SMESH_Gen Class Reference
#include <SMESH_Gen.hxx>
struct  TAlgoStateError
enum  ComputeFlags { SHAPE_ONLY = 1 , UPWARD = 2 , COMPACT_MESH = 4 , SHAPE_ONLY_UPWARD = 3 }
 SMESH_Gen ()
 ~SMESH_Gen ()
SMESH_Mesh * CreateMesh (bool theIsEmbeddedMode)
 Creates a mesh in a study. More...
SMESH_ParallelMesh * CreateParallelMesh (bool theIsEmbeddedMode)
 Creates a parallel mesh in a study. More...
bool Compute (::SMESH_Mesh &aMesh, const TopoDS_Shape &aShape, const int aFlags=COMPACT_MESH, const ::MeshDimension aDim=::MeshDim_3D, TSetOfInt *aShapesId=0, TopTools_IndexedMapOfShape *anAllowedSubShapes=0)
 Computes aMesh on aShape. More...
void PrepareCompute (::SMESH_Mesh &aMesh, const TopoDS_Shape &aShape)
 Prepare Compute a mesh. More...
void CancelCompute (::SMESH_Mesh &aMesh, const TopoDS_Shape &aShape)
const SMESH_subMesh * GetCurrentSubMesh () const
 Returns a sub-mesh being currently computed. More...
bool Evaluate (::SMESH_Mesh &aMesh, const TopoDS_Shape &aShape, MapShapeNbElems &aResMap, const bool anUpward=false, TSetOfInt *aShapesId=0)
bool CheckAlgoState (SMESH_Mesh &aMesh, const TopoDS_Shape &aShape)
void SetBoundaryBoxSegmentation (int theNbSegments)
 Sets number of segments per diagonal of boundary box of geometry by which default segment length of appropriate 1D hypotheses is defined. More...
int GetBoundaryBoxSegmentation () const
void SetDefaultNbSegments (int nb)
 Sets default number of segments per edge. More...
int GetDefaultNbSegments () const
bool GetAlgoState (SMESH_Mesh &aMesh, const TopoDS_Shape &aShape, std::list< SMESH_Gen::TAlgoStateError > &theErrors)
StudyContextStruct * GetStudyContext ()
 Returns StudyContextStruct for a study. More...
SMESH_Algo * GetAlgo (SMESH_Mesh &aMesh, const TopoDS_Shape &aShape, TopoDS_Shape *assignedTo=0)
 Finds algo to mesh a shape. More...
SMESH_Algo * GetAlgo (SMESH_subMesh *aSubMesh, TopoDS_Shape *assignedTo=0)
 Finds algo to mesh a sub-mesh. More...
int GetANewId ()
 Generate a new id unique within this Gen. More...
void send_mesh (SMESH_Mesh &aMesh, std::string filename)
bool parallelComputeSubMeshes (SMESH_Mesh &aMesh, const TopoDS_Shape &aShape, const ::MeshDimension aDim, TSetOfInt *aShapesId, TopTools_IndexedMapOfShape *allowedSubShapes, SMESH_subMesh::compute_event &computeEvent, const bool includeSelf, const bool complexShapeFirst, const bool aShapeOnly)
 Algo to run the computation of all the submeshes of a mesh in parallel. More...
bool sequentialComputeSubMeshes (SMESH_Mesh &aMesh, const TopoDS_Shape &aShape, const ::MeshDimension aDim, TSetOfInt *aShapesId, TopTools_IndexedMapOfShape *allowedSubShapes, SMESH_subMesh::compute_event &computeEvent, const bool includeSelf, const bool complexShapeFirst, const bool aShapeOnly)
 Algo to run the computation of all the submeshes of a mesh in sequentila. More...
static int GetShapeDim (const TopAbs_ShapeEnum &aShapeType)
 Return shape dimension by TopAbs_ShapeEnum. More...
static int GetShapeDim (const TopoDS_Shape &aShape)
static int GetFlatShapeDim (const TopoDS_Shape &aShape)
 Return shape dimension by exploding compounds. More...
static bool IsGlobalHypothesis (const SMESH_Hypothesis *theHyp, SMESH_Mesh &aMesh)
static std::vector< std::string > GetPluginXMLPaths ()
 Return paths to xml files of plugins. More...
