VISCOUS_3D::_ViscousBuilder Class Reference
Builder of viscous layers. More...
 _ViscousBuilder ()
 Constructor of _ViscousBuilder. More...
SMESH_ComputeErrorPtr Compute (SMESH_Mesh &mesh, const TopoDS_Shape &shape)
 Does its job. More...
SMESH_ComputeErrorPtr CheckHypotheses (SMESH_Mesh &mesh, const TopoDS_Shape &shape)
 Check validity of hypotheses. More...
void RestoreListeners ()
 At study restoration, restore event listeners used to clear an inferior dim sub-mesh modified by viscous layers. More...
bool MakeN2NMap (_MeshOfSolid *pm)
 computes SMESH_ProxyMesh::SubMesh::_n2n More...
bool findSolidsWithLayers (const bool checkFaceMesh=true)
 Finds SOLIDs to compute using viscous layers. More...
bool setBefore (_SolidData &solidBefore, _SolidData &solidAfter)
 Set a _SolidData to be computed before another. More...
bool findFacesWithLayers (const bool onlyWith=false)
void findPeriodicFaces ()
 Find FACEs to shrink, that are equally meshed before shrink (i.e. More...
void getIgnoreFaces (const TopoDS_Shape &solid, const StdMeshers_ViscousLayers *hyp, const TopoDS_Shape &hypShape, set< TGeomID > &ignoreFaces)
 Finds FACEs w/o layers for a given SOLID by an hypothesis. More...
int makeEdgesOnShape ()
 Set up _SolidData::_edgesOnShape. More...
bool makeLayer (_SolidData &data)
 Create the inner surface of the viscous layer and prepare data for infation. More...
void setShapeData (_EdgesOnShape &eos, SMESH_subMesh *sm, _SolidData &data)
 initialize data of _EdgesOnShape More...
bool setEdgeData (_LayerEdge &edge, _EdgesOnShape &eos, SMESH_MesherHelper &helper, _SolidData &data)
 Set data of _LayerEdge needed for smoothing. More...
gp_XYZ getFaceNormal (const SMDS_MeshNode *n, const TopoDS_Face &face, SMESH_MesherHelper &helper, bool &isOK, bool shiftInside=false)
 Return normal to a FACE at a node. More...
bool getFaceNormalAtSingularity (const gp_XY &uv, const TopoDS_Face &face, SMESH_MesherHelper &helper, gp_Dir &normal)
 Try to get normal at a singularity of a surface basing on it's nature. More...
gp_XYZ getWeigthedNormal (const _LayerEdge *edge)
 Return a normal at a node weighted with angles taken by faces. More...
gp_XYZ getNormalByOffset (_LayerEdge *edge, std::pair< TopoDS_Face, gp_XYZ > fId2Normal[], int nbFaces, bool lastNoOffset=false)
 Return a normal at a node by getting a common point of offset planes defined by the FACE normals. More...
bool findNeiborsOnEdge (const _LayerEdge *edge, const SMDS_MeshNode *&n1, const SMDS_MeshNode *&n2, _EdgesOnShape &eos, _SolidData &data)
 Find 2 neighbor nodes of a node on EDGE. More...
void findSimplexTestEdges (_SolidData &data, vector< vector< _LayerEdge * > > &edgesByGeom)
void computeGeomSize (_SolidData &data)
 Find maximal _LayerEdge length (layer thickness) limited by geometry. More...
bool findShapesToSmooth (_SolidData &data)
 Detect shapes (and _LayerEdge's on them) to smooth. More...
void limitStepSizeByCurvature (_SolidData &data)
 Limit data._stepSize by evaluating curvature of shapes and fill data._convexFaces. More...
void limitStepSize (_SolidData &data, const SMDS_MeshElement *face, const _LayerEdge *maxCosinEdge)
 Compute inflation step size by min size of element on a convex surface. More...
void limitStepSize (_SolidData &data, const double minSize)
bool inflate (_SolidData &data)
 Increase length of _LayerEdge's to reach the required thickness of layers. More...
bool smoothAndCheck (_SolidData &data, const int nbSteps, double &distToIntersection)
 Improve quality of layer inner surface and check intersection. More...
int invalidateBadSmooth (_SolidData &data, SMESH_MesherHelper &helper, vector< _LayerEdge * > &badSmooEdges, vector< _EdgesOnShape * > &eosC1, const int infStep)
 try to fix bad simplices by removing the last inflation step of some _LayerEdge's More...
void makeOffsetSurface (_EdgesOnShape &eos, SMESH_MesherHelper &)
 Create an offset surface. More...
void putOnOffsetSurface (_EdgesOnShape &eos, int infStep, vector< _EdgesOnShape * > &eosC1, int smooStep=0, int moveAll=false)
 Put nodes of a curved FACE to its offset surface. More...
void findCollisionEdges (_SolidData &data, SMESH_MesherHelper &helper)
 Fill data._collisionEdges. More...
void findEdgesToUpdateNormalNearConvexFace (_ConvexFace &convFace, _SolidData &data, SMESH_MesherHelper &helper)
 Find _LayerEdge's located on boundary of a convex FACE whose normal will be updated at each inflation step. More...
