SMDS_NodeFactory Class Reference
Allocate SMDS_MeshNode's. More...
#include <SMDS_ElementFactory.hxx>
Inheritance diagram for SMDS_NodeFactory:
 SMDS_NodeFactory (SMDS_Mesh *mesh)
 Create a factory of nodes in a given mesh. More...
 ~SMDS_NodeFactory ()
SMDS_MeshNode * NewNode (smIdType id)
 Return a SMDS_MeshNode by ID. NULL if the node with the given ID is already used. More...
const SMDS_MeshNode * FindNode (smIdType id)
 Return an used node by ID. NULL if the node with the given ID is not yet used. More...
void SetNbShapes (size_t nbShapes)
 Set a total number of sub-shapes in the main shape. More...
int GetShapeDim (int shapeID) const
 Return a dimension of a shape. More...
void SetShapeDim (int shapeID, int dim)
 Set a dimension of a shape. More...
virtual void Clear ()
 De-allocate all nodes. More...
virtual void Compact (std::vector< smIdType > &idNodesOldToNew)
 Remove unused nodes located not at the end of the last chunk. More...
virtual bool CompactChangePointers ()
 Return true if Compact() will change IDs of node. More...
smIdType GetFreeID ()
 Return minimal ID of a non-used element. More...
smIdType GetMaxID ()
 Return maximal ID of an used element. More...
smIdType GetMinID ()
 Return minimal ID of an used element. More...
SMDS_MeshElement * NewElement (const smIdType id)
 Return an element by ID. NULL if the element with the given ID is already used. More...
SMDS_MeshCell * NewCell (const smIdType id)
 Return a SMDS_MeshCell by ID. NULL if the cell with the given ID is already used. More...
const SMDS_MeshElement * FindElement (const smIdType id) const
 Return an used element by ID. NULL if the element with the given ID is not yet used. More...
smIdType NbUsedElements () const
 Return a number of used elements. More...
template<class ElemIterator >
boost::shared_ptr< ElemIterator > GetIterator (SMDS_MeshElement::Filter *filter, size_t nbElemsToReturn=-1)
 Return an iterator on all element filtered using a given filter. More...
boost::shared_ptr< ElemIterator > GetShapeIterator (int shapeID, size_t nbElemsToReturn, const SMDS_MeshElement *sm1stElem)
 Return an iterator on all element assigned to a given shape. More...
void SetAllNotMarked ()
 Clear marked flag of all elements. More...
void Free (const SMDS_MeshElement *)
 Mark the element as non-used. More...
smIdType FromVtkToSmds (vtkIdType vtkID)
 Return an SMDS ID by a Vtk one. More...
static int ChunkSize ()
 Return a number of elements in a chunk. More...
bool myIsNodal
SMDS_Mesh * myMesh
TChunkVector myChunks
TChunkPtrSet myChunksWithUnused
std::vector< vtkIdType > myVtkIDs
std::vector< smIdType > mySmdsIDs
smIdType myNbUsedElements
std::vector< char > myShapeDim
◆ SMDS_NodeFactory()
SMDS_NodeFactory::SMDS_NodeFactory ( SMDS_Mesh *  mesh)
◆ ~SMDS_NodeFactory()
SMDS_NodeFactory::~SMDS_NodeFactory ( )
References Clear().
◆ ChunkSize()
int SMDS_ElementFactory::ChunkSize ( )
int - chunk size
Referenced by SMDS_ElementFactory::GetShapeIterator(), and _RangeSet< RANGE >::Size().
◆ Clear()
void SMDS_NodeFactory::Clear ( )
Reimplemented from SMDS_ElementFactory.
References SMDS_ElementFactory::Clear().
Referenced by SMDS_Mesh::Clear(), and ~SMDS_NodeFactory().
◆ Compact()
void SMDS_NodeFactory::Compact ( std::vector< smIdType > &  theVtkIDsOldToNew)
◆ CompactChangePointers()
bool SMDS_NodeFactory::CompactChangePointers ( )
Return true if Compact() will change IDs of elements.
References SMDS_ElementFactory::GetMaxID(), and SMDS_ElementFactory::NbUsedElements().
