_QuadFaceGrid Class Reference
Class corresponding to a meshed composite face of a box. More...
typedef SMDS_SetIterator< const _QuadFaceGrid &, TChildren::const_iterator, SMDS::SimpleAccessor< const _QuadFaceGrid &, TChildren::const_iterator >, SMDS::PassAllValueFilter< _QuadFaceGrid > > TChildIterator
 _QuadFaceGrid ()
 constructor of non-initialized _QuadFaceGrid More...
bool Init (const TopoDS_Face &f, SMESH_ProxyMesh &mesh)
 < initialization More...
bool AddContinuousFace (const _QuadFaceGrid &f, const TopTools_MapOfShape &internalEdges)
 Try to set the side as bottom hirizontal side. More...
bool SetBottomSide (const _FaceSide &side, int *sideIndex=0)
 Return face adjacent to zero-based i-th side of this face. More...
_QuadFaceGrid * FindAdjacentForSide (int i, list< _QuadFaceGrid > &faces, EBoxSides id) const
 Reverse edges in order to have the bottom edge going along axes of the unit box. More...
void ReverseEdges ()
 Reverse edges in order to have them oriented along axes of the unit box. More...
bool IsComplex () const
int NbChildren () const
TChildIterator GetChildren () const
bool Contain (const TopoDS_Vertex &vertex) const
bool LoadGrid (SMESH_ProxyMesh &mesh)
 < Load nodes of a mesh More...
void ComputeIJK (int i1, int i2, double v3)
 Return number of segments on the hirizontal sides. More...
int GetNbHoriSegments (SMESH_ProxyMesh &mesh, bool withBrothers=false) const
 Return number of segments on the vertical sides. More...
int GetNbVertSegments (SMESH_ProxyMesh &mesh, bool withBrothers=false) const
 Return edge on the hirizontal bottom sides. More...
int GetHoriEdges (vector< TopoDS_Edge > &edges) const
 Return a node by its position. More...
const SMDS_MeshNode * GetNode (int iHori, int iVert) const
 Return node coordinates by its position. More...
gp_XYZ GetXYZ (int iHori, int iVert) const
 Return normalized parameters of nodes within the unitary cube. More...
gp_XYZ & GetIJK (int iCol, int iRow)
const _FaceSide & GetSide (int i) const
 < Return i-th face side (0<i<4) More...
TopoDS_Face GetFace () const
 Return normal to the face at vertex v. More...
bool GetNormal (const TopoDS_Vertex &v, gp_Vec &n) const
SMESH_ComputeErrorPtr GetError () const
void SetID (EBoxSides id)
void DumpGrid () const
 Dumps coordinates of grid nodes. More...
void DumpVertices () const
 Dump vertices. More...
Private Types
typedef list< _QuadFaceGrid > TChildren
bool error (const std::string &text, int code=COMPERR_ALGO_FAILED)
bool error (const SMESH_ComputeErrorPtr &err)
bool loadCompositeGrid (SMESH_ProxyMesh &mesh)
 Fill myGrid with nodes of patches. More...
bool fillGrid (SMESH_ProxyMesh &theMesh, vector< const SMDS_MeshNode * > &theGrid, const _Indexer &theIndexer, int theX, int theY)
 Store nodes of a simple face into grid starting from (x,y) position. More...
bool locateChildren ()
 Find out mutual location of children: find their right and up brothers. More...
void setBrothers (set< _QuadFaceGrid * > &notLocatedBrothers)
 Find right an upper brothers among notLocatedBrothers. More...
TopoDS_Face myFace
_FaceSide mySides
bool myReverse
TChildren myChildren
_QuadFaceGrid * myLeftBottomChild
_QuadFaceGrid * myRightBrother
_QuadFaceGrid * myUpBrother
_Indexer myIndexer
vector< const SMDS_MeshNode * > myGrid
vector< gp_XYZ > myIJK
SMESH_ComputeErrorPtr myError
EBoxSides myID
Provides simplified access to it's sub-mesh data.
