_RangeSet< RANGE > Struct Template Reference
Sorted set of ranges. More...
#include <SMDS_ElementFactory.hxx>
Inheritance diagram for _RangeSet< RANGE >:
typedef RANGE::attr_t attr_t
typedef boost::container::flat_set< RANGE > set_t
typedef set_t::const_iterator set_iterator
 _RangeSet ()
size_t Size () const
 Return a number of ranges. More...
int & First (set_iterator rangePtr)
 Return a mutable _Range::my1st of a range pointed by an iterator. More...
size_t Size (set_iterator rangePtr) const
 Return a number of elements in a range pointed by an iterator. More...
bool GetIndices (const attr_t theValue, TIndexRanges &theIndices, const attr_t *=0, const attr_t *=0) const
 Return ranges of indices (from,to) of elements having a given value. More...
attr_t GetValue (int theIndex) const
 Return value of an element attribute. More...
attr_t SetValue (int theIndex, attr_t theValue)
 Change value of an element attribute. More...
Data Fields
set_t mySet
template<class RANGE>
struct _RangeSet< RANGE >
◆ attr_t
template<class RANGE >
typedef RANGE::attr_t _RangeSet< RANGE >::attr_t
◆ set_iterator
typedef set_t::const_iterator _RangeSet< RANGE >::set_iterator
◆ set_t
typedef boost::container::flat_set< RANGE > _RangeSet< RANGE >::set_t
◆ _RangeSet()
_RangeSet< RANGE >::_RangeSet ( )
◆ First()
int & _RangeSet< RANGE >::First ( set_iterator  rangePtr)
Referenced by _RangeSet< RANGE >::SetValue().
◆ GetIndices()
bool _RangeSet< RANGE >::GetIndices ( const attr_t  theValue,
TIndexRanges &  theIndices,
const attr_t *  = 0,
const attr_t *  = 0
References _RangeSet< RANGE >::mySet, and _RangeSet< RANGE >::Size().
◆ GetValue()
attr_t _RangeSet< RANGE >::GetValue ( int  theIndex) const
[in]theIndex- element index
attr_t - attribute value
References _RangeSet< RANGE >::mySet.
Referenced by SMDS_ElementChunk::GetShapeID().
◆ SetValue()
attr_t _RangeSet< RANGE >::SetValue ( int  theIndex,
attr_t  theValue
[in]theValue- attribute value
attr_t - previous value
References _RangeSet< RANGE >::First(), _RangeSet< RANGE >::mySet, and _RangeSet< RANGE >::Size().
Referenced by SMDS_ElementChunk::Free(), SMDS_ElementChunk::SetShapeID(), and SMDS_ElementChunk::UseElement().
◆ Size() [1/2]
◆ Size() [2/2]
size_t _RangeSet< RANGE >::Size ( set_iterator  rangePtr) const
References SMDS_ElementFactory::ChunkSize(), and _RangeSet< RANGE >::mySet.
◆ mySet
