StdMeshers_Sweeper Struct Reference
Tool building internal nodes in a prism. More...
#include <StdMeshers_Prism_3D.hxx>
struct  TopBotTriangles
bool ComputeNodesByTrsf (const double tol, const bool allowHighBndError)
 Create internal nodes of the prism by computing an affine transformation from layer to layer. More...
bool CheckSameZ ()
 Check if all nodes of each layers have same logical Z. More...
bool ComputeNodesOnStraightSameZ ()
 Create internal nodes of the prism all located on straight lines with the same distribution along the lines. More...
bool ComputeNodesOnStraight ()
 Create internal nodes of the prism all located on straight lines with different distributions along the lines. More...
Data Fields
SMESH_MesherHelper * myHelper
TopoDS_Face myBotFace
TopoDS_Face myTopFace
std::vector< TNodeColumn * > myBndColumns
std::vector< TNodeColumn * > myIntColumns
Private Types
typedef std::vector< double > TZColumn
gp_XYZ bndPoint (int iP, int z) const
gp_XYZ intPoint (int iP, int z) const
bool projectIntPoints (const std::vector< gp_XYZ > &fromBndPoints, const std::vector< gp_XYZ > &toBndPoints, const std::vector< gp_XYZ > &fromIntPoints, std::vector< gp_XYZ > &toIntPoints, const double r, StdMeshers_ProjectionUtils::TrsfFinder3D &trsf, std::vector< gp_XYZ > *bndError)
 Projects internal nodes using transformation found by boundary nodes. More...
void prepareTopBotDelaunay ()
 Initialize *Delaunay members. More...
bool findDelaunayTriangles ()
 For each internal node column, find Delaunay triangles including it and Barycentric Coordinates within the triangles. More...
static void fillZColumn (TZColumn &zColumn, TNodeColumn &nodes)
 Compute Z of nodes of a straight column. More...
std::vector< TZColumn > myZColumns
StdMeshers_ProjectionUtils::DelaunayPtr myTopDelaunay
StdMeshers_ProjectionUtils::DelaunayPtr myBotDelaunay
TColStd_DataMapOfIntegerInteger myNodeID2ColID
std::vector< TopBotTriangles > myTopBotTriangles
◆ TZColumn
typedef std::vector< double > StdMeshers_Sweeper::TZColumn
◆ bndPoint()
gp_XYZ StdMeshers_Sweeper::bndPoint ( int  iP,
int  z
References myBndColumns.
◆ CheckSameZ()
bool StdMeshers_Sweeper::CheckSameZ ( )
Referenced by StdMeshers_Prism_3D::compute().
◆ ComputeNodesByTrsf()
bool StdMeshers_Sweeper::ComputeNodesByTrsf ( const double  tol,
References SMESH_MesherHelper::AddNode(), and StdMeshers_PrismAsBlock::myHelper.
◆ ComputeNodesOnStraight()
bool StdMeshers_Sweeper::ComputeNodesOnStraight ( )
References SMESH_MesherHelper::AddNode(), SMDS_MeshElement::GetID(), SMESH_MesherHelper::GetNodeUV(), and StdMeshers_PrismAsBlock::myHelper.
◆ ComputeNodesOnStraightSameZ()
bool StdMeshers_Sweeper::ComputeNodesOnStraightSameZ ( )
◆ fillZColumn()
void StdMeshers_Sweeper::fillZColumn ( TZColumn &  zColumn,
TNodeColumn &  nodes
staticprivate
◆ findDelaunayTriangles()
bool StdMeshers_Sweeper::findDelaunayTriangles ( )
◆ intPoint()
gp_XYZ StdMeshers_Sweeper::intPoint ( int  iP,
int  z
References myIntColumns.
◆ prepareTopBotDelaunay()
◆ projectIntPoints()
bool StdMeshers_Sweeper::projectIntPoints ( const std::vector< gp_XYZ > &  fromBndPoints,
const std::vector< gp_XYZ > &  toBndPoints,
const std::vector< gp_XYZ > &  fromIntPoints,
std::vector< gp_XYZ > &  toIntPoints,
const double  r,
StdMeshers_ProjectionUtils::TrsfFinder3D &  trsf,
std::vector< gp_XYZ > *  bndError
◆ myBndColumns
std::vector< TNodeColumn* > StdMeshers_Sweeper::myBndColumns
◆ myBotDelaunay
StdMeshers_ProjectionUtils::DelaunayPtr StdMeshers_Sweeper::myBotDelaunay
◆ myBotFace
TopoDS_Face StdMeshers_Sweeper::myBotFace
◆ myHelper
SMESH_MesherHelper* StdMeshers_Sweeper::myHelper
◆ myIntColumns
std::vector< TNodeColumn* > StdMeshers_Sweeper::myIntColumns
◆ myNodeID2ColID
TColStd_DataMapOfIntegerInteger StdMeshers_Sweeper::myNodeID2ColID
◆ myTopBotTriangles
std::vector< TopBotTriangles> StdMeshers_Sweeper::myTopBotTriangles
◆ myTopDelaunay
StdMeshers_ProjectionUtils::DelaunayPtr StdMeshers_Sweeper::myTopDelaunay
◆ myTopFace
TopoDS_Face StdMeshers_Sweeper::myTopFace
◆ myZColumns
std::vector< TZColumn > StdMeshers_Sweeper::myZColumns
