VISCOUS_2D::_ViscousBuilder2D Class Reference
Builder of viscous layers. More...
 _ViscousBuilder2D (SMESH_Mesh &theMesh, const TopoDS_Face &theFace, vector< const THypVL * > &theHyp, vector< TopoDS_Shape > &theHypShapes)
 Constructor of _ViscousBuilder2D. More...
SMESH_ComputeErrorPtr GetError () const
SMESH_ProxyMesh::Ptr Compute ()
 Does its job. More...
bool findEdgesWithLayers ()
 Finds EDGE's to make viscous layers on. More...
bool makePolyLines ()
 Create the inner front of the viscous layers and prepare data for inflation. More...
bool inflate ()
 Increase length of _LayerEdge's to reach the required thickness of layers. More...
bool fixCollisions ()
 Remove intersection of _PolyLine's. More...
bool refine ()
 Make faces. More...
bool shrink ()
 Create new edges and shrink edges existing on a non-advancable _PolyLine adjacent to an advancable one. More...
bool improve ()
 Improve quality of the created mesh elements. More...
bool toShrinkForAdjacent (const TopoDS_Face &adjFace, const TopoDS_Edge &E, const TopoDS_Vertex &V)
 Returns true if there will be a shrinked mesh on EDGE E of FACE adjFace near VERTEX V. More...
void setLenRatio (_LayerEdge &LE, const gp_Pnt &pOut)
 Compute and set _LayerEdge::_len2dTo3dRatio. More...
void setLayerEdgeData (_LayerEdge &lEdge, const double u, Handle(Geom2d_Curve)&pcurve, Handle(Geom_Curve)&curve, const gp_Pnt pOut, const bool reverse, GeomAPI_ProjectPointOnSurf *faceProj)
 initialize data of a _LayerEdge More...
void adjustCommonEdge (_PolyLine &LL, _PolyLine &LR)
 adjust common _LayerEdge of two adjacent _PolyLine's More...
void calcLayersHeight (const double totalThick, vector< double > &heights, const THypVL *hyp)
 Calculate height of layers for the given thickness. More...
bool removeMeshFaces (const TopoDS_Shape &face)
 Remove elements and nodes from a face. More...
const THypVL * getLineHypothesis (int iPL)
 Returns a hypothesis for a _PolyLine. More...
double getLineThickness (int iPL)
 Returns a layers thickness for a _PolyLine. More...
bool error (const string &text)
 Stores error description and returns false. More...
SMESHDS_Mesh * getMeshDS ()
_ProxyMeshOfFace * getProxyMesh ()
 Creates a _ProxyMeshOfFace and store it in a sub-mesh of FACE. More...
 Handle (Geom_Surface) _surface
SMESH_Mesh * _mesh
TopoDS_Face _face
vector< const THypVL * > _hyps
vector< TopoDS_Shape > _hypShapes
SMESH_ProxyMesh::Ptr _proxyMesh
SMESH_ComputeErrorPtr _error
SMESH_MesherHelper _helper
TSideVector _faceSideVec
vector< _PolyLine > _polyLineVec
vector< const THypVL * > _hypOfEdge
bool _is2DIsotropic
vector< TopoDS_Face > _clearedFaces
double _maxThickness
set< TGeomID > _ignoreShapeIds
set< TGeomID > _noShrinkVert
int _nbLE
Friends
class ::StdMeshers_ViscousLayers2D
◆ _ViscousBuilder2D()
_ViscousBuilder2D::_ViscousBuilder2D ( SMESH_Mesh &  theMesh,
const TopoDS_Face &  theFace,
vector< const THypVL * > &  theHyp,
vector< TopoDS_Shape > &  theHypShapes
◆ adjustCommonEdge()
◆ calcLayersHeight()
void _ViscousBuilder2D::calcLayersHeight ( const double  totalThick,
vector< double > &  heights,
const THypVL *  hyp
Height is measured from the outer boundary
References StdMeshers_ViscousLayers::GetNumberLayers(), and StdMeshers_ViscousLayers::GetStretchFactor().
Referenced by refine(), and shrink().
◆ Compute()
◆ error()
bool _ViscousBuilder2D::error ( const string &  text)
References _error, _face, _mesh, COMPERR_ALGO_FAILED, and SMESH_Mesh::GetSubMesh().
Referenced by findEdgesWithLayers(), and makePolyLines().
◆ findEdgesWithLayers()
◆ fixCollisions()
◆ GetError()
SMESH_ComputeErrorPtr VISCOUS_2D::_ViscousBuilder2D::GetError ( ) const
◆ getLineHypothesis()
const StdMeshers_ViscousLayers2D * _ViscousBuilder2D::getLineHypothesis ( int  iPL)
References _hypOfEdge, and _hyps.
Referenced by getLineThickness(), refine(), and shrink().
◆ getLineThickness()
double _ViscousBuilder2D::getLineThickness ( int  iPL)
References _maxThickness, and getLineHypothesis().
