StdMeshers_Quadrangle_2D Class Reference
#include <StdMeshers_Quadrangle_2D.hxx>
Inheritance diagram for StdMeshers_Quadrangle_2D:
struct  ForcedPoint
enum  Hypothesis_Status {
enum  hypothesis_type {
  ALGO_3D
 StdMeshers_Quadrangle_2D (int hypId, SMESH_Gen *gen)
virtual ~StdMeshers_Quadrangle_2D ()
virtual bool CheckHypothesis (SMESH_Mesh &aMesh, const TopoDS_Shape &aShape, Hypothesis_Status &aStatus)
 Compute the mesh on the given shape. More...
 Evaluate. More...
FaceQuadStruct::Ptr CheckAnd2Dcompute (SMESH_Mesh &aMesh, const TopoDS_Shape &aShape, const bool CreateQuadratic)
 CheckAnd2Dcompute. More...
FaceQuadStruct::Ptr CheckNbEdges (SMESH_Mesh &aMesh, const TopoDS_Shape &aShape, const bool considerMesh=false, SMESH_MesherHelper *aFaceHelper=0)
 Return FaceQuadStruct where sides ordered CCW, top and left sides reversed to be co-directed with bottom and right sides. More...
virtual bool FixInternalNodes (const SMESH_ProxyMesh &mesh, const TopoDS_Face &face)
 Method in which an algorithm generating a structured mesh fixes positions of in-face nodes after there movement due to insertion of viscous layers. More...
virtual void CancelCompute ()
 return compute error More...
void InitComputeError ()
bool OnlyUnaryInput () const
bool NeedShape () const
virtual int GetDim () const
SMESH_Gen * GetGen () const
const char * GetName () const
int GetID () const
int GetType () const
 Equality. More...
static bool IsApplicable (const TopoDS_Shape &aShape, bool toCheckAll)
 Return true if the algorithm can mesh this shape. More...
Protected Types
typedef std::map< StdMeshers_FaceSidePtr, std::vector< FaceQuadStruct::Ptr > > TQuadsBySide
bool checkNbEdgesForEvaluate (SMESH_Mesh &aMesh, const TopoDS_Shape &aShape, MapShapeNbElems &aResMap, std::vector< int > &aNbNodes, bool &IsQuadratic)
bool setNormalizedGrid (FaceQuadStruct::Ptr quad)
void splitQuadFace (SMESHDS_Mesh *theMeshDS, const int theFaceID, const SMDS_MeshNode *theNode1, const SMDS_MeshNode *theNode2, const SMDS_MeshNode *theNode3, const SMDS_MeshNode *theNode4)
 Split quadrangle in to 2 triangles by smallest diagonal. More...
bool computeQuadDominant (SMESH_Mesh &aMesh, const TopoDS_Face &aFace)
 Compute quadrangles and possibly triangles on all quads of myQuadList. More...
bool computeQuadDominant (SMESH_Mesh &aMesh, const TopoDS_Face &aFace, FaceQuadStruct::Ptr quad)
 Compute quadrangles and possibly triangles. More...
bool computeQuadPref (SMESH_Mesh &aMesh, const TopoDS_Face &aFace, FaceQuadStruct::Ptr quad)
 Create only quandrangle faces. More...
bool computeTriangles (SMESH_Mesh &aMesh, const TopoDS_Face &aFace, FaceQuadStruct::Ptr quad)
 Compute quadrangles and triangles on the quad. More...
bool evaluateQuadPref (SMESH_Mesh &aMesh, const TopoDS_Shape &aShape, std::vector< int > &aNbNodes, MapShapeNbElems &aResMap, bool isQuadratic)
 Evaluate only quandrangle faces. More...
bool computeReduced (SMESH_Mesh &aMesh, const TopoDS_Face &aFace, FaceQuadStruct::Ptr quad)
 Implementation of Reduced algorithm (meshing with quadrangles only) More...