void limitMaxLenByCurvature (_SolidData &data, SMESH_MesherHelper &helper)
 Limit _LayerEdge::_maxLen according to local curvature. More...
void limitMaxLenByCurvature (_LayerEdge *e1, _LayerEdge *e2, _EdgesOnShape &eos1, _EdgesOnShape &eos2, const bool isSmoothable)
bool updateNormals (_SolidData &data, SMESH_MesherHelper &helper, int stepNb, double stepSize)
 Modify normals of _LayerEdge's on EDGE's to avoid intersection with _LayerEdge's on neighbor EDGE's. More...
bool updateNormalsOfConvexFaces (_SolidData &data, SMESH_MesherHelper &helper, int stepNb)
 Modify normals of _LayerEdge's on _ConvexFace's. More...
void updateNormalsOfC1Vertices (_SolidData &data)
 Modify normals of _LayerEdge's on C1 VERTEXes. More...
bool updateNormalsOfSmoothed (_SolidData &data, SMESH_MesherHelper &helper, const int nbSteps, const double stepSize)
 Modify normals of _LayerEdge's on FACE to reflex smoothing. More...
bool isNewNormalOk (_SolidData &data, _LayerEdge &edge, const gp_XYZ &newNormal)
 Check if a new normal is OK. More...
bool refine (_SolidData &data)
 Create layers of prisms. More...
bool shrink (_SolidData &data)
 Shrink 2D mesh on faces to let space for inflated layers. More...
bool prepareEdgeToShrink (_LayerEdge &edge, _EdgesOnShape &eos, SMESH_MesherHelper &helper, const SMESHDS_SubMesh *faceSubMesh)
 Computes 2d shrink direction and finds nodes limiting shrinking. More...
void restoreNoShrink (_LayerEdge &edge) const
 Restore position of a sole node of a _LayerEdge based on _noShrinkShapes. More...
void fixBadFaces (const TopoDS_Face &F, SMESH_MesherHelper &helper, const bool is2D, const int step, set< const SMDS_MeshNode * > *involvedNodes=NULL)
 Try to fix triangles with high aspect ratio by swapping diagonals. More...
bool addBoundaryElements (_SolidData &data)
 Creates 2D and 1D elements on boundaries of new prisms. More...
bool error (const string &text, int solidID=-1)
 Stores error description and returns false. More...
SMESHDS_Mesh * getMeshDS () const
void makeGroupOfLE ()
 DEBUG. More...
SMESH_Mesh * _mesh
SMESH_ComputeErrorPtr _error
vector< _SolidData > _sdVec
TopTools_IndexedMapOfShape _solids
TopTools_MapOfShape _shrunkFaces
std::unique_ptr< Periodicity > _periodicity
int _tmpFaceID
PyDump * _pyDump
◆ _ViscousBuilder()
_ViscousBuilder::_ViscousBuilder ( )
◆ addBoundaryElements()
◆ CheckHypotheses()
SMESH_ComputeErrorPtr _ViscousBuilder::CheckHypotheses ( SMESH_Mesh &  mesh,
const TopoDS_Shape &  shape
◆ Compute()
◆ computeGeomSize()
◆ error()
◆ findCollisionEdges()
◆ findEdgesToUpdateNormalNearConvexFace()
◆ findFacesWithLayers()
◆ findNeiborsOnEdge()
◆ findPeriodicFaces()
void _ViscousBuilder::findPeriodicFaces ( )
periodic) and should remain equal after shrink
References _mesh, _periodicity, _sdVec, VISCOUS_3D::PeriodicFaces::_shriFace, VISCOUS_3D::_SolidData::_shrinkShape2Shape, getMeshDS(), SMESH_Mesh::GetSubMeshContaining(), VISCOUS_3D::ShrinkFace::IsPeriodic(), and SMESHDS_Mesh::ShapeToIndex().
Referenced by Compute().
◆ findShapesToSmooth()
bool _ViscousBuilder::findShapesToSmooth ( _SolidData &  data)
◆ findSimplexTestEdges()
void VISCOUS_3D::_ViscousBuilder::findSimplexTestEdges ( _SolidData &  data,
vector< vector< _LayerEdge * > > &  edgesByGeom
◆ findSolidsWithLayers()
◆ fixBadFaces()
◆ getFaceNormal()
gp_XYZ _ViscousBuilder::getFaceNormal ( const SMDS_MeshNode *  node,
const TopoDS_Face &  face,
SMESH_MesherHelper &  helper,
bool &  isOK,
bool  shiftInside = false
◆ getFaceNormalAtSingularity()
bool _ViscousBuilder::getFaceNormalAtSingularity ( const gp_XY &  uv,
gp_Dir &  normal
References MESHCUT::d, VISCOUS_3D::getRovolutionAxis(), and Handle().
Referenced by getFaceNormal().
