEndLength(), StdMeshers_UseExisting_1D::StdMeshers_UseExisting_1D(), StdMeshers_UseExisting_2D::StdMeshers_UseExisting_2D(), StdMeshers_ViscousLayerBuilder::StdMeshers_ViscousLayerBuilder(), StdMeshers_ViscousLayers::StdMeshers_ViscousLayers(), and StdMeshers_ViscousLayers2D::StdMeshers_ViscousLayers2D().
◆ _neededLowerHyps
◆ _onlyUnaryInput
◆ _param_algo_dim
◆ _progress
double SMESH_Algo::_progress
◆ _progressTic
int SMESH_Algo::_progressTic
◆ _quadraticMesh
◆ _requireDiscreteBoundary
◆ _requireShape
◆ _shapeType
◆ _smToCompute
◆ _supportSubmeshes
◆ _type
◆ _usedHypList
◆ myBlock
StdMeshers_PrismAsBlock StdMeshers_Prism_3D::myBlock
◆ myBotToColumnMap
TNode2ColumnMap StdMeshers_Prism_3D::myBotToColumnMap
◆ myHelper
◆ myPrevBottomSM
SMESH_subMesh* StdMeshers_Prism_3D::myPrevBottomSM
◆ myProjectTriangles
bool StdMeshers_Prism_3D::myProjectTriangles
◆ myPropagChains
TopTools_IndexedMapOfShape* StdMeshers_Prism_3D::myPropagChains
Referenced by Compute(), and findPropagationSource().
◆ mySetErrorToSM
bool StdMeshers_Prism_3D::mySetErrorToSM
◆ myShapeXYZ
std::vector<gp_XYZ> StdMeshers_Prism_3D::myShapeXYZ
Referenced by compute(), and setFaceAndEdgesXYZ().
◆ myUseBlock
bool StdMeshers_Prism_3D::myUseBlock
Referenced by compute(), and projectBottomToTop().
