StdMeshers_PrismAsBlock Class Reference
Tool analyzing and giving access to a prism geometry treating it like a block, i.e. More...
#include <StdMeshers_Prism_3D.hxx>
Inheritance diagram for StdMeshers_PrismAsBlock:
class  THorizontalEdgeAdaptor
 Class emulating geometry of a hirizontal edge. More...
class  TPCurveOnHorFaceAdaptor
 Class emulating pcurve on a hirizontal face. More...
class  TSideFace
 Class representing a part of a geom face or a union of seleral faces. More...
class  TVerticalEdgeAdaptor
 Class emulating geometry of a vertical edge. More...
enum  TShapeID {
  ID_NONE = 0 , ID_V000 = 1 , ID_V100 , ID_V010 ,
  ID_V110 , ID_V001 , ID_V101 , ID_V011 ,
  ID_V111 , ID_Ex00 , ID_Ex10 , ID_Ex01 ,
  ID_Ex11 , ID_E0y0 , ID_E1y0 , ID_E0y1 ,
  ID_E1y1 , ID_E00z , ID_E10z , ID_E01z ,
  ID_E11z , ID_Fxy0 , ID_Fxy1 , ID_Fx0z ,
  ID_Fx1z , ID_F0yz , ID_F1yz , ID_Shell ,
  ID_FirstV = ID_V000 , ID_FirstE = ID_Ex00 , ID_FirstF = ID_Fxy0
 StdMeshers_PrismAsBlock ()
 ~StdMeshers_PrismAsBlock ()
bool Init (SMESH_MesherHelper *helper, const Prism_3D::TPrismTopo &prism)
 Initialization. More...
SMESH_ComputeErrorPtr GetError () const
 Return problem description. More...
void Clear ()
 Free allocated memory. More...
size_t VerticalSize () const
 Return number of nodes on every vertical edge. More...
bool HasNotQuadElemOnTop () const
const TNodeColumn * GetNodeColumn (const SMDS_MeshNode *node) const
 Return pointer to column of nodes. More...
const TParam2ColumnMap * GetParam2ColumnMap (const int baseEdgeID, bool &isReverse) const
 Return TParam2ColumnMap for a base edge. More...
bool HasNodeColumn (const SMDS_MeshNode *node) const
bool GetLayersTransformation (std::vector< gp_Trsf > &trsf, const Prism_3D::TPrismTopo &prism) const
 Return transformations to get coordinates of nodes of each internal layer by nodes of the bottom. More...
SMESH_Mesh * Mesh () const
 Return pointer to mesh. More...
SMESHDS_Mesh * MeshDS () const
 Return pointer to mesh DS. More...
SMESH_subMesh * SubMesh (const int shapeID) const
 Return submesh of a shape. More...
SMESHDS_SubMesh * SubMeshDS (const int shapeID) const
 Return submesh DS of a shape. More...
const TopoDS_Shape & Shape (const int shapeID) const
 Return a in-block shape. More...
int ShapeID (const TopoDS_Shape &shape) const
 Return in-block ID of a shape. More...
bool LoadBlockShapes (const TopoDS_Shell &theShell, const TopoDS_Vertex &theVertex000, const TopoDS_Vertex &theVertex001, TopTools_IndexedMapOfOrientedShape &theShapeIDMap)
bool LoadBlockShapes (const TopTools_IndexedMapOfOrientedShape &theShapeIDMap)
 Initialize block geometry with shapes from theShapeIDMap. More...
bool LoadMeshBlock (const SMDS_MeshVolume *theVolume, const int theNode000Index, const int theNode001Index, std::vector< const SMDS_MeshNode * > &theOrderedNodes)
bool LoadFace (const TopoDS_Face &theFace, const int theFaceID, const TopTools_IndexedMapOfOrientedShape &theShapeIDMap)
 Load face geometry. More...