◆ getIgnoreFaces()
void _ViscousBuilder::getIgnoreFaces ( const TopoDS_Shape &  solid,
const StdMeshers_ViscousLayers *  hyp,
const TopoDS_Shape &  hypShape,
set< TGeomID > &  ignoreFaces
◆ getMeshDS()
◆ getNormalByOffset()
gp_XYZ _ViscousBuilder::getNormalByOffset ( _LayerEdge *  edge,
int  nbFaces,
bool  lastNoOffset = false
◆ getWeigthedNormal()
gp_XYZ _ViscousBuilder::getWeigthedNormal ( const _LayerEdge *  edge)
References VISCOUS_3D::_LayerEdge::_nodes, VISCOUS_3D::_LayerEdge::_simplices, and SMESH_TNodeXYZ::Set().
Referenced by getNormalByOffset(), and setEdgeData().
◆ inflate()
◆ invalidateBadSmooth()
◆ isNewNormalOk()
bool _ViscousBuilder::isNewNormalOk ( _SolidData &  data,
_LayerEdge &  edge,
const gp_XYZ &  newNormal
◆ limitMaxLenByCurvature() [1/2]
◆ limitMaxLenByCurvature() [2/2]
◆ limitStepSize() [1/2]
void _ViscousBuilder::limitStepSize ( _SolidData &  data,
References VISCOUS_3D::_SolidData::_stepSize, VISCOUS_3D::_SolidData::_stepSizeCoeff, VISCOUS_3D::_SolidData::_stepSizeNodes, and SMESH_TNodeXYZ::Distance().
◆ limitStepSize() [2/2]
◆ limitStepSizeByCurvature()
◆ makeEdgesOnShape()
◆ makeGroupOfLE()
◆ makeLayer()
bool _ViscousBuilder::makeLayer ( _SolidData &  data)
References VISCOUS_3D::_LayerEdge::_2neibors, VISCOUS_3D::_LayerEdge::_cosin, VISCOUS_3D::_2NearEdges::_edges, VISCOUS_3D::_EdgesOnShape::_edges, VISCOUS_3D::_SolidData::_edgesOnShape, VISCOUS_3D::_SolidData::_epsilon, VISCOUS_3D::_SolidData::_ignoreFaceIds, VISCOUS_3D::_SolidData::_index, VISCOUS_3D::_LayerEdge::_lenFactor, _mesh, VISCOUS_3D::_SolidData::_n2eMap, VISCOUS_3D::_LayerEdge::_neibors, VISCOUS_3D::_Simplex::_nNext, VISCOUS_3D::_LayerEdge::_nodes, VISCOUS_3D::_LayerEdge::_normal, VISCOUS_3D::_SolidData::_noShrinkShapes, VISCOUS_3D::_Simplex::_nPrev, VISCOUS_3D::_LayerEdge::_pos, VISCOUS_3D::_SolidData::_proxyMesh, VISCOUS_3D::_SolidData::_s2neMap, _sdVec, VISCOUS_3D::_EdgesOnShape::_shape, VISCOUS_3D::_SolidData::_shrinkShape2Shape, VISCOUS_3D::_LayerEdge::_simplices, VISCOUS_3D::_SolidData::_solid, VISCOUS_3D::_SolidData::_stepSize, VISCOUS_3D::_SolidData::_stepSizeNodes, VISCOUS_3D::_EdgesOnShape::_sWOL, _tmpFaceID, SMESH_ProxyMesh::SubMesh::AddElement(), SMESH_MesherHelper::AddNode(), SMDS_MeshElement::begin_nodes(), VISCOUS_3D::_LayerEdge::Block(), SMESH_MesherHelper::CheckNodeUV(), VISCOUS_3D::_LayerEdge::Copy(), debugMsg, dumpFunction, dumpFunctionEnd, dumpMove, Edge, SMDS_MeshElement::end_nodes(), error(), Face, findNeiborsOnEdge(), findShapesToSmooth(), SMESHDS_SubMesh::GetElements(), VISCOUS_3D::_MeshOfSolid::getFaceSubM(), SMESH_subMesh::GetId(), getMeshDS(), SMDS_MeshElement::GetNode(), SMESHDS_SubMesh::GetNodes(), SMESH_MesherHelper::GetNodeUV(), SMESH_MesherHelper::GetPeriodicIndex(), SMDS_MeshNode::GetPosition(), SMDS_MeshElement::getshapeId(), SMDS_MeshElement::GetShapeID(), SMESH_Mesh::GetSubMesh(), SMESH_subMesh::GetSubMeshDS(), SMESHDS_Mesh::IndexToShape(), SMESH_MesherHelper::IsDegenShape(), VISCOUS_3D::_LayerEdge::IsOnEdge(), SMESH_MesherHelper::IthVertex(), limitStepSize(), limitStepSizeByCurvature(), SMESH_MesherHelper::MaxTolerance(), SMESHDS_Mesh::MeshElements(), SMDS_MeshElement::NbCornerNodes(), VISCOUS_3D::_Factory::NewLayerEdge(), VISCOUS_3D::_LayerEdge::SetDataByNeighbors(), setEdgeData(), SMESH_MesherHelper::SetElementsOnShape(), SMESH_MesherHelper::SetSubShape(), VISCOUS_3D::_EdgesOnShape::ShapeType(), VISCOUS_3D::_EdgesOnShape::size(), SMDS_TOP_FACE, SMDSAbs_Face, VISCOUS_3D::_2NearEdges::srcNode(), VISCOUS_3D::_EdgesOnShape::SWOLType(), VISCOUS_3D::theMinSmoothCosin, SMESH_MesherHelper::ToFixNodeParameters(), and SMESH_Algo::VertexNode().