◆ TChildIterator
typedef SMDS_SetIterator< const _QuadFaceGrid&, TChildren::const_iterator, SMDS::SimpleAccessor<const _QuadFaceGrid&,TChildren::const_iterator>, SMDS::PassAllValueFilter<_QuadFaceGrid> > _QuadFaceGrid::TChildIterator
◆ TChildren
typedef list< _QuadFaceGrid > _QuadFaceGrid::TChildren
◆ _QuadFaceGrid()
_QuadFaceGrid::_QuadFaceGrid ( )
◆ AddContinuousFace()
bool _QuadFaceGrid::AddContinuousFace ( const _QuadFaceGrid &  f,
const TopTools_MapOfShape &  internalEdges
◆ ComputeIJK()
void _QuadFaceGrid::ComputeIJK ( int  i1,
int  i2,
double  v3
Fill myIJK with normalized parameters of nodes in myGrid.
[in]i1- coordinate index along rows of myGrid
[in]i2- coordinate index along columns of myGrid
[in]v3- value of the constant parameter
References GetIJK(), GetXYZ(), myIJK, and myIndexer.
Referenced by StdMeshers_CompositeHexa_3D::Compute().
◆ Contain()
bool _QuadFaceGrid::Contain ( const TopoDS_Vertex &  vertex) const
References _FaceSide::Contain(), and mySides.
◆ DumpGrid()
void _QuadFaceGrid::DumpGrid ( ) const
References myChildren, myGrid, myID, myIndexer, SetID(), SMDS_MeshNode::X(), SMDS_MeshNode::Y(), and SMDS_MeshNode::Z().
Referenced by loadCompositeGrid(), and LoadGrid().
◆ DumpVertices()
void _QuadFaceGrid::DumpVertices ( ) const
Dump vertices.
References B_BACK, B_BOTTOM, _FaceSide::Dump(), _FaceSide::GetSide(), myChildren, myID, mySides, and SetID().
Referenced by ReverseEdges().
◆ error() [1/2]
bool _QuadFaceGrid::error ( const SMESH_ComputeErrorPtr &  err)
References myError.
◆ error() [2/2]
bool _QuadFaceGrid::error ( const std::string &  text,
int  code = COMPERR_ALGO_FAILED
◆ fillGrid()
bool _QuadFaceGrid::fillGrid ( SMESH_ProxyMesh &  theMesh,
vector< const SMDS_MeshNode * > &  theGrid,
const _Indexer &  theIndexer,
int  theX,
int  theY
References error(), fillGrid(), GetError(), LoadGrid(), myGrid, myIndexer, myReverse, myRightBrother, and myUpBrother.
Referenced by fillGrid(), and loadCompositeGrid().
◆ FindAdjacentForSide()
_QuadFaceGrid * _QuadFaceGrid::FindAdjacentForSide ( int  i,
list< _QuadFaceGrid > &  faces,
EBoxSides  id
Return face adjacent to i-th side of this face, (0<i<4)
References GetSide(), SetBottomSide(), and SetID().
Referenced by StdMeshers_CompositeHexa_3D::Evaluate(), and StdMeshers_CompositeHexa_3D::findBoxFaces().
◆ GetChildren()
◆ GetError()
SMESH_ComputeErrorPtr _QuadFaceGrid::GetError ( ) const
◆ GetFace()
TopoDS_Face _QuadFaceGrid::GetFace ( ) const
References myFace.
Referenced by StdMeshers_CompositeHexa_3D::Evaluate().
◆ GetHoriEdges()
int _QuadFaceGrid::GetHoriEdges ( vector< TopoDS_Edge > &  edges) const
References _FaceSide::Edge(), GetHoriEdges(), _FaceSide::GetSide(), myLeftBottomChild, myRightBrother, mySides, and Q_BOTTOM.
Referenced by StdMeshers_CompositeHexa_3D::Evaluate(), and GetHoriEdges().
◆ GetIJK()
gp_XYZ & _QuadFaceGrid::GetIJK ( int  iCol,
int  iRow
◆ GetNbHoriSegments()
int _QuadFaceGrid::GetNbHoriSegments ( SMESH_ProxyMesh &  mesh,
bool  withBrothers = false
References GetNbHoriSegments(), _FaceSide::GetNbSegments(), _FaceSide::GetSide(), myLeftBottomChild, myRightBrother, mySides, and Q_BOTTOM.
