SMESH_MeshAlgos Namespace Reference
struct  CoincidentFreeBorders
struct  Edge
class  Intersector
 Cut faces of a triangular mesh. More...
struct  PolySegment
struct  TFreeBorderPart
class  Triangulate
 Divide a mesh face into triangles. More...
Typedefs
typedef std::vector< std::vector< const SMDS_MeshElement * > > TElemGroupVector
typedef std::vector< std::vector< const SMDS_MeshNode * > > TNodeGroupVector
typedef std::vector< const SMDS_MeshNode * > TFreeBorder
typedef std::vector< TFreeBorder > TFreeBorderVec
typedef std::vector< TFreeBorderPart > TCoincidentGroup
typedef std::vector< TCoincidentGroup > TCoincidentGroupVec
typedef std::vector< std::pair< const SMDS_MeshElement *, int > > TElemIntPairVec
typedef std::vector< std::pair< const SMDS_MeshNode *, int > > TNodeIntPairVec
typedef std::vector< PolySegment > TListOfPolySegments
SMESH_NodeSearcher * GetNodeSearcher (SMDS_Mesh &mesh)
 Return SMESH_NodeSearcher. More...
SMESH_NodeSearcher * GetNodeSearcher (SMDS_ElemIteratorPtr elemIt)
SMESH_ElementSearcher * GetElementSearcher (SMDS_Mesh &mesh, double tolerance=-1.)
 Return SMESH_ElementSearcher. More...
SMESH_ElementSearcher * GetElementSearcher (SMDS_Mesh &mesh, SMDS_ElemIteratorPtr elemIt, double tolerance=-1.)
 Return SMESH_ElementSearcher acting on a sub-set of elements. More...
bool IsOut (const SMDS_MeshElement *element, const gp_Pnt &point, double tol)
 Return true if the point is IN or ON of the element. More...
double GetDistance (const SMDS_MeshElement *elem, const gp_Pnt &point, gp_XYZ *closestPnt=0)
 Return minimal distance from a point to an element. More...
double GetDistance (const SMDS_MeshEdge *edge, const gp_Pnt &point, gp_XYZ *closestPnt=0)
 Return minimal distance from a point to an edge. More...
double GetDistance (const SMDS_MeshFace *face, const gp_Pnt &point, gp_XYZ *closestPnt=0)
 Return minimal distance from a point to a face. More...
double GetDistance (const SMDS_MeshVolume *volume, const gp_Pnt &point, gp_XYZ *closestPnt=0)
 Return minimal distance from a point to a volume. More...
void GetBarycentricCoords (const gp_XY &point, const gp_XY &t0, const gp_XY &t1, const gp_XY &t2, double &bc0, double &bc1)
 Returns barycentric coordinates of a point within a triangle. More...
bool IntersectRayVolume (const gp_Ax1 &ray, const double rayLen, const SMDS_MeshElement *vol, double &tMin, double &tMax, int &iFacetMin, int &iFacetMax)
 Intersect volume by a ray. More...
const SMDS_MeshElement * FindFaceInSet (const SMDS_MeshNode *n1, const SMDS_MeshNode *n2, const TIDSortedElemSet &elemSet, const TIDSortedElemSet &avoidSet, int *i1=0, int *i2=0)
 Return a face having linked nodes n1 and n2 and which is. More...
bool FaceNormal (const SMDS_MeshElement *F, gp_XYZ &normal, bool normalized=true)
 Calculate normal of a mesh face. More...
int NbCommonNodes (const SMDS_MeshElement *e1, const SMDS_MeshElement *e2)
 Return number of nodes common to two elements. More...
std::vector< const SMDS_MeshNode * > GetCommonNodes (const SMDS_MeshElement *e1, const SMDS_MeshElement *e2)
 Return nodes common to two elements. More...
bool IsOn2DBoundary (const SMDS_MeshNode *node, std::vector< const SMDS_MeshNode * > *neibors=nullptr)
 Return true if a node is on a boundary of 2D mesh. More...
bool IsRightOrder (const SMDS_MeshElement *face, const SMDS_MeshNode *node0, const SMDS_MeshNode *node1)
 Return true if node1 encounters first in the face and node2, after. More...