bool VertexPoint (const int theVertexID, gp_XYZ &thePoint) const
bool EdgePoint (const int theEdgeID, const gp_XYZ &theParams, gp_XYZ &thePoint) const
bool EdgeU (const int theEdgeID, const gp_XYZ &theParams, double &theU) const
bool FacePoint (const int theFaceID, const gp_XYZ &theParams, gp_XYZ &thePoint) const
bool FaceUV (const int theFaceID, const gp_XYZ &theParams, gp_XY &theUV) const
bool ShellPoint (const gp_XYZ &theParams, gp_XYZ &thePoint) const
bool ComputeParameters (const gp_Pnt &thePoint, gp_XYZ &theParams, const int theShapeID=ID_Shell, const gp_XYZ &theParamsHint=gp_XYZ(-1,-1,-1))
bool VertexParameters (const int theVertexID, gp_XYZ &theParams)
bool EdgeParameters (const int theEdgeID, const double theU, gp_XYZ &theParams)
void SetTolerance (const double tol)
double GetTolerance () const
bool IsToleranceReached () const
double DistanceReached () const
Standard_Integer NbVariables () const
Standard_Integer NbEquations () const
Standard_Boolean Value (const math_Vector &X, math_Vector &F)
Standard_Boolean Derivatives (const math_Vector &X, math_Matrix &D)
Standard_Boolean Values (const math_Vector &X, math_Vector &F, math_Matrix &D)
Standard_Integer GetStateNumber ()
static bool IsForwardEdge (SMESHDS_Mesh *meshDS, const TParam2ColumnMap &columnsMap, const TopoDS_Edge &bottomEdge, const int sideFaceID)
 Check curve orientation of a bottom edge. More...
static int NbVertices ()
static int NbEdges ()
static int NbFaces ()
static int NbSubShapes ()
static bool IsVertexID (int theShapeID)
static bool IsEdgeID (int theShapeID)
static bool IsFaceID (int theShapeID)
static int ShapeIndex (int theShapeID)
static void GetFaceEdgesIDs (const int faceID, std::vector< int > &edgeVec)
static void GetEdgeVertexIDs (const int edgeID, std::vector< int > &vertexVec)
static int GetCoordIndOnEdge (const int theEdgeID)
static double * GetShapeCoef (const int theShapeID)
static int GetShapeIDByParams (const gp_XYZ &theParams)
static std::ostream & DumpShapeID (const int theBlockShapeID, std::ostream &stream)
static bool Insert (const TopoDS_Shape &theShape, const int theShapeID, TopTools_IndexedMapOfOrientedShape &theShapeIDMap)
 / Insert theShape into theShapeIDMap with theShapeID More...
static bool FindBlockShapes (const TopoDS_Shell &theShell, const TopoDS_Vertex &theVertex000, const TopoDS_Vertex &theVertex001, TopTools_IndexedMapOfOrientedShape &theShapeIDMap)
static bool ShellPoint (const gp_XYZ &theParams, const std::vector< gp_XYZ > &thePointOnShape, gp_XYZ &thePoint)
static bool IsForwardEdge (const TopoDS_Edge &theEdge, const TopTools_IndexedMapOfOrientedShape &theShapeIDMap)
static int GetOrderedEdges (const TopoDS_Face &theFace, std::list< TopoDS_Edge > &theEdges, std::list< int > &theNbEdgesInWires, TopoDS_Vertex theFirstVertex=TopoDS_Vertex(), const bool theShapeAnalysisAlgo=false)
 Return number of wires and a list of oredered edges. More...
Protected Types
enum  { SQUARE_DIST = 0 , DRV_1 , DRV_2 , DRV_3 }
typedef std::pair< gp_XYZ, gp_XYZ > TxyzPair
void init ()
 Call it after geometry initialization. More...
double distance () const
double funcValue (double sqDist) const
bool computeParameters (const gp_Pnt &thePoint, gp_XYZ &theParams, const gp_XYZ &theParamsHint, int)
void refineParametersOnFace (const gp_Pnt &thePoint, gp_XYZ &theParams, int theFaceID)
 Find more precise solution. More...
bool findUVByHalfDivision (const gp_Pnt &thePoint, const gp_XY &theUV, const TFace &tface, gp_XYZ &theParams)
 Finds parameters corresponding to a given UV of a given face using half-division. More...
bool findUVAround (const gp_Pnt &thePoint, const gp_XY &theUV, const TFace &tface, gp_XYZ &theParams, int nbGetWorstLimit)
 Find parameters corresponding to a given UV of a given face by searching around the starting solution. More...
