StdMeshers_Hexa_3D Class Reference
#include <StdMeshers_Hexa_3D.hxx>
Inheritance diagram for StdMeshers_Hexa_3D:
enum  Hypothesis_Status {
enum  hypothesis_type {
  ALGO_3D
 StdMeshers_Hexa_3D (int hypId, SMESH_Gen *gen)
virtual ~StdMeshers_Hexa_3D ()
 Retrieves defined hypotheses. More...
 Generates hexahedron mesh on hexaedron like form using algorithm from "Application de l'interpolation transfinie � la cr�ation de maillages C0 ou G1 continus sur des triangles, quadrangles, tetraedres, pentaedres et hexaedres d�form�s. More...
 Computes hexahedral mesh from 2D mesh of block. More...
 Evaluate. More...
virtual void CancelCompute ()
 return compute error More...
void InitComputeError ()
bool OnlyUnaryInput () const
bool NeedShape () const
virtual int GetDim () const
SMESH_Gen * GetGen () const
const char * GetName () const
int GetID () const
int GetType () const
 Equality. More...
static bool IsApplicable (const TopoDS_Shape &aShape, bool toCheckAll)
 Return true if the algorithm can mesh this shape. More...
const StdMeshers_ViscousLayers * _viscousLayersHyp
const StdMeshers_BlockRenumber * _blockRenumberHyp
StdMeshers_Quadrangle_2D * _quadAlgo
bool _onlyUnaryInput
bool _requireDiscreteBoundary
bool _requireShape
bool _supportSubmeshes
bool _neededLowerHyps [4]
bool _quadraticMesh
int _error
std::string _comment
const SMDS_Mesh * _mesh
double _progress
int _progressTic
SMESH_Gen * _gen
int _shapeType
int _param_algo_dim
int _hypId
hypothesis_type _type
std::string _libName
◆ EMeshError
enum SMESH_Algo::EMeshError
MEr_OK
MEr_HOLES
MEr_BAD_ORI
MEr_EMPTY
◆ Hypothesis_Status
HYP_OK
HYP_MISSING
HYP_CONCURRENT
HYP_BAD_PARAMETER
HYP_HIDDEN_ALGO
HYP_HIDING_ALGO
HYP_UNKNOWN_FATAL
HYP_INCOMPATIBLE
HYP_NOTCONFORM
HYP_ALREADY_EXIST
HYP_BAD_DIM
HYP_BAD_SUBSHAPE
HYP_BAD_GEOMETRY
HYP_NEED_SHAPE
HYP_INCOMPAT_HYPS
◆ hypothesis_type
PARAM_ALGO
ALGO_0D
ALGO_1D
ALGO_2D
ALGO_3D
◆ InitWay
BY_MESH
BY_GEOM
BY_AVERAGE_LENGTH
◆ StdMeshers_Hexa_3D()
◆ ~StdMeshers_Hexa_3D()
StdMeshers_Hexa_3D::~StdMeshers_Hexa_3D ( )
References _quadAlgo.
◆ addBadInputElement()
◆ addBadInputElements()
const bool  addNodes = false
◆ CancelCompute()
◆ CheckHypothesis()
◆ Compute() [1/2]
bool StdMeshers_Hexa_3D::Compute ( SMESH_Mesh &  aMesh,
const TopoDS_Shape &  aShape
" Alain PERONNET - 8 janvier 1999
Implements SMESH_Algo.
