SMESH_Block::TEdge Class Reference
#include <SMESH_Block.hxx>
void Set (const int edgeID, Adaptor3d_Curve *curve, const bool isForward)
 Set edge data. More...
void Set (const int edgeID, const gp_XYZ &node1, const gp_XYZ &node2)
 Set coordinates of nodes at edge ends to work with mesh block. More...
Adaptor3d_Curve * GetCurve () const
double EndParam (int i) const
int CoordInd () const
const gp_XYZ & NodeXYZ (int i) const
gp_XYZ Point (const gp_XYZ &theParams) const
double GetU (const gp_XYZ &theParams) const
 TEdge ()
 ~TEdge ()
int myCoordInd
double myFirst
double myLast
Adaptor3d_Curve * myC3d
gp_XYZ myNodes [2]
◆ TEdge()
SMESH_Block::TEdge::TEdge ( )
◆ ~TEdge()
SMESH_Block::TEdge::~TEdge ( )
◆ CoordInd()
int SMESH_Block::TEdge::CoordInd ( ) const
◆ EndParam()
double SMESH_Block::TEdge::EndParam ( int  i) const
◆ GetCurve()
Adaptor3d_Curve * SMESH_Block::TEdge::GetCurve ( ) const
◆ GetU()
double SMESH_Block::TEdge::GetU ( const gp_XYZ &  theParams) const
◆ NodeXYZ()
const gp_XYZ & SMESH_Block::TEdge::NodeXYZ ( int  i) const
Referenced by SMESH_Block::TFace::Set().
◆ Point()
gp_XYZ SMESH_Block::TEdge::Point ( const gp_XYZ &  theParams) const
◆ Set() [1/2]
void SMESH_Block::TEdge::Set ( const int  edgeID,
Adaptor3d_Curve *  curve,
Set edge data.
edgeID- block sub-shape ID
curve- edge geometry
isForward- is curve orientation coincides with edge orientation in the block
References SMESH_Block::GetCoordIndOnEdge(), myC3d, myCoordInd, myFirst, and myLast.
Referenced by StdMeshers_PrismAsBlock::Init(), SMESH_Block::LoadBlockShapes(), and SMESH_Block::LoadMeshBlock().
◆ Set() [2/2]
const gp_XYZ &  node1,
const gp_XYZ &  node2
node1- coordinates of node with lower ID
node2- coordinates of node with upper ID
References SMESH_Block::GetCoordIndOnEdge().
◆ myC3d
Adaptor3d_Curve* SMESH_Block::TEdge::myC3d
Referenced by Set().
◆ myCoordInd
int SMESH_Block::TEdge::myCoordInd
◆ myFirst
double SMESH_Block::TEdge::myFirst
◆ myLast
double SMESH_Block::TEdge::myLast
◆ myNodes
gp_XYZ SMESH_Block::TEdge::myNodes[2]