void setCurrentSubMesh (SMESH_subMesh *sm)
 Sets a sub-mesh being currently computed. More...
void resetCurrentSubMesh ()
int _localId
StudyContextStruct * _studyContext
int _hypId
int _segmentation
int _nbSegments
volatile bool _compute_canceled
std::list< SMESH_subMesh * > _sm_current
◆ ComputeFlags
SHAPE_ONLY
UPWARD
COMPACT_MESH
SHAPE_ONLY_UPWARD
◆ SMESH_Gen()
SMESH_Gen::SMESH_Gen ( )
◆ ~SMESH_Gen()
SMESH_Gen::~SMESH_Gen ( )
◆ CancelCompute()
void SMESH_Gen::CancelCompute ( ::SMESH_Mesh &  aMesh,
const TopoDS_Shape &  aShape
◆ CheckAlgoState()
bool SMESH_Gen::CheckAlgoState ( SMESH_Mesh &  aMesh,
References GetAlgoState().
Referenced by SMESH_Gen_i::IsReadyToCompute().
◆ Compute()
bool SMESH_Gen::Compute ( ::SMESH_Mesh &  aMesh,
const TopoDS_Shape &  aShape,
const int  aFlags = COMPACT_MESH,
const ::MeshDimension  aDim = ::MeshDim_3D,
TSetOfInt *  aShapesId = 0,
TopTools_IndexedMapOfShape *  anAllowedSubShapes = 0
aMesh- the mesh.
aShape- the shape.
aFlags- ComputeFlags. By default compute the whole mesh and compact at the end.
aDim- upper level dimension of the mesh computation (for preview)
aShapesId- list of shapes with computed mesh entities (elements or nodes)
anAllowedSubShapes- shapes to mesh only. Mesh all if empty or nullptr
bool- true if none sub-mesh failed to compute
Referenced by StdMeshers_Prism_3D::assocOrProjBottom2Top(), SMESH_Gen_i::Compute(), StdMeshers_Import_1D::Compute(), StdMeshers_Import_1D2D::Compute(), StdMeshers_Prism_3D::computeBase(), StdMeshers_ProjectionUtils::MakeComputed(), and SMESH_Gen_i::Precompute().
◆ CreateMesh()
SMESH_Mesh * SMESH_Gen::CreateMesh ( bool  theIsEmbeddedMode)
if (theIsEmbeddedMode) { mesh modification commands are not logged }
References _localId, _studyContext, studyContextStruct::mapMesh, and studyContextStruct::myDocument.
Referenced by SMESH_Gen_i::createMesh().
◆ CreateParallelMesh()
SMESH_ParallelMesh * SMESH_Gen::CreateParallelMesh ( bool  theIsEmbeddedMode)
Referenced by SMESH_Gen_i::createParallelMesh().
◆ Evaluate()
bool SMESH_Gen::Evaluate ( ::SMESH_Mesh &  aMesh,
MapShapeNbElems &  aResMap,
const bool  anUpward = false,
aMesh- the mesh
aShape- the shape
aResMap- map for prospective numbers of elements
bool- is a success
Referenced by SMESH_Gen_i::Evaluate(), StdMeshers_Projection_1D2D::Evaluate(), and StdMeshers_Projection_2D::Evaluate().
◆ GetAlgo() [1/2]
SMESH_Algo * SMESH_Gen::GetAlgo ( SMESH_Mesh &  aMesh,
TopoDS_Shape *  assignedTo = 0
◆ GetAlgo() [2/2]
◆ GetAlgoState()
◆ GetANewId()
int SMESH_Gen::GetANewId ( )
References _hypId.