Referenced by inflate(), and makePolyLines().
◆ getMeshDS()
SMESHDS_Mesh * VISCOUS_2D::_ViscousBuilder2D::getMeshDS ( )
◆ getProxyMesh()
_ProxyMeshOfFace * _ViscousBuilder2D::getProxyMesh ( )
References _face, _mesh, and _proxyMesh.
◆ Handle()
VISCOUS_2D::_ViscousBuilder2D::Handle ( Geom_Surface  )
Referenced by makePolyLines(), and shrink().
◆ improve()
◆ inflate()
◆ makePolyLines()
◆ refine()
bool _ViscousBuilder2D::refine ( )
Make faces.
L._leftLine->_advancable &&
References VISCOUS_2D::_PolyLine::_advancable, _clearedFaces, VISCOUS_2D::_PolyLine::_edgeInd, _face, VISCOUS_2D::_PolyLine::_firstPntInd, _helper, _is2DIsotropic, VISCOUS_2D::_PolyLine::_lastPntInd, VISCOUS_2D::_PolyLine::_lEdges, VISCOUS_2D::_PolyLine::_leftLine, VISCOUS_2D::_PolyLine::_leftNodes, VISCOUS_2D::_LayerEdge::_length2D, _mesh, VISCOUS_2D::_PolyLine::_newFaces, VISCOUS_2D::_LayerEdge::_normal2D, _noShrinkVert, _polyLineVec, VISCOUS_2D::_PolyLine::_rightLine, VISCOUS_2D::_PolyLine::_rightNodes, VISCOUS_2D::_PolyLine::_segments, VISCOUS_2D::_LayerEdge::_uvIn, VISCOUS_2D::_LayerEdge::_uvOut, VISCOUS_2D::_PolyLine::_wire, SMDS_MeshGroup::Add(), SMESH_MesherHelper::AddFace(), SMESH_MesherHelper::AddNode(), calcLayersHeight(), SMESH_subMesh::COMPUTE, SMESH_subMesh::ComputeStateEngine(), StdMeshers_ViscousLayers::CreateGroup(), StdMeshers_FaceSide::EdgeID(), StdMeshers_FaceSide::FirstParameter(), StdMeshers_FaceSide::FirstU(), StdMeshers_FaceSide::FirstVertex(), SMESH_subMesh::GetComputeState(), VISCOUS_2D::_ProxyMeshOfFace::GetEdgeSubMesh(), StdMeshers_ViscousLayers::GetGroupName(), getLineHypothesis(), SMESH_MesherHelper::GetMesh(), getMeshDS(), SMESH_MesherHelper::GetNodeUV(), StdMeshers_ViscousLayers::GetNumberLayers(), SMESH_MesherHelper::GetPeriodicIndex(), getProxyMesh(), SMESH_Mesh::GetShapeToMesh(), SMESH_Mesh::GetSubMesh(), SMESH_MesherHelper::GetSubShapeOri(), StdMeshers_FaceSide::GetUVPtStruct(), SMESH::if(), VISCOUS_2D::_PolyLine::IsCommonEdgeShared(), StdMeshers_FaceSide::LastParameter(), StdMeshers_FaceSide::LastU(), StdMeshers_FaceSide::LastVertex(), uvPtStruct::node, VISCOUS_2D::_Segment::p1(), VISCOUS_2D::_Segment::p2(), SMESH_subMesh::READY_TO_COMPUTE, VISCOUS_2D::_ProxyMeshOfFace::_EdgeSubMesh::SetUVPtStructVec(), SMESHDS_Mesh::ShapeToIndex(), and SMDSAbs_Face.
Referenced by Compute().
