VISCOUS_2D::_PolyLine Struct Reference
Poly line composed of _Segment's of one EDGE. More...
typedef vector< _Segment >::iterator TSegIterator
typedef vector< _LayerEdge >::iterator TEdgeIterator
bool IsCommonEdgeShared (const _PolyLine &other)
 Return true if _LayerEdge at a common VERTEX between EDGEs with and w/o layer is common to the both _PolyLine's. More...
size_t FirstLEdge () const
bool IsAdjacent (const _Segment &seg, const _LayerEdge *LE=0) const
bool IsConcave () const
 Return true if the EDGE of this _PolyLine is concave. More...
Data Fields
StdMeshers_FaceSide * _wire
int _edgeInd
bool _advancable
bool _isStraight2D
_PolyLine * _leftLine
_PolyLine * _rightLine
int _firstPntInd
int _lastPntInd
int _index
vector< _LayerEdge > _lEdges
vector< _Segment > _segments
_SegmentTree::Ptr _segTree
vector< _PolyLine * > _reachableLines
vector< const SMDS_MeshNode * > _leftNodes
vector< const SMDS_MeshNode * > _rightNodes
TIDSortedElemSet _newFaces
It's used to detect intersection of inflated layers by intersecting _Segment's in 2D.
◆ TEdgeIterator
◆ TSegIterator
typedef vector<_Segment>::iterator VISCOUS_2D::_PolyLine::TSegIterator
◆ FirstLEdge()
size_t VISCOUS_2D::_PolyLine::FirstLEdge ( ) const
◆ IsAdjacent()
bool VISCOUS_2D::_PolyLine::IsAdjacent ( const _Segment &  seg,
const _LayerEdge *  LE = 0
◆ IsCommonEdgeShared()
bool _PolyLine::IsCommonEdgeShared ( const _PolyLine &  other)
If this is true, nodes of this _LayerEdge are inflated along a _PolyLine w/o layer, else the nodes are inflated along _normal2D of _LayerEdge of EDGE with layer
References _lEdges, _leftLine, and _rightLine.
Referenced by VISCOUS_2D::_ViscousBuilder2D::inflate(), VISCOUS_2D::_ViscousBuilder2D::refine(), and VISCOUS_2D::_ViscousBuilder2D::shrink().
◆ IsConcave()
bool _PolyLine::IsConcave ( ) const
References _lEdges.
◆ _advancable
◆ _edgeInd
◆ _firstPntInd
◆ _index
int VISCOUS_2D::_PolyLine::_index
◆ _isStraight2D
bool VISCOUS_2D::_PolyLine::_isStraight2D
◆ _lastPntInd
◆ _lEdges
◆ _leftLine
◆ _leftNodes
vector< const SMDS_MeshNode* > VISCOUS_2D::_PolyLine::_leftNodes
◆ _newFaces
◆ _reachableLines
◆ _rightLine
◆ _rightNodes
◆ _segments
◆ _segTree
◆ _wire
