SMDS_ElementChunk Class Reference
Allocate SMDS_MeshElement's (SMDS_MeshCell's or SMDS_MeshNode's ) and bind some attributes to elements: element ID, sub-shape ID, isMarked flag, parameters on shape. More...
#include <SMDS_ElementFactory.hxx>
 SMDS_ElementChunk (SMDS_ElementFactory *factory=0, smIdType id0=0)
 SMDS_ElementChunk constructor. More...
 ~SMDS_ElementChunk ()
 SMDS_ElementChunk destructor. More...
SMDS_MeshElement * Element (int index)
 Return an element by an index [0,ChunkSize()]. More...
const SMDS_MeshElement * Element (int index) const
smIdType GetUnusedID () const
 Return ID of the first non-used element. More...
void UseElement (const int index)
 Mark an element as used. More...
void Free (const SMDS_MeshElement *e)
 Mark an element as non-used. More...
int Index (const SMDS_MeshElement *e) const
 Return index of an element in the chunk. More...
smIdType Get1stID () const
 Return ID of the 1st element in the chunk. More...
TParam * GetPositionPtr (const SMDS_MeshElement *node, bool allocate=false)
 Return pointer to on-shape-parameters of a node. More...
const TUsedRangeSet & GetUsedRanges () const
 Return ranges of used/non-used elements. More...
const TUsedRangeSet & GetUsedRangesMinMax (bool &min, bool &max) const
const TSubIDRangeSet & GetSubIDRangesMinMax (int &, int &) const
 Return ranges of elements assigned to sub-shapes and min/max of sub-shape IDs. More...
void Compact ()
 Minimize allocated memory. More...
void Dump () const
 Print some data. More...
smIdType GetID (const SMDS_MeshElement *e) const
 Return an SMDS ID of an element. More...
vtkIdType GetVtkID (const SMDS_MeshElement *e) const
 Return a Vtk ID of an element. More...
void SetVTKID (const SMDS_MeshElement *e, const vtkIdType id)
 Set a Vtk ID of an element. More...
int GetShapeID (const SMDS_MeshElement *e) const
 Return ID of a shape an element is assigned to. More...
void SetShapeID (const SMDS_MeshElement *e, int shapeID) const
 Set ID of a shape an element is assigned to. More...
bool IsMarked (const SMDS_MeshElement *e) const
 Set isMarked flag of an element. More...
void SetIsMarked (const SMDS_MeshElement *e, bool is)
 Return isMarked flag of an element. More...
void SetAllNotMarked ()
 Clear marked flag of all elements. More...
SMDS_PositionPtr GetPosition (const SMDS_MeshNode *n) const
 Return SMDS_Position of a node on a shape. More...
void SetPosition (const SMDS_MeshNode *n, const SMDS_PositionPtr &pos, int shapeID)
 Set SMDS_Position of a node on a shape. More...
SMDS_Mesh * GetMesh ()
static bool IsUsed (const _UsedRange &r)
 Check if a given range holds used or non-used elements. More...
SMDS_ElementFactory * myFactory
SMDS_MeshElement * myElements
smIdType my1stID
TBitSet myMarkedSet
TUsedRangeSet myUsedRanges
TSubIDRangeSet mySubIDRanges
std::vector< TParam > myPositions
◆ SMDS_ElementChunk()
SMDS_ElementChunk::SMDS_ElementChunk ( SMDS_ElementFactory *  factory = 0,
smIdType  id0 = 0
[in]factory- the factory
[in]id0- ID of the 1st element
References SMDS_ElementFactory::myChunksWithUnused, myElements, myFactory, SMDS_ElementFactory::myIsNodal, _RangeSet< RANGE >::mySet, mySubIDRanges, and myUsedRanges.
◆ ~SMDS_ElementChunk()
SMDS_ElementChunk::~SMDS_ElementChunk ( )
◆ Compact()
void SMDS_ElementChunk::Compact ( )
References myFactory, myMarkedSet, myPositions, _RangeSet< RANGE >::mySet, mySubIDRanges, and myUsedRanges.
◆ Dump()
void SMDS_ElementChunk::Dump ( ) const
Print some data.
Print some data for debug purposes.
References my1stID, _RangeSet< RANGE >::mySet, mySubIDRanges, myUsedRanges, and _RangeSet< RANGE >::Size().
◆ Element() [1/2]
SMDS_MeshElement * SMDS_ElementChunk::Element ( int  index)
References myElements.
◆ Element() [2/2]
const SMDS_MeshElement * SMDS_ElementChunk::Element ( int  index) const
◆ Free()
◆ Get1stID()
smIdType SMDS_ElementChunk::Get1stID ( ) const
References my1stID.
