StdMeshers_PrismAsBlock::TSideFace Class Reference
Class representing a part of a geom face or a union of seleral faces. More...
Inheritance diagram for StdMeshers_PrismAsBlock::TSideFace:
 TSideFace (SMESH_Mesh &mesh, const int faceID, const Prism_3D::TQuadList &quadList, const TopoDS_Edge &baseEdge, TParam2ColumnMap *columnsMap, const double first=0.0, const double last=1.0)
 TSideFace (SMESH_Mesh &mesh, const std::vector< TSideFace * > &components, const std::vector< std::pair< double, double > > &params)
 TSideFace (const TSideFace &other)
 Copy constructor. More...
 ~TSideFace ()
 Deletes myComponents. More...
bool IsComplex () const
int FaceID () const
SMESH_Mesh * GetMesh () const
TParam2ColumnMap * GetColumns () const
gp_XY GetNodeUV (const TopoDS_Face &F, const SMDS_MeshNode *n, const SMDS_MeshNode *n2=0) const
const TopoDS_Edge & BaseEdge () const
int ColumnHeight () const
double GetColumns (const double U, TParam2ColumnIt &col1, TParam2ColumnIt &col2) const
 Find node columns for a parameter. More...
void GetNodesAtZ (const int Z, std::map< double, const SMDS_MeshNode * > &nodes) const
 Return all nodes at a given height together with their normalized parameters. More...
int NbComponents () const
TSideFace * GetComponent (const int i) const
void SetComponent (const int i, TSideFace *c)
TSideFace * GetComponent (const double U, double &localU) const
 Return a component corresponding to parameter. More...
bool IsForward () const
Adaptor3d_Surface * Surface () const
bool GetPCurves (Adaptor2d_Curve2d *pcurv[4]) const
 Return pcurves. More...
Adaptor2d_Curve2d * HorizPCurve (const bool isTop, const TopoDS_Face &horFace) const
 Returns geometry of pcurve on a horizontal face. More...
Adaptor3d_Curve * HorizCurve (const bool isTop) const
 Return geometry of the top or bottom curve. More...
Adaptor3d_Curve * VertiCurve (const bool isMax) const
 Return geometry of the vertical curve. More...
TopoDS_Edge GetEdge (const int edge) const
 Return boundary edge. More...
int InsertSubShapes (TBlockShapes &shapeMap) const
 Fill block sub-shapes. More...
gp_Pnt Value (const Standard_Real U, const Standard_Real V) const
 Return coordinates by normalized params. More...
void dumpNodes (int nbNodes) const
 Dump ids of nodes of sides. More...
Private Types
typedef boost::shared_ptr< BRepAdaptor_Surface > PSurface
int myID
 in-block ID More...
TParam2ColumnMap * myParamToColumnMap
PSurface mySurface
TopoDS_Edge myBaseEdge
std::map< int, PSurface > myShapeID2Surf
std::vector< std::pair< double, double > > myParams
bool myIsForward
std::vector< TSideFace * > myComponents
SMESH_MesherHelper myHelper
Or just an ordinary geom face
It's parametrization is within [0,1] range. It redefines Adaptor3d_Surface::Value(U,V) where U and V are within [0,1]
◆ PSurface
typedef boost::shared_ptr<BRepAdaptor_Surface> StdMeshers_PrismAsBlock::TSideFace::PSurface
◆ TSideFace() [1/3]
StdMeshers_PrismAsBlock::TSideFace::TSideFace ( SMESH_Mesh &  mesh,
const int  faceID,
const Prism_3D::TQuadList &  quadList,
const TopoDS_Edge &  baseEdge,
TParam2ColumnMap *  columnsMap,
const double  first = 0.0,
const double  last = 1.0
faceID- in-block ID
face- geom FACE
baseEdge- EDGE proreply oriented in the bottom EDGE !!!
columnsMap- map of node columns
first- first normalized param
last- last normalized param
References SMESH_MesherHelper::GetMeshDS(), StdMeshers_PrismAsBlock::IsForwardEdge(), myBaseEdge, myHelper, myID, myIsForward, myParams, myParamToColumnMap, myShapeID2Surf, mySurface, SMESH_MesherHelper::SetSubShape(), and SMESHDS_Mesh::ShapeToIndex().
Referenced by TSideFace().
◆ TSideFace() [2/3]
const std::vector< TSideFace * > &  components,
const std::vector< std::pair< double, double > > &  params
◆ TSideFace() [3/3]
StdMeshers_PrismAsBlock::TSideFace::TSideFace ( const TSideFace &  other)
Copy constructor.
other- other side
References myComponents, and TSideFace().