bool saveBetterSolution (const gp_XYZ &theNewParams, gp_XYZ &theParams, double sqDistance)
 Store a solution if it's better than a previous one. More...
gp_XYZ myPnt [8]
TEdge myEdge [12]
TFace myFace [6]
int myFaceIndex
double myFaceParam
int myNbIterations
double mySumDist
double myTolerance
bool mySquareFunc
gp_XYZ myPoint
gp_XYZ myParam
double myValues [4]
TxyzPair my3x3x3GridNodes [1000]
bool myGridComputed
void faceGridToPythonDump (const SMESH_Block::TShapeID face, const int nb=10)
 Prints a script creating a normal grid on the prism side. More...
bool myNotQuadOnTop
SMESH_MesherHelper * myHelper
TBlockShapes myShapeIDMap
SMESH_ComputeErrorPtr myError
TSideFace * mySide
std::vector< TParam2ColumnMap > myParam2ColumnMaps
std::map< int, std::pair< TParam2ColumnMap *, bool > > myShapeIndex2ColumnMap
the four side faces are emulated by division/uniting of missing/excess faces. It also manage associations between block sub-shapes and a mesh.
◆ TxyzPair
typedef std::pair<gp_XYZ,gp_XYZ> SMESH_Block::TxyzPair
◆ anonymous enum
anonymous enum
SQUARE_DIST
DRV_1
DRV_2
DRV_3
◆ TShapeID
enum SMESH_Block::TShapeID
ID_NONE
ID_V000
ID_V100
ID_V010
ID_V110
ID_V001
ID_V101
ID_V011
ID_V111
ID_Ex00
ID_Ex10
ID_Ex01
ID_Ex11
ID_E0y0
ID_E1y0
ID_E0y1
ID_E1y1
ID_E00z
ID_E10z
ID_E01z
ID_E11z
ID_Fxy0
ID_Fxy1
ID_Fx0z
ID_Fx1z
ID_F0yz
ID_F1yz
ID_Shell
ID_FirstV
ID_FirstE
ID_FirstF
◆ StdMeshers_PrismAsBlock()
StdMeshers_PrismAsBlock::StdMeshers_PrismAsBlock ( )
Initialization is needed
References mySide.
◆ ~StdMeshers_PrismAsBlock()
StdMeshers_PrismAsBlock::~StdMeshers_PrismAsBlock ( )
References Clear().
◆ Clear()
void StdMeshers_PrismAsBlock::Clear ( )
◆ computeParameters()
◆ ComputeParameters()
◆ Derivatives()
Standard_Boolean SMESH_Block::Derivatives ( const math_Vector &  X,
math_Matrix &  D
References SMESH_Block::Values().
◆ distance()
◆ DistanceReached()
double SMESH_Block::DistanceReached ( ) const
◆ DumpShapeID()
◆ EdgeParameters()
◆ EdgePoint()
bool SMESH_Block::EdgePoint ( const int  theEdgeID,
const gp_XYZ &  theParams,
gp_XYZ &  thePoint
◆ EdgeU()
bool SMESH_Block::EdgeU ( const int  theEdgeID,
double &  theU
◆ error()
bool StdMeshers_PrismAsBlock::error ( int  error,
const SMESH_Comment &  comment = ""
References SMESH_ComputeError::New().
Referenced by Init().
◆ faceGridToPythonDump()
void StdMeshers_PrismAsBlock::faceGridToPythonDump ( const SMESH_Block::TShapeID  face,
const int  nb = 10
◆ FacePoint()
bool SMESH_Block::FacePoint ( const int  theFaceID,
gp_XYZ &  thePoint
◆ FaceUV()
bool SMESH_Block::FaceUV ( const int  theFaceID,
gp_XY &  theUV
◆ FindBlockShapes()
bool SMESH_Block::FindBlockShapes ( const TopoDS_Shell &  theShell,
const TopoDS_Vertex &  theVertex000,
const TopoDS_Vertex &  theVertex001,
TopTools_IndexedMapOfOrientedShape &  theShapeIDMap
◆ findUVAround()
bool SMESH_Block::findUVAround ( const gp_Pnt &  thePoint,
const gp_XY &  theUV,
const TFace &  tface,
gp_XYZ &  theParams,
int  nbGetWorstLimit
[in]theUV- the UV to locate
[in]tface- the face
[in,out]theParams- the starting parameters to improve
[in]nbGetWorstLimit- nb of steps from the starting solution w/o improvement to stop searching in this direction
bool - true if found solution is within myTolerance
References SMESH_Block::distance(), SMESH_Block::TFace::GetUInd(), SMESH_Block::TFace::GetVInd(), SMESH_Block::TFace::Point(), and SMESH_Block::saveBetterSolution().