void Get1DBranches (SMDS_ElemIteratorPtr edgeIt, TElemGroupVector &edgeGroups, TNodeGroupVector &nodeGroups, const SMDS_MeshNode *startNode=0)
 Partition given 1D elements into groups of contiguous edges. More...
template<class ElemIter >
void MarkElems (ElemIter it, const bool isMarked)
 Mark elements given by SMDS_Iterator. More...
void MarkElems (ElemIter it, ElemIter end, const bool isMarked)
 Mark elements given by std iterators. More...
void MarkElemNodes (ElemIter it, const bool isMarked, const bool markElem=false)
 Mark nodes of elements given by SMDS_Iterator. More...
void MarkElemNodes (ElemIter it, ElemIter end, const bool isMarked, const bool markElem=false)
std::vector< Edge > FindSharpEdges (SMDS_Mesh *mesh, double angle, bool addExisting)
 Return sharp edges of faces and non-manifold ones. More...
std::vector< std::vector< const SMDS_MeshElement * > > SeparateFacesByEdges (SMDS_Mesh *mesh, const std::vector< Edge > &edges)
 Distribute all faces of the mesh between groups using given edges. More...
void FindCoincidentFreeBorders (SMDS_Mesh &mesh, double tolerance, CoincidentFreeBorders &foundFreeBordes)
 Returns TFreeBorder's coincident within the given tolerance. More...
void FindFreeBorders (SMDS_Mesh &mesh, TFreeBorderVec &foundFreeBordes, const bool closedOnly, bool *isManifold=0, bool *isGoodOri=0)
 Returns all or only closed TFreeBorder's. More...
void FillHole (const TFreeBorder &freeBorder, SMDS_Mesh &mesh, std::vector< const SMDS_MeshElement * > &newFaces)
 Fill a hole defined by a TFreeBorder with 2D elements. More...
void DeMerge (const SMDS_MeshElement *elem, std::vector< const SMDS_MeshNode * > &newNodes, std::vector< const SMDS_MeshNode * > &noMergeNodes)
 Find nodes whose merge makes the element invalid. More...
SMDS_Mesh * MakeOffset (SMDS_ElemIteratorPtr faceIt, SMDS_Mesh &mesh, const double offset, const bool theFixIntersections, TElemIntPairVec &new2OldFaces, TNodeIntPairVec &new2OldNodes)
 Create an offset mesh of given faces. More...
void MakePolyLine (SMDS_Mesh *mesh, TListOfPolySegments &segments, std::vector< const SMDS_MeshElement * > &newEdges, std::vector< const SMDS_MeshNode * > &newNodes, SMDS_MeshGroup *group=0, SMESH_ElementSearcher *searcher=0)
 Create a polyline consisting of 1D mesh elements each lying on a 2D element of the initial mesh. More...
std::vector< Edge > MakeSlot (SMDS_ElemIteratorPtr segmentIt, double width, SMDS_Mesh *mesh, std::vector< SMDS_MeshGroup * > &groupsToUpdate)
 Create a slot of given width around given 1D elements lying on a triangle mesh. More...
int MaxIndex (const gp_XYZ &x)
 Return coordinate index with maximal abs value. More...
Typedef Documentation
◆ TCoincidentGroup
◆ TCoincidentGroupVec
◆ TElemGroupVector
typedef std::vector< std::vector< const SMDS_MeshElement* > > SMESH_MeshAlgos::TElemGroupVector
◆ TElemIntPairVec
typedef std::vector< std::pair< const SMDS_MeshElement*, int > > SMESH_MeshAlgos::TElemIntPairVec
◆ TFreeBorder
typedef std::vector<const SMDS_MeshNode*> SMESH_MeshAlgos::TFreeBorder
◆ TFreeBorderVec
◆ TListOfPolySegments
◆ TNodeGroupVector
typedef std::vector< std::vector< const SMDS_MeshNode* > > SMESH_MeshAlgos::TNodeGroupVector
◆ TNodeIntPairVec
typedef std::vector< std::pair< const SMDS_MeshNode*, int > > SMESH_MeshAlgos::TNodeIntPairVec
◆ DeMerge()
void SMESH_MeshAlgos::DeMerge ( const SMDS_MeshElement *  elem,
std::vector< const SMDS_MeshNode * > &  newNodes,
std::vector< const SMDS_MeshNode * > &  noMergeNodes
(Degenerated elem is OK)
[in]elem- the element
[in]newNodes- nodes of the element after the merge
[out]noMergeNodes- nodes to undo merge
References SMDS_MeshCell::applyInterlace(), SMDS_MeshElement::GetEntityType(), SMDS_MeshElement::GetType(), SMDS_MeshCell::interlacedSmdsOrder(), SMDS_MeshElement::IsQuadratic(), SMDS_VolumeTool::Set(), SMDSAbs_Edge, SMDSAbs_Face, and SMDSAbs_Volume.