Referenced by _ChunkCompare::operator()().
◆ GetID()
smIdType SMDS_ElementChunk::GetID ( const SMDS_MeshElement *  e) const
References Index(), and my1stID.
Referenced by SMDS_MeshElement::GetID().
◆ GetMesh()
SMDS_Mesh * SMDS_ElementChunk::GetMesh ( )
◆ GetPosition()
SMDS_PositionPtr SMDS_ElementChunk::GetPosition ( const SMDS_MeshNode *  n) const
◆ GetPositionPtr()
TParam * SMDS_ElementChunk::GetPositionPtr ( const SMDS_MeshElement *  node,
bool  allocate = false
References Index(), and myPositions.
Referenced by GetPosition(), SetPosition(), and SetShapeID().
◆ GetShapeID()
int SMDS_ElementChunk::GetShapeID ( const SMDS_MeshElement *  e) const
References _RangeSet< RANGE >::GetValue(), Index(), and mySubIDRanges.
Referenced by GetPosition(), SMDS_MeshElement::GetShapeID(), and SetPosition().
◆ GetSubIDRangesMinMax()
const TSubIDRangeSet & SMDS_ElementChunk::GetSubIDRangesMinMax ( int &  ,
int &
References mySubIDRanges.
Referenced by SMDS_ElementFactory::GetShapeIterator().
◆ GetUnusedID()
smIdType SMDS_ElementChunk::GetUnusedID ( ) const
References IsUsed(), my1stID, _RangeSet< RANGE >::mySet, and myUsedRanges.
Referenced by SMDS_ElementFactory::GetFreeID().
◆ GetUsedRanges()
const TUsedRangeSet & SMDS_ElementChunk::GetUsedRanges ( ) const
References myUsedRanges.
◆ GetUsedRangesMinMax()
const TUsedRangeSet & SMDS_ElementChunk::GetUsedRangesMinMax ( bool &  min,
bool &  max
◆ GetVtkID()
vtkIdType SMDS_ElementChunk::GetVtkID ( const SMDS_MeshElement *  e) const
References SMDS_MeshElement::GetID(), myFactory, and SMDS_ElementFactory::myVtkIDs.
Referenced by SMDS_MeshElement::GetVtkID().
◆ Index()
int SMDS_ElementChunk::Index ( const SMDS_MeshElement *  e) const
Referenced by Free(), GetID(), GetPositionPtr(), GetShapeID(), IsMarked(), SetIsMarked(), and SetShapeID().
◆ IsMarked()
bool SMDS_ElementChunk::IsMarked ( const SMDS_MeshElement *  e) const
References Index(), and myMarkedSet.
Referenced by SMDS_MeshElement::isMarked().
◆ IsUsed()
static bool SMDS_ElementChunk::IsUsed ( const _UsedRange &  r)
References _Range< ATTR >::myValue.
Referenced by GetUnusedID().
◆ SetAllNotMarked()
void SMDS_ElementChunk::SetAllNotMarked ( )
References myMarkedSet.
◆ SetIsMarked()
void SMDS_ElementChunk::SetIsMarked ( const SMDS_MeshElement *  e,
bool  is
Referenced by Free().
◆ SetPosition()
void SMDS_ElementChunk::SetPosition ( const SMDS_MeshNode *  n,
const SMDS_PositionPtr &  pos,
int  shapeID
References GetPositionPtr(), GetShapeID(), and myFactory.
Referenced by SMDS_MeshNode::SetPosition().
◆ SetShapeID()
void SMDS_ElementChunk::SetShapeID ( const SMDS_MeshElement *  e,
int  shapeID
References GetPositionPtr(), Index(), mySubIDRanges, and _RangeSet< RANGE >::SetValue().
◆ SetVTKID()
void SMDS_ElementChunk::SetVTKID ( const SMDS_MeshElement *  e,
const vtkIdType  id
◆ UseElement()
void SMDS_ElementChunk::UseElement ( const int  index)
◆ my1stID
smIdType SMDS_ElementChunk::my1stID
Referenced by Dump(), Get1stID(), GetID(), and GetUnusedID().
◆ myElements
SMDS_MeshElement* SMDS_ElementChunk::myElements
◆ myFactory
◆ myMarkedSet
TBitSet SMDS_ElementChunk::myMarkedSet
◆ myPositions
std::vector<TParam> SMDS_ElementChunk::myPositions
Referenced by Compact(), Free(), and GetPositionPtr().
◆ mySubIDRanges
TSubIDRangeSet SMDS_ElementChunk::mySubIDRanges
◆ myUsedRanges
TUsedRangeSet SMDS_ElementChunk::myUsedRanges