References _blockRenumberHyp, SMESH_Hypothesis::_gen, _quadAlgo, SMESH_Algo::_quadraticMesh, _viscousLayersHyp, SMESH_MesherHelper::AddNode(), StdMeshers_RenumberHelper::AddReplacingNode(), SMESH_MesherHelper::AddVolume(), B_BACK, B_BOTTOM, B_FRONT, B_LEFT, B_RIGHT, B_TOP, StdMeshers_BlockRenumber::CheckHypothesis(), StdMeshers_Quadrangle_2D::CheckNbEdges(), SMESHDS_Mesh::CompactMesh(), COMPERR_BAD_SHAPE, StdMeshers_CompositeHexa_3D::Compute(), StdMeshers_ViscousLayers::Compute(), ComputePentahedralMesh(), COO_X, COO_Y, COO_Z, StdMeshers_RenumberHelper::DoReplaceNodes(), SMESH_Algo::error(), SMESHUtils::FreeVector(), SMESH_Gen::GetANewId(), SMESH_Algo::GetComputeError(), SMESH_Mesh::GetMeshDS(), SMDS_MeshElement::GetNode(), SMESH_MesherHelper::GetNodeU(), SMESH_Block::ID_E00z, SMESH_Block::ID_E01z, SMESH_Block::ID_E0y0, SMESH_Block::ID_E0y1, SMESH_Block::ID_E10z, SMESH_Block::ID_E11z, SMESH_Block::ID_E1y0, SMESH_Block::ID_E1y1, SMESH_Block::ID_Ex00, SMESH_Block::ID_Ex01, SMESH_Block::ID_Ex10, SMESH_Block::ID_Ex11, SMESH_Block::ID_F0yz, SMESH_Block::ID_F1yz, SMESH_Block::ID_Fx0z, SMESH_Block::ID_Fx1z, SMESH_Block::ID_Fxy0, SMESH_Block::ID_Fxy1, SMESH_Block::ID_Shell, SMESH_Block::ID_V000, SMESH_Block::ID_V001, SMESH_Block::ID_V010, SMESH_Block::ID_V011, SMESH_Block::ID_V100, SMESH_Block::ID_V101, SMESH_Block::ID_V110, SMESH_Block::ID_V111, SMESH_MesherHelper::IsQuadraticSubMesh(), SMESH_MesherHelper::IsSameElemGeometry(), StdMeshers_BlockRenumber::IsSolidIncluded(), SMESH_MesherHelper::LoadNodeColumns(), SMESHDS_Mesh::MeshElements(), SMDS_Mesh::Modified(), SMESHDS_SubMesh::NbElements(), SMESH_Mesh::NbTriangles(), Q_BOTTOM, SMESH_MesherHelper::SetElementsOnShape(), StdMeshers_CompositeHexa_3D::SetHypothesis(), SMESHDS_Mesh::SetNodeOnStructuredGrid(), SMESHDS_Mesh::SetStructuredGrid(), SMESH_MesherHelper::SetSubShape(), SMESH_Block::ShellPoint(), SMDSGeom_QUADRANGLE, and SMESH_MesherHelper::ToFixNodeParameters().
◆ Compute() [2/2]
SMESH_MesherHelper *  aHelper
◆ Continuity()
const TopoDS_Edge &  theE2
E1- the 1st edge
E2- the 2nd edge
References OCC_CATCH_SIGNALS.
◆ DataDependOnParams()
◆ EdgeLength()
◆ error() [1/3]
◆ error() [2/3]
Referenced by StdMeshers_Quadrangle_2D::addEnforcedNodes(), StdMeshers_Prism_3D::assocOrProjBottom2Top(), StdMeshers_Quadrangle_2D::CheckHypothesis(), CheckHypothesis(), StdMeshers_PolyhedronPerSolid_3D::CheckHypothesis(), StdMeshers_Projection_2D::CheckHypothesis(), StdMeshers_Quadrangle_2D::CheckNbEdges(), StdMeshers_Quadrangle_2D::checkNbEdgesForEvaluate(), StdMeshers_Prism_3D::compute(), StdMeshers_Cartesian_3D::Compute(), StdMeshers_CompositeHexa_3D::Compute(), StdMeshers_CompositeSegment_1D::Compute(), Compute(), StdMeshers_Import_1D::Compute(), StdMeshers_Import_1D2D::Compute(), StdMeshers_PolygonPerFace_2D::Compute(), StdMeshers_Prism_3D::Compute(), StdMeshers_Projection_1D::Compute(), StdMeshers_Projection_1D2D::Compute(), StdMeshers_Projection_2D::Compute(), StdMeshers_Projection_3D::Compute(), StdMeshers_QuadFromMedialAxis_1D2D::Compute(), StdMeshers_Quadrangle_2D::Compute(), StdMeshers_RadialPrism_3D::Compute(), StdMeshers_RadialQuadrangle_1D2D::Compute(), SMESH_Algo::Compute(), StdMeshers_HexaFromSkin_3D::Compute(), TNodeDistributor::Compute(), StdMeshers_Prism_3D::computeBase(), StdMeshers_RadialPrism_3D::computeLayerPositions(), StdMeshers_RadialQuadrangle_1D2D::computeLayerPositions(), StdMeshers_Quadrangle_2D::computeQuadDominant(), StdMeshers_Quadrangle_2D::computeQuadPref(), StdMeshers_Quadrangle_2D::computeReduced(), StdMeshers_Prism_3D::computeWalls(), SMESH_Algo::error(), StdMeshers_HexaFromSkin_3D::Evaluate(), StdMeshers_Import_1D::Evaluate(), StdMeshers_Import_1D2D::Evaluate(), StdMeshers_PolygonPerFace_2D::Evaluate(), StdMeshers_Prism_3D::Evaluate(), StdMeshers_Projection_1D::Evaluate(), StdMeshers_Projection_1D2D::Evaluate(), StdMeshers_Projection_2D::Evaluate(), StdMeshers_Projection_3D::Evaluate(), StdMeshers_CompositeHexa_3D::findBoxFaces(), StdMeshers_Quadrangle_2D::getCorners(), StdMeshers_Quadrangle_2D::getEnforcedUV(), SMESH_Algo::GetFeatures(), StdMeshers_ViscousLayerBuilder::GetShrinkGeometry(), StdMeshers_Prism_3D::getWallFaces(), StdMeshers_Prism_3D::initPrism(), StdMeshers_Prism_3D::projectBottomToTop(), and StdMeshers_Quadrangle_2D::setNormalizedGrid().
◆ error() [3/3]
◆ Evaluate()
◆ GetAssignedShapes()
◆ GetCompatibleHypoFilter()
◆ GetCompatibleHypothesis()
◆ GetComputeError()
◆ GetDim()
◆ GetFeatures() [1/2]
◆ GetFeatures() [2/2]
◆ GetGen()
◆ GetID()
◆ GetLibName()
◆ GetMeshByPersistentID()
◆ GetMeshError()
◆ GetName()
◆ GetNodeParamOnEdge()
const TopoDS_Edge &  theEdge,
Warning
◆ GetProgress()
◆ GetProgressByTic()
◆ GetShapeType()
◆ GetSortedNodesOnEdge()
theNodes- The resulting map
Warning
◆ GetType()
◆ GetUsedHypothesis()
const TopoDS_Shape &  aShape,
aMesh- the mesh
aShape- the shape
Referenced by StdMeshers_Cartesian_3D::CheckHypothesis(), StdMeshers_QuadFromMedialAxis_1D2D::CheckHypothesis(), StdMeshers_Quadrangle_2D::CheckHypothesis(), CheckHypothesis(), StdMeshers_Import_1D::CheckHypothesis(), StdMeshers_Import_1D2D::CheckHypothesis(), StdMeshers_PolyhedronPerSolid_3D::CheckHypothesis(), StdMeshers_Projection_1D::CheckHypothesis(), StdMeshers_Projection_2D::CheckHypothesis(), StdMeshers_Projection_3D::CheckHypothesis(), StdMeshers_RadialPrism_3D::CheckHypothesis(), StdMeshers_RadialQuadrangle_1D2D::CheckHypothesis(), StdMeshers_SegmentAroundVertex_0D::CheckHypothesis(), SMESH_subMesh::ComputeStateEngine(), VISCOUS_2D::_ViscousBuilder2D::findEdgesWithLayers(), VISCOUS_3D::_ViscousBuilder::findSolidsWithLayers(), SMESH_subMesh::getCollection(), StdMeshers_CompositeSegment_1D::GetFaceSide(), StdMeshers_Regular_1D::GetUsedHypothesis(), StdMeshers_Regular_1D::getVertexHyp(), and StdMeshers_ProjectionUtils::MakeComputed().