Referenced by SMESH_MeshEditor::applyMerge().
◆ FaceNormal()
◆ FillHole()
void SMESH_MeshAlgos::FillHole ( const TFreeBorder &  freeBorder,
SMDS_Mesh &  mesh,
std::vector< const SMDS_MeshElement * > &  newFaces
Fill with 2D elements a hole defined by a TFreeBorder.
References ObjectPool< X >::getNew(), and SMDSAbs_Face.
Referenced by SMESH_MeshEditor_i::FillHole().
◆ FindCoincidentFreeBorders()
◆ FindFaceInSet()
◆ FindFreeBorders()
void SMESH_MeshAlgos::FindFreeBorders ( SMDS_Mesh &  mesh,
TFreeBorderVec &  foundFreeBordes,
bool *  isManifold = 0,
bool *  isGoodOri = 0
◆ FindSharpEdges()
◆ Get1DBranches()
void SMESH_MeshAlgos::Get1DBranches ( SMDS_ElemIteratorPtr  theEdgeIt,
TElemGroupVector &  theEdgeGroups,
TNodeGroupVector &  theNodeGroups,
const SMDS_MeshNode *  theStartNode = 0
A node where number of meeting edges != 2 is a group end. An optional startNode is used to orient groups it belongs to.
a list of edge groups and a list of corresponding node groups. If a group is closed, the first and last nodes of the group are same.
References begin(), end(), SMDS_MeshNode::GetNode(), SMDS_MeshElement::GetNode(), SMDS_MeshElement::GetType(), reverse(), and SMDSAbs_Edge.
Referenced by SMESH_MeshEditor::ExtrusionAlongTrack(), and SMESH_MeshEditor_i::Get1DBranches().
◆ GetBarycentricCoords()
void SMESH_MeshAlgos::GetBarycentricCoords ( const gp_XY &  p,
const gp_XY &  t0,
const gp_XY &  t1,
const gp_XY &  t2,
double &  bc0,
double &  bc1
A not returned bc2 = 1. - bc0 - bc1. The point lies within the triangle if ( bc0 >= 0 && bc1 >= 0 && bc0+bc1 <= 1 )
Referenced by FaceQuadStruct::findCell(), SMESH_Delaunay::FindTriangle(), FaceQuadStruct::isNear(), and SMESH_MeshAlgos::Intersector::Algo::isPointInTriangle().
◆ GetCommonNodes()
std::vector< const SMDS_MeshNode * > SMESH_MeshAlgos::GetCommonNodes ( const SMDS_MeshElement *  e1,
const SMDS_MeshElement *  e2
References SMDS_MeshElement::GetNode(), SMDS_MeshElement::GetNodeIndex(), and SMDS_MeshElement::NbNodes().
◆ GetDistance() [1/4]
double SMESH_MeshAlgos::GetDistance ( const SMDS_MeshEdge *  edge,
const gp_Pnt &  point,
gp_XYZ *  closestPnt = 0
References MESHCUT::d, SMDS_MeshCell::interlacedNodesIterator(), and SMDS_MeshCell::NbNodes().
◆ GetDistance() [2/4]
double SMESH_MeshAlgos::GetDistance ( const SMDS_MeshElement *  elem,
◆ GetDistance() [3/4]
double SMESH_MeshAlgos::GetDistance ( const SMDS_MeshFace *  face,
Currently we ignore non-planarity and 2nd order of face
References GetDistance(), SMESH_MeshAlgos::Triangulate::GetTriangles(), SMDS_MeshCell::NbCornerNodes(), and SMDS_MeshCell::nodesIterator().
◆ GetDistance() [4/4]
double SMESH_MeshAlgos::GetDistance ( const SMDS_MeshVolume *  volume,
◆ GetElementSearcher() [1/2]
◆ GetElementSearcher() [2/2]
SMESH_ElementSearcher * SMESH_MeshAlgos::GetElementSearcher ( SMDS_Mesh &  mesh,
double  tolerance = -1.