void updateDegenUV (FaceQuadStruct::Ptr quad)
 Set UV of nodes on degenerated VERTEXes in the middle of degenerated EDGE. More...
void smooth (FaceQuadStruct::Ptr quad)
 Perform smoothing of 2D elements on a FACE with ignored degenerated EDGE. More...
bool check ()
 Checks validity of generated faces. More...
int getCorners (const TopoDS_Face &theFace, SMESH_Mesh &theMesh, std::list< TopoDS_Edge > &theWire, std::vector< TopoDS_Vertex > &theVertices, int &theNbDegenEdges, const bool considerMesh)
 Finds vertices at the most sharp face corners. More...
bool getEnforcedUV ()
 Fills myForcedPnts. More...
bool addEnforcedNodes ()
 Splits quads by adding points of enforced nodes and create nodes on the sides shared by quads. More...
int splitQuad (FaceQuadStruct::Ptr quad, int i, int j)
 Splits a quad at I or J. More...
void shiftQuad (FaceQuadStruct::Ptr &quad, const int num)
void updateSideUV (FaceQuadStruct::Side &side, int iForced, const TQuadsBySide &quads, int *iNext=NULL)
 Updates UV of a side after moving its node. More...
bool myQuadranglePreference
bool myTrianglePreference
int myTriaVertexID
bool myNeedSmooth
bool myCheckOri
const StdMeshers_QuadrangleParams * myParams
StdMeshers_QuadType myQuadType
SMESH_MesherHelper * myHelper
SMESH_ProxyMesh::Ptr myProxyMesh
std::list< FaceQuadStruct::Ptr > myQuadList
std::vector< ForcedPoint > myForcedPnts
bool _onlyUnaryInput
bool _requireDiscreteBoundary
bool _requireShape
bool _supportSubmeshes
bool _neededLowerHyps [4]
bool _quadraticMesh
int _error
std::string _comment
const SMDS_Mesh * _mesh
double _progress
int _progressTic
SMESH_Gen * _gen
int _shapeType
int _param_algo_dim
int _hypId
hypothesis_type _type
std::string _libName
◆ TQuadsBySide
◆ EMeshError
enum SMESH_Algo::EMeshError
MEr_OK
MEr_HOLES
MEr_BAD_ORI
MEr_EMPTY
◆ Hypothesis_Status
HYP_OK
HYP_MISSING
HYP_CONCURRENT
HYP_BAD_PARAMETER
HYP_HIDDEN_ALGO
HYP_HIDING_ALGO
HYP_UNKNOWN_FATAL
HYP_INCOMPATIBLE
HYP_NOTCONFORM
HYP_ALREADY_EXIST
HYP_BAD_DIM
HYP_BAD_SUBSHAPE
HYP_BAD_GEOMETRY
HYP_NEED_SHAPE
HYP_INCOMPAT_HYPS
◆ hypothesis_type
PARAM_ALGO
ALGO_0D
ALGO_1D
ALGO_2D
ALGO_3D
◆ InitWay
BY_MESH
BY_GEOM
BY_AVERAGE_LENGTH
◆ StdMeshers_Quadrangle_2D()
StdMeshers_Quadrangle_2D::StdMeshers_Quadrangle_2D ( int  hypId,
SMESH_Gen *  gen
◆ ~StdMeshers_Quadrangle_2D()
StdMeshers_Quadrangle_2D::~StdMeshers_Quadrangle_2D ( )
◆ addBadInputElement()
◆ addBadInputElements()
const bool  addNodes = false
◆ addEnforcedNodes()
◆ CancelCompute()
◆ check()
◆ CheckAnd2Dcompute()
FaceQuadStruct::Ptr StdMeshers_Quadrangle_2D::CheckAnd2Dcompute ( SMESH_Mesh &  aMesh,
const TopoDS_Shape &  aShape,
CheckAnd2Dcompute.
References SMESH_Algo::_quadraticMesh, CheckNbEdges(), and setNormalizedGrid().
