SMDS_MeshNode Class Reference
#include <SMDS_MeshNode.hxx>
Inheritance diagram for SMDS_MeshNode:
typedef SMDS_StdIterator< const SMDS_MeshNode *, SMDS_NodeIteratorPtr > iterator
void setXYZ (double x, double y, double z)
double X () const
double Y () const
double Z () const
void GetXYZ (double xyz[3]) const
 thread safe getting coords More...
SMDS_ElemIteratorPtr GetInverseElementIterator (SMDSAbs_ElementType type=SMDSAbs_All) const
int NbInverseElements (SMDSAbs_ElementType type=SMDSAbs_All) const
 Count inverse elements of given type. More...
SMDS_PositionPtr GetPosition () const
void SetPosition (const SMDS_PositionPtr &aPos, int shapeID=0)
virtual SMDSAbs_ElementType GetType () const
virtual VTKCellType GetVtkType () const
virtual SMDSAbs_EntityType GetEntityType () const
virtual SMDSAbs_GeometryType GetGeomType () const
virtual int NbNodes () const
virtual int NbEdges () const
virtual int NbFaces () const
virtual SMDS_ElemIteratorPtr nodesIterator () const
virtual SMDS_NodeIteratorPtr nodeIterator () const
virtual const SMDS_MeshNode * GetNode (const int ind) const
 Return node by its index. More...
virtual bool IsPoly () const
virtual bool IsQuadratic () const
virtual bool IsMediumNode (const SMDS_MeshNode *) const
 Check if a node is a medium node of a quadratic cell. More...
virtual int NbCornerNodes () const
virtual void Print (std::ostream &OS) const override
 Print self. More...
virtual SMDS_NodeIteratorPtr interlacedNodesIterator () const
virtual SMDS_NodeIteratorPtr nodesIteratorToUNV () const
iterator begin_nodes () const
iterator end_nodes () const
const SMDS_MeshNode * GetNodeWrap (const int ind) const
virtual bool IsValidIndex (const int ind) const
 Return true if index of node is valid (0 <= ind < NbNodes()) More...
int WrappedIndex (const int ind) const
 Return a valid corner node index, fixing the given one if necessary. More...
virtual int GetNodeIndex (const SMDS_MeshNode *node) const
 Check if a node belongs to the element. More...
virtual smIdType GetID () const
 Return ID of an element. More...
virtual vtkIdType GetVtkID () const
 Return VTK ID of this element. More...
virtual int getshapeId () const
virtual int GetShapeID () const
 Return ID of a shape this element was generated on. More...
virtual void setIsMarked (bool is) const
 Mark this element. More...
virtual bool isMarked () const
 Check if this element is marked. More...
bool IsNull () const
SMDS_Mesh * GetMesh () const
 Return the mesh this element belongs to. More...
void setVtkID (const vtkIdType vtkID)
 Store VTK ID. More...
virtual void setShapeID (const int shapeID) const
 Set ID of a shape this element was generated on. More...
SMDS_UnstructuredGrid * getGrid () const
 Return a SMDS_UnstructuredGrid. More...
SMDS_ElementChunk * myHolder
void init (double x=0, double y=0, double z=0)
double * getCoord () const
void AddInverseElement (const SMDS_MeshElement *elem)
void RemoveInverseElement (const SMDS_MeshElement *elem)
void ClearInverseElements ()
Friends
class SMDS_Mesh
◆ iterator
◆ AddInverseElement()
◆ begin_nodes()
◆ ClearInverseElements()
void SMDS_MeshNode::ClearInverseElements ( )
◆ end_nodes()
◆ getCoord()
double * SMDS_MeshNode::getCoord ( ) const
References SMDS_MeshElement::getGrid(), and SMDS_MeshElement::GetVtkID().
Referenced by X(), Y(), and Z().
◆ GetEntityType()
virtual SMDSAbs_EntityType SMDS_MeshNode::GetEntityType ( ) const
Implements SMDS_MeshElement.
References SMDSEntity_Node.
◆ GetGeomType()
virtual SMDSAbs_GeometryType SMDS_MeshNode::GetGeomType ( ) const
References SMDSGeom_NONE.
◆ getGrid()
◆ GetID()
smIdType SMDS_MeshElement::GetID ( ) const
Reimplemented in SMDS_CellOfNodes.
References SMDS_ElementChunk::GetID(), and SMDS_MeshElement::myHolder.