◆ MakeN2NMap()
◆ makeOffsetSurface()
◆ prepareEdgeToShrink()
◆ putOnOffsetSurface()
void _ViscousBuilder::putOnOffsetSurface ( _EdgesOnShape &  eos,
int  infStep,
vector< _EdgesOnShape * > &  eosC1,
int  smooStep = 0,
int  moveAll = false
References VISCOUS_3D::_LayerEdge::_cosin, VISCOUS_3D::_LayerEdge::_curvature, VISCOUS_3D::_EdgesOnShape::_edgeForOffset, VISCOUS_3D::_EdgesOnShape::_edges, VISCOUS_3D::_LayerEdge::_len, VISCOUS_3D::_LayerEdge::_neibors, VISCOUS_3D::_LayerEdge::_nodes, VISCOUS_3D::_LayerEdge::_normal, VISCOUS_3D::_ConvexFace::_normalsFixedOnBorders, VISCOUS_3D::_EdgesOnShape::_offsetValue, VISCOUS_3D::_LayerEdge::_pos, VISCOUS_3D::_EdgesOnShape::_shape, VISCOUS_3D::_EdgesOnShape::_shapeID, VISCOUS_3D::_LayerEdge::_simplices, VISCOUS_3D::_EdgesOnShape::_subMesh, VISCOUS_3D::_EdgesOnShape::_sWOL, VISCOUS_3D::_Curvature::_uv, VISCOUS_3D::_LayerEdge::BLOCKED, debugMsg, dumpFunction, dumpFunctionEnd, dumpMove, Face, VISCOUS_3D::_SolidData::GetConvexFace(), VISCOUS_3D::_EdgesOnShape::GetData(), SMESH_subMesh::getDependsOnIterator(), VISCOUS_3D::_SolidData::GetHelper(), SMESH_subMesh::GetId(), VISCOUS_3D::_SolidData::GetShapeEdges(), VISCOUS_3D::_LayerEdge::Is(), SMESH_MesherHelper::IsSubShape(), VISCOUS_3D::_LayerEdge::MARKED, VISCOUS_3D::_LayerEdge::MOVED, VISCOUS_3D::_LayerEdge::NbSteps(), VISCOUS_3D::_LayerEdge::PrevCheckPos(), putOnOffsetSurface(), VISCOUS_3D::_LayerEdge::RISKY_SWOL, VISCOUS_3D::_LayerEdge::Set(), SMDS_MeshNode::setXYZ(), VISCOUS_3D::_EdgesOnShape::ShapeType(), VISCOUS_3D::_EdgesOnShape::ShapeTypeLetter(), VISCOUS_3D::_LayerEdge::Unset(), VISCOUS_3D::_LayerEdge::UPD_NORMAL_CONV, and VISCOUS_3D::_LayerEdge::UpdatePositionOnSWOL().
Referenced by putOnOffsetSurface(), and smoothAndCheck().
◆ refine()
bool _ViscousBuilder::refine ( _SolidData &  data)
References VISCOUS_3D::_EdgesOnShape::_edges, VISCOUS_3D::_SolidData::_edgesOnShape, VISCOUS_3D::_EdgesOnShape::_eosC1, VISCOUS_3D::_EdgesOnShape::_hyp, VISCOUS_3D::_SolidData::_ignoreFaceIds, VISCOUS_3D::_SolidData::_index, VISCOUS_3D::_EdgesOnShape::_isRegularSWOL, VISCOUS_3D::_LayerEdge::_len, _mesh, VISCOUS_3D::_SolidData::_n2eMap, SMESH_TNodeXYZ::_node, VISCOUS_3D::_LayerEdge::_nodes, VISCOUS_3D::_LayerEdge::_normal, VISCOUS_3D::_LayerEdge::_pos, VISCOUS_3D::_SolidData::_reversedFaceIds, VISCOUS_3D::_SolidData::_s2neMap, VISCOUS_3D::_EdgesOnShape::_shape, VISCOUS_3D::_EdgesOnShape::_shapeID, VISCOUS_3D::_SolidData::_solid, VISCOUS_3D::_EdgesOnShape::_sWOL, VISCOUS_3D::_EdgesOnShape::_toSmooth, SMDS_MeshGroup::Add(), SMESH_MesherHelper::AddNode(), SMESH_MesherHelper::AddVolume(), COMPERR_WARNING, StdMeshers_ViscousLayers::CreateGroup(), Edge, error(), Face, VISCOUS_3D::AverageHyp::Get1stLayerThickness(), SMESH_subMesh::GetComputeError(), VISCOUS_3D::_SolidData::GetConvexFace(), SMESHDS_SubMesh::GetElements(), VISCOUS_3D::AverageHyp::GetGroupName(), VISCOUS_3D::_SolidData::GetHelper(), SMESH_MesherHelper::GetMesh(), getMeshDS(), SMESH_MesherHelper::GetNodeU(), SMESH_MesherHelper::GetNodeUV(), VISCOUS_3D::AverageHyp::GetNumberLayers(), SMDS_MeshNode::GetPosition(), VISCOUS_3D::_SolidData::GetShapeEdges(), VISCOUS_3D::_LayerEdge::GetSmoothedPos(), VISCOUS_3D::AverageHyp::GetStretchFactor(), SMESH_Mesh::GetSubMesh(), SMESH_MesherHelper::GetSubShapeID(), Handle(), SMESH_MesherHelper::HasDegeneratedEdges(), SMESH::if(), VISCOUS_3D::_LayerEdge::Is(), SMESHDS_Mesh::MeshElements(), SMESHDS_Mesh::MoveNode(), SMESH_BadInputElements::myBadElements, SMDS_MeshElement::NbCornerNodes(), SMDS_MeshElement::nodeIterator(), VISCOUS_3D::_LayerEdge::NORMAL_UPDATED, setEdgeData(), SMESH_MesherHelper::SetElementsOnShape(), SMESHDS_Mesh::SetNodeInVolume(), SMESHDS_Mesh::SetNodeOnEdge(), SMESHDS_Mesh::SetNodeOnFace(), SMESHDS_Mesh::ShapeToIndex(), VISCOUS_3D::_EdgesOnShape::ShapeType(), SMDSAbs_Volume, VISCOUS_3D::_LayerEdge::SMOOTHED, VISCOUS_3D::_LayerEdge::SmoothPos(), VISCOUS_3D::_EdgesOnShape::SWOLType(), SMESH_MesherHelper::WrapIndex(), SMDS_MeshNode::X(), and SMESH::XY.
◆ RestoreListeners()
void _ViscousBuilder::RestoreListeners ( )
◆ restoreNoShrink()
void _ViscousBuilder::restoreNoShrink ( _LayerEdge &  edge) const
◆ setBefore()
bool _ViscousBuilder::setBefore ( _SolidData &  solidBefore,
_SolidData &  solidAfter
References VISCOUS_3D::_SolidData::_before, _sdVec, VISCOUS_3D::_SolidData::_solid, and _solids.
Referenced by findFacesWithLayers().
◆ setEdgeData()
bool _ViscousBuilder::setEdgeData ( _LayerEdge &  edge,
_SolidData &  data
– moved to SetCosin()
References VISCOUS_3D::_LayerEdge::_2neibors, VISCOUS_3D::_LayerEdge::_cosin, VISCOUS_3D::_LayerEdge::_curvature, VISCOUS_3D::_LayerEdge::_flags, VISCOUS_3D::_EdgesOnShape::_hyp, VISCOUS_3D::_SolidData::_ignoreFaceIds, VISCOUS_3D::_SolidData::_index, VISCOUS_3D::_EdgesOnShape::_isRegularSWOL, VISCOUS_3D::_LayerEdge::_len, VISCOUS_3D::_LayerEdge::_lenFactor, VISCOUS_3D::_LayerEdge::_maxLen, VISCOUS_3D::_LayerEdge::_minAngle, VISCOUS_3D::_LayerEdge::_nodes, VISCOUS_3D::_LayerEdge::_normal, VISCOUS_3D::_LayerEdge::_pos, VISCOUS_3D::_EdgesOnShape::_shape, VISCOUS_3D::_EdgesOnShape::_shapeID, VISCOUS_3D::_LayerEdge::_simplices, VISCOUS_3D::_LayerEdge::_smooFunction, VISCOUS_3D::_SolidData::_solid, VISCOUS_3D::_EdgesOnShape::_sWOL, Edge, error(), Face, VISCOUS_3D::AverageHyp::Get1stLayerThickness(), VISCOUS_3D::getEdgeDir(), VISCOUS_3D::getFaceDir(), getFaceNormal(), SMDS_MeshElement::GetID(), SMDS_MeshNode::GetInverseElementIterator(), getMeshDS(), SMESH_MesherHelper::GetNodeU(), SMESH_MesherHelper::GetNodeUV(), getNormalByOffset(), SMDS_MeshElement::getshapeId(), VISCOUS_3D::_Simplex::GetSimplices(), SMESH_MesherHelper::GetSubShapeOri(), getWeigthedNormal(), SMESHDS_Mesh::IndexToShape(), VISCOUS_3D::_LayerEdge::Is(), SMESH_MesherHelper::IsSeamShape(), SMESH_MesherHelper::IsSubShape(), VISCOUS_3D::_LayerEdge::MULTI_NORMAL, VISCOUS_3D::_Factory::NewNearEdges(), SMESHDS_Mesh::RemoveFreeNode(), VISCOUS_3D::_LayerEdge::RISKY_SWOL, VISCOUS_3D::_LayerEdge::Set(), VISCOUS_3D::_LayerEdge::SetCosin(), VISCOUS_3D::_LayerEdge::SetMaxLen(), SMESHDS_Mesh::SetNodeOnEdge(), SMESHDS_Mesh::SetNodeOnFace(), VISCOUS_3D::_EdgesOnShape::ShapeType(), SMDSAbs_Face, VISCOUS_3D::_EdgesOnShape::SWOLType(), and VISCOUS_3D::AverageHyp::UseSurfaceNormal().