◆ CheckHypothesis()
bool StdMeshers_Quadrangle_2D::CheckHypothesis ( SMESH_Mesh &  aMesh,
Hypothesis_Status &  aStatus
◆ CheckNbEdges()
FaceQuadStruct::Ptr StdMeshers_Quadrangle_2D::CheckNbEdges ( SMESH_Mesh &  aMesh,
const bool  considerMesh = false,
SMESH_MesherHelper *  aFaceHelper = 0
◆ checkNbEdgesForEvaluate()
bool StdMeshers_Quadrangle_2D::checkNbEdgesForEvaluate ( SMESH_Mesh &  aMesh,
MapShapeNbElems &  aResMap,
std::vector< int > &  aNbNodes,
bool &  IsQuadratic
◆ Compute() [1/2]
◆ Compute() [2/2]
SMESH_MesherHelper *  aHelper
aMesh- the mesh
bool- is a success
aMesh- the mesh
bool- is a success
◆ computeQuadDominant() [1/2]
bool StdMeshers_Quadrangle_2D::computeQuadDominant ( SMESH_Mesh &  aMesh,
const TopoDS_Face &  aFace
◆ computeQuadDominant() [2/2]
◆ computeQuadPref()
◆ computeReduced()
◆ computeTriangles()
bool StdMeshers_Quadrangle_2D::computeTriangles ( SMESH_Mesh &  aMesh,
const TopoDS_Face &  aFace,
◆ Continuity()
const TopoDS_Edge &  theE2
E1- the 1st edge
E2- the 2nd edge
References OCC_CATCH_SIGNALS.
◆ DataDependOnParams()
◆ EdgeLength()
◆ error() [1/3]
◆ error() [2/3]
Referenced by addEnforcedNodes(), StdMeshers_Prism_3D::assocOrProjBottom2Top(), CheckHypothesis(), StdMeshers_Hexa_3D::CheckHypothesis(), StdMeshers_PolyhedronPerSolid_3D::CheckHypothesis(), StdMeshers_Projection_2D::CheckHypothesis(), CheckNbEdges(), checkNbEdgesForEvaluate(), StdMeshers_Prism_3D::compute(), StdMeshers_Cartesian_3D::Compute(), StdMeshers_CompositeHexa_3D::Compute(), StdMeshers_CompositeSegment_1D::Compute(), StdMeshers_Hexa_3D::Compute(), StdMeshers_Import_1D::Compute(), StdMeshers_Import_1D2D::Compute(), StdMeshers_PolygonPerFace_2D::Compute(), StdMeshers_Prism_3D::Compute(), StdMeshers_Projection_1D::Compute(), StdMeshers_Projection_1D2D::Compute(), StdMeshers_Projection_2D::Compute(), StdMeshers_Projection_3D::Compute(), StdMeshers_QuadFromMedialAxis_1D2D::Compute(), Compute(), StdMeshers_RadialPrism_3D::Compute(), StdMeshers_RadialQuadrangle_1D2D::Compute(), SMESH_Algo::Compute(), StdMeshers_HexaFromSkin_3D::Compute(), TNodeDistributor::Compute(), StdMeshers_Prism_3D::computeBase(), StdMeshers_RadialPrism_3D::computeLayerPositions(), StdMeshers_RadialQuadrangle_1D2D::computeLayerPositions(), computeQuadDominant(), computeQuadPref(), computeReduced(), StdMeshers_Prism_3D::computeWalls(), SMESH_Algo::error(), StdMeshers_HexaFromSkin_3D::Evaluate(), StdMeshers_Import_1D::Evaluate(), StdMeshers_Import_1D2D::Evaluate(), StdMeshers_PolygonPerFace_2D::Evaluate(), StdMeshers_Prism_3D::Evaluate(), StdMeshers_Projection_1D::Evaluate(), StdMeshers_Projection_1D2D::Evaluate(), StdMeshers_Projection_2D::Evaluate(), StdMeshers_Projection_3D::Evaluate(), StdMeshers_CompositeHexa_3D::findBoxFaces(), getCorners(), getEnforcedUV(), SMESH_Algo::GetFeatures(), StdMeshers_ViscousLayerBuilder::GetShrinkGeometry(), StdMeshers_Prism_3D::getWallFaces(), StdMeshers_Prism_3D::initPrism(), StdMeshers_Prism_3D::projectBottomToTop(), and setNormalizedGrid().