Referenced by StdMeshers_CompositeHexa_3D::Compute(), GetNbHoriSegments(), and loadCompositeGrid().
◆ GetNbVertSegments()
int _QuadFaceGrid::GetNbVertSegments ( SMESH_ProxyMesh &  mesh,
References _FaceSide::GetNbSegments(), GetNbVertSegments(), _FaceSide::GetSide(), myLeftBottomChild, mySides, myUpBrother, and Q_LEFT.
Referenced by StdMeshers_CompositeHexa_3D::Compute(), GetNbVertSegments(), and loadCompositeGrid().
◆ GetNode()
const SMDS_MeshNode * _QuadFaceGrid::GetNode ( int  iHori,
int  iVert
References myGrid, and myIndexer.
◆ GetNormal()
bool _QuadFaceGrid::GetNormal ( const TopoDS_Vertex &  v,
gp_Vec &  n
References _FaceSide::Contain(), myChildren, myFace, and mySides.
◆ GetSide()
const _FaceSide & _QuadFaceGrid::GetSide ( int  i) const
◆ GetXYZ()
gp_XYZ _QuadFaceGrid::GetXYZ ( int  iHori,
int  iVert
Referenced by StdMeshers_CompositeHexa_3D::Compute(), and ComputeIJK().
◆ Init()
◆ IsComplex()
◆ loadCompositeGrid()
bool _QuadFaceGrid::loadCompositeGrid ( SMESH_ProxyMesh &  mesh)
◆ LoadGrid()
◆ locateChildren()
bool _QuadFaceGrid::locateChildren ( )
References DUMP_VERT, ERR_LI, error(), _FaceSide::FirstVertex(), GetSide(), myChildren, myLeftBottomChild, Q_BOTTOM, and setBrothers().
Referenced by GetSide(), and loadCompositeGrid().
◆ NbChildren()
int _QuadFaceGrid::NbChildren ( ) const
◆ ReverseEdges()
void _QuadFaceGrid::ReverseEdges ( )
References DumpVertices(), myChildren, and myReverse.
Referenced by StdMeshers_CompositeHexa_3D::findBoxFaces().
◆ SetBottomSide()
bool _QuadFaceGrid::SetBottomSide ( const _FaceSide &  side,
int *  sideIndex = 0
References _FaceSide::Contain(), myChildren, myLeftBottomChild, myRightBrother, mySides, myUpBrother, and _FaceSide::SetBottomSide().
Referenced by FindAdjacentForSide(), and StdMeshers_CompositeHexa_3D::findBoxFaces().
◆ setBrothers()
void _QuadFaceGrid::setBrothers ( set< _QuadFaceGrid * > &  notLocatedBrothers)
References DUMP_VERT, _FaceSide::FirstVertex(), GetSide(), _FaceSide::LastVertex(), myRightBrother, myUpBrother, Q_BOTTOM, Q_LEFT, and setBrothers().
Referenced by locateChildren(), and setBrothers().
◆ SetID()
void _QuadFaceGrid::SetID ( EBoxSides  id)
◆ myChildren
◆ myError
SMESH_ComputeErrorPtr _QuadFaceGrid::myError
Referenced by error(), and GetError().
◆ myFace
TopoDS_Face _QuadFaceGrid::myFace
◆ myGrid
vector<const SMDS_MeshNode*> _QuadFaceGrid::myGrid
◆ myID
EBoxSides _QuadFaceGrid::myID
◆ myIJK
vector<gp_XYZ> _QuadFaceGrid::myIJK
Referenced by ComputeIJK(), and GetIJK().
◆ myIndexer
_Indexer _QuadFaceGrid::myIndexer
◆ myLeftBottomChild
◆ myReverse
bool _QuadFaceGrid::myReverse
◆ myRightBrother
_QuadFaceGrid* _QuadFaceGrid::myRightBrother
◆ mySides
◆ myUpBrother
_QuadFaceGrid* _QuadFaceGrid::myUpBrother