Referenced by makeLayer(), and refine().
◆ setShapeData()
◆ shrink()
bool _ViscousBuilder::shrink ( _SolidData &  data)
References VISCOUS_3D::_EdgesOnShape::_edges, _mesh, VISCOUS_3D::_LayerEdge::_nodes, VISCOUS_3D::_SolidData::_noShrinkShapes, _periodicity, VISCOUS_3D::_LayerEdge::_pos, VISCOUS_3D::_SolidData::_proxyMesh, _sdVec, VISCOUS_3D::_EdgesOnShape::_shape, VISCOUS_3D::_SolidData::_shrinkShape2Shape, _shrunkFaces, VISCOUS_3D::_LayerEdge::_simplices, VISCOUS_3D::_SolidData::_solid, VISCOUS_3D::_EdgesOnShape::_sWOL, VISCOUS_3D::_Shrinker1D::AddEdge(), SMESH_ProxyMesh::SubMesh::AddElement(), SMESHDS_SubMesh::AddElement(), VISCOUS_3D::_SmoothNode::ANGULAR, SMESHDS_Mesh::ChangeElementNodes(), SMESH_subMesh::CHECK_COMPUTE_STATE, SMESHDS_SubMesh::Clear(), VISCOUS_3D::_Shrinker1D::Compute(), SMESH_subMesh::COMPUTE_OK, SMESH_subMesh::COMPUTE_SUBMESH, SMESH_subMesh::ComputeStateEngine(), SMESHDS_SubMesh::Contains(), debugMsg, dumpChangeNodes, dumpFunction, dumpFunctionEnd, dumpMove, Edge, error(), Face, fixBadFaces(), VISCOUS_3D::_Shrinker1D::GeomEdge(), SMESH_subMesh::GetAlgo(), SMESH_subMesh::GetComputeState(), SMESH_subMesh::getDependsOnIterator(), SMESH_ProxyMesh::SubMesh::GetElements(), SMESHDS_SubMesh::GetElements(), VISCOUS_3D::_MeshOfSolid::getFaceSubM(), SMESH_subMesh::GetId(), SMDS_MeshNode::GetInverseElementIterator(), SMESH_MesherHelper::GetMeshDS(), getMeshDS(), SMDS_MeshElement::GetNode(), SMESHDS_SubMesh::GetNodes(), SMESH_MesherHelper::GetNodeU(), SMESH_MesherHelper::GetNodeUV(), SMDS_MeshNode::GetPosition(), VISCOUS_3D::_SolidData::GetShapeEdges(), VISCOUS_3D::_Simplex::GetSimplices(), SMESH_Algo::GetSortedNodesOnEdge(), SMESH_Mesh::GetSubMesh(), SMESH_subMesh::GetSubMeshDS(), SMESH_subMesh::GetSubShape(), Handle(), VISCOUS_3D::_LayerEdge::Is(), VISCOUS_3D::isConcave(), SMDS_MeshElement::isMarked(), SMESH_MesherHelper::IsSeamShape(), SMESH_MesherHelper::IthVertex(), VISCOUS_3D::_SmoothNode::LAPLACIAN, SMESHDS_Mesh::MoveNode(), VISCOUS_3D::PeriodicFaces::MoveNodes(), SMESH_ProxyMesh::SubMesh::NbElements(), SMESHDS_SubMesh::NbElements(), SMESHDS_SubMesh::NbNodes(), SMDS_MeshElement::NbNodes(), SMESH_Mesh::NbQuadrangles(), SMESH_Mesh::NbTriangles(), SMDS_MeshElement::nodeIterator(), prepareEdgeToShrink(), SMESHDS_Mesh::RemoveFreeElement(), SMESHDS_Mesh::RemoveFreeNode(), VISCOUS_3D::_Shrinker1D::RestoreParams(), SMESH_subMesh::SetAllowedSubShapes(), SMDS_MeshElement::setIsMarked(), StdMeshers_ViscousLayers2D::SetProxyMeshOfEdge(), SMESH_MesherHelper::SetSubShape(), SMDS_MeshNode::setXYZ(), SMESHDS_Mesh::ShapeToIndex(), VISCOUS_3D::_EdgesOnShape::ShapeType(), VISCOUS_3D::_LayerEdge::SHRUNK, VISCOUS_3D::_EdgesOnShape::size(), SMDSAbs_Face, VISCOUS_3D::_SolidData::SortOnEdge(), VISCOUS_3D::_Shrinker1D::SrcNode(), VISCOUS_3D::_EdgesOnShape::SWOLType(), VISCOUS_3D::_Shrinker1D::TgtNode(), VISCOUS_3D::ToClearSubWithMain(), SMESH_MesherHelper::ToFixNodeParameters(), and VISCOUS_3D::U_TGT.
