SMESH_Block Class Reference
#include <SMESH_Block.hxx>
Inheritance diagram for SMESH_Block:
class  TEdge
class  TFace
enum  TShapeID {
  ID_NONE = 0 , ID_V000 = 1 , ID_V100 , ID_V010 ,
  ID_V110 , ID_V001 , ID_V101 , ID_V011 ,
  ID_V111 , ID_Ex00 , ID_Ex10 , ID_Ex01 ,
  ID_Ex11 , ID_E0y0 , ID_E1y0 , ID_E0y1 ,
  ID_E1y1 , ID_E00z , ID_E10z , ID_E01z ,
  ID_E11z , ID_Fxy0 , ID_Fxy1 , ID_Fx0z ,
  ID_Fx1z , ID_F0yz , ID_F1yz , ID_Shell ,
  ID_FirstV = ID_V000 , ID_FirstE = ID_Ex00 , ID_FirstF = ID_Fxy0
 SMESH_Block ()
bool LoadBlockShapes (const TopoDS_Shell &theShell, const TopoDS_Vertex &theVertex000, const TopoDS_Vertex &theVertex001, TopTools_IndexedMapOfOrientedShape &theShapeIDMap)
bool LoadBlockShapes (const TopTools_IndexedMapOfOrientedShape &theShapeIDMap)
 Initialize block geometry with shapes from theShapeIDMap. More...
bool LoadMeshBlock (const SMDS_MeshVolume *theVolume, const int theNode000Index, const int theNode001Index, std::vector< const SMDS_MeshNode * > &theOrderedNodes)
bool LoadFace (const TopoDS_Face &theFace, const int theFaceID, const TopTools_IndexedMapOfOrientedShape &theShapeIDMap)
 Load face geometry. More...
bool VertexPoint (const int theVertexID, gp_XYZ &thePoint) const
bool EdgePoint (const int theEdgeID, const gp_XYZ &theParams, gp_XYZ &thePoint) const
bool EdgeU (const int theEdgeID, const gp_XYZ &theParams, double &theU) const
bool FacePoint (const int theFaceID, const gp_XYZ &theParams, gp_XYZ &thePoint) const
bool FaceUV (const int theFaceID, const gp_XYZ &theParams, gp_XY &theUV) const
bool ShellPoint (const gp_XYZ &theParams, gp_XYZ &thePoint) const
bool ComputeParameters (const gp_Pnt &thePoint, gp_XYZ &theParams, const int theShapeID=ID_Shell, const gp_XYZ &theParamsHint=gp_XYZ(-1,-1,-1))
bool VertexParameters (const int theVertexID, gp_XYZ &theParams)
bool EdgeParameters (const int theEdgeID, const double theU, gp_XYZ &theParams)
void SetTolerance (const double tol)
double GetTolerance () const
bool IsToleranceReached () const
double DistanceReached () const
Standard_Integer NbVariables () const
Standard_Integer NbEquations () const
Standard_Boolean Value (const math_Vector &X, math_Vector &F)
Standard_Boolean Derivatives (const math_Vector &X, math_Matrix &D)
Standard_Boolean Values (const math_Vector &X, math_Vector &F, math_Matrix &D)
Standard_Integer GetStateNumber ()
static int NbVertices ()
static int NbEdges ()
static int NbFaces ()
static int NbSubShapes ()
static bool IsVertexID (int theShapeID)
static bool IsEdgeID (int theShapeID)
static bool IsFaceID (int theShapeID)
static int ShapeIndex (int theShapeID)
static void GetFaceEdgesIDs (const int faceID, std::vector< int > &edgeVec)
static void GetEdgeVertexIDs (const int edgeID, std::vector< int > &vertexVec)
static int GetCoordIndOnEdge (const int theEdgeID)
static double * GetShapeCoef (const int theShapeID)
static int GetShapeIDByParams (const gp_XYZ &theParams)
static std::ostream & DumpShapeID (const int theBlockShapeID, std::ostream &stream)
static bool Insert (const TopoDS_Shape &theShape, const int theShapeID, TopTools_IndexedMapOfOrientedShape &theShapeIDMap)
 / Insert theShape into theShapeIDMap with theShapeID More...
static bool FindBlockShapes (const TopoDS_Shell &theShell, const TopoDS_Vertex &theVertex000, const TopoDS_Vertex &theVertex001, TopTools_IndexedMapOfOrientedShape &theShapeIDMap)
static bool ShellPoint (const gp_XYZ &theParams, const std::vector< gp_XYZ > &thePointOnShape, gp_XYZ &thePoint)
static bool IsForwardEdge (const TopoDS_Edge &theEdge, const TopTools_IndexedMapOfOrientedShape &theShapeIDMap)
static int GetOrderedEdges (const TopoDS_Face &theFace, std::list< TopoDS_Edge > &theEdges, std::list< int > &theNbEdgesInWires, TopoDS_Vertex theFirstVertex=TopoDS_Vertex(), const bool theShapeAnalysisAlgo=false)
 Return number of wires and a list of oredered edges. More...