Referenced by SMESH_Block::refineParametersOnFace().
◆ findUVByHalfDivision()
bool SMESH_Block::findUVByHalfDivision ( const gp_Pnt &  thePoint,
gp_XYZ &  theParams
[in]tface- the face
References SMESH_Block::distance(), SMESH_Block::TFace::GetUInd(), SMESH_Block::TFace::GetVInd(), SMESH_Block::TFace::IsUVInQuad(), SMESH_Block::TFace::Point(), and SMESH_Block::saveBetterSolution().
◆ funcValue()
double SMESH_Block::funcValue ( double  sqDist) const
◆ GetCoordIndOnEdge()
static int SMESH_Block::GetCoordIndOnEdge ( const int  theEdgeID)
◆ GetEdgeVertexIDs()
◆ GetError()
SMESH_ComputeErrorPtr StdMeshers_PrismAsBlock::GetError ( ) const
Referenced by StdMeshers_Prism_3D::compute().
◆ GetFaceEdgesIDs()
◆ GetLayersTransformation()
bool StdMeshers_PrismAsBlock::GetLayersTransformation ( std::vector< gp_Trsf > &  trsf,
const Prism_3D::TPrismTopo &  prism
Layer is a set of nodes at a certain step from bottom to top.
References GetParam2ColumnMap(), gpXYZ, ID_BOT_FACE, SMESH_Algo::isDegenerated(), SMESH_subMesh::IsEmpty(), MeshDS(), Prism_3D::TPrismTopo::myBottomEdges, Prism_3D::TPrismTopo::myNbEdgesInWires, SubMesh(), and VerticalSize().
◆ GetNodeColumn()
const TNodeColumn * StdMeshers_PrismAsBlock::GetNodeColumn ( const SMDS_MeshNode *  node) const
node- bottom node from which the returned column goes up
constTNodeColumn* - the found column
References SMDS_MeshElement::getshapeId(), and myShapeIndex2ColumnMap.
Referenced by StdMeshers_Prism_3D::compute(), and StdMeshers_Prism_3D::projectBottomToTop().
◆ GetOrderedEdges()
int SMESH_Block::GetOrderedEdges ( const TopoDS_Face &  theFace,
std::list< TopoDS_Edge > &  theEdges,
std::list< int > &  theNbEdgesInWires,
TopoDS_Vertex  theFirstVertex = TopoDS_Vertex(),
const bool  theShapeAnalysisAlgo = false
theFace- the face to process
theEdges- all ordered edges of theFace (outer edges go first).
theNbEdgesInWires- nb of edges (== nb of vertices in closed wire) in each wire
theFirstVertex- the vertex of the outer wire to set first in the returned list ( theFirstVertex may be NULL )
theShapeAnalysisAlgo- if true, ShapeAnalysis::OuterWire() is used to find the outer wire else BRepTools::OuterWire() is used.
int- nb of wires
Always try to set a seam edge first. BRepTools::OuterWire() fails e.g. in the case of issue 0020184, ShapeAnalysis::OuterWire() fails in the case of issue 0020452
References Edge, Handle(), and MESSAGE.
Referenced by SMESH_Pattern::Apply(), StdMeshers_Quadrangle_2D::CheckNbEdges(), StdMeshers_Quadrangle_2D::checkNbEdgesForEvaluate(), StdMeshers_Projection_2D::Compute(), SMESH_Block::FindBlockShapes(), StdMeshers_ProjectionUtils::FindFaceAssociation(), StdMeshers_FaceSide::GetFaceWires(), _QuadFaceGrid::Init(), StdMeshers_Prism_3D::initPrism(), SMESH_MesherHelper::IsStructured(), SMESH_Pattern::Load(), VISCOUS_3D::_SolidData::PrepareEdgesToSmoothOnFace(), VISCOUS_3D::ShrinkFace::SetBoundary(), and StdMeshers::Cartesian3D::Hexahedron::sortVertexNodes().