◆ error() [3/3]
◆ Evaluate()
◆ evaluateQuadPref()
bool StdMeshers_Quadrangle_2D::evaluateQuadPref ( SMESH_Mesh &  aMesh,
bool  isQuadratic
◆ FixInternalNodes()
◆ GetAssignedShapes()
◆ GetCompatibleHypoFilter()
◆ GetCompatibleHypothesis()
◆ GetComputeError()
◆ getCorners()
int StdMeshers_Quadrangle_2D::getCorners ( const TopoDS_Face &  theFace,
SMESH_Mesh &  theMesh,
std::list< TopoDS_Edge > &  theWire,
std::vector< TopoDS_Vertex > &  theVertices,
int &  theNbDegenEdges,
const bool  theConsiderMesh
[in]theFace- the FACE
[in,out]theWire- the ordered edges of the face. It can be modified to have the first VERTEX of the first EDGE in vertices
[out]theVertices- the found corner vertices in the order corresponding to the order of EDGEs in theWire
[out]theNbDegenEdges- nb of degenerated EDGEs in theFace
[in]theConsiderMesh- if true, only meshed VERTEXes are considered as possible corners
int - number of quad sides found: 0, 3 or 4
References COMPERR_BAD_INPUT_MESH, COMPERR_BAD_PARMETERS, COMPERR_BAD_SHAPE, SMESH_MesherHelper::CopySubShapeInfo(), StdMeshers_FaceSide::Edge(), SMESH_Algo::error(), StdMeshers_FaceSide::FirstVertex(), StdMeshers_QuadrangleParams::GetCorners(), SMESH_MesherHelper::GetMeshDS(), SMESHDS_Mesh::IndexToShape(), SMESH_Algo::isDegenerated(), SMESH_MesherHelper::IsSubShape(), SMESH_MesherHelper::IthVertex(), myCheckOri, myHelper, myParams, myTriaVertexID, StdMeshers_FaceSide::NbEdges(), StdMeshers_FaceSide::NbPoints(), StdMeshers_FaceSide::NbSegments(), SMESHDS_Mesh::ShapeToIndex(), and StdMeshers_FaceSide::VertexNode().
Referenced by CheckNbEdges().
◆ GetDim()
◆ getEnforcedUV()
◆ GetFeatures() [1/2]
◆ GetFeatures() [2/2]
◆ GetGen()
◆ GetID()
◆ GetLibName()
◆ GetMeshByPersistentID()
◆ GetMeshError()
◆ GetName()
◆ GetNodeParamOnEdge()
const TopoDS_Edge &  theEdge,
Warning
◆ GetProgress()
◆ GetProgressByTic()
◆ GetShapeType()
◆ GetSortedNodesOnEdge()
theNodes- The resulting map
Warning
◆ GetType()
◆ GetUsedHypothesis()
aMesh- the mesh
aShape- the shape
Referenced by StdMeshers_Cartesian_3D::CheckHypothesis(), StdMeshers_QuadFromMedialAxis_1D2D::CheckHypothesis(), CheckHypothesis(), StdMeshers_Hexa_3D::CheckHypothesis(), StdMeshers_Import_1D::CheckHypothesis(), StdMeshers_Import_1D2D::CheckHypothesis(), StdMeshers_PolyhedronPerSolid_3D::CheckHypothesis(), StdMeshers_Projection_1D::CheckHypothesis(), StdMeshers_Projection_2D::CheckHypothesis(), StdMeshers_Projection_3D::CheckHypothesis(), StdMeshers_RadialPrism_3D::CheckHypothesis(), StdMeshers_RadialQuadrangle_1D2D::CheckHypothesis(), StdMeshers_SegmentAroundVertex_0D::CheckHypothesis(), SMESH_subMesh::ComputeStateEngine(), VISCOUS_2D::_ViscousBuilder2D::findEdgesWithLayers(), VISCOUS_3D::_ViscousBuilder::findSolidsWithLayers(), SMESH_subMesh::getCollection(), StdMeshers_CompositeSegment_1D::GetFaceSide(), StdMeshers_Regular_1D::GetUsedHypothesis(), StdMeshers_Regular_1D::getVertexHyp(), and StdMeshers_ProjectionUtils::MakeComputed().