Referenced by SMESH_Gen_i::_GetInside(), SMESHDS_SubMesh::add(), SMESHDS_Mesh::Add0DElement(), SMESH_MeshEditor_i::Add0DElement(), SMESHDS_Mesh::Add0DElementWithID(), SMESHDS_Mesh::AddBall(), SMESH_MeshEditor_i::AddBall(), SMESHDS_Mesh::AddBallWithID(), SMESHDS_Mesh::AddEdge(), SMESH_MeshEditor_i::AddEdge(), SMESHDS_Mesh::AddEdgeWithID(), SMESHDS_Mesh::AddFace(), SMESH_MeshEditor_i::AddFace(), SMESHDS_Mesh::AddFaceWithID(), SMESH_MeshEditor_i::AddNode(), SMESHDS_Mesh::AddNode(), SMESHDS_Mesh::AddNodeWithID(), SMESH_MeshEditor_i::AddPolygonalFace(), SMESHDS_Mesh::AddPolygonalFace(), SMESH_MeshEditor_i::AddPolyhedralVolume(), SMESHDS_Mesh::AddPolyhedralVolume(), SMESH_MeshEditor_i::AddPolyhedralVolumeByFaces(), SMESH_MeshEditor_i::AddQuadPolygonalFace(), SMESHDS_Mesh::AddQuadPolygonalFace(), SMESHDS_Mesh::AddVolume(), SMESH_MeshEditor_i::AddVolume(), SMESHDS_Mesh::AddVolumeWithID(), SMESH_MeshEditor_i::AffectedElemGroupsInRegion(), SMESH_VisualObjDef::buildElemPrs(), SMESHDS_Mesh::ChangeElementNodes(), SMESHDS_Mesh::ChangePolyhedronNodes(), SMESHGUI_CreatePolyhedralVolumeDlg::checkEditLine(), SMESH_MesherHelper::CheckNodeU(), VISCOUS_3D::_ConvexFace::CheckPrisms(), SMDS_NodeFactory::Compact(), StdMeshers_Prism_3D::compute(), StdMeshers_Import_1D2D::Compute(), StdMeshers_PolyhedronPerSolid_3D::Compute(), StdMeshers_Projection_3D::Compute(), StdMeshers_RadialPrism_3D::Compute(), VISCOUS_3D::_ViscousBuilder::computeGeomSize(), StdMeshers_Sweeper::ComputeNodesOnStraight(), SMESH_Gen_i::ConcatenateCommon(), SMESHDS_GroupBase::Contains(), SMESHDS_GroupOnFilter::Contains(), SMDS_Mesh::Contains(), SMESH_MeshEditor::convertElemToQuadratic(), SMESH_MeshEditor::ConvertFromQuadratic(), SMESH_MeshEditor::ConvertToQuadratic(), MeshEditor_I::TPreviewMesh::Copy(), SMESH_Gen_i::CopyMesh(), SMESH_Gen_i::CopyMeshWithGeom(), SMESH_Mesh_i::CreateDimGroup(), SMESH_MeshEditor::CreateFlatElementsOnFacesGroups(), SMESH_MeshEditor::CreateHoleSkin(), SMESH_VisualObjDef::createPoints(), SMESH_MeshAlgos::Intersector::Algo::Cut(), SMESH_MeshAlgos::Intersector::CutByPlanes(), SMESHGUI_CuttingOfQuadsDlg::displayPreview(), SMESHGUI_CreatePolyhedralVolumeDlg::displaySimulation(), SMESH_MeshEditor::DoubleNodesOnGroupBoundaries(), StdMeshers_PrismAsBlock::THorizontalEdgeAdaptor::dumpNodes(), SMESH::SelectionProxy::elementConnectivity(), enlargeBoundingBox(), SMESH_MeshEditor::ExtrusionSweep(), VISCOUS_3D::_ViscousBuilder::findCollisionEdges(), SMESH::Controls::ManifoldPart::findConnected(), StdMeshers_Sweeper::findDelaunayTriangles(), SMESH_Mesh_i::FindElementByNodes(), SMESH_MeshEditor::FindEqualElements(), SMESH_MeshEditor::FindFreeBorder(), SMESH_MeshEditor::FindMatchingNodes(), SMESH_MeshEditor::FindShape(), SMESH_MeshEditor_i::FindSharpEdges(), findTriangles(), SMDS_ElementFactory::Free(), SMESH::Controls::FreeEdges::GetBoreders(), VISCOUS_3D::getDistFromEdge(), SMESH_VisualObjDef::GetEdgeNodes(), SMESHGUI_PreVisualObj::GetEdgeNodes(), SMESHDS_GroupOnFilter::getElementIds(), MeshEditor_I::getElementsAround(), SMESH_subMesh_i::GetElementsByType(), SMESH::Controls::Filter::GetElementsId(), SMESH_Mesh_i::GetElemNode(), LinkID_Gen::GetLinkID(), SMESH::Filter_i::GetMeshInfo(), SMESH::Filter_i::GetNbElementsByType(), getNodeElemDistance(), SMESH_Mesh_i::GetNodeInverseElements(), SMESH::Controls::ElementsOnShape::getNodeIsOut(), getNodeNodeDistance(), SMESH_VisualObjDef::GetNodeObjId(), SMESHGUI_PreVisualObj::GetNodeObjId(), SMESHGUI_PreVisualObj::GetNodeVTKId(), VISCOUS_3D::_EdgesOnShape::GetNormal(), SMESH_MeshEditor_i::GetPreviewData(), SMDS_ElementFactory::GetShapeIterator(), SMESH_Mesh_i::GetSubMeshNodesId(), SMESH::Controls::MultiConnection2D::GetValue(), SMESH::Controls::MultiConnection2D::GetValues(), SMESH::Controls::Length2D::GetValues(), SMDS_ElementChunk::GetVtkID(), SMESH_Hasher::HashCode(), SMESH_TLinkHasher::HashCode(), SMDS_VolumeTool::ID(), VISCOUS_3D::_ViscousBuilder::invalidateBadSmooth(), SMESH::Controls::FreeEdges::IsFreeEdge(), SMESH::Controls::ManifoldPart::isInPlane(), SMESH::Controls::ConnectedElements::IsSatisfy(), SMESH_ProxyMesh::IsTemporary(), VISCOUS_3D::_ViscousBuilder::makeGroupOfLE(), SMESH_Mesh_i::MakeGroupsOfBadInputElements(), StdMeshers_Penta_3D::MakeMeshOnFxy1(), SMESH_MeshAlgos::Intersector::Algo::MakeNewFaces(), StdMeshers_Penta_3D::MakeNodes(), SMESH_MeshAlgos::MakeOffset(), StdMeshers_Penta_3D::MakeVolumeMesh(), SMESH_MeshEditor::MergeNodes(), SMESH_MeshEditor_i::MoveClosestNodeToPoint(), SMESHDS_Mesh::MoveNode(), SMESH::Predicate_i::NbSatisfying(), SMESH::SelectionProxy::nodeConnectivity(), SMESH_MeshEditor::Offset(), SMESHGUI_CreatePolyhedralVolumeDlg::onTextChange(), SMESHGUI_ExtrusionAlongPathDlg::onTextChange(), SMESHGUI_RotationDlg::onTextChange(), SMESHGUI_ScaleDlg::onTextChange(), SMESHGUI_SewingDlg::onTextChange(), SMESHGUI_SingleEditDlg::onTextChange(), SMESHGUI_SymmetryDlg::onTextChange(), SMESHGUI_TranslationDlg::onTextChange(), SMESHGUI_MeshPatternDlg::onTextChanged(), TIDTypeCompare::operator()(), TIDCompare::operator()(), Prism_3D::TNode::operator<(), operator<<(), SMESH::SelectionProxy::perFaceConnectivity(), DriverCGNS_Write::Perform(), DriverDAT_W_SMDS_Mesh::Perform(), DriverUNV_W_SMDS_Mesh::Perform(), DriverMED_W_SMESHDS_Mesh::PerformInternal(), StdMeshers_Sweeper::prepareTopBotDelaunay(), Print(), SMESH::Controls::ManifoldPart::process(), SMESH::Controls::ElementsOnSurface::process(), StdMeshers_Prism_3D::projectBottomToTop(), SMESH_MeshEditor_i::ProjectPoint(), SMESHDS_Mesh::RemoveElement(), SMESHDS_Mesh::RemoveFreeElement(), SMESHDS_Mesh::RemoveFreeNode(), SMESHDS_Mesh::RemoveNode(), SMESH_MeshEditor::RemoveNodeWithReconnection(), SMESH_MeshEditor::removeQuadElem(), SMESH_ProxyMesh::removeTmpElement(), SMESH_MeshAlgos::Intersector::Algo::replaceIntNode(), SMESH_Mesh_i::ReplaceShape(), SMESH_Gen_i::Save(), VISCOUS_3D::_ViscousBuilder::setEdgeData(), SMESH::Controls::CoplanarFaces::SetMesh(), SMESH::Controls::ElementsOnShape::setNodeIsOut(), StdMeshers_MaxElementVolume::SetParametersByMesh(), SMDS_ElementChunk::SetVTKID(), SMESH_MeshEditor::SewSideElements(), VISCOUS_2D::_ViscousBuilder2D::shrink(), SMESH_TLink::SMESH_TLink(), VISCOUS_3D::_ViscousBuilder::smoothAndCheck(), SMESH_MeshEditor::SplitEdge(), SMESH_MeshEditor::SplitFace(), splitPolygon(), and SMESH_MeshEditor::sweepElement().
◆ GetInverseElementIterator()
SMDS_ElemIteratorPtr SMDS_MeshNode::GetInverseElementIterator ( SMDSAbs_ElementType  type = SMDSAbs_All) const
References SMDS_MeshElement::getGrid(), SMDS_UnstructuredGrid::GetLinks(), SMDS_MeshElement::GetMesh(), and SMDS_MeshElement::GetVtkID().
