SMESH_BadInputElements Struct Reference
#include <SMESH_ComputeError.hxx>
Inheritance diagram for SMESH_BadInputElements:
typedef std::list< const SMDS_MeshElement * > TElemList
 SMESH_BadInputElements (const SMDS_Mesh *mesh, int error=COMPERR_OK, std::string comment="", const SMESH_Algo *algo=0)
const SMDS_Mesh * GetMesh () const
const TElemList & GetElements ()
virtual bool HasBadElems () const
virtual SMDS_ElemIteratorPtr getElements ()
 < the descendant object return its elements just before the mesh compacting More...
virtual void tmpClear ()
 the descendant object re-add its elements after the mesh compacting More...
virtual void add (const SMDS_MeshElement *element)
 the descendant squeeze its element storage after re-adding elements More...
virtual void compact ()
 allow the descendant treat its elements before mesh clearing More...
bool IsOK () const
bool IsKO () const
bool IsCommon () const
std::string CommonName () const
static SMESH_ComputeErrorPtr New (int error=COMPERR_OK, std::string comment="", const SMESH_Algo *algo=0)
static SMESH_ComputeErrorPtr Worst (SMESH_ComputeErrorPtr er1, SMESH_ComputeErrorPtr er2)
Data Fields
TElemList myBadElements
int myName
std::string myComment
const SMESH_Algo * myAlgo
virtual void clear ()
SMDS_Mesh * myMesh
void beforeCompacting ()
 store vtkIDs of elements More...
void restoreElements (const std::vector< smIdType > &idNodessOldToNew, const std::vector< smIdType > &idCellsOldToNew)
 restore pointers to elements More...
std::vector< const SMDS_MeshElement * > myExternalElems
 elements not contained in the mesh More...
std::vector< vtkIdType > myVtkIDs
 vtk IDs of elements More...
std::vector< bool > myIsNode
std::set< SMDS_ElementHolder * >::iterator myPtrInMesh
◆ TElemList
◆ SMESH_BadInputElements()
SMESH_BadInputElements::SMESH_BadInputElements ( const SMDS_Mesh *  mesh,
int  error = COMPERR_OK,
std::string  comment = "",
const SMESH_Algo *  algo = 0
◆ add()
void SMESH_BadInputElements::add ( const SMDS_MeshElement *  element)
Implements SMDS_ElementHolder.
References myBadElements.
Referenced by StdMeshers_Quadrangle_2D::computeQuadDominant().
◆ beforeCompacting()
◆ clear()
virtual void SMDS_ElementHolder::clear ( )
◆ CommonName()
◆ compact()
virtual void SMESH_BadInputElements::compact ( )
◆ GetElements()
const TElemList & SMESH_BadInputElements::GetElements ( )
Referenced by SMESH_Algo::error().
◆ getElements()
SMDS_ElemIteratorPtr SMESH_BadInputElements::getElements ( )
the descendant object temporary remove its elements
◆ GetMesh()
const SMDS_Mesh * SMESH_BadInputElements::GetMesh ( ) const
◆ HasBadElems()
virtual bool SMESH_BadInputElements::HasBadElems ( ) const
Reimplemented from SMESH_ComputeError.
◆ IsCommon()
bool SMESH_ComputeError::IsCommon ( ) const
◆ IsKO()
bool SMESH_ComputeError::IsKO ( ) const
References COMPERR_OK, and COMPERR_WARNING.
◆ IsOK()
bool SMESH_ComputeError::IsOK ( ) const
References COMPERR_OK.
◆ New()
◆ restoreElements()
void SMDS_ElementHolder::restoreElements ( const std::vector< smIdType > &  idNodessOldToNew,
const std::vector< smIdType > &  idCellsOldToNew
privateinherited
◆ tmpClear()
void SMESH_BadInputElements::tmpClear ( )
◆ Worst()
SMESH_ComputeErrorPtr SMESH_ComputeError::Worst ( SMESH_ComputeErrorPtr  er1,
◆ myAlgo
const SMESH_Algo* SMESH_ComputeError::myAlgo
◆ myBadElements
TElemList SMESH_BadInputElements::myBadElements
◆ myComment
std::string SMESH_ComputeError::myComment
◆ myExternalElems
std::vector<const SMDS_MeshElement*> SMDS_ElementHolder::myExternalElems
privateinherited
Referenced by SMDS_ElementHolder::beforeCompacting(), and SMDS_ElementHolder::restoreElements().
◆ myIsNode
std::vector< bool > SMDS_ElementHolder::myIsNode
privateinherited
◆ myMesh
◆ myName
int SMESH_ComputeError::myName
Referenced by SMESH_ComputeError::CommonName().
◆ myPtrInMesh
std::set<SMDS_ElementHolder*>::iterator SMDS_ElementHolder::myPtrInMesh
privateinherited
◆ myVtkIDs
std::vector< vtkIdType > SMDS_ElementHolder::myVtkIDs
privateinherited