◆ InitComputeError()
◆ IsApplicable()
bool StdMeshers_Quadrangle_2D::IsApplicable ( const TopoDS_Shape &  aShape,
bool  toCheckAll
[in]aShape- shape to check
References SMESH_MesherHelper::Count(), Edge, and SMESH_Algo::isDegenerated().
Referenced by StdMeshers_QuadFromMedialAxis_1D2D::IsApplicableToShape(), and StdMeshers_RadialQuadrangle_1D2D::IsApplicableToShape().
◆ IsApplicableToShape()
virtual bool StdMeshers_Quadrangle_2D::IsApplicableToShape ( const TopoDS_Shape &  shape,
bool  toCheckAll
bool- true by default
Reimplemented from SMESH_2D_Algo.
Reimplemented in StdMeshers_QuadFromMedialAxis_1D2D, and StdMeshers_RadialQuadrangle_1D2D.
References SMESH::IsApplicable().
◆ IsAuxiliary()
bool- auxiliary or not
◆ IsContinuous()
const TopoDS_Edge &  E2
Referenced by StdMeshers_Prism_3D::allVerticalEdgesStraight(), and checkNbEdgesForEvaluate().
◆ isDegenerated()
◆ IsSameName()
◆ IsStatusFatal()
◆ IsStraight()
◆ LoadFrom()
load- the stream
std::ostream& - the stream
◆ LoadStringFromStream()
std::string &  txt
◆ NeedDiscreteBoundary()
◆ NeedLowerHyps()
◆ NeedShape()
Referenced by SMESH_Hypothesis_i::LoadFrom(), StdMeshers_CartesianParameters3D::SetAxisDirs(), StdMeshers_BlockRenumber::SetBlocksOrientation(), StdMeshers_ViscousLayers::SetBndShapes(), StdMeshers_Geometric1D::SetCommonRatio(), StdMeshers_ImportSource1D::SetCopySourceMesh(), StdMeshers_Adaptive1D::SetDeflection(), StdMeshers_Deflection1D::SetDeflection(), StdMeshers_QuadrangleParams::SetEnforcedNodes(), StdMeshers_AutomaticLength::SetFineness(), StdMeshers_CartesianParameters3D::SetFixedPoint(), StdMeshers_CartesianParameters3D::SetGrid(), StdMeshers_CartesianParameters3D::SetGridSpacing(), StdMeshers_ViscousLayers::SetGroupName(), StdMeshers_ImportSource1D::SetGroups(), StdMeshers_LayerDistribution::SetLayerDistribution(), StdMeshers_LocalLength::SetLength(), StdMeshers_MaxLength::SetLength(), StdMeshers_SegmentLengthAroundVertex::SetLength(), StdMeshers_Arithmetic1D::SetLength(), StdMeshers_StartEndLength::SetLength(), StdMeshers_MaxElementArea::SetMaxArea(), StdMeshers_Adaptive1D::SetMaxSize(), StdMeshers_MaxElementVolume::SetMaxVolume(), StdMeshers_ViscousLayers::SetMethod(), StdMeshers_Adaptive1D::SetMinSize(), StdMeshers_LengthFromEdges::SetMode(), StdMeshers_FixedPoints1D::SetNbSegments(), StdMeshers_ViscousLayers::SetNumberLayers(), StdMeshers_NumberOfLayers::SetNumberOfLayers(), StdMeshers_FixedPoints1D::SetPoints(), StdMeshers_LocalLength::SetPrecision(), StdMeshers_QuadrangleParams::SetQuadType(), StdMeshers_CartesianParameters3D::SetQuanta(), StdMeshers_Reversible1D::SetReversedEdges