Referenced by SMDS_Mesh::HasNumerationHoles().
◆ FindElement()
const SMDS_MeshElement * SMDS_ElementFactory::FindElement ( const smIdType  id) const
[in]id- element ID
const SMDS_MeshElement* - element pointer
References SMDS_MeshElement::IsNull(), and SMDS_ElementFactory::myChunks.
Referenced by SMDS_ElementFactory::Compact(), Compact(), SMDS_Mesh::Contains(), SMDS_Mesh::FindElement(), SMDS_Mesh::FindElementVtk(), FindNode(), SMDS_ElementFactory::Free(), and SMDS_Mesh::GetElementType().
◆ FindNode()
◆ Free()
◆ FromVtkToSmds()
smIdType SMDS_ElementFactory::FromVtkToSmds ( vtkIdType  vtkID)
[in]vtkID- Vtk ID
smIdType - SMDS ID
References SMDS_ElementFactory::mySmdsIDs.
Referenced by SMDS_Mesh::FromVtkToSmds().
◆ GetFreeID()
◆ GetIterator()
boost::shared_ptr< ElemIterator > SMDS_ElementFactory::GetIterator ( SMDS_MeshElement::Filter *  filter,
size_t  nbElemsToReturn = -1
◆ GetMaxID()
smIdType SMDS_ElementFactory::GetMaxID ( )
◆ GetMinID()
smIdType SMDS_ElementFactory::GetMinID ( )
smIdType - element ID
References SMDS_ElementFactory::myChunks.
Referenced by SMDS_Mesh::MinElementID(), and SMDS_Mesh::MinNodeID().
◆ GetShapeDim()
int SMDS_NodeFactory::GetShapeDim ( int  shapeID) const
References myShapeDim.
Referenced by Compact().
◆ GetShapeIterator()
boost::shared_ptr< ElemIterator > SMDS_ElementFactory::GetShapeIterator ( int  shapeID,
const SMDS_MeshElement *  sm1stElem
◆ NbUsedElements()
smIdType SMDS_ElementFactory::NbUsedElements ( ) const
◆ NewCell()
◆ NewElement()
SMDS_MeshElement * SMDS_ElementFactory::NewElement ( const smIdType  id)
[in]id- element ID
References SMDS_MeshElement::IsNull(), SMDS_ElementFactory::myChunks, SMDS_MeshElement::myHolder, SMDS_ElementFactory::myMesh, SMDS_ElementFactory::myNbUsedElements, SMDS_Mesh::setMyModified(), and SMDS_ElementFactory::SMDS_ElementChunk.
Referenced by SMDS_Mesh::AddBallWithID(), SMDS_ElementFactory::Compact(), Compact(), SMDS_ElementFactory::NewCell(), and NewNode().
◆ NewNode()
SMDS_MeshNode * SMDS_NodeFactory::NewNode ( smIdType  id)
References SMDS_ElementFactory::NewElement().
Referenced by SMDS_Mesh::AddNodeWithID().
◆ SetAllNotMarked()
void SMDS_ElementFactory::SetAllNotMarked ( )
Referenced by SMDS_Mesh::SetAllCellsNotMarked(), and SMDS_Mesh::SetAllNodesNotMarked().
◆ SetNbShapes()
void SMDS_NodeFactory::SetNbShapes ( size_t  nbShapes)
Referenced by SMDS_Mesh::setNbShapes().
◆ SetShapeDim()
void SMDS_NodeFactory::SetShapeDim ( int  shapeID,
int  dim
◆ myChunks
◆ myChunksWithUnused
◆ myIsNodal
bool SMDS_ElementFactory::myIsNodal
◆ myMesh
SMDS_Mesh* SMDS_ElementFactory::myMesh
◆ myNbUsedElements
smIdType SMDS_ElementFactory::myNbUsedElements
◆ myShapeDim
std::vector<char> SMDS_NodeFactory::myShapeDim
◆ mySmdsIDs
std::vector< smIdType > SMDS_ElementFactory::mySmdsIDs
◆ myVtkIDs
std::vector< vtkIdType > SMDS_ElementFactory::myVtkIDs
