FaceQuadStruct::Side Struct Reference
#include <StdMeshers_Quadrangle_2D.hxx>
struct  Contact
 Side (StdMeshers_FaceSidePtr theGrid=StdMeshers_FaceSidePtr())
 Constructor of a side of quad. More...
Side & operator= (const Side &otherSide)
 Side copying. More...
 operator StdMeshers_FaceSidePtr ()
 operator const StdMeshers_FaceSidePtr () const
void AddContact (int ip, Side *side, int iop)
 Sets up a contact between this and another side. More...
int ToSideIndex (int quadNodeIndex) const
 Converts node index of a quad to node index of this side. More...
int ToQuadIndex (int sideNodeIndex) const
 Converts node index of this side to node index of a quad. More...
bool IsForced (int nodeIndex) const
 Checks if a node is enforced. More...
bool IsReversed () const
bool Reverse (bool keepGrid)
 Reverse the side. More...
int NbPoints () const
double Param (int nodeIndex) const
 Returns a normalized parameter of a point indexed within a quadrangle. More...
double Length (int from=-1, int to=-1) const
 Returns side length. More...
gp_XY Value2d (double x) const
 Returns UV by a parameter normalized within a quadrangle. More...
const UVPtStruct & First () const
const UVPtStruct & Last () const
const std::vector< UVPtStruct > & GetUVPtStruct (bool isXConst=0, double constValue=0) const
Data Fields
StdMeshers_FaceSidePtr grid
int from
int to
int di
std::set< int > forced_nodes
std::vector< Contact > contacts
int nbNodeOut
◆ Side()
FaceQuadStruct::Side::Side ( StdMeshers_FaceSidePtr  theGrid = StdMeshers_FaceSidePtr())
◆ AddContact()
void FaceQuadStruct::Side::AddContact ( int  ip,
Side *  side,
int  iop
◆ First()
const UVPtStruct & FaceQuadStruct::Side::First ( ) const
◆ GetUVPtStruct()
const std::vector< UVPtStruct > & FaceQuadStruct::Side::GetUVPtStruct ( bool  isXConst = 0,
double  constValue = 0
◆ IsForced()
bool FaceQuadStruct::Side::IsForced ( int  nodeIndex) const
[in]nodeIndex- an index of a node in a size
bool - true if the node is forced
Referenced by StdMeshers_Quadrangle_2D::addEnforcedNodes().
◆ IsReversed()
bool FaceQuadStruct::Side::IsReversed ( ) const
◆ Last()
const UVPtStruct & FaceQuadStruct::Side::Last ( ) const
◆ Length()
double FaceQuadStruct::Side::Length ( int  from = -1,
int  to = -1
◆ NbPoints()
◆ operator const StdMeshers_FaceSidePtr()
FaceQuadStruct::Side::operator const StdMeshers_FaceSidePtr ( ) const
◆ operator StdMeshers_FaceSidePtr()
FaceQuadStruct::Side::operator StdMeshers_FaceSidePtr ( )
◆ operator=()
FaceQuadStruct::Side & FaceQuadStruct::Side::operator= ( const Side &  otherSide)
Side copying.
References contacts, di, forced_nodes, from, grid, nbNodeOut, and to.
◆ Param()
double FaceQuadStruct::Side::Param ( int  nodeIndex) const
◆ Reverse()
bool FaceQuadStruct::Side::Reverse ( bool  keepGrid)
Reverse the side.
◆ ToQuadIndex()
int FaceQuadStruct::Side::ToQuadIndex ( int  sideNodeIndex) const
◆ ToSideIndex()
int FaceQuadStruct::Side::ToSideIndex ( int  quadNodeIndex) const
Referenced by StdMeshers_Quadrangle_2D::addEnforcedNodes(), and StdMeshers_Quadrangle_2D::splitQuad().
◆ Value2d()
gp_XY FaceQuadStruct::Side::Value2d ( double  x) const
◆ contacts
std::vector<Contact> FaceQuadStruct::Side::contacts
◆ di
int FaceQuadStruct::Side::di
Referenced by operator=().
◆ forced_nodes
std::set<int> FaceQuadStruct::Side::forced_nodes
◆ from
int FaceQuadStruct::Side::from
◆ grid
◆ nbNodeOut
int FaceQuadStruct::Side::nbNodeOut
◆ to
int FaceQuadStruct::Side::to