◆ InitComputeError()
◆ IsApplicable()
bool StdMeshers_Hexa_3D::IsApplicable ( const TopoDS_Shape &  aShape,
bool  toCheckAll
[in]aShape- shape to check
References SMESH_MesherHelper::Count().
◆ IsApplicableToShape()
virtual bool StdMeshers_Hexa_3D::IsApplicableToShape ( const TopoDS_Shape &  shape,
bool  toCheckAll
bool- true by default
Reimplemented from SMESH_3D_Algo.
References SMESH::IsApplicable().
◆ IsAuxiliary()
bool- auxiliary or not
◆ IsContinuous()
const TopoDS_Edge &  E2
◆ isDegenerated()
◆ IsSameName()
◆ IsStatusFatal()
◆ IsStraight()
◆ LoadFrom()
load- the stream
std::ostream& - the stream
◆ LoadStringFromStream()
std::string &  txt
◆ NeedDiscreteBoundary()
◆ NeedLowerHyps()
◆ NeedShape()
Referenced by SMESH_Hypothesis_i::LoadFrom(), StdMeshers_CartesianParameters3D::SetAxisDirs(), StdMeshers_BlockRenumber::SetBlocksOrientation(), StdMeshers_ViscousLayers::SetBndShapes(), StdMeshers_Geometric1D::SetCommonRatio(), StdMeshers_ImportSource1D::SetCopySourceMesh(), StdMeshers_Adaptive1D::SetDeflection(), StdMeshers_Deflection1D::SetDeflection(), StdMeshers_QuadrangleParams::SetEnforcedNodes(), StdMeshers_AutomaticLength::SetFineness(), StdMeshers_CartesianParameters3D::SetFixedPoint(), StdMeshers_CartesianParameters3D::SetGrid(), StdMeshers_CartesianParameters3D::SetGridSpacing(), StdMeshers_ViscousLayers::SetGroupName(), StdMeshers_ImportSource1D::SetGroups(), StdMeshers_LayerDistribution::SetLayerDistribution(), StdMeshers_LocalLength::SetLength(), StdMeshers_MaxLength::SetLength(), StdMeshers_SegmentLengthAroundVertex::SetLength(), StdMeshers_Arithmetic1D::SetLength(), StdMeshers_StartEndLength::SetLength(), StdMeshers_MaxElementArea::SetMaxArea(), StdMeshers_Adaptive1D::SetMaxSize(), StdMeshers_MaxElementVolume::SetMaxVolume(), StdMeshers_ViscousLayers::SetMethod(), StdMeshers_Adaptive1D::SetMinSize(), StdMeshers_LengthFromEdges::SetMode(), StdMeshers_FixedPoints1D::SetNbSegments(), StdMeshers_ViscousLayers::SetNumberLayers(), StdMeshers_NumberOfLayers::SetNumberOfLayers(), StdMeshers_FixedPoints1D::SetPoints(), StdMeshers_LocalLength::SetPrecision(), StdMeshers_QuadrangleParams::SetQuadType(), StdMeshers_CartesianParameters3D::SetQuanta(), StdMeshers_Reversible1D::SetReversedEdges(), StdMeshers_CartesianParameters3D::SetSizeThreshold(), StdMeshers_ProjectionSource3D::SetSource3DShape(), StdMeshers_ProjectionSource1D::SetSourceEdge(), StdMeshers_ProjectionSource2D::SetSourceFace(), StdMeshers_ProjectionSource1D::SetSourceMesh(), StdMeshers_ProjectionSource2D::SetSourceMesh(), StdMeshers_ProjectionSource3D::SetSourceMesh(), StdMeshers_Geometric1D::SetStartLength(), StdMeshers_ViscousLayers::SetStretchFactor(), StdMeshers_CartesianParameters3D::SetToAddEdges(), StdMeshers_CartesianParameters3D::SetToConsiderInternalFaces(), StdMeshers_CartesianParameters3D::SetToCreateFaces(), StdMeshers_ViscousLayers::SetTotalThickness(), StdMeshers_CartesianParameters3D::SetToUseQuanta(), StdMeshers_CartesianParameters3D::SetToUseThresholdForInternalFaces(), StdMeshers_QuadrangleParams::SetTriaVertex(), StdMeshers_ProjectionSource1D::SetVertexAssociation(), StdMeshers_ProjectionSource2D::SetVertexAssociation(), and StdMeshers_ProjectionSource3D::SetVertexAssociation().