Referenced by SMESH_MeshEditor_i::Add0DElement(), VISCOUS_3D::_ViscousBuilder::addBoundaryElements(), SMESH_Delaunay::addCloseNodes(), VISCOUS_3D::_Shrinker1D::AddEdge(), SMESH_MeshEditor::AffectedElemGroupsInRegion(), centroidalSmooth(), StdMeshers_Quadrangle_2D::check(), StdMeshers_Import_1D::Compute(), StdMeshers_Import_1D2D::Compute(), StdMeshers_QuadToTriaAdaptor::Compute2ndPart(), SMESH_MeshEditor::ConvertToQuadratic(), SMESH_MeshEditor::Create0DElementsOnAllNodes(), SMESH_Mesh_i::CreateDimGroup(), SMESH_MeshEditor::CreateHoleSkin(), SMESH_MeshEditor::DoubleNodesInRegion(), SMESH_MeshEditor::ExtrusionSweep(), SMDS_Mesh::Find0DElement(), SMDS_Mesh::FindBall(), SMDS_Mesh::FindEdge(), SMDS_Mesh::FindFace(), SMESH_MeshAlgos::FindFaceInSet(), SMESH_MeshEditor::FindMatchingNodes(), StdMeshers_ProjectionUtils::FindMatchingNodesOnFaces(), VISCOUS_3D::_ViscousBuilder::findNeiborsOnEdge(), findSegment(), VISCOUS_3D::_ViscousBuilder::findShapesToSmooth(), findTriangles(), MeshEditor_I::getElementsAround(), SMDS_Mesh::GetElementsByNodes(), getExclusiveNodes(), VISCOUS_3D::_ViscousBuilder::getFaceNormal(), SMESH::Controls::ManifoldPart::getFacesByLink(), getFinitElements(), SMESH_ProxyMesh::GetInverseElementIterator(), SMESH_MeshEditor::GetLinkedNodes(), SMESH_MesherHelper::GetMediumPos(), SMESH_Mesh_i::GetNodeInverseElements(), VISCOUS_3D::_Simplex::GetSimplices(), SMESH::Controls::MultiConnection2D::GetValue(), SMESH_MesherHelper::IsCornerOfStructure(), SMESH::Controls::FreeEdges::IsFreeEdge(), SMDS_VolumeTool::IsFreeFace(), SMDS_VolumeTool::IsFreeFaceAdv(), SMDS_VolumeTool::IsFreeFaceCheckAllNodes(), SMESH_MeshEditor::IsMedium(), Prism_3D::TNode::IsNeighbor(), SMESH_MeshAlgos::IsOn2DBoundary(), SMESH::Controls::BareBorderFace::IsSatisfy(), SMESH::Controls::FreeFaces::IsSatisfy(), SMESH::Controls::ConnectedElements::IsSatisfy(), SMESH_MeshEditor::ExtrusParam::makeNodesByNormal2D(), SMESH_MeshAlgos::MakeOffset(), SMESH_Pattern::makePolyElements(), SMESH_MeshAlgos::MakeSlot(), SMESH_MeshEditor::makeWalls(), StdMeshers_QuadToTriaAdaptor::MergeAdjacent(), SMESH_MeshEditor::MergeNodes(), StdMeshers_QuadToTriaAdaptor::MergePiramids(), MyIterator< VALUE >::next(), SMESH::SelectionProxy::nodeConnectivity(), VISCOUS_3D::_ViscousBuilder::prepareEdgeToShrink(), SMESHDS_Mesh::RemoveNode(), SMESH_MeshEditor::RemoveNodeWithReconnection(), SMESH_MeshEditor_i::RemoveNodeWithReconnection(), SMESH_MeshEditor::RotationSweep(), VISCOUS_3D::_ViscousBuilder::setEdgeData(), SMESH::Controls::CoplanarFaces::SetMesh(), StdMeshers_SegmentLengthAroundVertex::SetParametersByMesh(), SMESH_MeshEditor::SewFreeBorder(), SMESH_MeshEditor::SewSideElements(), VISCOUS_2D::_ViscousBuilder2D::shrink(), VISCOUS_3D::_ViscousBuilder::shrink(), StdMeshers_Quadrangle_2D::smooth(), SMESH_MeshEditor::Smooth(), VISCOUS_3D::_Shrinker1D::SwapSrcTgtNodes(), SMESH_MeshEditor::Transform(), and SMESH_MeshEditor::UpdateVolumes().
◆ GetMesh()
◆ GetNode()
◆ GetNodeIndex()
int SMDS_MeshElement::GetNodeIndex ( const SMDS_MeshNode *  node) const
node- the node to check
int- node index within the element, -1 if not found
Reimplemented in SMDS_FaceOfNodes, SMDS_LinearEdge, SMDS_MeshCell, SMDS_MeshVolume, and SMDS_VolumeOfNodes.
References SMDS_MeshElement::nodesIterator().