Referenced by StdMeshers_Hexa_3D::Compute(), ComputePentahedralMesh(), EvaluatePentahedralMesh(), StdMeshers_Adaptive1D::GetAlgo(), StdMeshers_Adaptive1D_i::StdMeshers_Adaptive1D_i(), StdMeshers_Arithmetic1D_i::StdMeshers_Arithmetic1D_i(), StdMeshers_AutomaticLength_i::StdMeshers_AutomaticLength_i(), StdMeshers_BlockRenumber_i::StdMeshers_BlockRenumber_i(), StdMeshers_Cartesian_3D_i::StdMeshers_Cartesian_3D_i(), StdMeshers_CartesianParameters3D_i::StdMeshers_CartesianParameters3D_i(), StdMeshers_CompositeSegment_1D_i::StdMeshers_CompositeSegment_1D_i(), StdMeshers_Deflection1D_i::StdMeshers_Deflection1D_i(), StdMeshers_FixedPoints1D_i::StdMeshers_FixedPoints1D_i(), StdMeshers_Geometric1D_i::StdMeshers_Geometric1D_i(), StdMeshers_Hexa_3D::StdMeshers_Hexa_3D(), StdMeshers_Hexa_3D_i::StdMeshers_Hexa_3D_i(), StdMeshers_Import_1D2D_i::StdMeshers_Import_1D2D_i(), StdMeshers_Import_1D_i::StdMeshers_Import_1D_i(), StdMeshers_ImportSource1D_i::StdMeshers_ImportSource1D_i(), StdMeshers_ImportSource2D_i::StdMeshers_ImportSource2D_i(), StdMeshers_LayerDistribution2D_i::StdMeshers_LayerDistribution2D_i(), StdMeshers_LayerDistribution_i::StdMeshers_LayerDistribution_i(), StdMeshers_LengthFromEdges_i::StdMeshers_LengthFromEdges_i(), StdMeshers_LocalLength_i::StdMeshers_LocalLength_i(), StdMeshers_MaxElementArea_i::StdMeshers_MaxElementArea_i(), StdMeshers_MaxElementVolume_i::StdMeshers_MaxElementVolume_i(), StdMeshers_MaxLength_i::StdMeshers_MaxLength_i(), StdMeshers_NotConformAllowed_i::StdMeshers_NotConformAllowed_i(), StdMeshers_NumberOfLayers2D_i::StdMeshers_NumberOfLayers2D_i(), StdMeshers_NumberOfLayers_i::StdMeshers_NumberOfLayers_i(), StdMeshers_NumberOfSegments_i::StdMeshers_NumberOfSegments_i(), StdMeshers_PolygonPerFace_2D_i::StdMeshers_PolygonPerFace_2D_i(), StdMeshers_PolyhedronPerSolid_3D_i::StdMeshers_PolyhedronPerSolid_3D_i(), StdMeshers_Prism_3D_i::StdMeshers_Prism_3D_i(), StdMeshers_Projection_1D2D_i::StdMeshers_Projection_1D2D_i(), StdMeshers_Projection_1D_i::StdMeshers_Projection_1D_i(), StdMeshers_Projection_2D_i::StdMeshers_Projection_2D_i(), StdMeshers_Projection_3D_i::StdMeshers_Projection_3D_i(), StdMeshers_ProjectionSource1D_i::StdMeshers_ProjectionSource1D_i(), StdMeshers_ProjectionSource2D_i::StdMeshers_ProjectionSource2D_i(), StdMeshers_ProjectionSource3D_i::StdMeshers_ProjectionSource3D_i(), StdMeshers_Propagation_i::StdMeshers_Propagation_i(), StdMeshers_PropagOfDistribution_i::StdMeshers_PropagOfDistribution_i(), StdMeshers_QuadFromMedialAxis_1D2D_i::StdMeshers_QuadFromMedialAxis_1D2D_i(), StdMeshers_Quadrangle_2D_i::StdMeshers_Quadrangle_2D_i(), StdMeshers_QuadrangleParams_i::StdMeshers_QuadrangleParams_i(), StdMeshers_QuadranglePreference_i::StdMeshers_QuadranglePreference_i(), StdMeshers_QuadraticMesh_i::StdMeshers_QuadraticMesh_i(), StdMeshers_RadialPrism_3D_i::StdMeshers_RadialPrism_3D_i(), StdMeshers_RadialQuadrangle_1D2D_i::StdMeshers_RadialQuadrangle_1D2D_i(), StdMeshers_Regular_1D_i::StdMeshers_Regular_1D_i(), StdMeshers_SegmentAroundVertex_0D_i::StdMeshers_SegmentAroundVertex_0D_i(), StdMeshers_SegmentLengthAroundVertex_i::StdMeshers_SegmentLengthAroundVertex_i(), StdMeshers_StartEndLength_i::StdMeshers_StartEndLength_i(), StdMeshers_UseExisting_1D_i::StdMeshers_UseExisting_1D_i(), StdMeshers_UseExisting_2D_i::StdMeshers_UseExisting_2D_i(), StdMeshers_ViscousLayerBuilder_i::StdMeshers_ViscousLayerBuilder_i(), StdMeshers_ViscousLayers2D_i::StdMeshers_ViscousLayers2D_i(), and StdMeshers_ViscousLayers_i::StdMeshers_ViscousLayers_i().