(), StdMeshers_CartesianParameters3D::SetSizeThreshold(), StdMeshers_ProjectionSource3D::SetSource3DShape(), StdMeshers_ProjectionSource1D::SetSourceEdge(), StdMeshers_ProjectionSource2D::SetSourceFace(), StdMeshers_ProjectionSource1D::SetSourceMesh(), StdMeshers_ProjectionSource2D::SetSourceMesh(), StdMeshers_ProjectionSource3D::SetSourceMesh(), StdMeshers_Geometric1D::SetStartLength(), StdMeshers_ViscousLayers::SetStretchFactor(), StdMeshers_CartesianParameters3D::SetToAddEdges(), StdMeshers_CartesianParameters3D::SetToConsiderInternalFaces(), StdMeshers_CartesianParameters3D::SetToCreateFaces(), StdMeshers_ViscousLayers::SetTotalThickness(), StdMeshers_CartesianParameters3D::SetToUseQuanta(), StdMeshers_CartesianParameters3D::SetToUseThresholdForInternalFaces(), StdMeshers_QuadrangleParams::SetTriaVertex(), StdMeshers_ProjectionSource1D::SetVertexAssociation(), StdMeshers_ProjectionSource2D::SetVertexAssociation(), and StdMeshers_ProjectionSource3D::SetVertexAssociation().
◆ NumberOfPoints()
const TopoDS_Wire &  W
◆ OnlyUnaryInput()
◆ operator!=()
◆ operator==()
Equality.
◆ SaveStringToStream()
const std::string &  txt
◆ SaveTo()
save- the stream
◆ SetEventListener()
void SMESH_Algo::SetEventListener ( SMESH_subMesh *  subMesh)
This method is called when a submesh gets HYP_OK algo_state. After being set, event listener is notified on each event of a submesh. By default none listener is set
After being set, event listener is notified on each event of a submesh. By default non listener is set
Reimplemented in StdMeshers_Cartesian_3D, StdMeshers_CompositeSegment_1D, StdMeshers_Import_1D, StdMeshers_Import_1D2D, StdMeshers_QuadFromMedialAxis_1D2D, StdMeshers_RadialQuadrangle_1D2D, StdMeshers_Regular_1D, StdMeshers_Projection_1D, StdMeshers_Projection_1D2D, StdMeshers_Projection_2D, and StdMeshers_Projection_3D.
Referenced by SMESH_subMesh::AlgoStateEngine().
◆ SetLibName()
◆ setNormalizedGrid()
◆ SetParametersByDefaults()
Implements SMESH_Hypothesis.
◆ SetParametersByMesh()
◆ setSubMeshesToCompute()
◆ shiftQuad()
void StdMeshers_Quadrangle_2D::shiftQuad ( FaceQuadStruct::Ptr &  quad,
const int  num
References myQuadList.
Referenced by computeQuadPref(), and computeReduced().
◆ smooth()
◆ splitQuad()
int StdMeshers_Quadrangle_2D::splitQuad ( FaceQuadStruct::Ptr  quad,
int  I,
int  J
◆ splitQuadFace()
void StdMeshers_Quadrangle_2D::splitQuadFace ( SMESHDS_Mesh *  theMeshDS,
const SMDS_MeshNode *  theNode1,
const SMDS_MeshNode *  theNode2,
const SMDS_MeshNode *  theNode3,
const SMDS_MeshNode *  theNode4
References SMESH_MesherHelper::AddFace(), and myHelper.
