SMESH_ComputeError.hxx File Reference
#include "SMESH_Utils.hxx"
#include "SMDS_ElementHolder.hxx"
#include <list>
#include <boost/shared_ptr.hpp>
Include dependency graph for SMESH_ComputeError.hxx:
struct  SMESH_ComputeError
 Contains an algorithm and description of an occurred error. More...
struct  SMESH_BadInputElements
Typedefs
typedef boost::shared_ptr< SMESH_ComputeError > SMESH_ComputeErrorPtr
Enumerations
enum  SMESH_ComputeErrorName {
  COMPERR_OK = -1 , COMPERR_BAD_INPUT_MESH = -2 , COMPERR_STD_EXCEPTION = -3 , COMPERR_OCC_EXCEPTION = -4 ,
  COMPERR_SLM_EXCEPTION = -5 , COMPERR_EXCEPTION = -6 , COMPERR_MEMORY_PB = -7 , COMPERR_ALGO_FAILED = -8 ,
  COMPERR_BAD_SHAPE = -9 , COMPERR_WARNING = -10 , COMPERR_CANCELED = -11 , COMPERR_NO_MESH_ON_SHAPE = -12 ,
  COMPERR_BAD_PARMETERS = -13 , COMPERR_LAST_ALGO_ERROR = -100 , EDITERR_NO_MEDIUM_ON_GEOM = -101
Typedef Documentation
◆ SMESH_ComputeErrorPtr
typedef boost::shared_ptr<SMESH_ComputeError> SMESH_ComputeErrorPtr
◆ SMESH_ComputeErrorName
COMPERR_OK
wrong mesh on lower submesh
some std exception raised
OCC exception raised.
SALOME exception raised.
COMPERR_EXCEPTION
other exception raised
COMPERR_MEMORY_PB
std::bad_alloc exception
COMPERR_ALGO_FAILED
algo failed for some reason
COMPERR_BAD_SHAPE
bad geometry
COMPERR_WARNING
algo reports error but sub-mesh is computed anyway
COMPERR_CANCELED
compute canceled
no mesh elements assigned to sub-shape
incorrect hypotheses parameters
terminator of mesh computation errors
