StdMeshers_ProjectionUtils Namespace Reference
Methods common to Projection algorithms. More...
class  Delaunay
 Create a Delaunay triangulation of nodes on a face boundary and provide exploration of nodes shared by elements lying on the face. More...
class  Morph
 Morph mesh on the target FACE to lie within FACE boundary w/o distortion. More...
class  TrsfFinder2D
 Finds transformation between two sets of 2D points using a least square approximation. More...
class  TrsfFinder3D
 Finds transformation between two sets of 3D points using a least square approximation. More...
Typedefs
typedef StdMeshers_ShapeShapeBiDirectionMap TShapeShapeMap
typedef TopTools_IndexedDataMapOfShapeListOfShape TAncestorMap
typedef std::map< const SMDS_MeshNode *, const SMDS_MeshNode *, TIDCompare > TNodeNodeMap
typedef boost::shared_ptr< Delaunay > DelaunayPtr
bool FindSubShapeAssociation (const TopoDS_Shape &theShape1, SMESH_Mesh *theMesh1, const TopoDS_Shape &theShape2, SMESH_Mesh *theMesh2, TShapeShapeMap &theAssociationMap)
 Looks for association of all sub-shapes of two shapes. More...
int FindFaceAssociation (const TopoDS_Face &face1, TopoDS_Vertex VV1[2], const TopoDS_Face &face2, TopoDS_Vertex VV2[2], std::list< TopoDS_Edge > &edges1, std::list< TopoDS_Edge > &edges2, const bool isClosenessAssoc=false)
 Find association of edges of faces. More...
void InitVertexAssociation (const SMESH_Hypothesis *theHyp, TShapeShapeMap &theAssociationMap)
 Insert vertex association defined by a hypothesis into a map. More...
bool InsertAssociation (const TopoDS_Shape &theShape1, const TopoDS_Shape &theShape2, TShapeShapeMap &theAssociationMap)
 Inserts association theShape1 <-> theShape2 to TShapeShapeMap. More...
TopoDS_Edge GetEdgeByVertices (SMESH_Mesh *aMesh, const TopoDS_Vertex &V1, const TopoDS_Vertex &V2)
 Finds an edge by its vertices in a main shape of the mesh. More...
TopoDS_Face GetNextFace (const TAncestorMap &edgeToFaces, const TopoDS_Edge &edge, const TopoDS_Face &face)
 Return another face sharing an edge. More...
TopoDS_Vertex GetNextVertex (const TopoDS_Edge &edge, const TopoDS_Vertex &vertex)
 Return other vertex of an edge. More...
std::pair< int, TopoDS_Edge > GetPropagationEdge (SMESH_Mesh *aMesh, const TopoDS_Edge &anEdge, const TopoDS_Edge &fromEdge, TopTools_IndexedMapOfShape *chain=0)
 Return an oriented propagation edge. More...
bool FindMatchingNodesOnFaces (const TopoDS_Face &face1, SMESH_Mesh *mesh1, const TopoDS_Face &face2, SMESH_Mesh *mesh2, const TShapeShapeMap &assocMap, TNodeNodeMap &nodeIn2OutMap)
 Find corresponding nodes on two faces. More...
TopoDS_Shape OuterShape (const TopoDS_Face &face, TopAbs_ShapeEnum type)
 Return any sub-shape of a face belonging to the outer wire. More...
bool MakeComputed (SMESH_subMesh *sm, const int iterationNb=0)
 Check that submeshis is computed and try to compute it if is not. More...
std::string SourceNotComputedError (SMESH_subMesh *sm=0, SMESH_Algo *projAlgo=0)
 Returns an error message to show in case if MakeComputed( sm ) fails. More...
void SetEventListener (SMESH_subMesh *subMesh, TopoDS_Shape srcShape, SMESH_Mesh *srcMesh)
 Set event listeners to submesh with projection algo. More...
TopoDS_Edge GetBoundaryEdge (const TopoDS_Shape &edgeContainer, const SMESH_Mesh &mesh, std::list< TopoDS_Edge > *allBndEdges=0)
 Return a boundary EDGE (or all boundary EDGEs) of edgeContainer. More...
Typedef Documentation
◆ DelaunayPtr
typedef boost::shared_ptr< Delaunay > StdMeshers_ProjectionUtils::DelaunayPtr
◆ TAncestorMap
typedef TopTools_IndexedDataMapOfShapeListOfShape StdMeshers_ProjectionUtils::TAncestorMap
◆ TNodeNodeMap
◆ TShapeShapeMap
◆ FindFaceAssociation()
int StdMeshers_ProjectionUtils::FindFaceAssociation ( const TopoDS_Face &  face1,
const TopoDS_Face &  face2,
std::list< TopoDS_Edge > &  edges1,
std::list< TopoDS_Edge > &  edges2,
const bool  isClosenessAssoc = false
face1- face 1
VV1- vertices of face 1
face2- face 2
VV2- vertices of face 2 associated with oned of face 1
edges1- out list of edges of face 1
edges2- out list of edges of face 2
isClosenessAssoc- is association starting by VERTEX closeness
int- nb of edges in an outer wire in a success case, else zero
References CONT_BAD_RESULT, SMESH_Algo::EdgeLength(), SMESH_Block::GetOrderedEdges(), Handle(), SMESH_MesherHelper::IsClosedEdge(), SMESH_Algo::isDegenerated(), SMESH_MesherHelper::IthVertex(), RETURN_BAD_RESULT, and reverse().
Referenced by FindSubShapeAssociation().