Referenced by VISCOUS_3D::_ViscousBuilder::addBoundaryElements(), StdMeshers_QuadToTriaAdaptor::Compute2ndPart(), SMESH_MeshAlgos::Intersector::Algo::Cut(), SMESH_MeshAlgos::Intersector::CutByPlanes(), SMDS_UnstructuredGrid::extrudeVolumeFromFace(), SMDS_Mesh::FindEdge(), SMDS_Mesh::FindElement(), findExistingTriangulation(), SMESH_MeshAlgos::FindFaceInSet(), VISCOUS_3D::_LayerEdge::FindIntersection(), SMESH_MeshEditor::FindMatchingNodes(), SMESH_ElementSearcherImpl::findOuterBoundary(), findSegment(), SMESH_MeshAlgos::GetCommonNodes(), VISCOUS_3D::getDistFromEdge(), SMDS_Mesh::GetElementsByNodes(), VISCOUS_3D::_Simplex::GetSimplices(), SMESH::Controls::FreeEdges::IsFreeEdge(), SMDS_VolumeTool::IsFreeFace(), SMDS_MeshElement::IsMediumNode(), SMESH_MeshAlgos::IsOn2DBoundary(), SMESH_MeshAlgos::IsRightOrder(), SMESH::Controls::BareBorderFace::IsSatisfy(), StdMeshers_QuadToTriaAdaptor::LimitHeight(), _QuadFaceGrid::LoadGrid(), SMESH_MeshEditor::MakeBoundaryMesh(), SMESH_MeshAlgos::Intersector::Algo::MakeNewFaces(), SMESH_MeshAlgos::MakeOffset(), SMESH_MeshEditor::makeWalls(), SMESH_MeshEditor::MergeNodes(), SMESH_MeshAlgos::NbCommonNodes(), StdMeshers_QuadToTriaAdaptor::Preparation(), SMESH_MeshEditor::Reorient2DBy3D(), SMESH::Controls::CoplanarFaces::SetMesh(), SMESH_MeshEditor::SewSideElements(), StdMeshers_Quadrangle_2D::smooth(), VISCOUS_3D::_ViscousBuilder::smoothAndCheck(), and VISCOUS_3D::_Shrinker1D::SwapSrcTgtNodes().
◆ GetNodeWrap()
const SMDS_MeshNode * SMDS_MeshElement::GetNodeWrap ( const int  ind) const
ind- node index
constSMDS_MeshNode* - the node
Index is wrapped if it is out of a valid range of corner nodes
Referenced by SMESH_MeshAlgos::Intersector::Algo::Cut(), SMESH_MeshEditor::GetLinkedNodes(), and SMESH_MeshEditor::makeWalls().
◆ GetPosition()
SMDS_PositionPtr SMDS_MeshNode::GetPosition ( ) const
References SMDS_ElementChunk::GetPosition(), and SMDS_MeshElement::myHolder.
Referenced by StdMeshers_RenumberHelper::AddReplacingNode(), SMESH_MesherHelper::AddTLinks(), StdMeshers_Prism_3D::assocOrProjBottom2Top(), StdMeshers_Prism_3D::compute(), StdMeshers_Import_1D::Compute(), StdMeshers_Projection_2D::Compute(), SMESH_Gen_i::CopyMeshWithGeom(), SMESH_MeshEditor::copyPosition(), VISCOUS_3D::_ViscousBuilder::findCollisionEdges(), StdMeshers_ProjectionUtils::FindMatchingNodesOnFaces(), SMESH_2D_Algo::FixInternalNodes(), VISCOUS_3D::getDistFromEdge(), VISCOUS_3D::getFaceDir(), VISCOUS_3D::_ViscousBuilder::getFaceNormal(), SMESH_MesherHelper::GetMediumNode(), SMESH_MesherHelper::GetMediumPos(), SMESH_Algo::GetMeshError(), SMESH_MesherHelper::GetNodeU(), SMESH_MesherHelper::GetNodeUV(), Prism_3D::TNode::GetPositionType(), SMESH_ProxyMesh::GetProxyNode(), SMESH_Algo::GetSortedNodesOnEdge(), StdMeshers_FaceSide::GetUVPtStruct(), SMESH::Controls::Deflection2D::GetValue(), VISCOUS_3D::_LayerEdge::InvalidateStep(), SMESH_MesherHelper::IsCornerOfStructure(), SMESH_MesherHelper::IsReversedSubMesh(), VISCOUS_3D::_ViscousBuilder::limitStepSize(), SMESH_Pattern::Load(), StdMeshers_Penta_3D::LoadIJNodes(), VISCOUS_3D::_ViscousBuilder::makeLayer(), StdMeshers_Penta_3D::MakeNodes(), SMESH_MeshEditor::MergeNodes(), VISCOUS_3D::PeriodicFaces::MoveNodes(), StdMeshers_ProjectionUtils::Morph::Perform(), VISCOUS_3D::_ViscousBuilder::prepareEdgeToShrink(), StdMeshers_Prism_3D::projectBottomToTop(), SMESH_PreMeshInfo::readSubMeshes(), VISCOUS_3D::_ViscousBuilder::refine(), SMESH_MeshEditor::Remove(), SMESH_Mesh_i::ReplaceShape(), VISCOUS_3D::_ViscousBuilder::restoreNoShrink(), SMESH_Gen_i::Save(), VISCOUS_3D::_LayerEdge::SetNewLength2d(), VISCOUS_2D::_ViscousBuilder2D::shrink(), VISCOUS_3D::_ViscousBuilder::shrink(), VISCOUS_3D::_SmoothNode::Smooth(), SMESH_MeshEditor::Smooth(), VISCOUS_3D::_Smoother1D::smoothAnalyticEdge(), SMESH_MeshEditor::SplitEdge(), StdMeshers_PrismAsBlock::TPCurveOnHorFaceAdaptor::TPCurveOnHorFaceAdaptor(), VISCOUS_3D::_LayerEdge::UpdatePositionOnSWOL(), and StdMeshers_FaceSide::VertexNode().