◆ GetParam2ColumnMap()
const TParam2ColumnMap * StdMeshers_PrismAsBlock::GetParam2ColumnMap ( const int  baseEdgeID,
bool &  isReverse
baseEdgeID- base edge SMESHDS Index
isReverse- columns in-block orientation
constTParam2ColumnMap* - map
Referenced by StdMeshers_Prism_3D::compute(), and GetLayersTransformation().
◆ GetShapeCoef()
double * SMESH_Block::GetShapeCoef ( const int  theShapeID)
◆ GetShapeIDByParams()
int SMESH_Block::GetShapeIDByParams ( const gp_XYZ &  theParams)
◆ GetStateNumber()
Standard_Integer SMESH_Block::GetStateNumber ( )
◆ GetTolerance()
double SMESH_Block::GetTolerance ( ) const
◆ HasNodeColumn()
bool StdMeshers_PrismAsBlock::HasNodeColumn ( const SMDS_MeshNode *  node) const
References SMDS_MeshElement::getshapeId().
Referenced by StdMeshers_Prism_3D::assocOrProjBottom2Top(), and StdMeshers_Prism_3D::compute().
◆ HasNotQuadElemOnTop()
bool StdMeshers_PrismAsBlock::HasNotQuadElemOnTop ( ) const
◆ init()
void SMESH_Block::init ( )
◆ Init()
bool StdMeshers_PrismAsBlock::Init ( SMESH_MesherHelper *  helper,
const Prism_3D::TPrismTopo &  thePrism
Initialization.
helper- helper loaded with mesh and 3D shape
prism- prism topology
bool- false if a mesh or a shape are KO
thePrism- a prism data
References BOTTOM_EDGE, COMPERR_BAD_INPUT_MESH, error(), StdMeshers_PrismAsBlock::TSideFace::FaceID(), StdMeshers_PrismAsBlock::TSideFace::GetComponent(), SMESH_Block::TEdge::GetCurve(), SMESH_Block::GetEdgeVertexIDs(), SMESH_Block::GetFaceEdgesIDs(), SMESH_MesherHelper::GetMesh(), SMESH_MesherHelper::GetMeshDS(), StdMeshers_PrismAsBlock::TSideFace::GetPCurves(), SMDS_MeshElement::getshapeId(), gpXYZ, StdMeshers_PrismAsBlock::TSideFace::HorizCurve(), StdMeshers_PrismAsBlock::TSideFace::HorizPCurve(), ID_BOT_FACE, SMESH_Block::ID_F0yz, SMESH_Block::ID_F1yz, SMESH_Block::ID_FirstE, SMESH_Block::ID_FirstF, SMESH_Block::ID_FirstV, SMESH_Block::ID_Fx0z, SMESH_Block::ID_Fx1z, ID_TOP_FACE, SMESH_Block::init(), SMESH_Block::Insert(), StdMeshers_PrismAsBlock::TSideFace::InsertSubShapes(), StdMeshers_PrismAsBlock::TSideFace::IsComplex(), StdMeshers_PrismAsBlock::TSideFace::IsForward(), IsForwardEdge(), SMESH_MesherHelper::LoadNodeColumns(), MeshDS(), MESSAGE, Prism_3D::TPrismTopo::myBottom, Prism_3D::TPrismTopo::myBottomEdges, SMESH_Block::myEdge, myError, SMESH_Block::myFace, myHelper, Prism_3D::TPrismTopo::myNbEdgesInWires, Prism_3D::TPrismTopo::myNotQuadOnTop, myNotQuadOnTop, myParam2ColumnMaps, SMESH_Block::myPnt, myShapeIDMap, myShapeIndex2ColumnMap, mySide, Prism_3D::TPrismTopo::myTop, Prism_3D::TPrismTopo::myWallQuads, NB_WALL_FACES, SMESH_ComputeError::New(), QUAD_BOTTOM_SIDE, RETURN_BAD_RESULT, SMESH_Block::TEdge::Set(), SMESH_Block::TFace::Set(), StdMeshers_PrismAsBlock::TSideFace::SetComponent(), SMESHDS_Mesh::ShapeToIndex(), SHOWYXZ, StdMeshers_PrismAsBlock::TSideFace::Surface(), StdMeshers_PrismAsBlock::TSideFace::Value(), VerticalSize(), and StdMeshers_PrismAsBlock::TSideFace::VertiCurve().