◆ FindMatchingNodesOnFaces()
bool StdMeshers_ProjectionUtils::FindMatchingNodesOnFaces ( const TopoDS_Face &  face1,
SMESH_Mesh *  mesh1,
SMESH_Mesh *  mesh2,
const TShapeShapeMap &  assocMap,
TNodeNodeMap &  nodeIn2OutMap
◆ FindSubShapeAssociation()
bool StdMeshers_ProjectionUtils::FindSubShapeAssociation ( const TopoDS_Shape &  theShape1,
SMESH_Mesh *  theMesh1,
const TopoDS_Shape &  theShape2,
SMESH_Mesh *  theMesh2,
TShapeShapeMap &  theAssociationMap
theShape1- shape 1
theMesh1- mesh built on shape 1
theShape2- shape 2
theMesh2- mesh built on shape 2
theAssociation- association map to be filled that may contain association of one or two pairs of vertices
bool- true if association found
References StdMeshers_ShapeShapeBiDirectionMap::_assocType, StdMeshers_ShapeShapeBiDirectionMap::_map1to2, SMESHUtils::Add(), StdMeshers_ShapeShapeBiDirectionMap::Bind(), SMESH_MesherHelper::Count(), Edge, StdMeshers_ShapeShapeBiDirectionMap::Extent(), Face, FindFaceAssociation(), FindSubShapeAssociation(), SMESH_Mesh::GetAncestorMap(), SMESH_MesherHelper::GetAncestors(), SMESH_Mesh::GetAncestors(), GetBoundaryEdge(), GetEdgeByVertices(), SMESH_Mesh::GetMeshDS(), GetNextFace(), GetNextVertex(), GetPropagationEdge(), SMESH_MesherHelper::GetSubShapeOri(), InsertAssociation(), StdMeshers_ShapeShapeBiDirectionMap::IsBound(), SMESH_MesherHelper::IsClosedEdge(), StdMeshers_ShapeShapeBiDirectionMap::IsEmpty(), SMESH_MesherHelper::IthVertex(), SMESHDS_Mesh::MeshElements(), OuterShape(), RETURN_BAD_RESULT, StdMeshers_ShapeShapeBiDirectionMap::SetAssocType(), and SMESHDS_Mesh::ShapeToIndex().
Referenced by StdMeshers_Prism_3D::assocOrProjBottom2Top(), StdMeshers_Projection_1D::Compute(), StdMeshers_Projection_2D::Compute(), StdMeshers_Projection_3D::Compute(), StdMeshers_RadialPrism_3D::Compute(), StdMeshers_Projection_1D::Evaluate(), StdMeshers_Projection_1D2D::Evaluate(), StdMeshers_Projection_2D::Evaluate(), StdMeshers_RadialPrism_3D::Evaluate(), and FindSubShapeAssociation().
◆ GetBoundaryEdge()
TopoDS_Edge StdMeshers_ProjectionUtils::GetBoundaryEdge ( const TopoDS_Shape &  edgeContainer,
const SMESH_Mesh &  mesh,
std::list< TopoDS_Edge > *  allBndEdges = 0
References Edge, and SMESH_MesherHelper::GetAncestors().
◆ GetEdgeByVertices()
TopoDS_Edge StdMeshers_ProjectionUtils::GetEdgeByVertices ( SMESH_Mesh *  aMesh,
const TopoDS_Vertex &  V1,
const TopoDS_Vertex &  V2
References Edge, and SMESH_Mesh::GetAncestors().
Referenced by StdMeshers_Projection_2D::CheckHypothesis(), StdMeshers_Projection_3D::CheckHypothesis(), and FindSubShapeAssociation().
◆ GetNextFace()
TopoDS_Face StdMeshers_ProjectionUtils::GetNextFace ( const TAncestorMap &  edgeToFaces,
const TopoDS_Edge &  edge,
edgeToFaces- data map of descendants to ancestors
References Face.
◆ GetNextVertex()
TopoDS_Vertex StdMeshers_ProjectionUtils::GetNextVertex ( const TopoDS_Edge &  edge,
const TopoDS_Vertex &  vertex
◆ GetPropagationEdge()
pair< int, TopoDS_Edge > StdMeshers_ProjectionUtils::GetPropagationEdge ( SMESH_Mesh *  aMesh,
const TopoDS_Edge &  anEdge,
const TopoDS_Edge &  fromEdge,
TopTools_IndexedMapOfShape *  chain = 0
aMesh- mesh
fromEdge- start edge for propagation
chain- return, if provided, a propagation chain passed till anEdge; if anEdge.IsNull() then a full propagation chain is returned
pair<int,TopoDS_Edge>- propagation step and found edge
Referenced by StdMeshers_Prism_3D::Compute(), and FindSubShapeAssociation().
◆ InitVertexAssociation()
◆ InsertAssociation()
bool StdMeshers_ProjectionUtils::InsertAssociation ( const TopoDS_Shape &  theShape1,
theShape1- target shape
theShape2- source shape
theAssociationMap- association map
theBidirectional- if false, inserts theShape1 -> theShape2 association
bool- true if there was no association for these shapes before
References StdMeshers_ShapeShapeBiDirectionMap::Bind(), and SHOW_SHAPE.
Referenced by StdMeshers_Prism_3D::assocOrProjBottom2Top(), FindSubShapeAssociation(), and InitVertexAssociation().
◆ MakeComputed()
◆ OuterShape()
TopoDS_Shape StdMeshers_ProjectionUtils::OuterShape ( const TopoDS_Face &  face,
face- the face
type- type of sub-shape to return
TopoDS_Shape- the found sub-shape
Referenced by FindMatchingNodesOnFaces(), and FindSubShapeAssociation().
◆ SetEventListener()
void StdMeshers_ProjectionUtils::SetEventListener ( SMESH_subMesh *  subMesh,
SMESH_Mesh *  srcMesh
◆ SourceNotComputedError()