◆ getshapeId()
virtual int SMDS_MeshElement::getshapeId ( ) const
Referenced by SMESH_Delaunay::addCloseNodes(), SMESHDS_SubMesh::AddNode(), areNodesBound(), StdMeshers_Quadrangle_2D::check(), SMESH_MesherHelper::CheckNodeU(), SMESH_MesherHelper::CheckNodeUV(), StdMeshers_Import_1D2D::Compute(), VISCOUS_3D::_ViscousBuilder::computeGeomSize(), SMESHDS_SubMesh::Contains(), SMESH_MeshEditor::convertElemToQuadratic(), SMESH_MeshEditor::ConvertToQuadratic(), SMESH_MeshEditor::copyPosition(), SMESH_Pattern::createElements(), SMESH_MeshEditor::CreateHoleSkin(), SMESH_MeshEditor::DeleteDiag(), SMESH_Mesh_i::exportMEDFields(), VISCOUS_3D::_ViscousBuilder::findEdgesToUpdateNormalNearConvexFace(), StdMeshers_ProjectionUtils::FindMatchingNodesOnFaces(), SMESH_MeshEditor::FindShape(), VISCOUS_3D::_ViscousBuilder::findShapesToSmooth(), SMESH_MesherHelper::FixQuadraticElements(), SMESH_MesherHelper::GetCentralNode(), VISCOUS_3D::_ViscousBuilder::getFaceNormal(), SMESH_MesherHelper::GetMediumNode(), SMESH_MesherHelper::getMediumNodeOnComposedWire(), SMESH_MesherHelper::GetMediumPos(), StdMeshers_PrismAsBlock::GetNodeColumn(), SMESH_MesherHelper::GetNodeU(), SMESH_MesherHelper::GetNodeUV(), VISCOUS_3D::_EdgesOnShape::GetNormal(), StdMeshers_FaceSide::GetOrderedNodes(), SMESH_ProxyMesh::GetProxyNode(), SMESH_Mesh_i::GetShapeID(), VISCOUS_3D::_Simplex::GetSimplices(), SMESH_MesherHelper::GetSubShapeByNode(), StdMeshers_FaceSide::GetUVPtStruct(), SMESH::Controls::Deflection2D::GetValue(), StdMeshers_PrismAsBlock::HasNodeColumn(), StdMeshers_PrismAsBlock::Init(), SMESH_MeshEditor::InsertNodesIntoLink(), SMESH_MeshEditor::InverseDiag(), SMESH_MesherHelper::IsCornerOfStructure(), SMESH::Controls::BelongToGeom::IsSatisfy(), SMESH::Controls::LyingOnGeom::IsSatisfy(), SMESH_Pattern::Load(), VISCOUS_3D::_ViscousBuilder::makeLayer(), SMESH_MeshEditor::MergeNodes(), StdMeshers_QuadToTriaAdaptor::MergePiramids(), DriverGMF_Write::Perform(), SMESH_MeshEditor::QuadTo4Tri(), SMESH_MeshEditor::Remove(), SMESHDS_Mesh::RemoveElement(), SMESHDS_SubMesh::RemoveElement(), SMESHDS_Mesh::RemoveFreeElement(), SMESHDS_Mesh::RemoveFreeNode(), SMESHDS_Mesh::RemoveNode(), SMESHDS_SubMesh::RemoveNode(), SMESH_MeshEditor::removeQuadElem(), VISCOUS_3D::_ViscousBuilder::setEdgeData(), SMESH_MeshEditor::SewSideElements(), VISCOUS_2D::_ViscousBuilder2D::shrink(), StdMeshers_Quadrangle_2D::smooth(), VISCOUS_3D::_ViscousBuilder::smoothAndCheck(), SMESH_MeshEditor::SplitBiQuadraticIntoLinear(), StdMeshers_PrismAsBlock::TPCurveOnHorFaceAdaptor::TPCurveOnHorFaceAdaptor(), SMESH_MeshEditor::TriToQuad(), SMESHDS_Mesh::UnSetElementOnShape(), SMESHDS_Mesh::UnSetNodeOnShape(), SMESH_MeshEditor::UpdateVolumes(), StdMeshers_PrismAsBlock::TSideFace::Value(), and SMESH_Algo::VertexNode().
◆ GetShapeID()
◆ GetType()
virtual SMDSAbs_ElementType SMDS_MeshNode::GetType ( ) const
References SMDSAbs_Node.