Protected Types
enum  { SQUARE_DIST = 0 , DRV_1 , DRV_2 , DRV_3 }
typedef std::pair< gp_XYZ, gp_XYZ > TxyzPair
void init ()
 Call it after geometry initialization. More...
double distance () const
double funcValue (double sqDist) const
bool computeParameters (const gp_Pnt &thePoint, gp_XYZ &theParams, const gp_XYZ &theParamsHint, int)
void refineParametersOnFace (const gp_Pnt &thePoint, gp_XYZ &theParams, int theFaceID)
 Find more precise solution. More...
bool findUVByHalfDivision (const gp_Pnt &thePoint, const gp_XY &theUV, const TFace &tface, gp_XYZ &theParams)
 Finds parameters corresponding to a given UV of a given face using half-division. More...
bool findUVAround (const gp_Pnt &thePoint, const gp_XY &theUV, const TFace &tface, gp_XYZ &theParams, int nbGetWorstLimit)
 Find parameters corresponding to a given UV of a given face by searching around the starting solution. More...
bool saveBetterSolution (const gp_XYZ &theNewParams, gp_XYZ &theParams, double sqDistance)
 Store a solution if it's better than a previous one. More...
gp_XYZ myPnt [8]
TEdge myEdge [12]
TFace myFace [6]
int myFaceIndex
double myFaceParam
int myNbIterations
double mySumDist
double myTolerance
bool mySquareFunc
gp_XYZ myPoint
gp_XYZ myParam
double myValues [4]
TxyzPair my3x3x3GridNodes [1000]
bool myGridComputed
◆ TxyzPair
typedef std::pair<gp_XYZ,gp_XYZ> SMESH_Block::TxyzPair
◆ anonymous enum
anonymous enum
SQUARE_DIST
DRV_1
DRV_2
DRV_3
◆ TShapeID
ID_NONE
ID_V000
ID_V100
ID_V010
ID_V110
ID_V001
ID_V101
ID_V011
ID_V111
ID_Ex00
ID_Ex10
ID_Ex01
ID_Ex11
ID_E0y0
ID_E1y0
ID_E0y1
ID_E1y1
ID_E00z
ID_E10z
ID_E01z
ID_E11z
ID_Fxy0
ID_Fxy1
ID_Fx0z
ID_Fx1z
ID_F0yz
ID_F1yz
ID_Shell
ID_FirstV
ID_FirstE
ID_FirstF
◆ SMESH_Block()
SMESH_Block::SMESH_Block ( )
◆ computeParameters()
bool SMESH_Block::computeParameters ( const gp_Pnt &  thePoint,
gp_XYZ &  theParams,
const gp_XYZ &  theParamsHint,
int  theShapeID
◆ ComputeParameters()
◆ Derivatives()
Standard_Boolean SMESH_Block::Derivatives ( const math_Vector &  X,
math_Matrix &  D
References Values().
◆ distance()
◆ DistanceReached()
double SMESH_Block::DistanceReached ( ) const
◆ DumpShapeID()
ostream & SMESH_Block::DumpShapeID ( const int  theBlockShapeID,
std::ostream &  stream
◆ EdgeParameters()
bool SMESH_Block::EdgeParameters ( const int  theEdgeID,
const double  theU,
gp_XYZ &  theParams
◆ EdgePoint()
bool SMESH_Block::EdgePoint ( const int  theEdgeID,
const gp_XYZ &  theParams,
gp_XYZ &  thePoint
◆ EdgeU()
bool SMESH_Block::EdgeU ( const int  theEdgeID,
double &  theU
◆ FacePoint()
bool SMESH_Block::FacePoint ( const int  theFaceID,
gp_XYZ &  thePoint
◆ FaceUV()
bool SMESH_Block::FaceUV ( const int  theFaceID,
gp_XY &  theUV
◆ FindBlockShapes()
bool SMESH_Block::FindBlockShapes ( const TopoDS_Shell &  theShell,
const TopoDS_Vertex &  theVertex000,
const TopoDS_Vertex &  theVertex001,
TopTools_IndexedMapOfOrientedShape &  theShapeIDMap
◆ findUVAround()
bool SMESH_Block::findUVAround ( const gp_Pnt &  thePoint,
const gp_XY &  theUV,
const TFace &  tface,
gp_XYZ &  theParams,
int  nbGetWorstLimit
[in]theUV- the UV to locate
[in]tface- the face
[in,out]theParams- the starting parameters to improve
[in]nbGetWorstLimit- nb of steps from the starting solution w/o improvement to stop searching in this direction
bool - true if found solution is within myTolerance
References distance(), SMESH_Block::TFace::GetUInd(), SMESH_Block::TFace::GetVInd(), SMESH_Block::TFace::Point(), and saveBetterSolution().
