SMDS_ElementFactory Class Reference
Allocate SMDS_MeshElement's (SMDS_MeshCell's or SMDS_MeshNode's ) and bind some attributes to elements: element ID, element VTK ID, sub-mesh ID, position on shape. More...
#include <SMDS_ElementFactory.hxx>
Inheritance diagram for SMDS_ElementFactory:
 SMDS_ElementFactory (SMDS_Mesh *mesh, const bool isNodal=false)
 Create a factory of cells or nodes in a given mesh. More...
virtual ~SMDS_ElementFactory ()
smIdType GetFreeID ()
 Return minimal ID of a non-used element. More...
smIdType GetMaxID ()
 Return maximal ID of an used element. More...
smIdType GetMinID ()
 Return minimal ID of an used element. More...
SMDS_MeshElement * NewElement (const smIdType id)
 Return an element by ID. NULL if the element with the given ID is already used. More...
SMDS_MeshCell * NewCell (const smIdType id)
 Return a SMDS_MeshCell by ID. NULL if the cell with the given ID is already used. More...
const SMDS_MeshElement * FindElement (const smIdType id) const
 Return an used element by ID. NULL if the element with the given ID is not yet used. More...
smIdType NbUsedElements () const
 Return a number of used elements. More...
template<class ElemIterator >
boost::shared_ptr< ElemIterator > GetIterator (SMDS_MeshElement::Filter *filter, size_t nbElemsToReturn=-1)
 Return an iterator on all element filtered using a given filter. More...
boost::shared_ptr< ElemIterator > GetShapeIterator (int shapeID, size_t nbElemsToReturn, const SMDS_MeshElement *sm1stElem)
 Return an iterator on all element assigned to a given shape. More...
void SetAllNotMarked ()
 Clear marked flag of all elements. More...
void Free (const SMDS_MeshElement *)
 Mark the element as non-used. More...
smIdType FromVtkToSmds (vtkIdType vtkID)
 Return an SMDS ID by a Vtk one. More...
virtual void Clear ()
 De-allocate all elements. More...
virtual void Compact (std::vector< smIdType > &idCellsOldToNew)
 Remove unused elements located not at the end of the last chunk. More...
virtual bool CompactChangePointers ()
 Return true if Compact() will change IDs of elements. More...
static int ChunkSize ()
 Return a number of elements in a chunk. More...
bool myIsNodal
SMDS_Mesh * myMesh
TChunkVector myChunks
TChunkPtrSet myChunksWithUnused
std::vector< vtkIdType > myVtkIDs
std::vector< smIdType > mySmdsIDs
smIdType myNbUsedElements
Friends
class SMDS_ElementChunk
Elements are allocated by chunks, so there are used and non-used elements
◆ SMDS_ElementFactory()
SMDS_ElementFactory::SMDS_ElementFactory ( SMDS_Mesh *  mesh,
const bool  isNodal = false
◆ ~SMDS_ElementFactory()
SMDS_ElementFactory::~SMDS_ElementFactory ( )
References myChunks, and myChunksWithUnused.
◆ ChunkSize()
int SMDS_ElementFactory::ChunkSize ( )
int - chunk size
Referenced by GetShapeIterator(), and _RangeSet< RANGE >::Size().
◆ Clear()
void SMDS_ElementFactory::Clear ( )
Reimplemented in SMDS_NodeFactory.
References myChunks, myChunksWithUnused, myNbUsedElements, mySmdsIDs, and myVtkIDs.
Referenced by SMDS_NodeFactory::Clear(), and SMDS_Mesh::Clear().
◆ Compact()
void SMDS_ElementFactory::Compact ( std::vector< smIdType > &  theVtkIDsNewToOld)
Minimize allocated memory
[out]theVtkIDsNewToOld- theVtkIDsNewToOld[ new VtkID ] = old VtkID
References Compact(), FindElement(), Free(), GetMaxID(), SMDS_MeshElement::GetShapeID(), SMDS_MeshElement::GetVtkID(), myChunks, myChunksWithUnused, mySmdsIDs, myVtkIDs, NbUsedElements(), and NewElement().
Referenced by Compact(), and SMDS_Mesh::CompactMesh().
◆ CompactChangePointers()
◆ FindElement()
const SMDS_MeshElement * SMDS_ElementFactory::FindElement ( const smIdType  id) const
[in]id- element ID
const SMDS_MeshElement* - element pointer
References SMDS_MeshElement::IsNull(), and myChunks.
Referenced by Compact(), SMDS_NodeFactory::Compact(), SMDS_Mesh::Contains(), SMDS_Mesh::FindElement(), SMDS_Mesh::FindElementVtk(), SMDS_NodeFactory::FindNode(), Free(), and SMDS_Mesh::GetElementType().
◆ Free()
◆ FromVtkToSmds()
smIdType SMDS_ElementFactory::FromVtkToSmds ( vtkIdType  vtkID)
[in]vtkID- Vtk ID
smIdType - SMDS ID
References mySmdsIDs.
Referenced by SMDS_Mesh::FromVtkToSmds().
◆ GetFreeID()
◆ GetIterator()
boost::shared_ptr< ElemIterator > SMDS_ElementFactory::GetIterator ( SMDS_MeshElement::Filter *  filter,
size_t  nbElemsToReturn = -1
◆ GetMaxID()
smIdType SMDS_ElementFactory::GetMaxID ( )
◆ GetMinID()
smIdType SMDS_ElementFactory::GetMinID ( )
smIdType - element ID
References myChunks.
Referenced by SMDS_Mesh::MinElementID(), and SMDS_Mesh::MinNodeID().
◆ GetShapeIterator()
boost::shared_ptr< ElemIterator > SMDS_ElementFactory::GetShapeIterator ( int  shapeID,
const SMDS_MeshElement *  sm1stElem
References ChunkSize(), SMDS_MeshElement::GetID(), SMDS_ElementChunk::GetSubIDRangesMinMax(), and myChunks.
Referenced by SMDS_Mesh::shapeElementsIterator(), and SMDS_Mesh::shapeNodesIterator().
◆ NbUsedElements()
smIdType SMDS_ElementFactory::NbUsedElements ( ) const
◆ NewCell()
◆ NewElement()
SMDS_MeshElement * SMDS_ElementFactory::NewElement ( const smIdType  id)
[in]id- element ID
References SMDS_MeshElement::IsNull(), myChunks, SMDS_MeshElement::myHolder, myMesh, myNbUsedElements, SMDS_Mesh::setMyModified(), and SMDS_ElementChunk.
Referenced by SMDS_Mesh::AddBallWithID(), Compact(), SMDS_NodeFactory::Compact(), NewCell(), and SMDS_NodeFactory::NewNode().
◆ SetAllNotMarked()
void SMDS_ElementFactory::SetAllNotMarked ( )
Referenced by SMDS_Mesh::SetAllCellsNotMarked(), and SMDS_Mesh::SetAllNodesNotMarked().
◆ SMDS_ElementChunk
friend class SMDS_ElementChunk
friend
Referenced by GetFreeID(), and NewElement().
◆ myChunks
◆ myChunksWithUnused
◆ myIsNodal
bool SMDS_ElementFactory::myIsNodal
◆ myMesh
SMDS_Mesh* SMDS_ElementFactory::myMesh
◆ myNbUsedElements
smIdType SMDS_ElementFactory::myNbUsedElements
◆ mySmdsIDs
std::vector< smIdType > SMDS_ElementFactory::mySmdsIDs
◆ myVtkIDs
std::vector< vtkIdType > SMDS_ElementFactory::myVtkIDs