◆ Insert()
bool SMESH_Block::Insert ( const TopoDS_Shape &  theShape,
theShape- shape to insert
theShapeID- shape in-block ID
theShapeIDMap- map of block sub-shapes
Referenced by Init(), and StdMeshers_PrismAsBlock::TSideFace::InsertSubShapes().
◆ IsEdgeID()
◆ IsFaceID()
◆ IsForwardEdge() [1/2]
static bool SMESH_Block::IsForwardEdge ( const TopoDS_Edge &  theEdge,
const TopTools_IndexedMapOfOrientedShape &  theShapeIDMap
◆ IsForwardEdge() [2/2]
bool StdMeshers_PrismAsBlock::IsForwardEdge ( SMESHDS_Mesh *  meshDS,
const TParam2ColumnMap &  columnsMap,
const TopoDS_Edge &  bottomEdge,
meshDS- mesh DS
columnsMap- node columns map of side face
bottomEdge- the bottom edge
sideFaceID- side face in-block ID
bool- true if orientation coincide with in-block forward orientation
References SMESH_MesherHelper::GetSubShapeByNode(), SMESH_Block::ID_F0yz, SMESH_Block::ID_Fx1z, and SMESH_MesherHelper::IsClosedEdge().
Referenced by Init(), and StdMeshers_PrismAsBlock::TSideFace::TSideFace().
◆ IsToleranceReached()
bool SMESH_Block::IsToleranceReached ( ) const
◆ IsVertexID()
◆ LoadBlockShapes() [1/2]
bool SMESH_Block::LoadBlockShapes ( const TopoDS_Shell &  theShell,
◆ LoadBlockShapes() [2/2]
bool SMESH_Block::LoadBlockShapes ( const TopTools_IndexedMapOfOrientedShape &  theShapeIDMap)
bool- is a success
References Edge, Face, SMESH_Block::ID_FirstE, SMESH_Block::ID_V000, SMESH_Block::ID_V111, SMESH_Block::init(), SMESH_Block::IsEdgeID(), SMESH_Block::IsForwardEdge(), SMESH_Block::IsVertexID(), SMESH_Block::LoadFace(), SMESH_Block::myEdge, SMESH_Block::myPnt, and SMESH_Block::TEdge::Set().
◆ LoadFace()
bool SMESH_Block::LoadFace ( const TopoDS_Face &  theFace,
Load face geometry.
theFace- face
theFaceID- face in-block ID
bool- is a success
It is enough to compute params or coordinates on the face. Face sub-shapes must be loaded into theShapeIDMap before
References Edge, SMESH_Block::GetFaceEdgesIDs(), SMESH_Block::ID_FirstF, SMESH_Block::IsFaceID(), SMESH_Block::IsForwardEdge(), SMESH_Block::myFace, and SMESH_Block::TFace::Set().
Referenced by SMESH_Block::LoadBlockShapes().
◆ LoadMeshBlock()
◆ Mesh()
SMESH_Mesh * StdMeshers_PrismAsBlock::Mesh ( ) const
SMESH_Mesh- mesh
Referenced by StdMeshers_Prism_3D::projectBottomToTop().
◆ MeshDS()
SMESHDS_Mesh * StdMeshers_PrismAsBlock::MeshDS ( ) const
SMESHDS_Mesh- mesh DS
Referenced by GetLayersTransformation(), and Init().