◆ smoothAndCheck()
bool _ViscousBuilder::smoothAndCheck ( _SolidData &  data,
const int  nbSteps,
double &  distToIntersection
References VISCOUS_3D::_SolidData::_concaveFaces, VISCOUS_3D::_EdgesOnShape::_edges, VISCOUS_3D::_EdgesOnShape::_edgeSmoother, VISCOUS_3D::_SolidData::_edgesOnShape, VISCOUS_3D::_EdgesOnShape::_eosC1, VISCOUS_3D::_SolidData::_epsilon, VISCOUS_3D::_EdgesOnShape::_hyp, VISCOUS_3D::_SolidData::_index, _mesh, VISCOUS_3D::_SolidData::_n2eMap, VISCOUS_3D::_SolidData::_nbShapesToSmooth, VISCOUS_3D::_LayerEdge::_neibors, SMESH_TNodeXYZ::_node, VISCOUS_3D::_LayerEdge::_nodes, VISCOUS_3D::_LayerEdge::_pos, VISCOUS_3D::_SolidData::_proxyMesh, VISCOUS_3D::_EdgesOnShape::_shape, VISCOUS_3D::_EdgesOnShape::_shapeID, VISCOUS_3D::_LayerEdge::_simplices, VISCOUS_3D::_SolidData::_solid, VISCOUS_3D::_EdgesOnShape::_sWOL, VISCOUS_3D::_EdgesOnShape::_toSmooth, SMDS_MeshElement::begin_nodes(), VISCOUS_3D::_LayerEdge::BLOCKED, VISCOUS_3D::_LayerEdge::CheckNeiborsOnBoundary(), debugMsg, dumpCmd, dumpFunction, dumpFunctionEnd, Face, SMESH_MeshAlgos::FaceNormal(), VISCOUS_3D::_SolidData::GetConvexFace(), SMESH_MeshAlgos::GetElementSearcher(), SMESH_ProxyMesh::GetFaces(), SMDS_MeshElement::GetID(), getMeshDS(), SMDS_MeshElement::GetNodeIndex(), SMDS_MeshElement::getshapeId(), VISCOUS_3D::AverageHyp::GetTotalThickness(), Handle(), SMESH::if(), SMESHDS_Mesh::IndexToShape(), VISCOUS_3D::_LayerEdge::INTERSECTED, invalidateBadSmooth(), VISCOUS_3D::_LayerEdge::Is(), SMESH_MesherHelper::IsSubShape(), makeOffsetSurface(), VISCOUS_3D::_LayerEdge::MOVED, VISCOUS_3D::_LayerEdge::MULTI_NORMAL, VISCOUS_3D::_LayerEdge::NEAR_BOUNDARY, SMDS_MeshElement::nodesIterator(), VISCOUS_3D::_LayerEdge::ON_CONCAVE_FACE, VISCOUS_3D::_Smoother1D::Perform(), VISCOUS_3D::_LayerEdge::PrevCheckPos(), putOnOffsetSurface(), SMESH_MesherHelper::SetSubShape(), VISCOUS_3D::_EdgesOnShape::ShapeType(), VISCOUS_3D::_LayerEdge::Smooth(), VISCOUS_3D::_LayerEdge::SMOOTHED, VISCOUS_3D::_EdgesOnShape::SWOLType(), VISCOUS_3D::theThickToIntersection, VISCOUS_3D::AverageHyp::ToSmooth(), and VISCOUS_3D::_LayerEdge::Unset().
Referenced by inflate().
◆ updateNormals()
bool _ViscousBuilder::updateNormals ( _SolidData &  data,
int  stepNb,
double  stepSize
References VISCOUS_3D::_LayerEdge::_2neibors, VISCOUS_3D::_SolidData::_collisionEdges, VISCOUS_3D::_LayerEdge::_cosin, VISCOUS_3D::_CollisionEdges::_edge, VISCOUS_3D::_2NearEdges::_edges, VISCOUS_3D::_EdgesOnShape::_hyp, VISCOUS_3D::_SolidData::_index, VISCOUS_3D::_CollisionEdges::_intEdges, VISCOUS_3D::_LayerEdge::_len, VISCOUS_3D::_LayerEdge::_lenFactor, VISCOUS_3D::_LayerEdge::_maxLen, _mesh, VISCOUS_3D::_LayerEdge::_nodes, VISCOUS_3D::_LayerEdge::_normal, VISCOUS_3D::_EdgesOnShape::_sWOL, VISCOUS_3D::_SolidData::AddShapesToSmooth(), VISCOUS_3D::_LayerEdge::BLOCKED, dumpFunction, dumpFunctionEnd, Edge, VISCOUS_3D::AverageHyp::Get1stLayerThickness(), SMESH_MesherHelper::GetAncestors(), VISCOUS_3D::_TmpMeshFaceOnEdge::GetDir(), VISCOUS_3D::getEdgeDir(), getMeshDS(), VISCOUS_3D::_SolidData::GetShapeEdges(), SMESH_MesherHelper::GetSubShapeByNode(), VISCOUS_3D::_LayerEdge::InvalidateStep(), VISCOUS_3D::_LayerEdge::Is(), isNewNormalOk(), VISCOUS_3D::_LayerEdge::IsOnEdge(), VISCOUS_3D::_LayerEdge::LastSegment(), VISCOUS_3D::_LayerEdge::MARKED, VISCOUS_3D::_LayerEdge::NORMAL_UPDATED, VISCOUS_3D::_CollisionEdges::nSrc(), VISCOUS_3D::_CollisionEdges::nTgt(), VISCOUS_3D::_LayerEdge::SegTriaInter(), VISCOUS_3D::_LayerEdge::Set(), VISCOUS_3D::_LayerEdge::SetCosin(), VISCOUS_3D::_LayerEdge::SetDataByNeighbors(), VISCOUS_3D::_LayerEdge::SetMaxLen(), VISCOUS_3D::_LayerEdge::SetNewLength(), VISCOUS_3D::_LayerEdge::SetNormal(), SMDSAbs_Face, VISCOUS_3D::_2NearEdges::srcNode(), VISCOUS_3D::theMinSmoothCosin, VISCOUS_3D::_SolidData::UnmarkEdges(), updateNormalsOfC1Vertices(), and updateNormalsOfConvexFaces().