◆ ~TSideFace()
StdMeshers_PrismAsBlock::TSideFace::~TSideFace ( )
◆ BaseEdge()
const TopoDS_Edge & StdMeshers_PrismAsBlock::TSideFace::BaseEdge ( ) const
◆ ColumnHeight()
◆ dumpNodes()
void StdMeshers_PrismAsBlock::TSideFace::dumpNodes ( int  nbNodes) const
◆ FaceID()
int StdMeshers_PrismAsBlock::TSideFace::FaceID ( ) const
◆ GetColumns() [1/2]
TParam2ColumnMap * StdMeshers_PrismAsBlock::TSideFace::GetColumns ( ) const
◆ GetColumns() [2/2]
double StdMeshers_PrismAsBlock::TSideFace::GetColumns ( const double  U,
TParam2ColumnIt &  col1,
TParam2ColumnIt &  col2
U- parameter along a horizontal edge
col1- the 1st found column
col2- the 2nd found column
r- normalized position of U between the found columns
References GetColumns().
◆ GetComponent() [1/2]
StdMeshers_PrismAsBlock::TSideFace * StdMeshers_PrismAsBlock::TSideFace::GetComponent ( const double  U,
double &  localU
U- parameter along a horizontal size
localU- parameter along a horizontal size of a component
TSideFace*- found component
◆ GetComponent() [2/2]
TSideFace * StdMeshers_PrismAsBlock::TSideFace::GetComponent ( const int  i) const
◆ GetEdge()
TopoDS_Edge StdMeshers_PrismAsBlock::TSideFace::GetEdge ( const int  iEdge) const
◆ GetMesh()
SMESH_Mesh * StdMeshers_PrismAsBlock::TSideFace::GetMesh ( ) const
◆ GetNodesAtZ()
void StdMeshers_PrismAsBlock::TSideFace::GetNodesAtZ ( const int  Z,
std::map< double, const SMDS_MeshNode * > &  nodes
[in]Z- the height of interest
[out]nodes- map of parameter to node
Referenced by StdMeshers_PrismAsBlock::TPCurveOnHorFaceAdaptor::TPCurveOnHorFaceAdaptor().
◆ GetNodeUV()
gp_XY StdMeshers_PrismAsBlock::TSideFace::GetNodeUV ( const TopoDS_Face &  F,
const SMDS_MeshNode *  n,
const SMDS_MeshNode *  n2 = 0
◆ GetPCurves()
bool StdMeshers_PrismAsBlock::TSideFace::GetPCurves ( Adaptor2d_Curve2d *  pcurv[4]) const
Return pcurves.
pcurv- array of 4 pcurves
bool- is a success
References BOTTOM_EDGE, Handle(), TOP_EDGE, V0_EDGE, and V1_EDGE.
Referenced by StdMeshers_PrismAsBlock::Init().
◆ HorizCurve()
Adaptor3d_Curve * StdMeshers_PrismAsBlock::TSideFace::HorizCurve ( const bool  isTop) const
isTop-
Adaptor3d_Curve*-
◆ HorizPCurve()
Adaptor2d_Curve2d * StdMeshers_PrismAsBlock::TSideFace::HorizPCurve ( const bool  isTop,
const TopoDS_Face &  horFace
isTop- is top or bottom face
horFace- a horizontal face
Adaptor2d_Curve2d*- curve adaptor
◆ InsertSubShapes()
int StdMeshers_PrismAsBlock::TSideFace::InsertSubShapes ( TBlockShapes &  shapeMap) const
◆ IsComplex()
bool StdMeshers_PrismAsBlock::TSideFace::IsComplex ( ) const
◆ IsForward()
bool StdMeshers_PrismAsBlock::TSideFace::IsForward ( ) const
◆ NbComponents()
int StdMeshers_PrismAsBlock::TSideFace::NbComponents ( ) const
◆ SetComponent()
void StdMeshers_PrismAsBlock::TSideFace::SetComponent ( const int  i,
TSideFace *  c
◆ Surface()
Adaptor3d_Surface * StdMeshers_PrismAsBlock::TSideFace::Surface ( ) const
◆ Value()
gp_Pnt StdMeshers_PrismAsBlock::TSideFace::Value ( const Standard_Real  U,
◆ VertiCurve()
Adaptor3d_Curve * StdMeshers_PrismAsBlock::TSideFace::VertiCurve ( const bool  isMax) const
isMax- true means curve located closer to (1,1,1) block point
Adaptor3d_Curve*- curve adaptor
◆ myBaseEdge
TopoDS_Edge StdMeshers_PrismAsBlock::TSideFace::myBaseEdge
◆ myComponents
std::vector< TSideFace* > StdMeshers_PrismAsBlock::TSideFace::myComponents
◆ myHelper
SMESH_MesherHelper StdMeshers_PrismAsBlock::TSideFace::myHelper
◆ myID
int StdMeshers_PrismAsBlock::TSideFace::myID
in-block ID
◆ myIsForward
bool StdMeshers_PrismAsBlock::TSideFace::myIsForward
◆ myParams
std::vector< std::pair< double, double> > StdMeshers_PrismAsBlock::TSideFace::myParams
◆ myParamToColumnMap
TParam2ColumnMap* StdMeshers_PrismAsBlock::TSideFace::myParamToColumnMap
◆ myShapeID2Surf
std::map< int, PSurface > StdMeshers_PrismAsBlock::TSideFace::myShapeID2Surf
Referenced by TSideFace(), and Value().
◆ mySurface
PSurface StdMeshers_PrismAsBlock::TSideFace::mySurface