◆ NbEdges()
static int SMESH_Block::NbEdges ( )
◆ NbEquations()
Standard_Integer SMESH_Block::NbEquations ( ) const
◆ NbFaces()
static int SMESH_Block::NbFaces ( )
◆ NbSubShapes()
static int SMESH_Block::NbSubShapes ( )
◆ NbVariables()
Standard_Integer SMESH_Block::NbVariables ( ) const
◆ NbVertices()
static int SMESH_Block::NbVertices ( )
◆ refineParametersOnFace()
void SMESH_Block::refineParametersOnFace ( const gp_Pnt &  thePoint,
gp_XYZ &  theParams,
int  theFaceID
◆ saveBetterSolution()
bool SMESH_Block::saveBetterSolution ( const gp_XYZ &  theNewParams,
gp_XYZ &  theParams,
double  sqDistance
[in]theNewParams- a new solution
[out]theParams- the parameters to store solution in
[in]sqDistance- a square distance reached at theNewParams
bool - true if the reached distance is within the tolerance
References SMESH_Block::distance(), SMESH_Block::myTolerance, SMESH_Block::myValues, and SMESH_Block::SQUARE_DIST.
Referenced by SMESH_Block::findUVAround(), and SMESH_Block::findUVByHalfDivision().
◆ SetTolerance()
void SMESH_Block::SetTolerance ( const double  tol)
◆ Shape()
const TopoDS_Shape & StdMeshers_PrismAsBlock::Shape ( const int  shapeID) const
shapeID- shape given by in-block index
SMESHDS_SubMesh*- found submesh
◆ ShapeID()
int StdMeshers_PrismAsBlock::ShapeID ( const TopoDS_Shape &  shape) const
shape- block sub-shape
int- ID or zero if the shape has no ID
◆ ShapeIndex()
◆ ShellPoint() [1/2]
◆ ShellPoint() [2/2]
◆ SubMesh()
SMESH_subMesh * StdMeshers_PrismAsBlock::SubMesh ( const int  shapeID) const
SMESH_subMesh*- found submesh
◆ SubMeshDS()
SMESHDS_SubMesh * StdMeshers_PrismAsBlock::SubMeshDS ( const int  shapeID) const
SMESHDS_SubMesh*- found submesh DS
◆ Value()
Standard_Boolean SMESH_Block::Value ( const math_Vector &  X,
math_Vector &  F
◆ Values()
◆ VertexParameters()
bool SMESH_Block::VertexParameters ( const int  theVertexID,
gp_XYZ &  theParams
◆ VertexPoint()
bool SMESH_Block::VertexPoint ( const int  theVertexID,
gp_XYZ &  thePoint
◆ VerticalSize()
size_t StdMeshers_PrismAsBlock::VerticalSize ( ) const
int- number of nodes including end nodes
Referenced by StdMeshers_Prism_3D::assocOrProjBottom2Top(), GetLayersTransformation(), Init(), and StdMeshers_Prism_3D::projectBottomToTop().
◆ my3x3x3GridNodes
TxyzPair SMESH_Block::my3x3x3GridNodes[1000]
◆ myEdge
◆ myError
SMESH_ComputeErrorPtr StdMeshers_PrismAsBlock::myError
Referenced by Clear(), and Init().
◆ myFace
◆ myFaceIndex
int SMESH_Block::myFaceIndex
◆ myFaceParam
double SMESH_Block::myFaceParam
◆ myGridComputed
bool SMESH_Block::myGridComputed
◆ myHelper
◆ myNbIterations
int SMESH_Block::myNbIterations
◆ myNotQuadOnTop
bool StdMeshers_PrismAsBlock::myNotQuadOnTop
◆ myParam
gp_XYZ SMESH_Block::myParam
◆ myParam2ColumnMaps
std::vector< TParam2ColumnMap > StdMeshers_PrismAsBlock::myParam2ColumnMaps
◆ myPnt
gp_XYZ SMESH_Block::myPnt[8]
◆ myPoint
gp_XYZ SMESH_Block::myPoint
◆ myShapeIDMap
TBlockShapes StdMeshers_PrismAsBlock::myShapeIDMap
◆ myShapeIndex2ColumnMap
std::map< int, std::pair< TParam2ColumnMap*, bool > > StdMeshers_PrismAsBlock::myShapeIndex2ColumnMap
Referenced by Clear(), GetNodeColumn(), and Init().
◆ mySide
◆ mySquareFunc
bool SMESH_Block::mySquareFunc
◆ mySumDist
double SMESH_Block::mySumDist
◆ myTolerance
◆ myValues