◆ updateNormalsOfC1Vertices()
◆ updateNormalsOfConvexFaces()
bool _ViscousBuilder::updateNormalsOfConvexFaces ( _SolidData &  data,
int  stepNb
References VISCOUS_3D::_CentralCurveOnEdge::_adjFace, VISCOUS_3D::_SolidData::_convexFaces, VISCOUS_3D::_LayerEdge::_cosin, VISCOUS_3D::_CentralCurveOnEdge::_curvaCenters, VISCOUS_3D::_CentralCurveOnEdge::_edge, VISCOUS_3D::_EdgesOnShape::_edges, VISCOUS_3D::_ConvexFace::_face, VISCOUS_3D::_SolidData::_index, VISCOUS_3D::_CentralCurveOnEdge::_isDegenerated, VISCOUS_3D::_CentralCurveOnEdge::_ledges, VISCOUS_3D::_LayerEdge::_len, VISCOUS_3D::_LayerEdge::_neibors, VISCOUS_3D::_LayerEdge::_nodes, VISCOUS_3D::_CentralCurveOnEdge::_normals, VISCOUS_3D::_ConvexFace::_normalsFixed, VISCOUS_3D::_ConvexFace::_normalsFixedOnBorders, VISCOUS_3D::_EdgesOnShape::_shape, VISCOUS_3D::_ConvexFace::_subIdToEOS, VISCOUS_3D::_EdgesOnShape::_sWOL, VISCOUS_3D::_EdgesOnShape::_toSmooth, VISCOUS_3D::_SolidData::AddShapesToSmooth(), VISCOUS_3D::_ConvexFace::CheckPrisms(), SMESH_MesherHelper::Count(), debugMsg, dumpFunction, dumpFunctionEnd, Edge, VISCOUS_3D::_ConvexFace::GetCenterOfCurvature(), VISCOUS_3D::getFaceDir(), SMESH_MesherHelper::GetMeshDS(), VISCOUS_3D::_SolidData::GetShapeEdges(), VISCOUS_3D::_LayerEdge::InvalidateStep(), SMESH_MesherHelper::IthVertex(), VISCOUS_3D::_LayerEdge::MOVED, VISCOUS_3D::_LayerEdge::NEAR_BOUNDARY, VISCOUS_3D::_LayerEdge::NORMAL_UPDATED, VISCOUS_3D::_LayerEdge::Set(), VISCOUS_3D::_LayerEdge::SetCosin(), VISCOUS_3D::_LayerEdge::SetNewLength(), VISCOUS_3D::_LayerEdge::SetNormal(), VISCOUS_3D::_CentralCurveOnEdge::SetShapes(), VISCOUS_3D::_LayerEdge::SetSmooLen(), SMESH_MesherHelper::SetSubShape(), SMESHDS_Mesh::ShapeToIndex(), VISCOUS_3D::_EdgesOnShape::ShapeType(), VISCOUS_3D::_SolidData::SortOnEdge(), and VISCOUS_3D::theMinSmoothCosin.
Referenced by updateNormals().
◆ updateNormalsOfSmoothed()
◆ _error
SMESH_ComputeErrorPtr VISCOUS_3D::_ViscousBuilder::_error
◆ _mesh
◆ _periodicity
std::unique_ptr<Periodicity> VISCOUS_3D::_ViscousBuilder::_periodicity
Referenced by findPeriodicFaces(), and shrink().
◆ _pyDump
PyDump* VISCOUS_3D::_ViscousBuilder::_pyDump
Referenced by Compute(), and inflate().
◆ _sdVec
◆ _shrunkFaces
TopTools_MapOfShape VISCOUS_3D::_ViscousBuilder::_shrunkFaces
Referenced by shrink().
◆ _solids
TopTools_IndexedMapOfShape VISCOUS_3D::_ViscousBuilder::_solids
◆ _tmpFaceID
int VISCOUS_3D::_ViscousBuilder::_tmpFaceID