◆ GetBoundaryBoxSegmentation()
int SMESH_Gen::GetBoundaryBoxSegmentation ( ) const
◆ GetCurrentSubMesh()
const SMESH_subMesh * SMESH_Gen::GetCurrentSubMesh ( ) const
References _sm_current.
Referenced by SMESH_Mesh::GetComputeProgress().
◆ GetDefaultNbSegments()
int SMESH_Gen::GetDefaultNbSegments ( ) const
◆ GetFlatShapeDim()
int SMESH_Gen::GetFlatShapeDim ( const TopoDS_Shape &  aShape)
References GetFlatShapeDim(), and GetShapeDim().
Referenced by GetFlatShapeDim().
◆ GetPluginXMLPaths()
std::vector< std::string > SMESH_Gen::GetPluginXMLPaths ( )
References env_sep.
Referenced by _pyHypothesisReader::_pyHypothesisReader(), and SMESH_Algo::GetFeatures().
◆ GetShapeDim() [1/2]
◆ GetShapeDim() [2/2]
static int SMESH_Gen::GetShapeDim ( const TopoDS_Shape &  aShape)
◆ GetStudyContext()
◆ IsGlobalHypothesis()
bool SMESH_Gen::IsGlobalHypothesis ( const SMESH_Hypothesis *  theHyp,
SMESH_Mesh &  aMesh
◆ parallelComputeSubMeshes()
◆ PrepareCompute()
void SMESH_Gen::PrepareCompute ( ::SMESH_Mesh &  aMesh,
References _compute_canceled, and resetCurrentSubMesh().
Referenced by SMESH_Gen_i::Compute().
◆ resetCurrentSubMesh()
void SMESH_Gen::resetCurrentSubMesh ( )
Referenced by PrepareCompute().
◆ send_mesh()
void SMESH_Gen::send_mesh ( SMESH_Mesh &  aMesh,
◆ sequentialComputeSubMeshes()
bool SMESH_Gen::sequentialComputeSubMeshes ( SMESH_Mesh &  aMesh,
TSetOfInt *  aShapesId,
TopTools_IndexedMapOfShape *  allowedSubShapes,
SMESH_subMesh::compute_event &  computeEvent,
◆ SetBoundaryBoxSegmentation()
void SMESH_Gen::SetBoundaryBoxSegmentation ( int  theNbSegments)
Referenced by SMESH_Gen_i::SetBoundaryBoxSegmentation().
◆ setCurrentSubMesh()
void SMESH_Gen::setCurrentSubMesh ( SMESH_subMesh *  sm)
An algorithm can call Compute() for a sub-shape, hence we keep a stack of sub-meshes
Referenced by sequentialComputeSubMeshes().
◆ SetDefaultNbSegments()
void SMESH_Gen::SetDefaultNbSegments ( int  nb)
Referenced by SMESH_Gen_i::SetDefaultNbSegments().
◆ _compute_canceled
volatile bool SMESH_Gen::_compute_canceled
◆ _hypId
int SMESH_Gen::_hypId
Referenced by GetANewId(), and SMESH_Gen().
◆ _localId
int SMESH_Gen::_localId
◆ _nbSegments
int SMESH_Gen::_nbSegments
Referenced by SMESH_Gen().
◆ _segmentation
int SMESH_Gen::_segmentation
◆ _sm_current
std::list< SMESH_subMesh* > SMESH_Gen::_sm_current
◆ _studyContext
StudyContextStruct* SMESH_Gen::_studyContext
