SMDS_SetIterator< VALUE, VALUE_SET_ITERATOR, ACCESOR, VALUE_FILTER > Class Template Reference
SMDS_Iterator iterating over abstract set of values like STL containers. More...
#include <SMDS_SetIterator.hxx>
Inheritance diagram for SMDS_SetIterator< VALUE, VALUE_SET_ITERATOR, ACCESOR, VALUE_FILTER >:
typedef VALUE value_type
 SMDS_SetIterator (const VALUE_SET_ITERATOR &begin, const VALUE_SET_ITERATOR &end, const VALUE_FILTER &filter=VALUE_FILTER())
virtual void init (const VALUE_SET_ITERATOR &begin, const VALUE_SET_ITERATOR &end, const VALUE_FILTER &filter=VALUE_FILTER())
 Initialization. More...
virtual bool more ()
 Return true iff there are other object in this iterator. More...
virtual VALUE next ()
 Return the current object and step to the next one. More...
virtual void remove ()
 Delete the current element and step to the next one. More...
VALUE_SET_ITERATOR _beg
VALUE_SET_ITERATOR _end
VALUE_FILTER _filter
template<typename VALUE, typename VALUE_SET_ITERATOR, typename ACCESOR = SMDS::SimpleAccessor<VALUE,VALUE_SET_ITERATOR>, typename VALUE_FILTER = SMDS::PassAllValueFilter<VALUE>>
class SMDS_SetIterator< VALUE, VALUE_SET_ITERATOR, ACCESOR, VALUE_FILTER >
BE CAREFUL: iterator pointed value is static_cast'ed to VALUE
◆ value_type
template<typename VALUE >
typedef VALUE SMDS_Iterator< VALUE >::value_type
◆ SMDS_SetIterator()
template<typename VALUE , typename VALUE_SET_ITERATOR , typename ACCESOR = SMDS::SimpleAccessor<VALUE,VALUE_SET_ITERATOR>, typename VALUE_FILTER = SMDS::PassAllValueFilter<VALUE>>
SMDS_SetIterator< VALUE, VALUE_SET_ITERATOR, ACCESOR, VALUE_FILTER >::SMDS_SetIterator ( const VALUE_SET_ITERATOR &  begin,
const VALUE_SET_ITERATOR &  end,
const VALUE_FILTER &  filter = VALUE_FILTER()
◆ init()
virtual void SMDS_SetIterator< VALUE, VALUE_SET_ITERATOR, ACCESOR, VALUE_FILTER >::init ( const VALUE_SET_ITERATOR &  begin,
◆ more()
virtual bool SMDS_SetIterator< VALUE, VALUE_SET_ITERATOR, ACCESOR, VALUE_FILTER >::more ( )
◆ next()
virtual VALUE SMDS_SetIterator< VALUE, VALUE_SET_ITERATOR, ACCESOR, VALUE_FILTER >::next ( )
◆ remove()
virtual void SMDS_Iterator< VALUE >::remove ( )
◆ _beg
VALUE_SET_ITERATOR SMDS_SetIterator< VALUE, VALUE_SET_ITERATOR, ACCESOR, VALUE_FILTER >::_beg
◆ _end
VALUE_SET_ITERATOR SMDS_SetIterator< VALUE, VALUE_SET_ITERATOR, ACCESOR, VALUE_FILTER >::_end
◆ _filter
VALUE_FILTER SMDS_SetIterator< VALUE, VALUE_SET_ITERATOR, ACCESOR, VALUE_FILTER >::_filter