◆ GetNodeSearcher() [1/2]
SMESH_NodeSearcher * SMESH_MeshAlgos::GetNodeSearcher ( SMDS_ElemIteratorPtr  elemIt)
◆ GetNodeSearcher() [2/2]
SMESH_NodeSearcher * SMESH_MeshAlgos::GetNodeSearcher ( SMDS_Mesh &  mesh)
◆ IntersectRayVolume()
bool SMESH_MeshAlgos::IntersectRayVolume ( const gp_Ax1 &  ray,
const SMDS_MeshElement *  vol,
double &  tMin,
double &  tMax,
int &  iFacetMin,
int &  iFacetMax
Intersect a ray with a convex volume.
[in]ray- the ray
[in]rayLen- ray length
[in]vol- the volume
[out]tMin- return a ray parameter where the ray enters the volume
[out]tMax- return a ray parameter where the ray exit the volume
[out]iFacetMin- facet index where the ray enters the volume
[out]iFacetMax- facet index where the ray exit the volume
bool - true if the ray intersects the volume
References SMDS_VolumeTool::GetFaceNodes(), SMDS_VolumeTool::GetFaceNormal(), SMDS_VolumeTool::NbFaces(), and SMDS_VolumeTool::Set().
◆ IsOn2DBoundary()
bool SMESH_MeshAlgos::IsOn2DBoundary ( const SMDS_MeshNode *  theNode,
std::vector< const SMDS_MeshNode * > *  theNeibors = nullptr
Optionally returns two neighboring boundary nodes (or more in non-manifold mesh)
References SMDS_MeshNode::GetInverseElementIterator(), SMDS_MeshElement::GetNode(), SMDS_MeshElement::GetNodeIndex(), SMDS_MeshElement::NbCornerNodes(), and SMDSAbs_Face.
Referenced by SMESH_MeshEditor::RemoveNodeWithReconnection().
◆ IsOut()
◆ IsRightOrder()
bool SMESH_MeshAlgos::IsRightOrder ( const SMDS_MeshElement *  face,
const SMDS_MeshNode *  node0,
const SMDS_MeshNode *  node1
The nodes are supposed to be neighbor nodes in the face.
References SMDS_MeshElement::GetNodeIndex(), SMDS_MeshElement::IsMediumNode(), SMDS_MeshElement::IsQuadratic(), and SMDS_MeshElement::NbNodes().
Referenced by findExistingTriangulation(), and FindFreeBorders().
◆ MakeOffset()
SMDS_Mesh * SMESH_MeshAlgos::MakeOffset ( SMDS_ElemIteratorPtr  theFaceIt,
SMDS_Mesh &  theSrcMesh,
const double  theOffset,
TElemIntPairVec &  theNew2OldFaces,
TNodeIntPairVec &  theNew2OldNodes
Create an offsetMesh of given faces.
[in]faceIt- the input faces
[in]theFixIntersections- to fix self intersections of the offset mesh or not
[out]new2OldFaces- history of faces
[out]new2OldNodes- history of nodes
SMDS_Mesh* - the new offset mesh, a caller should delete
[out]new2OldFaces- history of faces (new face -> old face ID)
[out]new2OldNodes- history of nodes (new node -> old node ID)
References SMDS_Mesh::AddFace(), SMDS_Mesh::AddNode(), SMDS_Mesh::AddNodeWithID(), SMDS_Mesh::AddPolygonalFace(), SMDS_Mesh::AddQuadPolygonalFace(), SMDS_MeshElement::begin_nodes(), SMDS_Mesh::ChangeElementNodes(), SMESH_MeshAlgos::Intersector::Cut(), SMDS_MeshElement::end_nodes(), FaceNormal(), SMDS_Mesh::FindNode(), GetElementSearcher(), SMDS_MeshElement::GetEntityType(), SMDS_MeshElement::GetID(), SMDS_MeshNode::GetInverseElementIterator(), SMDS_Mesh::GetMeshInfo(), SMDS_MeshElement::GetNodeIndex(), SMDS_MeshElement::GetType(), SMDS_MeshElement::isMarked(), SMESH_MeshAlgos::Intersector::MakeNewFaces(), SMDS_Mesh::MoveNode(), SMDS_MeshInfo::NbFaces(), SMDS_MeshInfo::NbTriangles(), SMESH_TNodeXYZ::Node(), SMDS_MeshElement::nodesIterator(), ORDER_QUADRATIC, SMDS_Mesh::RemoveFreeElement(), SMESH_TNodeXYZ::Set(), SMDS_MeshElement::setIsMarked(), SMDSAbs_Face, SMDSEntity_BiQuad_Quadrangle, SMDSEntity_BiQuad_Triangle, SMDSEntity_Polygon, SMDSEntity_Quad_Polygon, SMDSEntity_Quad_Quadrangle, SMDSEntity_Quad_Triangle, SMDSEntity_Quadrangle, SMDSEntity_Triangle, and SMDS_MeshNode::X().
