FaceQuadStruct Struct Reference
#include <StdMeshers_Quadrangle_2D.hxx>
struct  Side
struct  SideIterator
typedef boost::shared_ptr< FaceQuadStruct > Ptr
 FaceQuadStruct (const TopoDS_Face &F=TopoDS_Face(), const std::string &nm="main")
 Constructor of a quad. More...
UVPtStruct & UVPt (int i, int j)
double & U (int i, int j)
double & V (int i, int j)
void shift (size_t nb, bool keepUnitOri, bool keepGrid=false)
 Rotate sides of a quad CCW by given nb of quartes. More...
int & nbNodeOut (int iSide)
bool findCell (const gp_XY &uv, int &i, int &j)
 Finds indices of a grid quad enclosing the given enforced UV. More...
bool isNear (const gp_XY &uv, int &i, int &j, int nbLoops=1)
 Looks for UV in quads around a given (I,J) and precise (I,J) More...
bool isEqual (const gp_XY &uv, int i, int j)
 Checks if a given UV is equal to a given grid point. More...
void normPa2IJ (double x, double y, int &i, int &j)
 Find indices (i,j) of a point in uv_grid by normalized parameters (x,y) More...
void updateUV (const gp_XY &uv, int i, int j, bool isVertical)
 Recompute UV of grid points around a moved point in one direction. More...
Data Fields
std::vector< Side > side
std::vector< UVPtStruct > uv_grid
int iSize
int jSize
TopoDS_Face face
Bnd_B2d uv_box
std::string name
◆ Ptr
typedef boost::shared_ptr<FaceQuadStruct> FaceQuadStruct::Ptr
◆ FaceQuadStruct()
FaceQuadStruct::FaceQuadStruct ( const TopoDS_Face &  F = TopoDS_Face(),
const std::string &  nm = "main"
References side.
◆ findCell()
bool FaceQuadStruct::findCell ( const gp_XY &  uv,
int &  i,
int &  j
References SMESH_MeshAlgos::GetBarycentricCoords(), iSize, isNear(), jSize, normPa2IJ(), uvPtStruct::UV(), uv_box, and UVPt().
◆ isEqual()
bool FaceQuadStruct::isEqual ( const gp_XY &  uv,
int  i,
int  j
References face, Handle(), iSize, jSize, and UVPt().
◆ isNear()
bool FaceQuadStruct::isNear ( const gp_XY &  uv,
int &  i,
int &  j,
int  nbLoops = 1
References SMESH_MeshAlgos::GetBarycentricCoords(), iSize, jSize, uvPtStruct::UV(), and UVPt().
Referenced by findCell().
◆ nbNodeOut()
int & FaceQuadStruct::nbNodeOut ( int  iSide)
◆ normPa2IJ()
void FaceQuadStruct::normPa2IJ ( double  x,
double  y,
int &  i,
int &  j
References iSize, jSize, and UVPt().
◆ shift()
void FaceQuadStruct::shift ( size_t  nb,
bool  ori,
bool  keepGrid = false
nb- number of rotation quartes
ori- to keep orientation of sides as in an unit quad or not
keepGrid- if true Side::grid is not changed, Side::from and Side::to are altered instead
References FaceQuadStruct::Side::contacts, iSize, jSize, NB_QUAD_SIDES, QUAD_BOTTOM_SIDE, QUAD_TOP_SIDE, reverse(), side, uv_grid, and UVPt().
◆ U()
double & FaceQuadStruct::U ( int  i,
int  j
◆ updateUV()
void FaceQuadStruct::updateUV ( const gp_XY &  uv,
int  i,
int  j,
bool  isVertical
References calcUV(), iSize, jSize, uvPtStruct::u, uvPtStruct::UV(), UVPt(), uvPtStruct::v, uvPtStruct::x, and uvPtStruct::y.
◆ UVPt()
◆ V()
double & FaceQuadStruct::V ( int  i,
int  j
◆ face
TopoDS_Face FaceQuadStruct::face
Referenced by isEqual().
◆ iSize
◆ jSize
◆ name
std::string FaceQuadStruct::name
◆ side
◆ uv_box
Bnd_B2d FaceQuadStruct::uv_box
◆ uv_grid
std::vector< UVPtStruct> FaceQuadStruct::uv_grid