◆ NumberOfPoints()
const TopoDS_Wire &  W
◆ OnlyUnaryInput()
◆ operator!=()
◆ operator==()
Equality.
◆ SaveStringToStream()
const std::string &  txt
◆ SaveTo()
save- the stream
◆ SetEventListener()
void SMESH_Algo::SetEventListener ( SMESH_subMesh *  subMesh)
This method is called when a submesh gets HYP_OK algo_state. After being set, event listener is notified on each event of a submesh. By default none listener is set
After being set, event listener is notified on each event of a submesh. By default non listener is set
Reimplemented in StdMeshers_Cartesian_3D, StdMeshers_CompositeSegment_1D, StdMeshers_Import_1D, StdMeshers_Import_1D2D, StdMeshers_QuadFromMedialAxis_1D2D, StdMeshers_RadialQuadrangle_1D2D, StdMeshers_Regular_1D, StdMeshers_Projection_1D, StdMeshers_Projection_1D2D, StdMeshers_Projection_2D, and StdMeshers_Projection_3D.
Referenced by SMESH_subMesh::AlgoStateEngine().
◆ SetLibName()
◆ SetParametersByDefaults()
Implements SMESH_Hypothesis.
◆ SetParametersByMesh()
◆ setSubMeshesToCompute()
◆ SubMeshesToCompute()
◆ SubmeshRestored()
subMesh- restored submesh
◆ SupportSubmeshes()
◆ VertexNode() [1/3]
const SMESH_Mesh *  mesh
V- the vertex
mesh- mesh
◆ VertexNode() [2/3]
◆ VertexNode() [3/3]
const SMESH_Mesh *  mesh,
const bool  checkV = true
V- the vertex
mesh- the mesh
V- the vertex
◆ _assigedShapeList
◆ _badInputElements
◆ _blockRenumberHyp
const StdMeshers_BlockRenumber* StdMeshers_Hexa_3D::_blockRenumberHyp
Referenced by CheckHypothesis(), and Compute().
◆ _comment
◆ _compatibleAllHypFilter
◆ _compatibleHypothesis
◆ _compatibleNoAuxHypFilter
◆ _computeCanceled
◆ _error
int SMESH_Algo::_error
◆ _gen
◆ _hypId
◆ _libName
privateinherited
◆ _mesh
◆ _name
Referenced by SMESHDS_Hypothesis::GetName(), SMESHDS_Hypothesis::IsSameName(), SMESHDS_Hypothesis::operator==(), SMESHDS_Hypothesis::SMESHDS_Hypothesis(), StdMeshers_Adaptive1D::StdMeshers_Adaptive1D(), StdMeshers_Arithmetic1D::StdMeshers_Arithmetic1D(), StdMeshers_AutomaticLength::StdMeshers_AutomaticLength(), StdMeshers_BlockRenumber::StdMeshers_BlockRenumber(), StdMeshers_Cartesian_3D::StdMeshers_Cartesian_3D(), StdMeshers_CartesianParameters3D::StdMeshers_CartesianParameters3D(), StdMeshers_CompositeHexa_3D::StdMeshers_CompositeHexa_3D(), StdMeshers_CompositeSegment_1D::StdMeshers_CompositeSegment_1D(), StdMeshers_Deflection1D::StdMeshers_Deflection1D(), StdMeshers_FixedPoints1D::StdMeshers_FixedPoints1D(), StdMeshers_Geometric1D::StdMeshers_Geometric1D(), StdMeshers_Hexa_3D(), StdMeshers_HexaFromSkin_3D::StdMeshers_HexaFromSkin_3D(), StdMeshers_Import_1D::StdMeshers_Import_1D(), StdMeshers_Import_1D2D::StdMeshers_Import_1D2D(), StdMeshers_ImportSource1D::StdMeshers_ImportSource1D(), StdMeshers_ImportSource2D::StdMeshers_ImportSource2D(), StdMeshers_LayerDistribution::StdMeshers_LayerDistribution(), StdMeshers_LayerDistribution2D::StdMeshers_LayerDistribution2D(), StdMeshers_LengthFromEdges::StdMeshers_LengthFromEdges(), StdMeshers_LocalLength::StdMeshers_LocalLength(), StdMeshers_MaxElementArea::StdMeshers_MaxElementArea(), StdMeshers_MaxElementVolume::StdMeshers_MaxElementVolume(), StdMeshers_MaxLength::StdMeshers_MaxLength(), StdMeshers_NotConformAllowed::StdMeshers_NotConformAllowed(), StdMeshers_NumberOfLayers::StdMeshers_NumberOfLayers(), StdMeshers_NumberOfLayers2D::StdMeshers_NumberOfLayers2D(), StdMeshers_NumberOfSegments::StdMeshers_NumberOfSegments(), StdMeshers_PolygonPerFace_2D::StdMeshers_PolygonPerFace_2D(), StdMeshers_PolyhedronPerSolid_3D::StdMeshers_PolyhedronPerSolid_3D(), StdMeshers_Prism_3D::StdMeshers_Prism_3D(), StdMeshers_Projection_1D::StdMeshers_Projection_1D(), StdMeshers_Projection_1D2D::StdMeshers_Projection_1D2D(), StdMeshers_Projection_2D::StdMeshers_Projection_2D(), StdMeshers_Projection_3D::StdMeshers_Projection_3D(), StdMeshers_ProjectionSource1D::StdMeshers_ProjectionSource1D(), StdMeshers_ProjectionSource2D::StdMeshers_ProjectionSource2D(), StdMeshers_ProjectionSource3D::StdMeshers_ProjectionSource3D(), StdMeshers_Propagation::StdMeshers_Propagation(), StdMeshers_PropagOfDistribution::StdMeshers_PropagOfDistribution(), StdMeshers_QuadFromMedialAxis_1D2D::StdMeshers_QuadFromMedialAxis_1D2D(), StdMeshers_Quadrangle_2D::StdMeshers_Quadrangle_2D(), StdMeshers_QuadrangleParams::StdMeshers_QuadrangleParams(), StdMeshers_QuadranglePreference::StdMeshers_QuadranglePreference(), StdMeshers_QuadraticMesh::StdMeshers_QuadraticMesh(), StdMeshers_RadialPrism_3D::StdMeshers_RadialPrism_3D(), StdMeshers_RadialQuadrangle_1D2D::StdMeshers_RadialQuadrangle_1D2D(), StdMeshers_Regular_1D::StdMeshers_Regular_1D(), StdMeshers_SegmentAroundVertex_0D::StdMeshers_SegmentAroundVertex_0D(), StdMeshers_SegmentLengthAroundVertex::StdMeshers_SegmentLengthAroundVertex(), StdMeshers_StartEndLength::StdMeshers_StartEndLength(), StdMeshers_UseExisting_1D::StdMeshers_UseExisting_1D(), StdMeshers_UseExisting_2D::StdMeshers_UseExisting_2D(), StdMeshers_ViscousLayerBuilder::StdMeshers_ViscousLayerBuilder(), StdMeshers_ViscousLayers::StdMeshers_ViscousLayers(), and StdMeshers_ViscousLayers2D::StdMeshers_ViscousLayers2D().
◆ _neededLowerHyps
◆ _onlyUnaryInput
◆ _param_algo_dim
◆ _progress
double SMESH_Algo::_progress
◆ _progressTic
int SMESH_Algo::_progressTic
◆ _quadAlgo
StdMeshers_Quadrangle_2D* StdMeshers_Hexa_3D::_quadAlgo
◆ _quadraticMesh
◆ _requireDiscreteBoundary
◆ _requireShape
◆ _shapeType
◆ _smToCompute
◆ _supportSubmeshes
◆ _type
◆ _usedHypList
◆ _viscousLayersHyp
const StdMeshers_ViscousLayers* StdMeshers_Hexa_3D::_viscousLayersHyp