◆ GetVtkID()
◆ GetVtkType()
virtual VTKCellType SMDS_MeshNode::GetVtkType ( ) const
◆ GetXYZ()
◆ init()
◆ interlacedNodesIterator()
◆ isMarked()
◆ IsMediumNode()
virtual bool SMDS_MeshNode::IsMediumNode ( const SMDS_MeshNode *  node) const
Reimplemented from SMDS_MeshElement.
◆ IsNull()
◆ IsPoly()
virtual bool SMDS_MeshNode::IsPoly ( ) const
◆ IsQuadratic()
virtual bool SMDS_MeshNode::IsQuadratic ( ) const
◆ IsValidIndex()
bool SMDS_MeshElement::IsValidIndex ( const int  ind) const
ind- node index
bool- index check result
References SMDS_MeshElement::NbNodes().
◆ NbCornerNodes()
virtual int SMDS_MeshNode::NbCornerNodes ( ) const
◆ NbEdges()
virtual int SMDS_MeshNode::NbEdges ( ) const
◆ NbFaces()
virtual int SMDS_MeshNode::NbFaces ( ) const
◆ NbInverseElements()
◆ NbNodes()
virtual int SMDS_MeshNode::NbNodes ( ) const
◆ nodeIterator()
SMDS_NodeIteratorPtr SMDS_MeshNode::nodeIterator ( ) const
◆ nodesIterator()
SMDS_ElemIteratorPtr SMDS_MeshNode::nodesIterator ( ) const
◆ nodesIteratorToUNV()
virtual SMDS_NodeIteratorPtr SMDS_MeshElement::nodesIteratorToUNV ( ) const
Reimplemented in SMDS_MeshCell.
◆ Print()
void SMDS_MeshNode::Print ( std::ostream &  OS) const
overridevirtual
Print self.
References SMDS_MeshElement::GetID(), X(), Y(), and Z().
◆ RemoveInverseElement()
void SMDS_MeshNode::RemoveInverseElement ( const SMDS_MeshElement *  elem)
◆ setIsMarked()
◆ SetPosition()
void SMDS_MeshNode::SetPosition ( const SMDS_PositionPtr &  aPos,
int  shapeID = 0
◆ setShapeID()
void SMDS_MeshElement::setShapeID ( const int  shapeID) const
◆ setVtkID()
void SMDS_MeshElement::setVtkID ( const vtkIdType  vtkID)
◆ setXYZ()
◆ WrappedIndex()
int SMDS_MeshElement::WrappedIndex ( const int  ind) const
ind- node index
int- valid node index
References SMDS_MeshElement::NbCornerNodes().
Referenced by SMDS_PolygonalFaceOfNodes::GetNode().
◆ X()
double SMDS_MeshNode::X ( ) const
References getCoord().
Referenced by averageByElement(), averageBySurface(), SMESH_Mesh_i::BaryCenter(), StdMeshers_Import_1D2D::Compute(), StdMeshers_QuadToTriaAdaptor::Compute2ndPart(), StdMeshers_Quadrangle_2D::computeQuadDominant(), StdMeshers_Quadrangle_2D::computeQuadPref(), StdMeshers_Quadrangle_2D::computeReduced(), MeshEditor_I::TPreviewMesh::Copy(), SMESH_Gen_i::CopyMesh(), SMESH_MeshEditor::CreateFlatElementsOnFacesGroups(), SMESH_VisualObjDef::createPoints(), SMESHGUI_CuttingOfQuadsDlg::displayPreview(), SMESH_MeshEditor::DoubleNodes(), SMESH_MeshEditor::doubleNodes(), _QuadFaceGrid::DumpGrid(), SMESH::SelectionProxy::elementGravityCenter(), enlargeBoundingBox(), SMESH_MeshAlgos::FaceNormal(), SMESHGUI_MergeDlg::FindGravityCenter(), StdMeshers_Penta_3D::FindNodeOnShape(), SMESH_2D_Algo::FixInternalNodes(), SMESH_MesherHelper::FixQuadraticElements(), SMESH_Gen_i::GetBadInputElements(), SMESH_MesherHelper::GetCentralNode(), Prism_3D::TNode::GetCoords(), SMESH_MesherHelper::GetMediumNode(), SMESH_MesherHelper::getMediumNodeOnComposedWire(), getNodeNodeDistance(), SMESH_Mesh_i::GetNodeXYZ(), SMESH_MeshEditor_i::GetPreviewData(), StdMeshers_Import_1D::importMesh(), VISCOUS_3D::_Simplex::IsForward(), SMESH::Controls::ElementsOnSurface::isOnSurface(), SMESH_Pattern::isReversed(), SMESH_Pattern::Load(), StdMeshers_Penta_3D::MakeNodes(), SMESH_MeshAlgos::MakeOffset(), SMESH_NodeSearcherImpl::MoveNode(), VISCOUS_3D::PeriodicFaces::MoveNodes(), SMESH::SelectionProxy::nodeCoordinates(), DriverDAT_W_SMDS_Mesh::Perform(), DriverUNV_W_SMDS_Mesh::Perform(), StdMeshers_ProjectionUtils::Morph::Perform(), DriverMED_W_SMESHDS_Mesh::PerformInternal(), SMESH_Gen_i::Precompute(), StdMeshers_QuadToTriaAdaptor::Preparation(), Print(), project(), StdMeshers_Prism_3D::projectBottomToTop(), VISCOUS_3D::_ViscousBuilder::refine(), VISCOUS_3D::_ViscousBuilder::restoreNoShrink(), SMESH_MeshEditor::RotationSweep(), SMESHGUI_ExtrusionAlongPathDlg::SelectionIntoArgument(), SMESHGUI_ExtrusionDlg::SelectionIntoArgument(), SMESHGUI_RevolutionDlg::SelectionIntoArgument(), SMESHGUI_RotationDlg::SelectionIntoArgument(), SMESHGUI_ScaleDlg::SelectionIntoArgument(), SMESHGUI_SymmetryDlg::SelectionIntoArgument(), SMESHGUI_TranslationDlg::SelectionIntoArgument(), SMDS_VolumeTool::Set(), StdMeshers_Penta_3D::SetHorizEdgeXYZ(), SMESHUtils::SMESH_RegularGrid::SetNode(), SMESHGUI_IdPreview::SetPointsData(), SMESH_MeshEditor::SewFreeBorder(), SMESH_MeshEditor::SewSideElements(), VISCOUS_2D::_ViscousBuilder2D::shrink(), StdMeshers_Quadrangle_2D::smooth(), SMESH_MeshEditor::Smooth(), SMESH_MeshEditor::SplitEdge(), SMESH_OctreeNode::UpdateByMoveNode(), and DriverSTL_W_SMDS_Mesh::writeBinary().
◆ Y()
double SMDS_MeshNode::Y ( ) const
Referenced by averageByElement(), averageBySurface(), SMESH_Mesh_i::BaryCenter(), StdMeshers_Quadrangle_2D::computeQuadDominant(), MeshEditor_I::TPreviewMesh::Copy(), SMESH_Gen_i::CopyMesh(), SMESH_MeshEditor::CreateFlatElementsOnFacesGroups(), SMESH_VisualObjDef::createPoints(), SMESHGUI_CuttingOfQuadsDlg::displayPreview(), SMESH_MeshEditor::DoubleNodes(), SMESH_MeshEditor::doubleNodes(), _QuadFaceGrid::DumpGrid(), SMESH::SelectionProxy::elementGravityCenter(), enlargeBoundingBox(), SMESH_MeshAlgos::FaceNormal(), SMESHGUI_MergeDlg::FindGravityCenter(), StdMeshers_Penta_3D::FindNodeOnShape(), SMESH_Gen_i::GetBadInputElements(), Prism_3D::TNode::GetCoords(), SMESH_MesherHelper::GetMediumNode(), getNodeNodeDistance(), SMESH_Mesh_i::GetNodeXYZ(), SMESH_MeshEditor_i::GetPreviewData(), StdMeshers_Import_1D::importMesh(), VISCOUS_3D::_Simplex::IsForward(), SMESH::Controls::ElementsOnSurface::isOnSurface(), SMESH_Pattern::isReversed(), SMESH_Pattern::Load(), StdMeshers_Penta_3D::MakeNodes(), SMESH::SelectionProxy::nodeCoordinates(), DriverDAT_W_SMDS_Mesh::Perform(), DriverUNV_W_SMDS_Mesh::Perform(), DriverMED_W_SMESHDS_Mesh::PerformInternal(), SMESH_Gen_i::Precompute(), StdMeshers_QuadToTriaAdaptor::Preparation(), Print(), project(), SMESH_MeshEditor::RotationSweep(), SMESHGUI_ExtrusionAlongPathDlg::SelectionIntoArgument(), SMESHGUI_ExtrusionDlg::SelectionIntoArgument(), SMESHGUI_RevolutionDlg::SelectionIntoArgument(), SMESHGUI_RotationDlg::SelectionIntoArgument(), SMESHGUI_ScaleDlg::SelectionIntoArgument(), SMESHGUI_SymmetryDlg::SelectionIntoArgument(), SMESHGUI_TranslationDlg::SelectionIntoArgument(), SMDS_VolumeTool::Set(), StdMeshers_Penta_3D::SetHorizEdgeXYZ(), SMESHUtils::SMESH_RegularGrid::SetNode(), SMESHGUI_IdPreview::SetPointsData(), SMESH_MeshEditor::SewFreeBorder(), SMESH_MeshEditor::SewSideElements(), SMESH_MeshEditor::Smooth(), SMESH_OctreeNode::UpdateByMoveNode(), and DriverSTL_W_SMDS_Mesh::writeBinary().
◆ Z()
double SMDS_MeshNode::Z ( ) const
◆ SMDS_Mesh
friend class SMDS_Mesh
friend
◆ myHolder