Referenced by refineParametersOnFace().
◆ findUVByHalfDivision()
bool SMESH_Block::findUVByHalfDivision ( const gp_Pnt &  thePoint,
gp_XYZ &  theParams
[in]tface- the face
References distance(), SMESH_Block::TFace::GetUInd(), SMESH_Block::TFace::GetVInd(), SMESH_Block::TFace::IsUVInQuad(), SMESH_Block::TFace::Point(), and saveBetterSolution().
◆ funcValue()
double SMESH_Block::funcValue ( double  sqDist) const
Referenced by Value(), and Values().
◆ GetCoordIndOnEdge()
static int SMESH_Block::GetCoordIndOnEdge ( const int  theEdgeID)
◆ GetEdgeVertexIDs()
◆ GetFaceEdgesIDs()
◆ GetOrderedEdges()
int SMESH_Block::GetOrderedEdges ( const TopoDS_Face &  theFace,
std::list< TopoDS_Edge > &  theEdges,
std::list< int > &  theNbEdgesInWires,
TopoDS_Vertex  theFirstVertex = TopoDS_Vertex(),
const bool  theShapeAnalysisAlgo = false
theFace- the face to process
theEdges- all ordered edges of theFace (outer edges go first).
theNbEdgesInWires- nb of edges (== nb of vertices in closed wire) in each wire
theFirstVertex- the vertex of the outer wire to set first in the returned list ( theFirstVertex may be NULL )
theShapeAnalysisAlgo- if true, ShapeAnalysis::OuterWire() is used to find the outer wire else BRepTools::OuterWire() is used.
int- nb of wires
Always try to set a seam edge first. BRepTools::OuterWire() fails e.g. in the case of issue 0020184, ShapeAnalysis::OuterWire() fails in the case of issue 0020452
References Edge, Handle(), and MESSAGE.
Referenced by SMESH_Pattern::Apply(), StdMeshers_Quadrangle_2D::CheckNbEdges(), StdMeshers_Quadrangle_2D::checkNbEdgesForEvaluate(), StdMeshers_Projection_2D::Compute(), FindBlockShapes(), StdMeshers_ProjectionUtils::FindFaceAssociation(), StdMeshers_FaceSide::GetFaceWires(), _QuadFaceGrid::Init(), StdMeshers_Prism_3D::initPrism(), SMESH_MesherHelper::IsStructured(), SMESH_Pattern::Load(), VISCOUS_3D::_SolidData::PrepareEdgesToSmoothOnFace(), VISCOUS_3D::ShrinkFace::SetBoundary(), and StdMeshers::Cartesian3D::Hexahedron::sortVertexNodes().
◆ GetShapeCoef()
double * SMESH_Block::GetShapeCoef ( const int  theShapeID)
◆ GetShapeIDByParams()
int SMESH_Block::GetShapeIDByParams ( const gp_XYZ &  theParams)
◆ GetStateNumber()
Standard_Integer SMESH_Block::GetStateNumber ( )
◆ GetTolerance()
double SMESH_Block::GetTolerance ( ) const
◆ init()
void SMESH_Block::init ( )
References myGridComputed, myNbIterations, and mySumDist.
Referenced by StdMeshers_PrismAsBlock::Init(), LoadBlockShapes(), and LoadMeshBlock().
◆ Insert()
bool SMESH_Block::Insert ( const TopoDS_Shape &  theShape,
theShape- shape to insert
theShapeID- shape in-block ID
theShapeIDMap- map of block sub-shapes
Referenced by StdMeshers_PrismAsBlock::Init(), and StdMeshers_PrismAsBlock::TSideFace::InsertSubShapes().
◆ IsEdgeID()
◆ IsFaceID()
static bool SMESH_Block::IsFaceID ( int  theShapeID)
◆ IsForwardEdge()
static bool SMESH_Block::IsForwardEdge ( const TopoDS_Edge &  theEdge,
const TopTools_IndexedMapOfOrientedShape &  theShapeIDMap
◆ IsToleranceReached()
bool SMESH_Block::IsToleranceReached ( ) const
References distance(), and myTolerance.