Referenced by SMESH_MeshEditor::Offset().
◆ MakePolyLine()
void SMESH_MeshAlgos::MakePolyLine ( SMDS_Mesh *  mesh,
TListOfPolySegments &  segments,
std::vector< const SMDS_MeshElement * > &  newEdges,
SMDS_MeshGroup *  group = 0,
SMESH_ElementSearcher *  searcher = 0
Positions of new nodes are found by cutting the mesh by the plane passing through pairs of points specified by each PolySegment structure. If there are several paths connecting a pair of points, the shortest path is selected by the module. Position of the cutting plane is defined by the two points and an optional vector lying on the plane specified by a PolySegment. By default the vector is defined by Mesh module as following. A middle point of the two given points is computed. The middle point is projected to the mesh. The vector goes from the middle point to the projection point. In case of planar mesh, the vector is normal to the mesh.
[in,out]segments- PolySegment's defining positions of cutting planes. Return the used vector and position of the middle point.
[in]group- an optional group where created mesh segments will be added.
References SMESHUtils::Deleter< TOBJ >::_obj, SMDS_MeshGroup::Add(), SMDS_Mesh::AddEdge(), SMDS_Mesh::AddNode(), FaceNormal(), GetElementSearcher(), SMESH_ElementSearcher::GetElementsInSphere(), SMESH_MeshAlgos::PolySegment::myFace, SMESH_MeshAlgos::PolySegment::myMidProjPoint, SMESH_MeshAlgos::PolySegment::myNode1, SMESH_MeshAlgos::PolySegment::myNode2, SMESH_MeshAlgos::PolySegment::myVector, SMESH_MeshAlgos::PolySegment::myXYZ, SMDS_Mesh::nodesIterator(), SMESH_ElementSearcher::Project(), and SMDSAbs_Face.
Referenced by SMESH_MeshEditor_i::MakePolyLine(), and MakeSlot().
◆ MakeSlot()
◆ MarkElemNodes() [1/2]
void SMESH_MeshAlgos::MarkElemNodes ( ElemIter  it,
const bool  markElem = false
◆ MarkElemNodes() [2/2]
ElemIter  end,
References end(), and MarkElems().
◆ MarkElems() [1/2]
void SMESH_MeshAlgos::MarkElems ( ElemIter  it,
const bool  isMarked
◆ MarkElems() [2/2]
ElemIter  end,
const bool  isMarked
References end().
◆ MaxIndex()
int SMESH_MeshAlgos::MaxIndex ( const gp_XYZ &  x)
Referenced by SMESH_MeshAlgos::Intersector::Algo::Cut(), and SMESH_MeshAlgos::Intersector::Algo::setPlaneIndices().
◆ NbCommonNodes()
int SMESH_MeshAlgos::NbCommonNodes ( const SMDS_MeshElement *  e1,
◆ SeparateFacesByEdges()
std::vector< std::vector< const SMDS_MeshElement * > > SMESH_MeshAlgos::SeparateFacesByEdges ( SMDS_Mesh *  mesh,
const std::vector< Edge > &  edges
Distribute all faces of the mesh between groups using given edges as group boundaries.
References SMDS_MeshElement::begin_nodes(), SMDS_MeshElement::end_nodes(), SMDS_Mesh::facesIterator(), SMDS_MeshElement::isMarked(), SMDS_MeshElement::NbCornerNodes(), SMDS_Mesh::NbFaces(), and SMDS_MeshElement::setIsMarked().
Referenced by SMESH_Mesh_i::FaceGroupsSeparatedByEdges().
