SMESH_Block::TFace Class Reference
#include <SMESH_Block.hxx>
void Set (const int faceID, Adaptor3d_Surface *S, Adaptor2d_Curve2d *c2d[4], const bool isForward[4])
 Set face data. More...
void Set (const int faceID, const TEdge &edgeU0, const TEdge &edgeU1)
 Set face data to work with mesh block. More...
gp_XY GetUV (const gp_XYZ &theParams) const
gp_XYZ Point (const gp_XYZ &theParams) const
int GetUInd () const
int GetVInd () const
void GetCoefs (int i, const gp_XYZ &theParams, double &eCoef, double &vCoef) const
const Adaptor3d_Surface * Surface () const
bool IsUVInQuad (const gp_XY &uv, const gp_XYZ &param0, const gp_XYZ &param1, const gp_XYZ &param2, const gp_XYZ &param3) const
gp_XY GetUVRange () const
 TFace ()
 ~TFace ()
int myCoordInd [4]
double myFirst [4]
double myLast [4]
Adaptor2d_Curve2d * myC2d [4]
gp_XY myCorner [4]
Adaptor3d_Surface * myS
gp_XYZ myNodes [4]
◆ TFace()
SMESH_Block::TFace::TFace ( )
◆ ~TFace()
SMESH_Block::TFace::~TFace ( )
◆ GetCoefs()
void SMESH_Block::TFace::GetCoefs ( int  i,
const gp_XYZ &  theParams,
double &  eCoef,
double &  vCoef
◆ GetUInd()
◆ GetUV()
gp_XY SMESH_Block::TFace::GetUV ( const gp_XYZ &  theParams) const
◆ GetUVRange()
gp_XY SMESH_Block::TFace::GetUVRange ( ) const
◆ GetVInd()
◆ IsUVInQuad()
bool SMESH_Block::TFace::IsUVInQuad ( const gp_XY &  uv,
const gp_XYZ &  param0,
const gp_XYZ &  param1,
const gp_XYZ &  param2,
const gp_XYZ &  param3
◆ Point()
◆ Set() [1/2]
void SMESH_Block::TFace::Set ( const int  faceID,
Adaptor3d_Surface *  S,
Adaptor2d_Curve2d *  c2D[4],
Set face data.
faceID- block sub-shape ID
S- face surface geometry
c2d- 4 pcurves in the order as returned by GetFaceEdgesIDs(faceID)
isForward- orientation of pcurves comparing with block edge direction
References SMESH_Block::GetCoordIndOnEdge(), and SMESH_Block::GetFaceEdgesIDs().
Referenced by StdMeshers_PrismAsBlock::Init(), SMESH_Block::LoadFace(), and SMESH_Block::LoadMeshBlock().
◆ Set() [2/2]
const TEdge &  edgeU0,
const TEdge &  edgeU1
edgeU0- filled data of edge u0 = GetFaceEdgesIDs(faceID)[ 0 ]
edgeU1- filled data of edge u1 = GetFaceEdgesIDs(faceID)[ 1 ]
References SMESH_Block::GetCoordIndOnEdge(), SMESH_Block::GetFaceEdgesIDs(), and SMESH_Block::TEdge::NodeXYZ().
◆ Surface()
const Adaptor3d_Surface * SMESH_Block::TFace::Surface ( ) const
◆ myC2d
Adaptor2d_Curve2d* SMESH_Block::TFace::myC2d[4]
◆ myCoordInd
int SMESH_Block::TFace::myCoordInd[4]
◆ myCorner
gp_XY SMESH_Block::TFace::myCorner[4]
◆ myFirst
double SMESH_Block::TFace::myFirst[4]
◆ myLast
double SMESH_Block::TFace::myLast[4]
◆ myNodes
gp_XYZ SMESH_Block::TFace::myNodes[4]
◆ myS
Adaptor3d_Surface* SMESH_Block::TFace::myS