Referenced by computeQuadDominant().
◆ SubMeshesToCompute()
◆ SubmeshRestored()
subMesh- restored submesh
◆ SupportSubmeshes()
◆ updateDegenUV()
void StdMeshers_Quadrangle_2D::updateDegenUV ( FaceQuadStruct::Ptr  quad)
WARNING: this method must be called AFTER retrieving UVPtStruct's from quad
References Handle(), SMESH_MesherHelper::IsDegenShape(), myHelper, myNeedSmooth, StdMeshers_FaceSide::New(), QUAD_TOP_SIDE, uvPtStruct::u, and uvPtStruct::v.
Referenced by Compute().
◆ updateSideUV()
◆ VertexNode() [1/3]
const SMESH_Mesh *  mesh
V- the vertex
mesh- mesh
◆ VertexNode() [2/3]
const SMESHDS_Mesh *  meshDS
◆ VertexNode() [3/3]
const SMESH_Mesh *  mesh,
const bool  checkV = true
V- the vertex
mesh- the mesh
V- the vertex
◆ _assigedShapeList
◆ _badInputElements
◆ _comment
◆ _compatibleAllHypFilter
◆ _compatibleHypothesis
◆ _compatibleNoAuxHypFilter
◆ _computeCanceled
◆ _error
int SMESH_Algo::_error
◆ _gen
◆ _hypId
◆ _libName
privateinherited
◆ _mesh
◆ _name
Referenced by SMESHDS_Hypothesis::GetName(), SMESHDS_Hypothesis::IsSameName(), SMESHDS_Hypothesis::operator==(), SMESHDS_Hypothesis::SMESHDS_Hypothesis(), StdMeshers_Adaptive1D::StdMeshers_Adaptive1D(), StdMeshers_Arithmetic1D::StdMeshers_Arithmetic1D(), StdMeshers_AutomaticLength::StdMeshers_AutomaticLength(), StdMeshers_BlockRenumber::StdMeshers_BlockRenumber(), StdMeshers_Cartesian_3D::StdMeshers_Cartesian_3D(), StdMeshers_CartesianParameters3D::StdMeshers_CartesianParameters3D(), StdMeshers_CompositeHexa_3D::StdMeshers_CompositeHexa_3D(), StdMeshers_CompositeSegment_1D::StdMeshers_CompositeSegment_1D(), StdMeshers_Deflection1D::StdMeshers_Deflection1D(), StdMeshers_FixedPoints1D::StdMeshers_FixedPoints1D(), StdMeshers_Geometric1D::StdMeshers_Geometric1D(), StdMeshers_Hexa_3D::StdMeshers_Hexa_3D(), StdMeshers_HexaFromSkin_3D::StdMeshers_HexaFromSkin_3D(), StdMeshers_Import_1D::StdMeshers_Import_1D(), StdMeshers_Import_1D2D::StdMeshers_Import_1D2D(), StdMeshers_ImportSource1D::StdMeshers_ImportSource1D(), StdMeshers_ImportSource2D::StdMeshers_ImportSource2D(), StdMeshers_LayerDistribution::StdMeshers_LayerDistribution(), StdMeshers_LayerDistribution2D::StdMeshers_LayerDistribution2D(), StdMeshers_LengthFromEdges::StdMeshers_LengthFromEdges(), StdMeshers_LocalLength::StdMeshers_LocalLength(), StdMeshers_MaxElementArea::StdMeshers_MaxElementArea(), StdMeshers_MaxElementVolume::StdMeshers_MaxElementVolume(), StdMeshers_MaxLength::StdMeshers_MaxLength(), StdMeshers_NotConformAllowed::StdMeshers_NotConformAllowed(), StdMeshers_NumberOfLayers::StdMeshers_NumberOfLayers(), StdMeshers_NumberOfLayers2D::StdMeshers_NumberOfLayers2D(), StdMeshers_NumberOfSegments::StdMeshers_NumberOfSegments(), StdMeshers_PolygonPerFace_2D::StdMeshers_PolygonPerFace_2D(), StdMeshers_PolyhedronPerSolid_3D::StdMeshers_PolyhedronPerSolid_3D(), StdMeshers_Prism_3D::StdMeshers_Prism_3D(), StdMeshers_Projection_1D::StdMeshers_Projection_1D(), StdMeshers_Projection_1D2D::StdMeshers_Projection_1D2D(), StdMeshers_Projection_2D::StdMeshers_Projection_2D(), StdMeshers_Projection_3D::StdMeshers_Projection_3D(), StdMeshers_ProjectionSource1D::StdMeshers_ProjectionSource1D(), StdMeshers_ProjectionSource2D::StdMeshers_ProjectionSource2D(), StdMeshers_ProjectionSource3D::StdMeshers_ProjectionSource3D(), StdMeshers_Propagation::StdMeshers_Propagation(), StdMeshers_PropagOfDistribution::StdMeshers_PropagOfDistribution(), StdMeshers_QuadFromMedialAxis_1D2D::StdMeshers_QuadFromMedialAxis_1D2D(), StdMeshers_Quadrangle_2D(), StdMeshers_QuadrangleParams::StdMeshers_QuadrangleParams(), StdMeshers_QuadranglePreference::StdMeshers_QuadranglePreference(), StdMeshers_QuadraticMesh::StdMeshers_QuadraticMesh(), StdMeshers_RadialPrism_3D::StdMeshers_RadialPrism_3D(), StdMeshers_RadialQuadrangle_1D2D::StdMeshers_RadialQuadrangle_1D2D(), StdMeshers_Regular_1D::StdMeshers_Regular_1D(), StdMeshers_SegmentAroundVertex_0D::StdMeshers_SegmentAroundVertex_0D(), StdMeshers_SegmentLengthAroundVertex::StdMeshers_SegmentLengthAroundVertex(), StdMeshers_StartEndLength::StdMeshers_StartEndLength(), StdMeshers_UseExisting_1D::StdMeshers_UseExisting_1D(), StdMeshers_UseExisting_2D::StdMeshers_UseExisting_2D(), StdMeshers_ViscousLayerBuilder::StdMeshers_ViscousLayerBuilder(), StdMeshers_ViscousLayers::StdMeshers_ViscousLayers(), and StdMeshers_ViscousLayers2D::StdMeshers_ViscousLayers2D().
◆ _neededLowerHyps
◆ _onlyUnaryInput
◆ _param_algo_dim
◆ _progress
double SMESH_Algo::_progress
◆ _progressTic
int SMESH_Algo::_progressTic
◆ _quadraticMesh
◆ _requireDiscreteBoundary
◆ _requireShape
◆ _shapeType
◆ _smToCompute
◆ _supportSubmeshes
◆ _type
◆ _usedHypList
◆ myCheckOri
◆ myForcedPnts
std::vector< ForcedPoint > StdMeshers_Quadrangle_2D::myForcedPnts
◆ myHelper
◆ myNeedSmooth
◆ myParams
const StdMeshers_QuadrangleParams* StdMeshers_Quadrangle_2D::myParams
◆ myProxyMesh
SMESH_ProxyMesh::Ptr StdMeshers_Quadrangle_2D::myProxyMesh
◆ myQuadList
◆ myQuadranglePreference
bool StdMeshers_Quadrangle_2D::myQuadranglePreference
Referenced by CheckHypothesis(), Compute(), and Evaluate().
◆ myQuadType
StdMeshers_QuadType StdMeshers_Quadrangle_2D::myQuadType
◆ myTrianglePreference
bool StdMeshers_Quadrangle_2D::myTrianglePreference
◆ myTriaVertexID
int StdMeshers_Quadrangle_2D::myTriaVertexID
