SMESH_TypeDefs.hxx File Reference
#include <Basics_OCCTVersion.hxx>
#include "SMESH_Utils.hxx"
#include "SMDS_SetIterator.hxx"
#include "SMDS_MeshNode.hxx"
#include <smIdType.hxx>
#include <gp_XYZ.hxx>
#include <gp_XY.hxx>
#include <NCollection_Sequence.hxx>
#include <map>
#include <list>
#include <set>
#include <cassert>
#include <boost/make_shared.hpp>
Include dependency graph for SMESH_TypeDefs.hxx:
struct  SMESHUtils::Deleter< TOBJ >
 Auto pointer. More...
struct  SMESHUtils::ArrayDeleter< TOBJ >
 Auto pointer to array. More...
struct  SMESH_TLink
 A sorted pair of nodes. More...
struct  SMESH_TLinkHasher
struct  SMESH_OrientedLink
 SMESH_TLink knowing its orientation. More...
struct  SMESH_TNodeXYZ
 SMDS_MeshNode -> gp_XYZ converter. More...
struct  SMESH_Hasher
struct  uvPtStruct
 Data of a node generated on FACE boundary. More...
struct  uvPtStruct::NodeAccessor
namespace  SMESHUtils
Typedefs
typedef std::map< const SMDS_MeshElement *, std::list< const SMDS_MeshElement * >, TIDCompare > TElemOfElemListMap
typedef std::map< const SMDS_MeshElement *, std::list< const SMDS_MeshNode * >, TIDCompare > TElemOfNodeListMap
typedef std::map< const SMDS_MeshNode *, const SMDS_MeshNode *, TIDCompare > TNodeNodeMap
 Set of elements sorted by ID, to be used to assure predictability of edition. More...
typedef std::set< const SMDS_MeshElement *, TIDCompare > TIDSortedElemSet
typedef std::set< const SMDS_MeshNode *, TIDCompare > TIDSortedNodeSet
typedef std::pair< const SMDS_MeshNode *, const SMDS_MeshNode * > NLink
typedef boost::shared_ptr< FaceQuadStruct > TFaceQuadStructPtr
typedef SMESH_TLink SMESH_Link
typedef SMESH_TNodeXYZ SMESH_NodeXYZ
typedef struct uvPtStruct UVPtStruct
typedef std::vector< UVPtStruct > UVPtStructVec
typedef std::vector< const SMDS_MeshElement * > SMESH_SequenceOfElemPtr
typedef const SMDS_MeshNode * SMDS_MeshNodePtr
typedef NCollection_Sequence< SMDS_MeshNodePtr > SMESH_SequenceOfNode
template<class TVECTOR >
void SMESHUtils::FreeVector (TVECTOR &vec)
 Enforce freeing memory allocated by std::vector. More...
void SMESHUtils::CompactVector (TVECTOR &vec)
template<class ELEM_SET >
SMDS_ElemIteratorPtr SMESHUtils::elemSetIterator (const ELEM_SET &elements)
template<typename ENUM >
void SMESHUtils::Increment (ENUM &v, int delta=1)
 Increment enum value. More...
ENUM SMESHUtils::Add (ENUM v, int delta)
 Return incremented enum value. More...
Typedef Documentation
◆ NLink
typedef std::pair< const SMDS_MeshNode*, const SMDS_MeshNode* > NLink
◆ SMDS_MeshNodePtr
◆ SMESH_Link
◆ SMESH_NodeXYZ
◆ SMESH_SequenceOfElemPtr
typedef std::vector< const SMDS_MeshElement* > SMESH_SequenceOfElemPtr
◆ SMESH_SequenceOfNode
◆ TElemOfElemListMap
typedef std::map<const SMDS_MeshElement*, std::list<const SMDS_MeshElement*>, TIDCompare > TElemOfElemListMap
◆ TElemOfNodeListMap
typedef std::map<const SMDS_MeshElement*, std::list<const SMDS_MeshNode*>, TIDCompare > TElemOfNodeListMap
◆ TFaceQuadStructPtr
typedef boost::shared_ptr<FaceQuadStruct> TFaceQuadStructPtr
◆ TIDSortedElemSet
typedef std::set< const SMDS_MeshElement*, TIDCompare > TIDSortedElemSet
◆ TIDSortedNodeSet
typedef std::set< const SMDS_MeshNode*, TIDCompare > TIDSortedNodeSet
◆ TNodeNodeMap
typedef std::map<const SMDS_MeshNode*, const SMDS_MeshNode*, TIDCompare> TNodeNodeMap
◆ UVPtStruct
◆ UVPtStructVec