◆ IsVertexID()
◆ LoadBlockShapes() [1/2]
bool SMESH_Block::LoadBlockShapes ( const TopoDS_Shell &  theShell,
◆ LoadBlockShapes() [2/2]
bool SMESH_Block::LoadBlockShapes ( const TopTools_IndexedMapOfOrientedShape &  theShapeIDMap)
bool- is a success
References Edge, Face, ID_FirstE, ID_V000, ID_V111, init(), IsEdgeID(), IsForwardEdge(), IsVertexID(), LoadFace(), myEdge, myPnt, and SMESH_Block::TEdge::Set().
◆ LoadFace()
bool SMESH_Block::LoadFace ( const TopoDS_Face &  theFace,
Load face geometry.
theFace- face
theFaceID- face in-block ID
bool- is a success
It is enough to compute params or coordinates on the face. Face sub-shapes must be loaded into theShapeIDMap before
References Edge, GetFaceEdgesIDs(), ID_FirstF, IsFaceID(), IsForwardEdge(), myFace, and SMESH_Block::TFace::Set().
Referenced by LoadBlockShapes().
◆ LoadMeshBlock()
◆ NbEdges()
static int SMESH_Block::NbEdges ( )
◆ NbEquations()
Standard_Integer SMESH_Block::NbEquations ( ) const
◆ NbFaces()
static int SMESH_Block::NbFaces ( )
◆ NbSubShapes()
static int SMESH_Block::NbSubShapes ( )
◆ NbVariables()
Standard_Integer SMESH_Block::NbVariables ( ) const
◆ NbVertices()
static int SMESH_Block::NbVertices ( )
◆ refineParametersOnFace()
void SMESH_Block::refineParametersOnFace ( const gp_Pnt &  thePoint,
gp_XYZ &  theParams,
int  theFaceID
[in]thePoint- the point
[in,out]theParams- solution to precise
[in]theFaceID- FACE ID
References distance(), findUVAround(), findUVByHalfDivision(), SMESH_Block::TFace::GetUInd(), SMESH_Block::TFace::GetVInd(), ID_FirstF, myFace, myTolerance, SMESH_Block::TFace::Point(), and SMESH_Block::TFace::Surface().
Referenced by computeParameters(), and ComputeParameters().
◆ saveBetterSolution()
bool SMESH_Block::saveBetterSolution ( const gp_XYZ &  theNewParams,
gp_XYZ &  theParams,
double  sqDistance
[in]theNewParams- a new solution
[out]theParams- the parameters to store solution in
[in]sqDistance- a square distance reached at theNewParams
bool - true if the reached distance is within the tolerance
References distance(), myTolerance, myValues, and SQUARE_DIST.
Referenced by findUVAround(), and findUVByHalfDivision().
◆ SetTolerance()
void SMESH_Block::SetTolerance ( const double  tol)
References myTolerance.
◆ ShapeIndex()
◆ ShellPoint() [1/2]
bool SMESH_Block::ShellPoint ( const gp_XYZ &  theParams,
const std::vector< gp_XYZ > &  thePointOnShape,
gp_XYZ &  thePoint
◆ ShellPoint() [2/2]
◆ Value()
Standard_Boolean SMESH_Block::Value ( const math_Vector &  X,
math_Vector &  F
◆ Values()
Standard_Boolean SMESH_Block::Values ( const math_Vector &  X,
math_Vector &  F,
math_Matrix &  D
◆ VertexParameters()
bool SMESH_Block::VertexParameters ( const int  theVertexID,
gp_XYZ &  theParams
References ID_V000, ID_V010, ID_V100, and ID_V110.
Referenced by ComputeParameters(), and EdgeParameters().
◆ VertexPoint()
bool SMESH_Block::VertexPoint ( const int  theVertexID,
gp_XYZ &  thePoint
◆ my3x3x3GridNodes
TxyzPair SMESH_Block::my3x3x3GridNodes[1000]
Referenced by ComputeParameters().
◆ myEdge
◆ myFace
◆ myFaceIndex
int SMESH_Block::myFaceIndex
◆ myFaceParam
double SMESH_Block::myFaceParam
◆ myGridComputed
bool SMESH_Block::myGridComputed
Referenced by ComputeParameters(), and init().
◆ myNbIterations
int SMESH_Block::myNbIterations
◆ myParam
gp_XYZ SMESH_Block::myParam
Referenced by computeParameters(), Value(), and Values().
◆ myPnt
gp_XYZ SMESH_Block::myPnt[8]
◆ myPoint
gp_XYZ SMESH_Block::myPoint
◆ mySquareFunc
bool SMESH_Block::mySquareFunc
Referenced by computeParameters().
◆ mySumDist
double SMESH_Block::mySumDist
◆ myTolerance
◆ myValues
double SMESH_Block::myValues[4]