◆ removeMeshFaces()
bool _ViscousBuilder2D::removeMeshFaces ( const TopoDS_Shape &  face)
◆ setLayerEdgeData()
void _ViscousBuilder2D::setLayerEdgeData ( _LayerEdge &  lEdge,
const double  u,
Handle(Geom2d_Curve)&  pcurve,
Handle(Geom_Curve)&  curve,
const gp_Pnt  pOut,
const bool  reverse,
GeomAPI_ProjectPointOnSurf *  faceProj
◆ setLenRatio()
void _ViscousBuilder2D::setLenRatio ( _LayerEdge &  LE,
const gp_Pnt &  pOut
◆ shrink()
bool _ViscousBuilder2D::shrink ( )
References VISCOUS_2D::_PolyLine::_advancable, VISCOUS_2D::_PolyLine::_edgeInd, _face, VISCOUS_2D::_PolyLine::_firstPntInd, _helper, VISCOUS_2D::_PolyLine::_index, VISCOUS_2D::_PolyLine::_lastPntInd, VISCOUS_2D::_PolyLine::_lEdges, VISCOUS_2D::_PolyLine::_leftLine, VISCOUS_2D::_PolyLine::_leftNodes, VISCOUS_2D::_LayerEdge::_len2dTo3dRatio, VISCOUS_2D::_LayerEdge::_length2D, _maxThickness, _mesh, VISCOUS_2D::_LayerEdge::_normal2D, _noShrinkVert, _polyLineVec, VISCOUS_2D::_PolyLine::_rightLine, VISCOUS_2D::_PolyLine::_rightNodes, VISCOUS_2D::_PolyLine::_segments, VISCOUS_2D::_LayerEdge::_uvIn, VISCOUS_2D::_LayerEdge::_uvOut, VISCOUS_2D::_LayerEdge::_uvRefined, VISCOUS_2D::_PolyLine::_wire, SMESH_MesherHelper::AddEdge(), SMESH_MesherHelper::AddNode(), calcLayersHeight(), SMESHDS_Mesh::ChangeElementNodes(), StdMeshers_FaceSide::Edge(), StdMeshers_FaceSide::EdgeID(), StdMeshers_FaceSide::EdgeLength(), Face, VISCOUS_2D::_ProxyMeshHolder::FindProxyMeshOfFace(), StdMeshers_FaceSide::FirstU(), StdMeshers_FaceSide::FirstVertex(), SMESH_MesherHelper::GetAncestors(), VISCOUS_2D::_ProxyMeshOfFace::GetEdgeSubMesh(), SMDS_MeshElement::GetID(), SMDS_MeshNode::GetInverseElementIterator(), getLineHypothesis(), getMeshDS(), SMDS_MeshElement::GetNode(), StdMeshers_ViscousLayers::GetNumberLayers(), SMDS_MeshNode::GetPosition(), getProxyMesh(), SMDS_MeshElement::getshapeId(), SMESH_Mesh::GetSubMesh(), StdMeshers_FaceSide::GetUVPtStruct(), Handle(), VISCOUS_2D::_PolyLine::IsCommonEdgeShared(), SMESH_MesherHelper::IsRealSeam(), StdMeshers_FaceSide::LastU(), StdMeshers_FaceSide::LastVertex(), SMESHDS_Mesh::MoveNode(), SMDS_MeshElement::NbNodes(), uvPtStruct::node, uvPtStruct::normParam, uvPtStruct::param, removeMeshFaces(), SMESH_MesherHelper::SetElementsOnShape(), SMESH_MesherHelper::SetSubShape(), VISCOUS_2D::_ProxyMeshOfFace::_EdgeSubMesh::SetUVPtStructVec(), SMESHDS_Mesh::ShapeToIndex(), SMDS_TOP_EDGE, SMDS_TOP_VERTEX, SMDSAbs_Edge, VISCOUS_3D::ToClearSubWithMain(), toShrinkForAdjacent(), uvPtStruct::u, uvPtStruct::v, and SMDS_MeshNode::X().
◆ toShrinkForAdjacent()
bool _ViscousBuilder2D::toShrinkForAdjacent ( const TopoDS_Face &  adjFace,
const TopoDS_Edge &  E,
const TopoDS_Vertex &  V
◆ ::StdMeshers_ViscousLayers2D
friend class ::StdMeshers_ViscousLayers2D
friend
◆ _clearedFaces
vector<TopoDS_Face> VISCOUS_2D::_ViscousBuilder2D::_clearedFaces
Referenced by refine().
◆ _error
SMESH_ComputeErrorPtr VISCOUS_2D::_ViscousBuilder2D::_error
◆ _face
TopoDS_Face VISCOUS_2D::_ViscousBuilder2D::_face
◆ _faceSideVec
◆ _helper
SMESH_MesherHelper VISCOUS_2D::_ViscousBuilder2D::_helper
◆ _hypOfEdge
vector< const THypVL* > VISCOUS_2D::_ViscousBuilder2D::_hypOfEdge
◆ _hyps
vector< const THypVL* > VISCOUS_2D::_ViscousBuilder2D::_hyps
◆ _hypShapes
vector< TopoDS_Shape > VISCOUS_2D::_ViscousBuilder2D::_hypShapes
◆ _ignoreShapeIds
set<TGeomID> VISCOUS_2D::_ViscousBuilder2D::_ignoreShapeIds
◆ _is2DIsotropic
bool VISCOUS_2D::_ViscousBuilder2D::_is2DIsotropic
Referenced by makePolyLines(), and refine().
◆ _maxThickness
double VISCOUS_2D::_ViscousBuilder2D::_maxThickness
◆ _mesh
◆ _nbLE
int VISCOUS_2D::_ViscousBuilder2D::_nbLE
◆ _noShrinkVert
set<TGeomID> VISCOUS_2D::_ViscousBuilder2D::_noShrinkVert
◆ _polyLineVec
vector<_PolyLine> VISCOUS_2D::_ViscousBuilder2D::_polyLineVec
◆ _proxyMesh
SMESH_ProxyMesh::Ptr VISCOUS_2D::_ViscousBuilder2D::_proxyMesh
Referenced by Compute(), getProxyMesh(), and improve().
